W5100
W5100
    WIZNET
    LQFP80_10X10MM
    W5100是一款功能齐全的单芯片互联网10/100以太网控制器,专为需要易于集成、稳定性、性能、面积和系统成本控制的嵌入式应用而设计。
W5100 数据手册
W5100 Datasheet W5100 Datasheet Version 1.1.6 © 2008 WIZnet Co., Inc. All Rights Reserved. For more information, visit our website at http://www.wiznet.co.kr © Copyright 2008 WIZnet Co., Inc. All rights reserved. 1 W5100 Datasheet Document History Information Version Date Descriptions Ver. 1.0.0 Dec. 21, 2006 Released with W5100 Launching Ver. 1.0.1 Jan. 10, 2006 LB bit in Mode register is not used . W5100 is used only in Big-endian ordering. Ver. 1.1.1 Jun. 19, 2007 Modified the OPMODE2-0 signals descriptions (P. 10) Modified the TEST_MODE3-0 signals description (P.11) Modified the Colck signals description (P.12) Modified the LINKLED signal description (P.12) Modified the explanation of RECV_INT in Sn_IR register (P. 27) Replaced the reset value of Sn_DHAR register (0x00 to 0xFF, P. 30) Modifted the explanation of Sn_DIPR, Sn_DPORT register(P. 31) Replaced the reset value of Sn_MSS register (0xFFFF to 0x0000, P. 31) Ver. 1.1.2 Sep. 28, 2007 Modified the Operating temperature (P. 63) Ver. 1.1.3 Oct. 18, 2007 Changed the wrong word “MISO signal” (P. 10) Modified the SPI Timing diagram and description (P. 66) Ver. 1.1.4 Oct. 18, 2007 Modified the diagram (P. 40) Ver. 1.1.5 Nov. 11, 2007 Modified the Crystal Characteristics value (P. 67) Ver. 1.1.6 Jan. 30, 2008 Modified the SEN signals description (P.10) Changed the wrong word “SCLK” (P. 66) © Copyright 2008 WIZnet Co., Inc. All rights reserved. 2 W5100 Datasheet WIZnet’s online Technical Support If you have something to ask about WIZnet Products, write down your question on Q&A Board of ‘Support’ menu in WIZnet website (www.wiznet.co.kr). WIZnet Engineer will give an answer as soon as possible. Click © Copyright 2008 WIZnet Co., Inc. All rights reserved. 3 W5100 Datasheet W5100 Datasheet The W5100 is a full-featured, single-chip Internet-enabled 10/100 Ethernet controller designed for embedded applications where ease of integration, stability, performance, area and system cost control are required. The W5100 has been designed to facilitate easy implementation of Internet connectivity without OS. The W5100 is IEEE 802.3 10BASE-T and 802.3u 100BASE-TX compliant. The W5100 includes fully hardwired, market-proven TCP/IP stack and integrated Ethernet MAC & PHY. Hardwired TCP/IP stack supports TCP, UDP, IPv4, ICMP, ARP, IGMP and PPPoE which has been proven in various applications for several years. 16Kbytes internal buffer is included for data transmission. No need of consideration for handling Ethernet Controller, but simple socket programming is required. For easy integration, three different interfaces like memory access way, called direct, indirect bus and SPI, are supported on the MCU side. Target Applications The W5100 is well suited for many embedded applications, including: - Home Network Devices: Set-Top Boxes, PVRs, Digital Media Adapters - Serial-to-Ethernet: Access Controls, LED displays, Wireless AP relays, etc. - Parallel-to-Ethernet: POS / Mini Printers, Copiers - USB-to-Ethernet: Storage Devices, Network Printers - GPIO-to-Ethernet: Home Network Sensors - Security Systems: DVRs, Network Cameras, Kiosks - Factory and Building Automations - Medical Monitoring Equipments - Embedded Servers © Copyright 2008 WIZnet Co., Inc. All rights reserved. 4 W5100 Datasheet Features - Support Hardwired TCP/IP Protocols : TCP, UDP, ICMP, IPv4 ARP, IGMP, PPPoE, Ethernet - 10BaseT/100BaseTX Ethernet PHY embedded - Support Auto Negotiation (Full-duplex and half duplex) - Support Auto MDI/MDIX - Support ADSL connection (with support PPPoE Protocol with PAP/CHAP Authentication mode) - Supports 4 independent sockets simultaneously - Not support IP Fragmentation - Internal 16Kbytes Memory for Tx/Rx Buffers - 0.18 µm CMOS technology - 3.3V operation with 5V I/O signal tolerance - Small 80 Pin LQFP Package - Lead-Free Package - Support Serial Peripheral Interface(SPI MODE 0, 3) - Multi-function LED outputs (TX, RX, Full/Half duplex, Collision, Link, Speed) © Copyright 2008 WIZnet Co., Inc. All rights reserved. 5 W5100 Datasheet Block Diagram © Copyright 2008 WIZnet Co., Inc. All rights reserved. 6 W5100 Datasheet Table of Contents 1. Pin Assignment ................................................................................................................... 8 1.1 MCU Interface Signals ................................................................................................ 9 1.2 PHY Signals.............................................................................................................. 10 1.3 Miscellaneous Signals............................................................................................... 11 1.4 Power Supply Signals ............................................................................................... 11 1.5 Clock Signals ........................................................................................................... 12 1.6 LED Signals .............................................................................................................. 12 2. Memory Map .................................................................................................................... 13 3. W5100 Registers............................................................................................................... 14 3.1 common registers .................................................................................................... 14 3.2 Socket registers....................................................................................................... 15 4. Register Descriptions........................................................................................................ 19 4.1 Common Registers ................................................................................................... 19 4.2 Socket Registers ...................................................................................................... 25 5. Functional Descriptions .................................................................................................... 37 5.1 Initialization............................................................................................................ 37 5.2.1 TCP ............................................................................................................... 40 5.2.1.1 SERVER mode....................................................................................... 41 5.2.1.2 CLIENT mode ....................................................................................... 48 5.2.2 UDP ............................................................................................................... 50 5.2.3 IP raw............................................................................................................ 56 5.2.4 MAC raw ........................................................................................................ 57 6. Application Information.................................................................................................... 59 6.1 Direct Bus Interface mode ....................................................................................... 59 6.2 Indirect Bus Interface mode .................................................................................... 59 6.3 SPI (Serial Peripheral Interface) mode ..................................................................... 60 6.3.1 Device Operations ......................................................................................... 61 6.3.2 Commands..................................................................................................... 61 6.3.3 Process of using general SPI Master device (According to SPI protocol)......... 61 7. Electrical Specifications ................................................................................................... 63 8. IR Reflow Temperature Profile (Lead-Free) ....................................................................... 68 9. Package Descriptions........................................................................................................ 69 © Copyright 2008 WIZnet Co., Inc. All rights reserved. 7 W5100 Datasheet 1. Pin Assignment Pinout W5100 © Copyright 2008 WIZnet Co., Inc. All rights reserved. 8 W5100 Datasheet 1.1 MCU Interface Signals Symbol Type /RESET I Pin No 59 Description RESET This pin is active Low input to initialize or reinitialize W5100. By asserting this pin low for at least 2us, all internal registers will be re-initialized to their default states. ADDR14-0 I 38, 39, ADDRESS 40, 41, These pins are used to select a register or memory. 42, 45, Address pins are internally pulled down. 46, 47, 48, 49, 50, 51, 52, 53, 54 DATA7-0 I/O 19, 20, DATA 21, 22, These pins are used to read and write register or 23, 24, memory data. 25, 26 /CS I 55 CHIP SELECT Chip Select is for MCU to access to internal registers or memory. /WR and /RD select direction of data transfer. This pin is active low. /INT O 56 INTERRUPT This pin Indicates that W5100 requires MCU attention after socket connecting, disconnecting, data receiving or timeout. The interrupt is cleared by writing IR(Interrupt Register) or Sn_IR (Socket nth Interrupt Register). All interrupts are maskable. This pin is active low. /WR I 57 WRITE ENABLE Strobe from MCU to write an internal register/memory selected by ADDR[14:0]. Data is latched into the W5100 on the rising edge of this input. This signal is active low. /RD I 58 READ ENABLE © Copyright 2008 WIZnet Co., Inc. All rights reserved. 