Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
PBSS4032PD
30 V, 2.7 A PNP low VCEsat (BISS) transistor
Rev. 01 — 27 January 2010
Product data sheet
1. Product profile
1.1 General description
PNP low VCEsat Breakthrough In Small Signal (BISS) transistor in a SOT457 (SC-74)
small Surface-Mounted Device (SMD) plastic package.
NPN complement: PBSS4032ND.
1.2 Features
Low collector-emitter saturation voltage VCEsat
Optimized switching time
High collector current capability IC and ICM
High collector current gain (hFE) at high IC
High energy efficiency due to less heat generation
AEC-Q101 qualified
Smaller required Printed-Circuit Board (PCB) area than for conventional transistors
1.3 Applications
DC-to-DC conversion
Battery-driven devices
Power management
Charging circuits
1.4 Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCEO
collector-emitter voltage
open base
−30
V
IC
collector current
−2.7
A
ICM
peak collector current
single pulse;
tp ≤ 1 ms
−5
A
RCEsat
collector-emitter
saturation resistance
IC = −3 A;
IB = −300 mA
88
130
mΩ
[1]
Pulse test: tp ≤ 300 μs; δ ≤ 0.02.
[1]
PBSS4032PD
NXP Semiconductors
2. Pinning information
Table 2.
Pinning
Pin
Description
1
collector
2
collector
3
base
4
emitter
5
collector
6
collector
Simplified outline
6
Graphic symbol
4
5
1, 2, 5, 6
3
1
2
3
4
sym030
3. Ordering information
Table 3.
Type number
PBSS4032PD
Package
Name
Description
Version
SC-74
plastic surface-mounted package; 6 leads
SOT457
4. Marking
Table 4.
Marking codes
Type number
Marking code
PBSS4032PD
ZG
5. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VCBO
collector-base voltage
open emitter
−30
V
VCEO
open base
−30
V
VEBO
emitter-base voltage
open collector
−5
V
IC
collector current
−2.7
A
ICM
−5
A
IB
base current
−0.5
A
single pulse;
tp ≤ 1 ms
PBSS4032PD_1
Product data sheet
© NXP B.V. 2010. All rights reserved.
2 of 14
PBSS4032PD
NXP Semiconductors
Table 5.
Limiting values …continued
Symbol
Ptot
Parameter
Conditions
total power dissipation
Tamb ≤ 25 °C
Min
Max
Unit
[1]
480
mW
[2]
750
mW
[3]
1
W
Tj
junction temperature
150
°C
Tamb
ambient temperature
−55
+150
°C
Tstg
storage temperature
−65
+150
°C
[1]
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
[2]
Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 6 cm2.
[3]
Device mounted on a ceramic PCB, Al2O3, standard footprint.
006aab931
1200
Ptot
(mW)
800
(1)
(2)
(3)
400
−75
−25
25
75
125
175
Tamb (°C)
(1) Ceramic PCB, Al2O3, standard footprint
(2) FR4 PCB, mounting pad for collector 6 cm2
(3) FR4 PCB, standard footprint
Fig 1.
Power derating curves
PBSS4032PD_1
Product data sheet
3 of 14
PBSS4032PD
NXP Semiconductors
6. Thermal characteristics
Table 6.
Symbol
Parameter
Conditions
thermal resistance from
junction to ambient
Rth(j-a)
in free air
Min
Typ
Max
Unit
[1]
260
K/W
[2]
160
K/W
[3]
125
K/W
45
K/W
junction to solder point
Rth(j-sp)
[1]
[2]
[3]
006aab932
103
Zth(j-a)
(K/W)
duty cycle = 1
0.75
102
0.5
0.33
0.2
0.1
0.05
10
0.02
0.01
10−1
10−5
10−4
10−3
10−2
10−1
1
10
102
103
tp (s)
Fig 2.
Transient thermal impedance from junction to ambient as a function of pulse duration; typical values
PBSS4032PD_1
Product data sheet
4 of 14
PBSS4032PD
NXP Semiconductors
006aab933
103
Zth(j-a)
(K/W)
duty cycle = 1
102
0.75
0.5
0.33
0.2
0.1
10
0.05
0.02
0.01
1
10−1
10−5
10−4
10−3
10−2
10−1
1
10
102
103
tp (s)
Fig 3.
006aab934
103
Zth(j-a)
(K/W)
duty cycle = 1
102
0.75
0.5
0.33
0.2
0.1
10
0.05
0.02
1
0.01
10−1
10−5
10−4
10−3
10−2
10−1
1
10
102
103
tp (s)
Fig 4.
PBSS4032PD_1
Product data sheet
5 of 14
PBSS4032PD
NXP Semiconductors
7. Characteristics
Table 7.
