MMBT3904DC
NPN Transistor
DFN1x0.6-3L
Features
For Switching and AF Amplifer Applications.
3.C
Equivalent Circuit
2.E
3.Collector
1.B
1.Base 2.Emitter 3.Collector
Marking Code :
1.Base
1E
2.. Emitter
Absolute Maximum Ratings
Ratings at 25℃ ambient temperature unless otherwise specified.
Parameter
Symbol
Value
Unit
Collector Base Voltage
VCBO
60
V
Collector Emitter Voltage
VCEO
40
V
Emitter Base Voltage
VEBO
6
V
Collector Current
IC
200
mA
Maximum Power Dissipation
PD
250
mW
Junction Temperature
TJ
150
TSTG
-55 to +150
Storage Temperature Range
www.pingjingsemi.com
Revision:1.0 Dec-2021
1/4
MMBT3904DC
NPN Transistor
Electrical Characteristics (TA=25℃)
Parameter
Symbol
Min.
Max.
Unit
40
70
100
300
at VCE = 1 V, IC = 50 mA
60
at VCE = 1 V, IC = 100 mA
30
ICBO
50
nA
IEBO
50
nA
V(BR)CBO
60
V
V(BR)CEO
40
V
V(BR)EBO
6
V
VCE(sat)
0.2
V
0.3
0.65
0.85
0.95
FT
300
MHz
Cob
4
pF
DC Current Gain
at VCE = 1 V, IC = 0.1 mA
at VCE = 1 V, IC = 1 mA
at VCE = 1 V, IC = 10 mA
Collector Base Cutoff Current
at VCB = 30V
Emitter Base Cutoff Current
at VEB = 6 V
Collector Base Breakdown Voltage
at IC = 10 μA
Collector Emitter Breakdown Voltage
at IC = 1 mA
Emitter Base Breakdown Voltage
at IE = 10 μA
HFE
Collector Emitter Saturation Voltage
at IC = 10 mA, IB = 1 mA
at IC = 50 mA, IB = 5 mA
Base Emitter Saturation Voltage
VBE(sat)
Transition Frequency
at VCE = 20 V, IC = 10 mA,f = 100 MHz
Output Capacitance
at VCB = 5 V, IE = 0, f = 1 MHz
V
2/4
MMBT3904DC
NPN Transistor
DC Current Gain hFE
Collector-Emitter Saturation
Voltage VCE(sat) (V)
Typical Characteristic Curves
Collector Current IC (mA)
Base-Emitter On Voltage
VBE(on) (V)
Base-Emitter Saturation Voltage
VBE(sat) (V)
Capacitance C (pF)
ICBO (nA)
Reverse Bias Volatge VR (V)
Common Emitter
VCE = 1V
Base-Emitter Voltage VBE (V)
Power Dissipation PD (mW)
Ambient Temperature Ta (℃)
3/4
MMBT3904DC
NPN Transistor
Package Outline
DFN1x0.6-3L-0009
Dimensions in mm
Ordering Information
Device
Package
MMBT3904DC
DFN1x0.6-3L
Shipping
10,000PCS/Reel&7inches
4/4
很抱歉,暂时无法提供与“MMBT3904DC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.04350
- 500+0.03915
- 5000+0.03625
- 10000+0.03480
- 30000+0.03335
- 50000+0.03248