9 from MCU to read an W5100 Datasheet Strobe internal register/memory selected by ADDR[14:0]. This signal is active low. SEN I 31 SPI ENABLE This pin selects Enable/disable of the SPI Mode. Low = SPI Mode Disable High = SPI Mode Enable If you don’t use SPI mode, then you tied this signal to ‘0’. SCLK I 30 SPI CLOCK This pin is used to SPI Clock signal Pin. /SCS I 29 SPI SLAVE SELECT This pin is used to SPI Slave Select signal Pin. This pin is active low MOSI I 28 SPI MASTER OUT SLAVE IN This pin is used to SPI MOSI signal pin. MISO O 27 SPI MASTER IN SLAVE OUT This pin is used to SPI MISO signal pin. 1.2 PHY Signals Symbol Type RXIP I Pin No 5 Description RXIP/RXIN Signal Pair The differential data from the media is received on RXIN I 6 the RXIP/RXIN signal pair. TXOP O 8 TXOP/TXON Signal Pair TXON O 9 RSET_BG O 1 The differential data is transmitted to the media on the TXOP/TXIN signal pair. PHY Off-chip resistor Connect a resistor of 12.3 ㏀±1% to the ground. Refer to the “Reference schematic”. OPMODE2-0 I 65, 64, 63 OPERATION CONTROL MODE [2:0] 000 © Copyright 2008 WIZnet Co., Inc. All rights reserved. Description Auto-negotiation enable with all capabilities 10 Auto-negotiation with 100 BASE-TX FDX/HDX ability 010 Auto-negotiation with 10 BASE-T FDX/HDX ability 011 Reserved 100 Manual selection of 100 BASE-TX FDX 101 Manual selection of 100 BASE-TX HDX 110 Manual selection of 10 BASE-T FDX 111 Manual selection of 10 BASE-T HDX W5100 Datasheet 001 1.3 Miscellaneous Signals Symbol Type Pin No TEST_MODE3-0 I 34, 35, 36, 37 Description W5100 MODE SELECT Normal mode : 0000 Other test modes are internal test mode. NC I/O 3, 60, NC 61, 62, TEST PIN for W5100 78, 79, ( for factory use only) 80 1.4 Power Supply Signals Symbol Type Pin No VCC3V3A Power VCC3V3D Power VCC1V8A Power 7, 74 1.8V power supply for Analog part VCC1V8D Power 15, 16, 1.8V power supply for Digital part 2 12, 18, 44 Description 3.3V power supply for Analog part 3.3V power supply for Digital part 33, 69 GNDA Ground 4, 10, 77 Analog ground GNDD Ground 13, 14, 17, Digital ground 32, 43, 68, © Copyright 2008 WIZnet Co., Inc. All rights reserved. 11 O 11 W5100 Datasheet V18 1.8V regulator output voltage 1.5 Clock Signals Symbol Type Pin No XTLP I 76 Description 25MHz crystal input/output A 25MHz parallel-resonant crystal is used to connect XTLN 75 these pins to stabilize the internal oscillator If you want to use oscillator, 25MHz clock to connect XTLP signals and XTLN is open. MUST use 1.8V level oscillator. 1.6 LED Signals Symbol Type Pin No LINKLED O 66 Description Link LED Active low in link state indicates a good status for 10/100M. It is always ON when the link is OK and it flashes while in a TX or RX state. SPDLED O 67 Link speed LED Active low indicates the link speed is 100Mbps. FDXLED O 70 Full duplex LED Active low indicates the status of full-duplex mode. COLLED O 71 Collision LED Active low indicates the presence of collision activity. RXLED O 72 Receive activity LED Active low indicates the presence of receiving activity. TXLED O 73 Transmit activity LED Active low indicates the presence of transmitting activity. © Copyright 2008 WIZnet Co., Inc. All rights reserved. 12 W5100 Datasheet 2. Memory Map W5100 is composed of Common Register, Socket Register, TX Memory, and RX Memory as shown below. 0x0000 Common Registers 0x0030 Reserved 0x0400 Socket Registers 0x0800 Reserved 0x4000 TX memory 0x6000 RX memory 0x8000 Memory Map © Copyright 2008 WIZnet Co., Inc. All rights reserved. 13 W5100 Datasheet 3. W5100 Registers 3.1 common registers Address Register Address Register 0x0000 Mode (MR) 0x001A RX Memory Size (RMSR) Gateway Address 0x001B TX Memory Size (TMSR) 0x0001 (GAR0) 0x0002 (GAR1) 0x001C (PATR0) 0x0003 (GAR2) 0x001D (PATR1) 0x0004 (GAR3) 0x001E Subnet mask Address ~ 0x0005 (SUBR0) 0x0027 0x0006 (SUBR1) 0x0028 0x0007 (SUBR2) 0x0008 (SUBR3) Authentication Type in PPPoE Reserved PPP LCP Request Timer (PTIMER) 0x0029 PPP LCP Magic number Source Hardware Address (PMAGIC) 0x0009 (SHAR0) Unreachable IP Address 0x000A (SHAR1) 0x002A (UIPR0) 0x000B (SHAR2) 0x002B (UIPR1) 0x000C (SHAR3) 0x002C (UIPR2) 0x000D (SHAR4) 0x002D (UIPR3) 0x000E (SHAR5) Unreachable Port Source IP Address 0x002E (UPORT0) 0x000F (SIPR0) 0x002F (UPORT1) 0x0010 (SIPR1) 0x0030 0x0011 (SIPR2) ~ 0x0012 (SIPR3) 0x03FF 0x0013 Reserved Reserved 0x0014 0x0015 Interrupt (IR) 0x0016 Interrupt Mask (IMR) Retry Time 0x0017 (RTR0) 0x0018 (RTR1) 0x0019 Retry Count (RCR) © Copyright 2008 WIZnet Co., Inc. All rights reserved. 14 W5100 Datasheet 3.2 Socket registers Address Register Address Register 0x0400 Socket 0 Mode (S0_MR) 0x0415 Socket 0 IP TOS (S0_TOS) 0x0401 Socket 0 Command (S0_CR) 0x0416 Socket 0 IP TTL (S0_TTL) 0x0402 Socket 0 Interrupt (S0_IR) 0x0417 0x0403 Socket 0 Status (S0_SR) Socket 0 Source Port ~ Reserved 0x041F Socket 0 TX Free Size 0x0404 (S0_PORT0) 0x0405 (S0_PORT1) 0x0420 (S0_TX_FSR0) Socket 0 Destination Hardware Address 0x0421 (S0_TX_FSR1) Socket 0 TX Read Pointer 0x0406 (S0_DHAR0) 0x0407 (S0_DHAR1) 0x0422 (S0_TX_RD0) 0x0408 (S0_DHAR2) 0x0423 (S0_TX_RD1) 0x0409 (S0_DHAR3) 0x040A (S0_DHAR4) 0x0424 (S0_TX_WR0) 0x040B (S0_DHAR5) 0x0425 (S0_TX_WR1) Socket 0 TX Write Pointer Socket 0 Destination IP Address Socket 0 RX Received Size 0x040C (S0_DIPR0) 0x0426 (S0_RX_RSR0) 0x040D (S0_DIPR1) 0x0427 (S0_RX_RSR1) 0x040E (S0_DIPR2) 0x040F (S0_DIPR3) 0x0428 (S0_RX_RD0) Socket 0 Destination Port 0x0429 (S0_RX_RD1) 0x0410 (S0_DPORT0) 0x042A Reserved 0x0411 (S0_DPORT1) 0x042B Socket 0 Maximum Segment Size 0x042C 0x0412 (S0_MSSR0) 0x0413 (S0_MSSR1) Socket 0 RX Read Pointer ~ Reserved 0x04FF Socket 0 Protocol in IP Raw mode 0x0414 (S0_PROTO) © Copyright 2008 WIZnet Co., Inc. All rights reserved. 15 Register Address Register 0x0500 Socket 1 Mode (S1_MR) 0x0515 Socket 1 IP TOS (S1_TOS) 0x0501 Socket 1 Command (S1_CR) 0x0516 Socket 1 IP TTL (S1_TTL) 0x0502 Socket 1 Interrupt (S1_IR) 0x0517 0x0503 Socket 1 Status (S1_SR) Socket 1 Source Port ~ Reserved 0x051F Socket 1 TX Free Size 0x0504 (S1_PORT0) 0x0505 (S1_PORT1) 0x0520 (S1_TX_FSR0) Socket 1 Destination Hardware Address 0x0521 (S1_TX_FSR1) Socket 1 TX Read Pointer 0x0506 (S1_DHAR0) 0x0507 (S1_DHAR1) 0x0522 (S1_TX_RD0) 0x0508 (S1_DHAR2) 0x0523 (S1_TX_RD1) 0x0509 (S1_DHAR3) 0x050A (S1_DHAR4) 0x0524 (S1_TX_WR0) 0x050B (S1_DHAR5) 0x0525 (S1_TX_WR1) Socket 1 TX Write Pointer Socket 1 Destination IP Address Socket 1 RX Received Size 0x050C (S1_DIPR0) 0x0526 (S1_RX_RSR0) 0x050D (S1_DIPR1) 0x0527 (S1_RX_RSR1) 0x050E (S1_DIPR2) 0x050F (S1_DIPR3) 0x0528 (S1_RX_RD0) Socket 1 Destination Port 0x0529 (S1_RX_RD1) 0x0510 (S1_DPORT0) 0x052A Reserved 0x0511 (S1_DPORT1) 0x052B Socket 1 Maximum Segment Size 0x052C 0x0512 (S1_MSSR0) 0x0513 (S1_MSSR1) W5100 Datasheet Address Socket 1 RX Read Pointer ~ Reserved 0x05FF Socket 1 Protocol in IP Raw mode 0x0514 (S1_PROTO) © Copyright 2008 WIZnet Co., Inc. All rights reserved. 16 Register Address Register 0x0600 Socket 2 Mode (S2_MR) 0x0615 Socket 2 IP TOS (S2_TOS) 0x0601 Socket 2 Command (S2_CR) 0x0616 Socket 2 IP TTL (S2_TTL) 0x0602 Socket 2 Interrupt (S2_IR) 0x0617 0x0603 Socket 2 Status (S2_SR) Socket 2 Source Port ~ Reserved 0x061F Socket 2 TX Free Size 0x0604 (S2_PORT0) 0x0605 (S2_PORT1) 0x0620 (S2_TX_FSR0) Socket 2 Destination Hardware Address 0x0621 (S2_TX_FSR1) Socket 2 TX Read Pointer 0x0606 (S2_DHAR0) 0x0607 (S2_DHAR1) 0x0622 (S2_TX_RD0) 0x0608 (S2_DHAR2) 0x0623 (S2_TX_RD1) 0x0609 (S2_DHAR3) 0x060A (S2_DHAR4) 0x0624 (S2_TX_WR0) 0x060B (S2_DHAR5) 0x0625 (S2_TX_WR1) Socket 2 TX Write Pointer Socket 2 Destination IP Address Socket 2 RX Received Size 0x060C (S2_DIPR0) 0x0626 (S2_RX_RSR0) 0x060D (S2_DIPR1) 0x0627 (S2_RX_RSR1) 0x060E (S2_DIPR2) 0x060F (S2_DIPR3) 0x0628 (S2_RX_RD0) Socket 2 Destination Port 0x0629 (S2_RX_RD1) 0x0610 (S2_DPORT0) 0x062A Reserved 0x0611 (S2_DPORT1) 0x062B Socket 2 Maximum Segment Size 0x062C 0x0612 (S2_MSSR0) 0x0613 (S2_MSSR1) W5100 Datasheet Address Socket 2 RX Read Pointer ~ Reserved 0x06FF Socket 2 Protocol in IP Raw mode 0x0614 (S2_PROTO) © Copyright 2008 WIZnet Co., Inc. All rights reserved. 17 Register Address Register 0x0700 Socket 3 Mode (S3_MR) 0x0715 Socket 3 IP TOS (S3_TOS) 0x0701 Socket 3 Command (S3_CR) 0x0716 Socket 3 IP TTL (S3_TTL) 0x0702 Socket 3 Interrupt (S3_IR) 0x0717 0x0703 Socket 3 Status (S3_SR) Socket 3 Source Port ~ Reserved 0x071F Socket 3 TX Free Size 0x0704 (S3_PORT0) 0x0705 (S3_PORT1) 0x0720 (S3_TX_FSR0) Socket 3 Destination Hardware Address 0x0721 (S3_TX_FSR1) Socket 3 TX Read Pointer 0x0706 (S3_DHAR0) 0x0707 (S3_DHAR1) 0x0722 (S3_TX_RD0) 0x0708 (S3_DHAR2) 0x0723 (S3_TX_RD1) 0x0709 (S3_DHAR3) 0x070A (S3_DHAR4) 0x0724 (S3_TX_WR0) 0x070B (S3_DHAR5) 0x0725 (S3_TX_WR1) Socket 3 TX Write Pointer Socket 3 Destination IP Address Socket 3 RX Received Size 0x070C (S3_DIPR0) 0x0726 (S3_RX_RSR0) 0x070D (S3_DIPR1) 0x0727 (S3_RX_RSR1) 0x070E (S3_DIPR2) 0x070F (S3_DIPR3) 0x0728 (S3_RX_RD0) Socket 3 Destination Port 0x0729 (S3_RX_RD1) 0x0710 (S3_DPORT0) 0x072A Reserved 0x0711 (S3_DPORT1) 0x072B Socket 3 Maximum Segment Size 0x072C 0x0712 (S3_MSSR0) 0x0713 (S3_MSSR1) W5100 Datasheet Address Socket 3 RX Read Pointer ~ Reserved 0x07FF Socket 3 Protocol in IP Raw mode 0x0714 (S3_PROTO) © Copyright 2008 WIZnet Co., Inc. All rights reserved. 