PJM04P30SG
P-Channel Enhancement Mode Power MOSFET
SOT-23-6
Features
⚫ High power and current handing capability
4.S
⚫ VDS= -30V,ID= -4.1A
5.D
RDS(on)< 60mΩ @VGS= -10V
3.G
6.D
2.D
1.D
Marking Code:3407
Pin Assignment
Applications
⚫ PWM applications
⚫ Load switch
⚫ Power management
Schematic Diagram
D
D
D
D
G
S
1、2、5、6:Drain
3:Gate
Top View
4:Source
Absolute Maximum Ratings
Ratings at 25℃ ambient temperature unless otherwise specified.
Parameter
Symbol
Value
Unit
Drain-Source Voltage
-VDS
30
V
Gate-Source Voltage
VGS
±20
V
Drain Current-Continuous
-ID
4.1
A
Drain Current-Pulsed Note1
-IDM
A
Maximum Power Dissipation
PD
1.2
W
Junction Temperature
TJ
150
°C
TSTG
-55 to +150
°C
RθJA
104
°C/W
Storage Temperature Range
Thermal Characteristics
Thermal Resistance,Junction-to-Ambient Note2
www.pingjingsemi.com
Revision:1.0 Jul-2021
1/7
PJM04P30SG
Electrical Characteristics
(Ta=25℃ unless otherwise specified)
Parameter
Symbol
Test Condition
Min.
Typ.
Max.
Unit
Drain-Source Breakdown Voltage
-V(BR)DSS
VGS=0V,ID=-250μA
30
V
Zero Gate Voltage Drain Current
-IDSS
VDS=-24V,VGS=0V
1
μA
Gate-Body Leakage Current
IGSS
VGS=±20V,VDS=0V
±100
nA
Gate Threshold Voltage Note3
-VGS(th)
VDS=VGS,ID=-250μA
1
1.4
3
V
Drain-source on-resistance Note2
RDS(on)
VGS=-10V, ID=-4.1A
50
60
mΩ
VGS=-4.5V, ID=-3A
68
87
mΩ
Forward Transconductance Note3
gFS
VDS=-5V,ID=-4A
5.5
S
650
pF
105
pF
Static Characteristics
Dynamic Characteristics
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
65
pF
Turn-on Delay Time
td(on)
8.5
nS
Turn-on Rise Time
tr
VDD=-15V,RL=3.6Ω
4.5
nS
Turn-off Delay Time
td(off)
VGS=-10V,RCEN=3Ω
26
nS
VDS=-15V,VGS=0V,f=1MHz
Switching Characteristics
Turn-off Fall Time
tf
12.5
nS
Total Gate Charge
Qg
12.5
nC
Gate-Source Charge
Qgs
2.8
nC
Gate-Drain Charge
Qgd
2.7
nC
1.2
V
4.1
A
VDS=-15V
ID= -4.1A,VGS=-10V
Source-Drain Diode Characteristics
Diode Forward Voltage Note3
-VSD
Diode Forward Current Note2
-IS
VGS=0V,IS=-4.1A
Note: 1. Repetitive Rating: Pulse width limited by maximum junction temperature.
2. Surface Mounted on FR4 Board, t ≤ 10 sec.
3. Pulse Test: Pulse width≤300μs, duty cycle≤2%.
2/7
PJM04P30SG
-ID Drain Current (A)
RDS(on) On-Resistance(mΩ)
Typical Characteristic Curves
Normalized On-Resistance
-VDS Drain-Source Voltage (V)
-4.1A
-VGS Gate-Source Voltage (V)
TJ Junction Temperature(℃)
C Capacitance (pF)
-4.1A
Ciss
Coss
Crss
3/7
-IS Reverse Drain Current (A)
PJM04P30SG
ID= -4.1A
Qg Gate Charge (nC)
r(t),Normalized Effective
Transient Thermal Impedance
Square Wave Pluse Duration(sec)
4/7
PJM04P30SG
Package Outline
SOT-23-6
Dimensions in mm
2.92
±0.1
0.127 +0.05/-0.02
10
1.6
2.8
±0.1
±0.1
1.9±0.1
12
R0.15MAX
0.95±0.1
0.35±0.05
R0.15MAX
0.06
12
± 0.05
0.65
±0.1
1.1
±0.1
10
Ordering Information
Device
Package
Shipping
PJM04P30SG
SOT-23-6
3,000PCS/Reel&7inches
5/7
PJM04P30SG
Conditions of Soldering and Storage
Recommended condition of reflow soldering
Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust
the following parameters:
Time length of peak temperature (longer)
Time length of soldering (longer)
Thickness of solder paste (thicker)
Conditions of hand soldering
Temperature: 370 OC
Time: 3s max.
Times: one time
Storage conditions
Temperature
5 to 40 OC
Humidity
30 to 80% RH
Recommended period
One year after manufacturing
6/7
PJM04P30SG
Package Specifications
The method of packaging
Cover Tape
3,000 pcs per reel
SOT-23-6
Carrier Tape
30,000 pcs per box
10 reels per box
120,000 pcs per carton
4 boxes per carton
Embossed tape and reel data
D
A
T2
T1
B
C
E
Symbol
A
B
C
E
F
D
T1
T2
Value (unit: mm)
Ø 177.8±1
2.7±0.2
Ø 13.5±0.2
Ø 54.5±0.2
12.3±0.3
9.6+2/-0.3
1.0±0.2
1.2±0.2
F
1.55±0.05
3.50±0.05
2.00±0.05
1.10±0.10
4.00±0.10
8±0.10
4.00±0.10
1.75±0.10
Reel (7'')
Pin1
Tape (8mm)
7/7
很抱歉,暂时无法提供与“PJM04P30SG”相匹配的价格&库存,您可以联系我们找货