Characteristics
Tamb = 25 °C unless otherwise specified.
Symbol Parameter
ICBO
Conditions
collector-base cut-off VCB = −30 V; IE = 0 A
current
VCB = −30 V; IE = 0 A;
Tj = 150 °C
Typ
Max
Unit
−100
nA
−55
μA
ICES
collector-emitter
cut-off current
VCE = −24 V; VBE = 0 V
−100
nA
IEBO
emitter-base cut-off
current
VEB = −5 V; IC = 0 A
−100
nA
hFE
DC current gain
VCE = −2 V;
IC = −500 mA
[1]
200
350
VCE = −2 V; IC = −1 A
[1]
200
300
VCE = −2 V; IC = −2 A
[1]
100
160
VCE = −2 V; IC = −4 A
[1]
25
40
−87
−130
mV
VCEsat
collector-emitter
saturation voltage
IC = −500 mA;
IB = −50 mA
IC = −1 A; IB = −50 mA
[1]
−140
−210
mV
IC = −1 A; IB = −10 mA
[1]
−205
−300
mV
IC = −2 A; IB = −40 mA
[1]
−280
−420
mV
IC = −2 A; IB = −200 mA
[1]
−170
−255
mV
IC = −3 A; IB = −300 mA
[1]
−265
−395
mV
RCEsat
collector-emitter
[1]
88
130
mΩ
VBEsat
base-emitter
saturation voltage
IC = −1 A; IB = −100 mA
[1]
−0.83
−0.9
V
[1]
−1.11
−1.2
V
VBEon
base-emitter turn-on
voltage
−0.85
−0.95
V
VCC = −12.5 V;
IC = −1 A; IBon = −0.05 A;
IBoff = 0.05 A
ns
55
ns
75
ns
130
ns
td
delay time
tr
rise time
ton
turn-on time
ts
storage time
tf
fall time
80
ns
toff
turn-off time
210
ns
fT
transition frequency
104
MHz
Cc
collector capacitance VCB = −10 V;
IE = ie = 0 A; f = 1 MHz
59
pF
[1]
VCE = −10 V;
IC = −100 mA;
f = 100 MHz
PBSS4032PD_1
Product data sheet
Min
6 of 14
PBSS4032PD
NXP Semiconductors
006aab943
800
hFE
006aab944
−4.0
IC
(A)
(1)
IB (mA) = −50
−40
−3.0
600
−30
−20
(2)
−2.0
400
−45
−35
−25
−15
−10
−5
(3)
−1.0
200
−10−1
−1
−10
−102
0.0
0.0
−103
−104
IC (mA)
VCE = −2 V
−1.0
−2.0
−3.0
−4.0
−5.0
VCE (V)
Tamb = 25 °C
(1) Tamb = 100 °C
(2) Tamb = 25 °C
(3) Tamb = −55 °C
Fig 5.
DC current gain as a function of collector
current; typical values
006aab945
−1.6
VBE
(V)
Fig 6.
Collector current as a function of
collector-emitter voltage; typical values
006aab946
−1.4
VBEsat
(V)
−1.2
−1.1
(1)
−0.8
(1)
−0.8
(2)
(2)
(3)
−0.4
−0.5
0.0
−10−1
−1
−10
−102
−103
−104
IC (mA)
(3)
−0.2
−10−1
VCE = −2 V
−1
−103
−104
IC (mA)
(1) Tamb = −55 °C
(2) Tamb = 25 °C
(2) Tamb = 25 °C
(3) Tamb = 100 °C
(3) Tamb = 100 °C
Base-emitter voltage as a function of collector
Fig 8.
Base-emitter saturation voltage as a function
of collector current; typical values
PBSS4032PD_1
Product data sheet
−102
IC/IB = 20
(1) Tamb = −55 °C
Fig 7.
−10
7 of 14
PBSS4032PD
NXP Semiconductors
006aab947
−1
VCEsat
(V)
006aab948
−1
VCEsat
(V)
(1)
−10−1
−10−1
(1)
(2)
(2)
(3)
−10−2
−10−1
−1
−10
(3)
−102
−103
−104
IC (mA)
−10−2
−10−1
−1
−102
−103
−104
IC (mA)
Tamb = 25 °C
IC/IB = 20
(1) Tamb = 100 °C
(1) IC/IB = 100
(2) Tamb = 25 °C
(2) IC/IB = 50
(3) Tamb = −55 °C
(3) IC/IB = 10
Fig 9.