18 W5100 Datasheet 4. Register Descriptions 4.1 Common Registers MR (Mode Register) [R/W] [0x0000] [0x00] This register is used for S/W reset, memory test mode, ping block mode, PPPoE mode and Indirect bus I/F. 7 6 5 RST Bit 4 3 PB PPPoE Symbol 2 1 0 AI IND Description S/W Reset 7 RST If this bit is ‘1’, internal register will be initialized. It will be automatically cleared after reset. 6 Reserved Reserved 5 Reserved Reserved Ping Block Mode 4 PB 0 : Disable Ping block 1 : Enable Ping block If the bit is set as ‘1’, there is no response to the ping request. PPPoE Mode 0 : Disable PPPoE mode 1 : Enable PPPoE mode 3 PPPoE If you use ADSL without router or etc, you should set the bit as ‘1’ to connect to ADSL Server. For more detail, refer to the application note, “How to connect ADSL”. 2 Not Used Not Used Address Auto-Increment in Indirect Bus I/F 0 : Disable auto-increment 1 AI 1 : Enable auto-increment At the Indirect Bus I/F mode, if this bit is set as ‘1’, the address will be automatically increased by 1 whenever read and write are performed. For more detail, refer to “6.2 Indirect Bus IF Mode”. 0 IND Indirect Bus I/F mode © Copyright 2008 WIZnet Co., Inc. All rights reserved. 19 W5100 Datasheet 0 : Disable Indirect bus I/F mode 1 : Enable Indirect bus I/F mode If this bit is set as ‘1’, Indirect BUS I/F mode is set. For more detail, refer to “6. Application Information”, “6.2 Indirect Bus IF Mode”. GWR (Gateway IP Address Register) [R/W] [0x0001 – 0x0004] [0x00] This Register sets up the default gateway address. Ex) in case of “192.168.0.1” 0x0001 0x0002 0x0003 0x0004 192 (0xC0) 168 (0xA8) 0 (0x00) 1 (0x01) SUBR (Subnet Mask Register) [R/W] [0x0005 – 0x0008] [0x00] This register sets up the subnet mask address. Ex) in case of “255.255.255.0” 0x0005 0x0006 0x0007 0x0008 255 (0xFF) 255 (0xFF) 255 (0xFF) 0 (0x00) SHAR (Source Hardware Address Register) [R/W] [0x0009 – 0x000E] [0x00] This register sets up the Source Hardware address. Ex) In case of “00.08.DC.01.02.03” 0x0009 0x000A 0x000B 0x000C 0x000D 0x000E 0x00 0x08 0xDC 0x01 0x02 0x03 SIPR (Source IP Address Register) [R/W] [0x000F – 0x0012] [0x00] This register sets up the Source IP address. Ex) in case of “192.168.0.3” 0x000F 0x0010 0x0011 0x0012 192 (0xC0) 168 (0xA8) 0 (0x00) 3 (0x03) © Copyright 2008 WIZnet Co., Inc. All rights reserved. 20 W5100 Datasheet IR (Interrupt Register) [R] [0x0015] [0x00] This register is accessed by the host processor to know the cause of an interrupt. Any interrupt can be masked in the Interrupt Mask Register (IMR). The /INT signal retain low as long as any masked signal is set, and will not go high until all masked bits in this Register have been cleared. 7 6 5 4 3 2 1 0 CONFLICT UNREACH PPPoE Reserved S3_INT S2_INT S1_INT S0_INT Bit Symbol Description IP Conflict 7 CONFLICT It is set as ‘1’, when there is ARP request with same IP address as Source IP address. This bit is cleared to ‘0’ by writing ‘1’ to this bit. Destination unreachable W5100 will receive ICMP(Destination Unreachable) packet if non-existing destination IP address is transmitted during UDP data transmission. (Refer 6 UNREACH to “5.2.2 UDP”). In this case, the IP address and the port number will be saved in Unreachable IP Address (UIPR) and Unreachable Port Register (UPORT), and the bit will be set as ‘1’. This bit will be cleared to ‘0’ by writing ‘1’ to this bit. PPPoE Connection Close 5 PPPoE In the PPPoE Mode, if the PPPoE connection is closed, ‘1’ is set. This bit will be cleared to ‘0’ by writing ‘1’ to this bit. 4 Reserved Reserved Occurrence of Socket 3 Socket Interrupt It is set in case that interrupt occurs at the socket 3. For more detailed 3 S3_INT information of socket interrupt, refer to “Socket 3 Interrupt Register (S3_IR)”. This bit will be automatically cleared when S3_IR is cleared to 0x00. Occurrence of Socket 2 Socket Interrupt It is set in case that interrupt occurs at the socket 2. For more detailed 2 S2_INT information of socket interrupt, refer to “Socket 2 Interrupt Register(S2_IR)”. This bit will be automatically cleared when S2_IR is cleared to 0x00. Occurrence of Socket 1 Socket Interrupt 1 S1_INT It is set in case that interrupt occurs at the socket 1. For more detailed information of socket interrupt, refer to “Socket 1 Interrupt Register © Copyright 2008 WIZnet Co., Inc. All rights reserved. 21 W5100 Datasheet (S1_IR)”. This bit will be automatically cleared when S1_IR is cleared to 0x00. Occurrence of Socket 0 Socket Interrupt It is set in case that interrupt occurs at the socket 0. For more detailed 0 S0_INT information of socket interrupt, refer to “Socket 0 Interrupt Register (S0_IR)”. This bit will be automatically cleared when S0_IR is cleared to 0x00. IMR (Interrupt Mask Register) [R/W] [0x0016] [0x00] The Interrupt Mask Register is used to mask interrupts. Each interrupt mask bit corresponds to a bit in the Interrupt Register (IR). If an interrupt mask bit is set, an interrupt will be issued whenever the corresponding bit in the IR is set. If any bit in the IMR is set as ‘0’, an interrupt will not occur though the bit in the IR is set. 7 6 5 4 3 2 1 0 IM_IR7 IM_IR6 IM_IR5 Reserved IM_IR3 IM_IR2 IM_IR1 IM_IR0 Bit Symbol Description 7 IM_IR7 IP Conflict Enable 6 IM_IR6 Destination unreachable Enable 5 IM_IR5 PPPoE Close Enable 4 Reserved 3 IM_IR3 Occurrence of Socket 3 Socket Interrupt Enable 2 IM_IR2 Occurrence of Socket 2 Socket Interrupt Enable 1 IM_IR1 Occurrence of Socket 1 Socket Interrupt Enable 0 IM_IR0 Occurrence of Socket 0 Socket Interrupt Enable It should be set as ‘0’ RTR (Retry Time-value Register) [R/W] [0x0017 – 0x0018] [0x07D0] This register sets the period of timeout. Value 1 means 100us. The initial value is 2000(0x07D0). That will be set as 200ms. Ex) For 400ms configuration, set as 4000(0x0FA0) 0x0017 0x0018 0x0F 0xA0 Re-transmission will occur if there is no response from the remote peer to the commands of CONNECT, DISCON, CLOSE, SEND, SEND_MAC and SEND_KEEP, or the response is delayed. © Copyright 2008 WIZnet Co., Inc. All rights reserved. 22 W5100 Datasheet RCR (Retry Count Register) [R/W] [0x0019] [0x08] This register sets the number of re-transmission. If retransmission occurs more than the number recorded in RCR, Timeout Interrupt (TIMEOUT bit of Socket n Interrupt Register (Sn_IR) is set as ‘1’) will occur. RMSR(RX Memory Size Register) [R/W] [0x001A] [0x55] This register assigns total 8K RX Memory to each socket. 7 6 5 Socket 3 S1 4 3 Socket 2 S0 S1 2 1 Socket 1 S0 S1 0 Socket 0 S0 S1 S0 The memory size according to the configuration of S1, S0, is as below. S1 S0 Memory size 0 0 1KB 0 1 2KB 1 0 4KB 1 1 8KB According to the value of S1 and S0, the memory is assigned to the sockets from socket 0 within the range of 8KB. If there is not enough memory to be assigned, the socket should not be used. The initial value is 0x55 and the 2K memory is assigned to each 4 sockets respectively. Ex) When setting as 0xAA, the 4KB memory should be assigned to each socket. However, the total memory size is 8KB. The memory is normally assigned to the socket 0 and 1, but not to the socket 2 and 3. Therefore, socket 2 and 3 can not be absolutely used. Socket 3 Socket 2 Socket 1 Socket 0 0KB 0KB 4KB 4KB TMSR(TX Memory Size Register) [R/W] [0x001B] [0x55] This register is used in assigning total 8K TX Memory to sockets. Configuration can be done in the same way of RX Memory Size Register (RMSR). The initial value is 0x55 and it is to assign 2K memory to 4 sockets respectively. © Copyright 2008 WIZnet Co., Inc. All rights reserved. 23 W5100 Datasheet PATR (Authentication Type in PPPoE mode) [R] [0x001C-0x001D] [0x0000] This register notifies authentication method that has been agreed at the connection with PPPoE Server. W5100 supports two types of Authentication method - PAP and CHAP. Value Authentication Type 0xC023 PAP 0xC223 CHAP PTIMER (PPP Link Control Protocol Request Timer Register) [R/W] [0x0028] [0x28] This register indicates the duration for sending LCP Echo Request. Value 1 is about 25ms. Ex) in case that PTIMER is 200, 200 * 25(ms) = 5000(ms) = 5 seconds PMAGIC (PPP Link Control Protocol Magic number Register) [R/W] [0x0029] [0x00] This register is used in Magic number option during LCP negotiation. Refer to the application note, “How to connect ADSL”. UIPR (Unreachable IP Address Register) [R] [0x002A – 0x002D] [0x00] In case of data transmission using UDP (refer to “5.2.2. UDP”), if transmitting to non-existing IP address, ICMP (Destination Unreachable) packet will be received. In this case, that IP address and port number will be saved in the Unreachable IP Address Register(UIPR) and Unreachable Port Register(UPORT) respectively. Ex) in case of “192.168.0.11”, 0x002A 0x002B 0x002C 0x002D 192 (0xC0) 168 (0xA8) 0 (0x00) 11 (0x0B) UPORT (Unreachable Port Register) [R] [0x002E – 0x002F] [0x0000] Refer to Unreachable IP Address Register (UIPR) Ex) In case of 5000(0x1388), 0x002E 0x002F 0x13 0x88 © Copyright 2008 WIZnet Co., Inc. All rights reserved. 