ES3DC-PJ
ES3DC-PJ
    PJ(平晶)
    SMC(DO-214AB)
    快/超快二极管 SMC Vrrm=200V Vf=1V Ir=5μA
ES3DC-PJ 数据手册
ES3AC-PJ~ES3JC-PJ Surface Mount Fast Recovery Rectifiers Features SMC  For surface mount applications 2  Glass Passivated Chip Junction  Superfast reverse recovery time 1  Low profile package 1.Cathode 2.Anode Marking Code: ES3AC-PJ:ES3A ES3BC-PJ:ES3B ES3CC-PJ:ES3C ES3DC-PJ:ES3D ES3EC-PJ:ES3E ES3GC-PJ:ES3G ES3JC-PJ:ES3J Absolute Maximum Ratings and Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Parameter Symbols ES3AC-PJ ES3BC-PJ ES3CC-PJ ES3DC-PJ ES3EC-PJ ES3GC-PJ ES3JC-PJ Units Maximum Repetitive Peak Reverse Voltage VRRM 50 100 150 200 300 400 600 V Maximum RMS Voltage VRMS 35 70 105 140 210 280 420 V Maximum DC Blocking Voltage VDC 50 100 150 200 300 400 600 V Maximum Average Forward Rectified Current at TC =125 °C IF(AV) 3.0 A IFSM 90 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load VF Maximum Instantaneous Forward Voltage at 3 A 1.0 1.25 1.68 V Maximum DC Reverse Current at Rated DC Blocking Voltage IR TA = 25 °C TA = 125 °C 5 μA 100 Cj 40 RθJA 40 RθJC 16 Maximum Reverse Recovery Time Note3 Trr 35 nS Junction Temperature TJ 150 °C TSTG -55 to +150 °C Typical Junction Capacitance Note1 Typical Thermal Resistance Note2 Storage Temperature Range pF °C/W Note: 1. Measured at 1 MHz and applied reverse voltage of 4 V D.C 2. P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. 3. Measured with IF = 0.5 A, IR = 1 A, Irr = 0.25 A www.pingjingsemi.com Revision:1.0 Sep-2021 1/3 ES3AC-PJ~ES3JC-PJ Surface Mount Fast Recovery Rectifiers 300 3.5 I R - Reverse Current (μA) Average Forward Current (A) Typical Characteristic Curves 3.0 2.5 2.0 1.5 1.0 0.5 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 T J =125°C 10 T J =75°C 1.0 T J =25°C 0.1 100 125 150 175 0 20 40 10 T J =25°C 1.0 ES3AC-PJ~ES3DC-PJ ES3EC-PJ/ES3GC-PJ 0.1 ES3JC-PJ 0.01 0.001 0.5 0 1.0 1.5 2.0 2.5 Instaneous Forward Voltage (V) Peak Forward Surage Current (A) 80 100 % of PIV.VOLTS Junction Capacitance (pF) Instaneous Forward Current (A) Case Temperature (°C) 60 T J =25°C 100 10 1 0.1 T J=25°C f = 1.0MHz V sig = 50mV p-p 1.0 10 100 Reverse Voltage (V) 126 108 90 72 54 36 18 00 8.3 ms Single Half Sine Wave (JEDEC Method) 1 10 100 Number of Cycles www.pingjingsemi.com Revision:1.0 Sep-2021 2/3 ES3AC-PJ~ES3JC-PJ Surface Mount Fast Recovery Rectifiers Package Outline SMC Dimensions in mm E A A1 A C b D L mil www.pingjingsemi.com Revision:1.0 Sep-2021 VM A A E D E1 A1 C L b max 2.62 7.0 6.2 8.0 0.21 0.31 1.6 3.25 min 2.00 6.5 5.6 7.6 0.05 0.15 0.9 2.75 max 103 276 244 315 8.3 12 63 128 min 79 256 220 299 2.0 5.9 35 108 UNIT mm E1 3/3
ES3DC-PJ 价格&库存
很抱歉,暂时无法提供与“ES3DC-PJ”相匹配的价格&库存,您可以联系我们找货