−10
Collector-emitter saturation voltage as a
function of collector current; typical values
006aab949
103
RCEsat
(Ω)
102
Fig 10. Collector-emitter saturation voltage as a
006aab950
104
RCEsat
(Ω)
103
102
10
10
(1)
1
(1)
(2)
(2)
1
10−1
(3)
10−2
−10−1
−1
−10
−102
10−1
−103
−104
IC (mA)
(3)
10−2
10−1
1
102
103
104
IC (mA)
Tamb = 25 °C
IC/IB = 20
(1) Tamb = 100 °C
(1) IC/IB = 100
(2) Tamb = 25 °C
(2) IC/IB = 50
(3) Tamb = −55 °C
(3) IC/IB = 10
Fig 11. Collector-emitter saturation resistance as a
Fig 12. Collector-emitter saturation resistance as a
PBSS4032PD_1
Product data sheet
10
8 of 14
PBSS4032PD
NXP Semiconductors
8. Test information
− IB
input pulse
(idealized waveform)
90 %
− I Bon (100 %)
10 %
− I Boff
output pulse
− IC
90 %
− I C (100 %)
10 %
t
td
ts
tr
t on
tf
t off
006aaa266
Fig 13. BISS transistor switching time definition
VBB
RB
VCC
RC
Vo
(probe)
oscilloscope
450 Ω
(probe)
450 Ω
oscilloscope
R2
VI
DUT
R1
mgd624
Fig 14. Test circuit for switching times
8.1 Quality information
This product has been qualified in accordance with the Automotive Electronics Council
(AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is
suitable for use in automotive applications.
PBSS4032PD_1
Product data sheet
9 of 14
PBSS4032PD
NXP Semiconductors
9. Package outline
3.1
2.7
6
3.0
2.5
1.7
1.3
1.1
0.9
5
4
2
3
0.6
0.2
pin 1 index
1
0.40
0.25
0.95
0.26
0.10
1.9
Dimensions in mm
04-11-08
Fig 15. Package outline SOT457 (SC-74)
10. Packing information
Table 8.
Packing methods
The indicated -xxx are the last three digits of the 12NC ordering code.[1]
Type number
Package Description
PBSS4032PD SOT457
[1]
3000
10000
4 mm pitch, 8 mm tape and reel
[2]
-115
-135
[3]
-215
-235
For further information and the availability of packing methods, see Section 14.
[2]
T1: normal taping
[3]
T2: reverse taping
PBSS4032PD_1
Product data sheet
Packing quantity
10 of 14
PBSS4032PD
NXP Semiconductors
11. Soldering
3.45
1.95
0.45 0.55
(6×) (6×)
0.95
solder lands
solder resist
3.3 2.825
0.95
solder paste
occupied area
0.7
(6×)
Dimensions in mm
0.8
(6×)
2.4
sot457_fr
Fig 16. Reflow soldering footprint SOT457 (SC-74)
5.3
1.5
(4×)
solder lands
1.475
0.45
(2×)
5.05
solder resist
occupied area
1.475
Dimensions in mm
preferred transport
direction during soldering
1.45
(6×)
2.85
sot457_fw
Fig 17. Wave soldering footprint SOT457 (SC-74)
PBSS4032PD_1
Product data sheet
11 of 14
PBSS4032PD
NXP Semiconductors
12. Revision history
Table 9.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PBSS4032PD_1
20100127
Product data sheet
PBSS4032PD_1
Product data sheet
12 of 14
PBSS4032PD
NXP Semiconductors
13. Legal information
13.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nxp.com.
13.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. NXP Semiconductors does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local NXP Semiconductors sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
13.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, NXP Semiconductors does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — NXP Semiconductors reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — NXP Semiconductors products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of an NXP Semiconductors product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. NXP Semiconductors accepts no liability for inclusion and/or use of
NXP Semiconductors products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. NXP Semiconductors makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — NXP Semiconductors products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nxp.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by NXP Semiconductors. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from national authorities.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
13.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
14. Contact information
For more information, please visit: http://www.nxp.com
For sales office addresses, please send an email to: salesaddresses@nxp.com
PBSS4032PD_1
Product data sheet
13 of 14
PBSS4032PD
NXP Semiconductors
15. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
8.1
9
10
11
12
13
13.1
13.2
13.3
13.4
14
15
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2
Thermal characteristics . . . . . . . . . . . . . . . . . . 4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Test information . . . . . . . . . . . . . . . . . . . . . . . . . 9
Quality information . . . . . . . . . . . . . . . . . . . . . . 9
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10
Packing information . . . . . . . . . . . . . . . . . . . . 10
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12
Legal information. . . . . . . . . . . . . . . . . . . . . . . 13
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Contact information. . . . . . . . . . . . . . . . . . . . . 13
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section ‘Legal information’.
© NXP B.V. 2010.
Date of release: 27 January 2010
Document identifier: PBSS4032PD_1