24 W5100 Datasheet 4.2 Socket Registers Sn1_MR (Socket n Mode Register) [R/W] [0x0400, 0x0500, 0x0600, 0x0700] [0x00]2 This register sets up socket option or protocol type for each socket. 7 6 5 MULTI Bit 4 ND / MC Symbol 3 2 1 0 P3 P2 P1 P0 Description Multicasting 0 : disable Multicasting 1 : enable Multicasting 7 MULTI It is applied only in case of UDP. For using multicasting, write multicast group address to Socket n Destination IP and multicast group port number to Socket n Destination Port Register, before OPEN command. 6 Reserved Reserved Use No Delayed ACK 0 : Disable No Delayed ACK option 1 : Enable No Delayed ACK option, It is applied only in case of TCP. If this bit is set as ‘1’, ACK packet is transmitted whenever receiving data packet from the peer. If this bit is 5 ND/MC cleared to ‘0’, ACK packet is transmitted according to internal Timeout mechanism. Multicast 0 : using IGMP version 2 1 : using IGMP version 1 It is applied only in case of MULTI bit is ‘1’ 4 Reserved Reserved Protocol 3 2 P3 P2 Sets up corresponding socket as TCP, UDP, or IP RAW mode P3 P2 P1 P0 Meaning 0 0 0 0 Closed 0 0 0 1 TCP n is socket number (0, 1, 2, 3). [Read/Write] [address of socket 0, address of socket 1, address of socket 2, address of socket 3] [Reset value] 1 2 © Copyright 2008 WIZnet Co., Inc. All rights reserved. 25 P1 0 1 0 UDP 0 0 1 1 IPRAW W5100 Datasheet 1 0 * In case of socket 0, MACRAW and PPPoE mode exist. 0 P0 P3 P2 P1 P0 Meaning 0 1 0 0 MACRAW 0 1 0 1 PPPoE Sn_CR (Socket n Command Register) [R/W] [0x0401, 0x0501, 0x0601, 0x0701] [0x00] This register is utilized for socket n initialization, close, connection establishment, termination, data transmission and command receipt. After performing the commands, the register value will be automatically cleared to 0x00. Value Symbol Description It is used to initialize the socket. According to the value of Socket n 0x01 OPEN Mode Register (Sn_MR), Socket n Status Register(Sn_SR) value is changed to SOCK_INIT, SOCK_UDP, SOCK_IPRAW, or SOCK_MACRAW. For more detail, refer to 5. Functional Description. It is only used in TCP mode. It changes the value of Socket n Status Register (Sn_SR) to SOCK_LISTEN 0x02 LISTEN in order to wait for a connection request from any remote peer (TCP Client). For more detail, refer to 5.2.1.1 SERVER mode. It is only used in TCP mode. 0x04 CONNECT It sends a connection request to remote peer(TCP SERVER). If the connection is failed, Timeout interrupt will occur. For more detail, refer to 5.2.1.2 CLIENT mode. It is only used in TCP mode. It sends a connection termination request. If connection termination is failed, Timeout interrupt will occur. For more detail, refer to 5.2.1.1 0x08 DISCON SERVER mode. * In case of using CLOSE command instead of DISCON, only the value of Socket n Status Register(Sn_SR) is changed to SOCK_CLOSED without the connection termination process. 0x10 CLOSE It is used to close the socket. It changes the value of Socket n Status Register(Sn_SR) to SOCK_CLOSED. © Copyright 2008 WIZnet Co., Inc. All rights reserved. 26 W5100 Datasheet It transmits the data as much as the increased size of Socket n TX Write 0x20 SEND Pointer. For more detail, refer to Socket n TX Free Size Register (Sn_TX_FSR), Socket n TX Write Pointer Register(Sn_TX_WR), and Socket n TX Read Pointer Register(Sn_TX_RR) or 5.2.1.1. SERVER mode. It is used in UDP mode. The basic operation is same as SEND. Normally SEND operation needs 0x21 SEND_MAC Destination Hardware Address that is received in ARP(Address Resolution Protocol) process. SEND_MAC uses Socket n Destination Hardware Address(Sn_DHAR) that is written by users without ARP process. It is only used in TCP mode. 0x22 SEND_KEEP It checks the connection status by sending 1byte data. If the connection is already terminated or peer has no response, Timeout interrupt will occur. Receiving is processed with the value of Socket n RX Read Pointer Register(Sn_RX_RD). 0x40 RECV For more detail, refer to 5.2.1.1 SERVER mode Receiving Process with Socket n RX Received Size Register (Sn_RX_RSR), Socket n RX Write Pointer Register(Sn_RX_WR), and Socket n RX Read Pointer Register(Sn_RX_RD) Sn_IR (Socket n Interrupt Register) [R] [0x0402, 0x0502, 0x0602, 0x0702] [0x00] This register is used for notifying connection establishment and termination, receiving data and Timeout. The Socket n Interrupt Register must be cleared by writing ‘1’. 7 6 5 4 3 2 1 0 Reserved Reserved Reserved SEND_OK TIMEOUT RECV DISCON CON Bit Symbol Description 7 Reserved Reserved 6 Reserved Reserved 5 Reserved Reserved 4 SEND_OK It is set as ‘1’ if send operation is completed. TIMEOUT It is set as ‘1’ if Timeout occurs during connection establishment or 3 2 termination and data transmission. RECV It is set as ‘1’ whenever W5100 receives data. And it is also set as ‘1’ © Copyright 2008 WIZnet Co., Inc. All rights reserved. 27 W5100 Datasheet if received data remains after execute CMD_RECV command. 1 DISCON It is set as ‘1’ if connection termination is requested or finished. 0 CON It is set as ‘1’ if connection is established. Sn_SR (Socket n Status Register) [R] [0x0403, 0x0503, 0x0603, 0x0703] [0x00] This register has the status value of socket n. The main status is shown in the below diagram. Value 0x00 Symbol SOCK_CLOSED Description It is shown in case that CLOSE commands are given to Sn_CR, and Timeout interrupt is asserted or connection is terminated. In this SOCK_CLOSED status, no operation occurs and all resources for the connection is released. © Copyright 2008 WIZnet Co., Inc. All rights reserved. 28 SOCK_INIT W5100 Datasheet 0x13 It is shown in case that Sn_MR is set as TCP and OPEN commands are given to Sn_CR. This is the initial step for TCP connection establishment of a socket. In this SOCK_INIT status, the command type (LISTEN or CONNECT) of Sn_CR will decide the operation type – TCP server mode or Client mode. 0x14 SOCK_LISTEN It is shown in case that LISTEN commands are given to Sn_CR at the SOCK_INIT status. The related socket will operate as TCP Server mode, and become ESTBLISHED status if connection request is normally received. 0x17 SOCK_ESTABLISHED It is shown in case that connection is established. In this status, TCP data is transmitted and received. 0x1C SOCK_CLOSE_WAIT It is shown in case that connection termination request is received from peer host. At this status, the Acknowledge message has been received from the peer, but not disconnected. The connection can be closed by receiving the DICON or CLOSE commands. 0x22 SOCK_UDP It is shown in case that OPEN commands are given to Sn_CR when Sn_MR is set as UDP. As this status does not need the connection process with peer, the data can be directly transmitted and received. 0x32 SOCK_IPRAW It is shown in case that OPEN commands are given to Sn_CR when Sn_MR is set as IPRAW. At the IPRAW status, the following protocols of IP Header are not processed. Refer to “IP RAW” for more information. 0x42 SOCK_MACRAW It is shown in case that OPEN commands are given to S0_CR when S0_MR is set as MACRAW. At the MAC RAW status, there is no protocol process for a packet. For more information, refer to “MAC RAW”. 0x5F SOCK_PPPOE It is shown in case that OPEN commands are given to S0_CR when S0_MR is set as PPPoE. Below is shown during changing the status. Value 0x15 Symbol SOCK_SYNSENT Description It is shown in case that CONNECT commands are given to Socket n Command Register(Sn_CR) at the SOCK_INIT status. It is automatically changed to SOCK_ESTABLISH when the © Copyright 2008 WIZnet Co., Inc. All rights reserved. 29 W5100 Datasheet connection is established. 0x16 SOCK_SYNRECV It is shown in case that connection request is received from remote peer(CLIENT). It normally responds to the requests and changes to SOCK_ESTABLISH. 0x18 SOCK_FIN_WAIT 0x1A SOCK_CLOSING 0X1B SOCK_TIME_WAIT 0X1D SOCK_LAST_ACK 0x11 SOCK_ARP It is shown in the process of connection termination. If the termination is normally processed or Timeout interrupt is asserted, it will be automatically changed to SOCK_CLOSED. It is shown when ARP Request is sent in order to acquire 0x21 hardware address of remote peer when it sends connection 0x31 request in TCP mode or sends data in UDP mode. If ARP Reply is received, it changes to the status, SOCK_SYNSENT, SOCK_UDP or SOCK_ICMP, for the next operation. Sn_PORT (Socket n Source Port Register) [R/W] [0x0404–0x0405, 0x0504–0x0505, 0x0604– 0x0605, 0x0704–0x0705] [0x00] This register sets the Source Port number for each Socket when using TCP or UDP mode, and the set-up needs to be made before executing the OPEN Command. Ex) In case of Socket 0 Port = 5000(0x1388), configure as below, 0x0404 0x0405 0x13 0x88 Sn_DHAR (Socket n Destination Hardware Address Register) [R/W] [0x0406–0x040B, 0x0506–0x050B, 0x0606–0x060B, 0x0706–0x070B] [0xFF] This register sets the Destination Hardware address of each Socket. Ex) In case of Socket 0 Destination Hardware address = 08.DC.00.01.02.10, configuration is as below, 0x0406 0x0407 0x0408 0x0409 0x040A 0x040B 0x08 0xDC 0x00 0x01 0x02 0x0A © Copyright 2008 WIZnet Co., Inc. All rights reserved. 30 W5100 Datasheet Sn_DIPR (Socket n Destination IP Address Register) [R/W] [0x040C–0x040F, 0x050C–0x050F, 0x060C–0x060F, 0x070C–0x070F] [0x00] This register sets the Destination IP Address of each Socket to be used in setting the TCP connection. In active mode, IP address needs to be set before executing the Connect command. In passive mode, W5100 sets up the connection and then is internally updated with peer IP. In UDP mode, this register value decided to user’s written value after receiving peer’s ARP response. Before receiving peer’s ARP response, this register has reset value. Ex) In case of Socket 0 Destination IP address = 192.168.0.11, configure as below. 0x040C 0x040D 0x040E 0x040F 192 (0xC0) 168 (0xA8) 0 (0x00) 11 (0x0B) Sn_DPORT (Socket n Destination Port Register) [R/W] [0x0410–0x0411, 0x0510–0x0511, 0x0610–0x0611, 0x0710–0x0711] [0x00] This register sets the Destination Port number of each socket to be used in setting the TCP connection. In active mode, port number needs to be set before executing the Connect command. In passive mode, W5100 sets up the connection and then is internally updated with peer port number. In UDP mode, this register value decided to user’s written value after receiving peer’s ARP response. Before receiving peer’s ARP response, this register has reset value. Ex) In case of Socket 0 Destination Port = 5000(0x1388), configure as below, 0x0410 0x0411 0x13 0x88 Sn_MSS (Socket n Maximum Segment Size Register) [R/W] [0x0412-0x0413, 0x05120x0513, 0x0612-0x0613, 0x0712-0x0713] [0x 0000] This register is used for MSS (Maximum Segment Size) of TCP, and the register displays MSS set by the other party when TCP is activated in Passive Mode. Ex) In case of Socket 0 MSS = 1460(0x05B4), configure as below, 0x0412 0x0413 0x05 0xB4 © Copyright 2008 WIZnet Co., Inc. All rights reserved. 31 W5100 Datasheet Sn_PROTO (Socket n IP Protocol Register) [R/W] [0x0414, 0x0514, 0x0614, 0x0714] [0x00] This IP Protocol Register is used to set up the Protocol Field of IP Header at the IP Layer RAW Mode. There are several protocol numbers defined in advance by registering to IANA. For the overall list of upper level protocol identification number that IP is using, refer to online documents of IANA (http://www.iana.org/assignments/protocol-numbers). Ex) Internet Control Message Protocol (ICMP) = 0x01, Internet Group Management Protocol = 0x02 Sn_TOS (Socket n IP Type Of Service Register) [R/W] [0x0415,0x0515,0x0615,0x0715] [0x00] This register sets up at the TOS(Type of Service) Field of IP Header. Sn_TTL (Socket n IP Time To Live Register) [R/W] [0x0416,0x0516,0x0616,0x0716] [0x80] This register sets up at the TTL(Time To Live) Field of IP Header. Sn_TX_FSR (Socket n TX Free Size Register) [R] [0x0420-0x0421, 0x0520-0x0521, 0x0620-0x0621, 0x0720-0x0721] [0x0800] This register notifies the information of data size that user can transmit. For data transmission, user should check this value first and control the size of transmitting data. When checking this register, user should read upper byte(0x0420,0x0520,0x0620,0x0720) first and lower byte(0x0421,0x0521,0x0621,0x0721) later to get the correct value. Ex) In case of 2048(0x0800) in S0_TX_FSR, 0x0420 0x0421 0x08 0x00 Total size can be decided according to the value of TX Memory Size Register. In the process of transmission, it will be reduced by the size of transmitting data, and automatically increased after transmission finished. © Copyright 2008 WIZnet Co., Inc. All rights reserved. 32 W5100 Datasheet Sn_TX_RR (Socket n TX Read Pointer Register) [R] [0x0422-0x0423, 0x0522-0x0523, 0x0622-0x0623, 0x0722-0x0723] [0x0000] This register shows the address that transmission is finished at the TX Memory. With the SEND command of Socket n Command Register, it transmits data from current Sn_TX_RR to Sn_TX_WR and automatically changes after transmission is finished. Therefore, after transmission is finished, Sn_TX_RR and Sn_TX_WR will have same value. When reading this register, user should read upper byte (0x0422, 0x0522, 0x0622, 0x0722) first and lower byte (0x0423, 0x0523, 0x0623, 0x0723) later to get the correct value. Sn_TX_WR (Socket n TX Write Pointer Register) [R/W] [0x0424-0x0425, 0x0524-0x0525, 0x0624-0x0625, 0x0724-0x0725] [0x0000] This register offers the location information to write the transmission data. When reading this register, user should read upper byte (0x0424, 0x0524, 0x0624, 0x0724) first and lower byte (0x0425, 0x0525, 0x0625, 0x0725) later to get the correct value. Ex) In case of 2048(0x0800) in S0_TX_WR, 0x0424 0x0425 0x08 0x00 But this value itself is not the physical address to write. So, the physical address should be calculated as follow. 1. Socket n TX Base Address (hereafter we'll call gSn_TX_BASE) and Socket n TX Mask Address (hereafter we'll call gSn_TX_MASK) are calculated on TMSR value. Refer to the psedo code of the Initialization if the detail is needed. 2. The bitwise-AND operation of two values, Sn_TX_WR and gSn_TX_MASK give result the offset address(hereafter we'll call get_offset) in TX memory range of the socket. 3. Two values get_offset and gSn_TX_BASE are added together to give result the physical address(hereafter, we'll call get_start_address). Now, write the transmission data to get_start_address as large as you want. (* There's a case that it exceeds the TX memory upper-bound of the socket while writing. In this case, write the transmission data to the upper-bound, and change the physical address to the gSn_TX_BASE. Next, write the rest of the transmission data.) After that, be sure to increase the Sn_TX_WR value as much as the data size that indicates the size of writing data. Finally, give SEND command to Sn_CR(Socket n Command Register). Refer to the psedo code of the transmission part on TCP Server mode if the detail is needed. © Copyright 2008 WIZnet Co., Inc. All rights reserved. 33 W5100 Datasheet Calculate physical address © Copyright 2008 WIZnet Co., Inc. All rights reserved. 34 W5100 Datasheet Sn_RX_RSR (RX Received Size Register) [R] [0x0426-0x0427, 0x0526-0x0527, 0x06260x0627, 0x0726-0x0727] [0x0000] This register notifies the data size received in RX Memory. As this value is internally calculated with the values of Sn_RX_RD and Sn_RX_WR, it is automatically changed by RECV command of Socket n Command Register(Sn_CR) and receiving data for remote peer. When reading this register, user should read upper byte(0x0426,0x0526,0x0626,0x0726) first and lower byte(0x0427,0x0527,0x0627,0x0727) later to get the correct value. Ex) In case of 2048(0x0800) in S0_RX_RSR, 0x0426 0x0427 0x08 0x00 The total size of this value can be decided according to the value of RX Memory Size Register. Sn_RX_RD (Socket n RX Read Pointer Register) [R/W] [0x0428-0x0429, 0x0528-0x0529, 0x0628-0x0629, 0x0728-0x0729] [0x0000] This register offers the location information to read the receiving data. When reading this register, user should read upper byte (0x0428, 0x0528, 0x0628, 0x0728) first and lower byte (0x0429, 0x0529, 0x0629, 0x0729) later to get the correct value. Ex) In case of 2048(0x0800) in S0_RX_RD, 0x0428 0x0429 0x08 0x00 But this value itself is not the physical address to read. So, the physical address should be calculated as follow. 1. Socket n RX Base Address (hereafter we'll call gSn_RX_BASE) and Socket n RX Mask Address (hereafter we'll call gSn_RX_MASK) are calculated on RMSR value. Refer to the pseudo code of the 5.1 Initialization if the detail is needed. 2. The bitwise-AND operation of two values, Sn_RX_RD and gSn_RX_MASK give result the offset address(hereafter we'll call get_offset), in RX memory range of the socket. 3. Two values get_offset and gSn_RX_BASE are added together to give result the physical address(hereafter, we'll call get_start_address). Now, read the receiving data from get_start_address as large as you want. (* There's a case that it exceeds the RX memory upper-bound of the socket while reading. In this case, read the receiving data to the upper-bound, and change the physical address to the gSn_RX_BASE. Next, read the rest of the receiving data.) After that, be sure to increase the Sn_RX_RD value as large as the data size that indicates the © Copyright 2008 WIZnet Co., Inc. All rights reserved. 35 W5100 Datasheet size of reading data. (* Must not increase more than the size of received data. So must check Sn_RX_RSR before receiving process.) Finally, give RECV command to Sn_CR(Socket n Command Register). Refer to the pseudo code of the receiving part on TCP Server mode if the detail is needed. © Copyright 2008 WIZnet Co., Inc. All rights reserved. 36 W5100 Datasheet 5. Functional Descriptions By setting some register and memory operation, W5100 provides internet connectivity. This chapter describes how it can be operated. 5.1 Initialization „ Basic Setting For the W5100 operation, select and utilize appropriate registers shown below. 1. Mode Register (MR) 2. Interrupt Mask Register (IMR) 3. Retry Time-value Register (RTR) 4. Retry Count Register (RCR) For more information of above registers, refer to the “Register Descriptions”. „ Setting network information Below register is for basic network configuration information to be configured according to the network environment. 1. Gateway Address Register (GAR) 2. Source Hardware Address Register (SHAR) 3. Subnet Mask Register (SUBR) 4. Source IP Address Register (SIPR) The Source Hardware Address Register (SHAR) is the H/W address to be used in MAC layer, and can be used with the address that manufacturer has been assigned. The MAC address can be assigned from IEEE. For more detail, refer to IEEE homepage. „ Set socket memory information This stage sets the socket tx/rx memory information. The base address and mask address of each socket are fixed and saved in this stage. In case of, assign 2K rx memory per socket. { RMSR = 0x55; // assign 2K rx memory per socket. gS0_RX_BASE = chip_base_address + RX_memory_base_address(0x6000); gS0_RX_MASK = 2K – 1 ; // 0x07FF, for getting offset address within assigned socket 0 RX memory. gS1_RX_BASE = gS0_BASE + (gS0_MASK + 1); gS1_RX_MASK = 2K – 1 ; © Copyright 2008 WIZnet Co., Inc. All rights reserved. 37 W5100 Datasheet gS2_RX_BASE = gS1_BASE + (gS1_MASK + 1); gS2_RX_MASK = 2K – 1 ; gS3_RX_BASE = gS2_BASE + (gS2_MASK + 1); gS3_RX_MASK = 2K – 1 ; TMSR = 0x55; // assign 2K tx memory per socket. Same method, set gS0_TX_BASE, gS0_TX_MASK, gS1_TX_BASE, gS1_TX_MASK, gS2_TX_BASE, gS2_TX_MASK, gS3_TX_BASE and gS3_TX_MASK. } In case of, assign 4K,2K,1K,1K. { RMSR = 0x06; // assign 4K,2K,1K,1K rx memory per socket. gS0_RX_BASE = chip_base_address + RX_memory_base_address(0x6000); gS0_RX_MASK = 4K – 1 ; // 0x0FFF, for getting offset address within assigned socket 0 RX memory. gS1_RX_BASE = gS0_BASE + (gS0_MASK + 1); gS1_RX_MASK = 2K – 1 ; // 0x07FF gS2_RX_BASE = gS1_BASE + (gS1_MASK + 1); gS2_RX_MASK = 1K – 1 ; // 0x03FF gS3_RX_BASE = gS2_BASE + (gS2_MASK + 1); gS3_RX_MASK = 1K – 1 ; // 0x03FF TMSR = 0x06; // assign 4K,2K,1K,1K rx memory per socket. Same method, set gS0_TX_BASE, gS0_TX_MASK, gS1_TX_BASE, gS1_TX_MASK, gS2_TX_BASE, gS2_TX_MASK, gS3_TX_BASE and gS3_TX_MASK. } © Copyright 2008 WIZnet Co., Inc. All rights reserved. 38 W5100 Datasheet © Copyright 2008 WIZnet Co., Inc. All rights reserved. 39 W5100 Datasheet 5.2 Data Communications Data communication is available through TCP, UDP, IP-Raw and MAC-Raw . In order to select it, configure protocol field of Socket n Mode Register(Sn_MR) of the communication sockets (W5100 supports total 4 sockets). 5.2.1 TCP TCP is the connection based communication method that will establish connection in advance and deliver the data through the connection by using IP Address and Port number of the systems. There are two methods to establish the connection. One is SERVER mode(passive open) that is waiting for connection request. The other is CLIENT mode (active open) that sends connection request to a server. © Copyright 2008 WIZnet Co., Inc. All rights reserved. 40 W5100 Datasheet 5.2.1.1 SERVER mode „ Socket Initialization In order to initialize a socket, set the operation mode and port of the socket, and provide OPEN command to the command register of the socket. Below is the registers related. Socket n Mode Register (Sn_MR) Socket n Source Port Register (Sn_PORT) Socket n Command Register (Sn_CR) It initializes the socket n as TCP, { START: /* sets TCP mode */ Sn_MR = 0x01; /* sets source port number */ Sn_PORT = source_port; © Copyright 2008 WIZnet Co., Inc. All rights reserved. 41 W5100 Datasheet /* sets OPEN command */ Sn_CR = OPEN; if (Sn_SR != SOCK_INIT) Sn_CR = CLOSE; goto START; } „ LISTEN Set the LISTEN command to the command register. The related register is below. Socket n Command Register (Sn_CR) { /* listen socket */ Sn_CR = LISTEN; if (Sn_SR != SOCK_LISTEN) Sn_CR = CLOSE; goto START; // check socket status } „ ESTABLISHED ? If connection request is received from remote peer (the status of SOCK_SYNRECV), W5100 sends ACK packet and changes to SOCK_ESTABLISHED status. This status can be checked as below. First method : { If (Sn_IR(CON bit) == ‘1’) goto ESTABLISHED stage; /* In this case, if the interrupt of Socket n is activated, interrupt occurs. Refer to Interrupt Register(IR), Interrupt Mask Register (IMR) and Socket n Interrupt Register (Sn_IR). */ } Second method : { If (Sn_SR == SOCK_ESTABLISHED) goto ESTABLISHED stage; } As connection is established, data transmission and receipt can be performed. © Copyright 2008 WIZnet Co., Inc. All rights reserved. 42 W5100 Datasheet „ ESTABLISHED : Received Data ? Check as below to know if data is received from remote peer or not. First method : { If (Sn_IR(RECV bit) == ‘1’) goto Receiving Process stage; /* In this case, if the interrupt of Socket n is activated, interrupt occurs. Refer to Interrupt Register(IR), Interrupt Mask Register (IMR) and Socket n Interrupt Register (Sn_IR). */ } Second Method : { if (Sn_RX_RSR != 0x0000) goto Receiving Process stage; } „ ESTABLISHED : Receiving Process Received data can be processed as below. { /* first, get the received size */ get_size = Sn_RX_RSR; /* calculate offset address */ get_offset = Sn_RX_RD & gSn_RX_MASK; /* calculate start address(physical address) */ get_start_address = gSn_RX_BASE + get_offset; /* if overflow socket RX memory */ if ( (get_offset + get_size) > (gSn_RX_MASK + 1) ) { /* copy upper_size bytes of get_start_address to destination_addr */ upper_size = (gSn_RX_MASK + 1) – get_offset; memcpy(get_start_address, destination_addr, upper_size); /* update destination_addr*/ destination_addr += upper_size; /* copy left_size bytes of gSn_RX_BASE to destination_addr */ left_size = get_size – upper_size; © Copyright 2008 WIZnet Co., Inc. All rights reserved. 43 W5100 Datasheet memcpy(gSn_RX_BASE, destination_addr, left_size); } else { /* copy get_size bytes of get_start_address to destination_addr */ memcpy(get_start_address, destination_addr, get_size); } /* increase Sn_RX_RD as length of get_size */ Sn_RX_RD += get_size; /* set RECV command */ Sn_CR = RECV; } „ ESTABLISHED : Send DATA ? / Sending Process The sending procedure is as below. { /* first, get the free TX memory size */ FREESIZE: get_free_size = Sn_TX_FSR; if (get_free_size < send_size) goto FREESIZE; /* calculate offset address */ get_offset = Sn_TX_WR & gSn_TX_MASK; /* calculate start address(physical address) */ get_start_address = gSn_TX_BASE + get_offset; /* if overflow socket TX memory */ if ( (get_offset + send_size) > (gSn_TX_MASK + 1) ) { /* copy upper_size bytes of source_addr to get_start_address */ upper_size = (gSn_TX_MASK + 1) – get_offset; memcpy(source_addr, get_start_address, upper_size); /* update source_addr*/ source_addr += upper_size; /* copy left_size bytes of source_addr to gSn_TX_BASE */ left_size = send_size – upper_size; © Copyright 2008 WIZnet Co., Inc. All rights reserved. 44 W5100 Datasheet memcpy(source_addr, gSn_TX_BASE, left_size); } else { /* copy send_size bytes of source_addr to get_start_address */ memcpy(source_addr, get_start_address, send_size); } /* increase Sn_TX_WR as length of send_size */ Sn_TX_WR += send_size; /* set SEND command */ Sn_CR = SEND; } „ ESTABLISHED : Received FIN? Waiting for a connection termination request from remote peer. It can be checked as below if it received connection termination request of remote peer. First method : { If (Sn_IR(DISCON bit) == ‘1’) goto CLOSED stage; /* In this case, if the interrupt of Socket n is activated, interrupt occurs. Refer to Interrupt Register(IR), Interrupt Mask Register (IMR) and Socket n Interrupt Register (Sn_IR). */ } Second method : { If (Sn_SR == SOCK_CLOSE_WAIT) goto CLOSED stage; } „ ESTABLISHED : Disconnect ? / Disconnecting Process Check if user requests to terminate this connection. To terminate the connection, proceed as below, { /* set DISCON command */ Sn_CR = DISCON; } © Copyright 2008 WIZnet Co., Inc. All rights reserved. 45 W5100 Datasheet „ ESTABLISHED : CLOSED ? No connection state at all. It can be checked as below, First method : { If (Sn_IR(DISCON bit) == ‘1’) goto CLOSED stage; /* In this case, if the interrupt of Socket n is activated, interrupt occurs. Refer to Interrupt Register(IR), Interrupt Mask Register (IMR) and Socket n Interrupt Register (Sn_IR). */ } Second method : { If (Sn_SR == SOCK_CLOSED) goto CLOSED stage; } „ ESTABLISHED : Timeout In case that connection is closed due to the error of remote peer during data receiving or connection closing process, data transmission can not be normally processed. At this time Timeout occurs after some time. First method : { If (Sn_IR(TIMEOUT bit) == ‘1’) goto CLOSED stage; /* In this case, if the interrupt of Socket n is activated, interrupt occurs. Refer to Interrupt Register(IR), Interrupt Mask Register (IMR) and Socket n Interrupt Register (Sn_IR). */ } Second method : { If (Sn_SR == SOCK_CLOSED) goto CLOSED stage; } © Copyright 2008 WIZnet Co., Inc. All rights reserved. 46 W5100 Datasheet „ Socket Close This process should be processed in case that connection is closed after data exchange, socket should be closed with Timeout occurrence, or forcible disconnection is necessary due to abnormal operation. { /* set CLOSE command */ Sn_CR = CLOSE; } © Copyright 2008 WIZnet Co., Inc. All rights reserved. 47 W5100 Datasheet 5.2.1.2 CLIENT mode Whole process is shown as below. „ Socket Initialization Refer to “5.2.1.1 SERVER mode” (The operation is same as SERVER). „ CONNECT Send connection request to remote HOST(SERVER) is as below. { /* Write the value of server_ip, server_port to the Socket n Destination IP Address Register(Sn_DIPR), Socket n Destination Port Register(Sn_DPORT). */ Sn_DIPR = server_ip; Sn_DPORT = server_port; /* set CONNECT command */ © Copyright 2008 WIZnet Co., Inc. All rights reserved. 48 W5100 Datasheet Sn_CR = CONNECT; } „ ESTABLISHED ? The connection is established. It can be checked as below, First method : { If (Sn_IR(CON bit) == ‘1’) goto ESTABLISHED stage; /* In this case, if the interrupt of Socket n is activated, interrupt occurs. Refer to Interrupt Register(IR), Interrupt Mask Register (IMR) and Socket n Interrupt Register (Sn_IR). */ } Second method : { If (Sn_SR == SOCK_ESTABLISHED) goto ESTABLISHED stage; } „ Timeout Socket is closed as Timeout occurs as there is not response from remote peer. It can be checked as below. First method : { If (Sn_IR(TIMEOUT bit) == ‘1’) goto CLOSED stage; /* In this case, if the interrupt of Socket n is activated, interrupt occurs. Refer to Interrupt Register(IR), Interrupt Mask Register (IMR) and Socket n Interrupt Register (Sn_IR). */ } Second method : { If (Sn_SR == SOCK_CLOSED) goto CLOSED stage; } „ ESTABLISHED Refer to “5.2.1.1. SERVER mode” (The operation is same as SERVER mode) © Copyright 2008 WIZnet Co., Inc. All rights reserved. 49 W5100 Datasheet 5.2.2 UDP UDP provides unreliable and connectionless datagram transmission structure. It processes data without connection establishment. Therefore, UDP message can be lost, overlapped or reversed. As packets can arrive faster, recipient can not process all of them. In this case, user application should guarantee the reliability of data transmission. UDP transmission can be processed as below, „ Socket Initialization Initialize the socket n as UDP. { START: /* sets UDP mode */ Sn_MR = 0x02; /* sets source port number */ /* ※ The value of Source Port can be appropriately delivered when remote HOST knows it. */ Sn_PORT = source_port; /* sets OPEN command */ Sn_CR = OPEN; /* Check if the value of Socket n Status Register(Sn_SR) is SOCK_UDP. */ if (Sn_SR != SOCK_UDP) Sn_CR = CLOSE; goto START; } © Copyright 2008 WIZnet Co., Inc. All rights reserved. 50 W5100 Datasheet „ Received DATA? It can be checked as below if data is received from remote peer. First method : { if (Sn_RX_RSR != 0x0000) goto Receiving Process stage; } Second Method : { If (Sn_IR(RECV bit) == ‘1’) goto Receiving Process stage; /* In this case, if the interrupt of Socket n is activated, interrupt occurs. Refer to Interrupt Register(IR), Interrupt Mask Register (IMR) and Socket n Interrupt Register (Sn_IR). */ } „ Receiving Process Received data can be processed as below. In case of UDP, 8byte header is attached to receiving data. The structure of the header is as below. { /* first, get the received size */ get_size = Sn_RX_RSR; /* calculate offset address */ get_offset = Sn_RX_RD & gSn_RX_MASK; /* calculate start address(physical address) */ get_start_address = gSn_RX_BASE + get_offset; /* read head information (8 bytes) */ header_size = 8; © Copyright 2008 WIZnet Co., Inc. All rights reserved. 51 W5100 Datasheet /* if overflow socket RX memory */ if ( (get_offset + header_size) > (gSn_RX_MASK + 1) ) { /* copy upper_size bytes of get_start_address to header_addr */ upper_size = (gSn_RX_MASK + 1) – get_offset; memcpy(get_start_address, header_addr, upper_size); /* update header_addr*/ header_addr += upper_size; /* copy left_size bytes of gSn_RX_BASE to header_addr */ left_size = header_size – upper_size; memcpy(gSn_RX_BASE, header_addr, left_size); /* update get_offset */ get_offset = left_size; } else { /* copy header_size bytes of get_start_address to header_addr */ memcpy(get_start_address, header_addr, header_size); /* update get_offset */ get_offset += header_size; } /* update get_start_address */ get_start_address = gSn_RX_BASE + get_offset; /* save remote peer information & received data size */ peer_ip = header[0 to 3]; peer_port = header[4 to 5]; get_size = header[6 to 7]; /* if overflow socket RX memory */ if ( (get_offset + get_size) > (gSn_RX_MASK + 1) ) { /* copy upper_size bytes of get_start_address to destination_addr */ upper_size = (gSn_RX_MASK + 1) – get_offset; memcpy(get_start_address, destination_addr, upper_size); /* update destination_addr*/ destination_addr += upper_size; © Copyright 2008 WIZnet Co., Inc. All rights reserved. 52 W5100 Datasheet /* copy left_size bytes of gSn_RX_BASE to destination_addr */ left_size = get_size – upper_size; memcpy(gSn_RX_BASE, destination_addr, left_size); } else { /* copy get_size bytes of get_start_address to destination_addr */ memcpy(get_start_address, destination_addr, get_size); } /* increase Sn_RX_RD as length of get_size+header_size */ Sn_RX_RD = Sn_RX_RD + get_size + header_size; /* set RECV command */ Sn_CR = RECV; } „ Send Data? / Sending Process Data transmission process is as below. { /* first, get the free TX memory size */ FREESIZE: get_free_size = Sn_TX_FSR; if (get_free_size < send_size) goto FREESIZE; /* Write the value of remote_ip, remote_port to the Socket n Destination IP Address Register(Sn_DIPR), Socket n Destination Port Register(Sn_DPORT). */ Sn_DIPR = remote_ip; Sn_DPORT = remote_port; /* calculate offset address */ get_offset = Sn_TX_WR & gSn_TX_MASK; /* calculate start address(physical address) */ get_start_address = gSn_TX_BASE + get_offset; /* if overflow socket TX memory */ if ( (get_offset + send_size) > (gSn_TX_MASK + 1) ) { © Copyright 2008 WIZnet Co., Inc. All rights reserved. 53 W5100 Datasheet /* copy upper_size bytes of source_addr to get_start_address */ upper_size = (gSn_TX_MASK + 1) – get_offset; memcpy(source_addr, get_start_address, upper_size); /* update source_addr*/ source_addr += upper_size; /* copy left_size bytes of source_addr to gSn_TX_BASE */ left_size = send_size – upper_size; memcpy(source_addr, gSn_TX_BASE, left_size); } else { /* copy send_size bytes of source_addr to get_start_address */ memcpy(source_addr, get_start_address, send_size); } /* increase Sn_TX_WR as length of send_size */ Sn_TX_WR += send_size; /* set SEND command */ Sn_CR = SEND; } „ Complete Sending? The sending completion should be checked after SEND command. { If (Sn_CR == 0x00) transmission is completed. } „ Timeout Timeout occurs if remote peer does not exist or data transmission is not normally processed. It can be checked as below. { If (Sn_IR(TIMEOUT bit) == ‘1’) goto next stage; /* In this case, if the interrupt of Socket n is activated, interrupt occurs. Refer to Interrupt Register(IR), Interrupt Mask Register (IMR) and Socket n Interrupt Register (Sn_IR). */ } © Copyright 2008 WIZnet Co., Inc. All rights reserved. 54 W5100 Datasheet „ Finished? / Socket Close If all the actions are finished, close the socket. { /* set CLOSE command */ Sn_CR = CLOSE; } © Copyright 2008 WIZnet Co., Inc. All rights reserved. 55 W5100 Datasheet 5.2.3 IP raw IP Raw mode can be utilized if transport layer protocol of some ICMP or IGMP that W5100 does not support, needs to be processed. „ Socket Initialization It initializes the socket as IP raw. { START: /* sets IP raw mode */ Sn_MR = 0x03; /* sets Protocol value */ /* The value of Protocol is used in Protocol Field of IP Header. For the list of protocol identification number of upper classification, refer to on line documents of IANA (http://www.iana.org/assignments/protocol-numbers). */ Sn_PROTO = protocol_value; /* sets OPEN command */ Sn_CR = OPEN; /* Check if the value of Socket n Status Register(Sn_SR) is SOCK_IPRAW. */ if (Sn_SR != SOCK_IPRAW) Sn_CR = CLOSE; goto START; } © Copyright 2008 WIZnet Co., Inc. All rights reserved. 56 W5100 Datasheet „ Received DATA? It is same as UDP. Refer to “5.2.2 UDP”. „ Receiving Process This is same as UDP. Refer to “5.2.2 UDP” except the header information and header size. In case of IP raw, 6byte header is attached to the data received. The header structure is as below. „ Send DATA? / Sending Process This is same as UDP. Refer to “5.2.2 UDP” except that remote_port information is not needed. „ Complete Sending „ Timeout „ Finished? / Socket Closed Next actions are same as UDP. Refer to “5.2.2 UDP”. 5.2.4 MAC raw MAC Raw mode(only supported in socket 0) can be utilized. „ Socket Initialization It initializes the socket as MAC raw. { START: /* sets MAC raw mode */ © Copyright 2008 WIZnet Co., Inc. All rights reserved. 57 W5100 Datasheet Sn_MR = 0x04; /* sets OPEN command */ Sn_CR = OPEN; /* Check if the value of Socket n Status Register(Sn_SR) is SOCK_MACRAW. */ if (Sn_SR != SOCK_MACRAW) Sn_CR = CLOSE; goto START; } „ Received DATA? This is same as UDP. Refer to “5.2.2 UDP”. „ Receiving Process MAC raw received Ethernet packet having packet size information. In case of MAC raw, 2byte header is attached to the data received. The header structure is as below. „ Send DATA? / Sending Process This is same as UDP. Refer to “5.2.2 UDP” except that remote_port information is not needed. © Copyright 2008 WIZnet Co., Inc. All rights reserved. 58 W5100 Datasheet 6. Application Information For the communication with MCU, W5100 provides Direct, Indirect Bus I/F, and SPI I/F modes. For the communication with Ethernet PHY, MII is used. 6.1 Direct Bus Interface mode Direct Bus I/F mode uses 15bit address line and 8bit data line, /CS, /RD, /WR, /INT. 6.2 Indirect Bus Interface mode Indirect Bus I/F mode uses 2bit address line and 8bit data line, /CS, /RD, /WR, /INT. [14:2], other address lines should process Pull-down. Indirect bus I/F mode related register is as below. © Copyright 2008 WIZnet Co., Inc. All rights reserved. 59 Symbol W5100 Datasheet Value Description It performs the selection of Indirect bus I/F mode, address 0x00 MR automatic increase. Refer to “4. Register Description” for more detail. Indirect bus I/F mode address Register Big-endian use only · In case of Big-endian ordering 0x01 IDM_AR0 0x01 0x02 0x02 IDM_AR1 IDM_AR0 : MSB IDM_AR1 : LSB Ex) In case of reading S0_CR(0x0401), 0x03 IDM_DR 0x01(IDM_AR0) 0x02(IDM_AR1) 0x04 0x01 Indirect bus I/F mode data Register In order to read or write the internal register or internal TX/RX Memory, 1. Write the address to read or write on IDM_AR0, 1. 2. Read or Write IDM_DR. In order to read or write the data on the sequential address, set AI bit of MR(Mode Register). With this, user performs above 1 only one time. Whenever read or write IDM_DR, IDM_AR , the value is automatically increased by 1. Therefore, the value can be processed on the sequential address just by continuous reading or writing of IDM_DR. 6.3 SPI (Serial Peripheral Interface) mode Serial Peripheral Interface Mode uses only four pins for data communication. Four pins are SCLK, /SS, MOSI, MISO. At the W5100, SPI_EN pin is used for SPI operation. © Copyright 2008 WIZnet Co., Inc. All rights reserved. 60 W5100 Datasheet 6.3.1 Device Operations The W5100 is controlled by a set of instruction that is sent from a host controller, commonly referred to as the SPI Master. The SPI Master communicates with W5100 via the SPI bus which is composed of four signal lines: Slave Select(/SS), Serial Clock(SCLK), MOSI(Master Out Slave In), MISO(Master In Slave Out). The SPI protocol defines four modes for its operation (Mode 0, 1, 2, 3). Each mode differs according to the SCLK polarity and phase - how the polarity and phase control the flow of data on the SPI bus. The W5100 operates as SPI Slave device and supports the most common modes - SPI Mode 0 and 3. The only difference between SPI Mode 0 and 3 is the polarity of the SCLK signal at the inactive state. With SPI Mode 0 and 3, data is always latched in on the rising edge of SCLK and always output on the falling edge of SCLK. 6.3.2 Commands According to SPI protocol, there are only two data lines used between SPI devices. So, it is necessary to define OP-Code. W5100 uses two types of OP-Code - Read OP-Code and Write OP-Code. Except for those two OP-Codes, W5100 will be ignored and no operation will be started. In SPI Mode, W5100 operates in “unit of 32-bit stream”. The unit of 32-bit stream is composed of 1 byte OP-Code Field, 2 bytes Address Field and 1 byte data Field. OP-Code, Address and data bytes are transferred with the most significant bit(MSB) first and least significant bit(LSB) last. In other words, the first bit of SPI data is MSB of OP-Code Field and the last bit of SPI data is LSB of Data-Field. W5100 SPI data format is as below. Command OP-Code Field Address Field Data Field Write operation 0xF0 1111 0000 2 bytes 1 byte Read operation 0x0F 0000 1111 2 bytes 1 byte 6.3.3 Process of using general SPI Master device (According to SPI protocol) © Copyright 2008 WIZnet Co., Inc. All rights reserved. 61 W5100 Datasheet 1. Configure Input/Output direction on SPI Master device pins. * /SS (Slave Select) : Output pin * SCLK (Serial Clock) : Output pin * MOSI (Master Out Slave In) : Output pin * MISO (Master In Slave Out) : Input pin 2. Configure /SS as ‘High’ 3. Configure the registers on SPI Master device. * SPI Enable bit on SPCR register (SPI Control Register) * Master/Slave select bit on SPCR register * SPI Mode bit on SPCR register * SPI data rate bit on SPCR register and SPSR register (SPI State Register) 4. Write desired value for transmission on SPDR register (SPI Data Register). 5. Configure /SS as ‘Low’ (data transfer start) 6. Wait for reception complete 7. If all data transmission ends, configure /SS as ‘High’ © Copyright 2008 WIZnet Co., Inc. All rights reserved. 62 W5100 Datasheet 7. Electrical Specifications Absolute Maximum Ratings Symbol Parameter Rating Unit VDD DC Supply voltage -0.5 to 3.6 V VIN DC input voltage -0.5 to 5.5 (5V tolerant) V IIN DC input current ±5 mA TOP Operating temperature -40 to 85 °C TSTG Storage temperature -55 to 125 °C *COMMENT: Stressing the device beyond the “Absolute Maximum Ratings” may cause permanent damage. DC Characteristics Symbol VDD Parameter Test Condition DC Supply voltage Junction Min Typ Max Unit 3.0 3.6 V temperature is from -55°C to 125°C VIH High level input voltage 2.0 5.5 V VIL Low level input voltage - 0.5 0.8 V VOH High level output voltage 2.0 3.6 V 0.0 0.4 V ±5 µA IOH = 2, 4, 8, 12, 16, 24 mA VOL Low level output voltage IOL = -2, -4, -8, -12, 16, -24 mA II Input Current VIN = VDD POWER DISSIPATION Symbol P10Base P100Base Parameter Power consumption Test Condition in 10BaseT Power 100BaseT Vcc 3.3V Temperature 25°C consumption in Vcc 3.3V Temperature 25°C © Copyright 2008 WIZnet Co., Inc. All rights reserved. Min Typ Max Unit - 138 183 mA - 146 183 mA 63 W5100 Datasheet AC Characteristics Reset Timing Description 1 Reset Cycle Time 2 /RESET to internal PLOCK Min Max 2 us - - 10 ms Min Max 80 ns - 8 ns - Register/Memory READ Timing Description 1 Read Cycle Time 2 Valid Address to /CS low time 3 /CS low to /RD low time - 1 ns 4 /RD high to /CS high time - 1 ns 5 /RD low to Valid Data Output time - 80 ns 6 /RD high to Data High-Z Output time - 1 ns © Copyright 2008 WIZnet Co., Inc. All rights reserved. 64 W5100 Datasheet Register/Memory WRITE Timing Description Min Max 70 ns - 7 ns - 1 Write Cycle Time 2 Valid Address to /CS low time 3 /CS low to /WR high time 70 ns - 4 /CS low to /WR low time - 1 ns 5 /WR high to /CS high time - 1 ns 6 /WR low to Valid Data time - 14 ns © Copyright 2008 WIZnet Co., Inc. All rights reserved. 65 W5100 Datasheet SPI Timing Description Mode 1 /SS low to SCLK high Slave 21 ns - 2 Input setup time Slave 7 ns - 3 Input hold time Slave 28 ns - 4 Output setup time Slave 7 ns 14 ns 5 Output hold time Slave 21 ns - 6 SCLK time Slave 70 ns 7 SCLK high to /SS high Slave 21ns © Copyright 2008 WIZnet Co., Inc. All rights reserved. Min Max 66 W5100 Datasheet Crystal Characteristics Parameter Range Frequency 25 MHz Frequency Tolerance (at 25℃) ±30 ppm Shunt Capacitance 7pF Max Drive Level 100uW Load Capacitance 27pF Aging (at 25℃) ±3ppm / year Max Transformer Characteristics Parameter Transmit End Receive End Turn Ratio 1:1 1:1 Inductance 350 uH 350 uH Symmetrical TX & RX channels for auto MDI/MDIX capability © Copyright 2008 WIZnet Co., Inc. All rights reserved. 67 W5100 Datasheet 8. IR Reflow Temperature Profile (Lead-Free) Moisture Sensitivity Level : 3 Dry Pack Required : Yes Average Ramp-Up Rate 3° C/second max. (Tsmax to Tp) Preheat – Temperature Min (Tsmin) 150 °C – Temperature Max (Tsmax) 200 °C – Time (tsmin to tsmax) 60-180 seconds Time maintained above: – Temperature (TL) 217 °C – Time (tL) 60-150 seconds Peak/Classification Temperature (Tp) 260 + 0 °C Time within 5 °C of actual Peak Temperature (tp) 20-40 seconds Ramp-Down Rate 6 °C/second max. Time 25 °C to Peak Temperature 8 minutes max. © Copyright 2008 WIZnet Co., Inc. All rights reserved. 68 W5100 Datasheet 9. Package Descriptions ☞ Above diagram shows PIN dimension. All 80 pins are not displayed. SYMBOL MILLIMETER INCH MIN. NOM. MAX. MIN. NOM. MAX. A - - 1.60 - - 0.063 A1 0.05 - 0.15 0.002 - 0.006 © Copyright 2008 WIZnet Co., Inc. All rights reserved. 69 1.35 1.40 1.45 0.053 0.055 D 12.00 BSC. 0.472 BSC. D1 10.00 BSC. 0.393 BSC. E 12.00 BSC. 0.472 BSC. E1 10.00 BSC. 0.393 BSC. 0.057 R2 0.08 - 0.20 0.003 - 0.008 R1 0.08 - - 0.003 - - θ 0° 3.5° 7° 0° 3.5° 7° θ1 0° - - 0° - - θ2 11° 12° 13° 11° 12° 13° θ3 11° 12° 13° 11° 12° 13° c 0.09 - 0.20 0.004 - 0.008 L 0.45 0.60 0.75 0.018 0.024 0.030 L1 1.00 REF W5100 Datasheet A2 0.039 REF S 0.20 - - 0.008 - - b 0.13 0.16 0.23 0.005 0.006 0.009 e 0.40 BSC 0.016 BSC D2 7.60 0.299 E2 7.60 0.299 aaa 0.20 0.008 bbb 0.20 0.008 ccc 0.08 0.003 ddd 0.07 0.003 Note : 1. DIMENSIONS D1 AND E1 DO NOT INCLUDE MOLD PROTRUSION. ALLOWABLE PROTRUSION IS 0.25mm PER SIDE. D1 AND E1 ARE MAXIMUM PLASTIC BODY SIZE DIMENSIONS INCLUDING MOLD MISMATCH. 2. DIMENSION b DOES NOT INCLUDE DAMBAR PROTRUSION. ALLOWABLE DAMBAR PROTRUSION SHALL NOT CAUSE THE LEAD WIDTH TO EXCEED THE MAXIMUM b DIMENSION BY MORE THAN 0.08mm. DAMBAR CAN NOT BE LOCATED ON THE LOWER RADIUS OR THE FOOT. MINIMUM SPACE BETWEEN PROTRUSION AND AN ADJACENT LEAD IS 0.07mm FOR 0.4mm AND 0.5mm PITCH PACKAGES. © Copyright 2008 WIZnet Co., Inc. All rights reserved. 70
W5100 价格&库存
很抱歉,暂时无法提供与“W5100”相匹配的价格&库存,您可以联系我们找货
W5100
  • 160+29.70503160+3.60307
  • 320+29.56622320+3.58623
  • 480+29.56556480+3.58615
  • 640+29.56491640+3.58607
  • 800+29.56426800+3.58599
