PBSS4021SN,115
PBSS4021SN,115
    NEXPERIA(安世)
    SOIC8_150MIL
    三极管 NPN Ic=7.5A Vceo=20V hfe=550 P=2.3W SOIC8_150MIL 4.9X3.9MM
PBSS4021SN,115 数据手册
PBSS4021SN 20 V, 7.5 A NPN/NPN low VCEsat (BISS) transistor Rev. 2 — 11 October 2010 Product data sheet 1. Product profile 1.1 General description NPN/NPN low VCEsat Breakthrough In Small Signal (BISS) transistor in a SOT96-1 (SO8) medium power Surface-Mounted Device (SMD) plastic package. Table 1. Product overview Type number PBSS4021SN Package Nexperia Name PNP/PNP complement SOT96-1 SO8 PBSS4021SP NPN/PNP complement PBSS4021SPN 1.2 Features and benefits „ „ „ „ „ Very low collector-emitter saturation voltage VCEsat High collector current capability IC and ICM High collector current gain (hFE) at high IC High efficiency due to less heat generation Smaller required Printed-Circuit Board (PCB) area than for conventional transistors 1.3 Applications „ „ „ „ „ Loadswitch Battery-driven devices Power management Charging circuits Power switches (e.g. motors, fans) 1.4 Quick reference data Table 2. Quick reference data Symbol Parameter Conditions Min Typ Max Unit open base - - 20 V - - 7.5 A - - 15 A - 25 35 mΩ VCEO collector-emitter voltage IC collector current ICM peak collector current single pulse; tp ≤ 1 ms RCEsat collector-emitter saturation resistance IC = 5 A; IB = 0.5 A [1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. [1] PBSS4021SN Nexperia 20 V, 7.5 A NPN/NPN low VCEsat (BISS) transistor 2. Pinning information Table 3. Pinning Pin Description 1 emitter TR1 2 base TR1 3 emitter TR2 4 base TR2 5 collector TR2 6 collector TR2 7 collector TR1 8 collector TR1 Simplified outline 8 Graphic symbol 8 5 7 TR1 1 4 1 6 5 TR2 2 3 4 006aaa966 3. Ordering information Table 4. Ordering information Type number PBSS4021SN Package Name Description Version SO8 plastic small outline package; 8 leads; body width 3.9 mm SOT96-1 4. Marking Table 5. Marking codes Type number Marking code PBSS4021SN 4021SN 5. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit Per transistor VCBO collector-base voltage open emitter - 20 V VCEO collector-emitter voltage open base - 20 V VEBO emitter-base voltage open collector - 5 V IC collector current - 7.5 A ICM peak collector current - 15 A IB base current Ptot PBSS4021SN Product data sheet total power dissipation single pulse; tp ≤ 1 ms Tamb ≤ 25 °C All information provided in this document is subject to legal disclaimers. Rev. 2 — 11 October 2010 - 1 A [1] - 0.73 W [2] - 1 W [3] - 1.7 W © Nexperia B.V. 2017. All rights reserved 2 of 15 PBSS4021SN Nexperia 20 V, 7.5 A NPN/NPN low VCEsat (BISS) transistor Table 6. Limiting values …continued In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions total power dissipation Tamb ≤ 25 °C Min Max Unit [1] - 0.86 W [2] - 1.4 W [3] - 2.3 W Per device Ptot Tj junction temperature - 150 °C Tamb ambient temperature −55 +150 °C Tstg storage temperature −65 +150 °C [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 1 cm2. [3] Device mounted on a ceramic PCB, Al2O3, standard footprint. 006aac234 3.0 Ptot (W) (1) 2.0 (2) 1.0 (3) 0.0 −75 −25 25 75 125 175 Tamb (°C) (1) Ceramic PCB, Al2O3, standard footprint (2) FR4 PCB, mounting pad for collector 1 cm2 (3) FR4 PCB, standard footprint Fig 1. PBSS4021SN Product data sheet Per device: Power derating curves All information provided in this document is subject to legal disclaimers. Rev. 2 — 11 October 2010 © Nexperia B.V. 2017. All rights reserved 3 of 15 PBSS4021SN Nexperia 20 V, 7.5 A NPN/NPN low VCEsat (BISS) transistor 6. Thermal characteristics Table 7. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit [1] - - 170 K/W [2] - - 125 K/W [3] - - 75 K/W - - 40 K/W [1] - - 145 K/W [2] - - 90 K/W [3] - - 55 K/W Per transistor thermal resistance from junction to ambient Rth(j-a) in free air thermal resistance from junction to solder point Rth(j-sp) Per device thermal resistance from junction to ambient Rth(j-a) in free air [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 1 cm2. [3] Device mounted on a ceramic PCB, Al2O3, standard footprint. 006aac235 103 Zth(j-a) (K/W) duty cycle = 1 0.75 102 0.5 0.33 0.2 0.1 10 0.05 0.02 1 0.01 0 10−1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) FR4 PCB, standard footprint Fig 2. Per transistor: Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PBSS4021SN Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 11 October 2010 © Nexperia B.V. 2017. All rights reserved 4 of 15 PBSS4021SN Nexperia 20 V, 7.5 A NPN/NPN low VCEsat (BISS) transistor 006aac236 103 Zth(j-a) (K/W) duty cycle = 1 102 0.75 0.5 0.33 0.2 0.1 10 0.05 0.02 0.01 1 0 10−1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) FR4 PCB, mounting pad for collector 1 cm2 Fig 3. Per transistor: Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 006aac237 102 duty cycle = 1 0.75 Zth(j-a) (K/W) 0.5 0.33 0.2 10 0.1 0.05 0.02 0.01 1 0 10−1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) Ceramic PCB, Al2O3, standard footprint Fig 4. Per transistor: Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PBSS4021SN Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 11 October 2010 © Nexperia B.V. 2017. All rights reserved 5 of 15 PBSS4021SN Nexperia 20 V, 7.5 A NPN/NPN low VCEsat (BISS) transistor 7. Characteristics Table 8. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit Per transistor ICBO collector-base cut-off current VCB = 20 V; IE = 0 A - - 100 nA VCB = 20 V; IE = 0 A; Tj = 150 °C - - 50 μA ICES collector-emitter cut-off current VCE = 16 V; VBE = 0 V - - 100 nA IEBO emitter-base cut-off current VEB = 5 V; IC = 0 A - - 100 nA hFE DC current gain VCE = 2 V [1] IC = 500 mA 300 550 - IC = 1 A 300 550 - IC = 2 A 300 500 - IC = 4 A 250 450 - 100 200 - IC = 1 A; IB = 50 mA - 30 45 mV IC = 1 A; IB = 10 mA - 40 60 mV IC = 2 A; IB = 40 mA - 60 90 mV IC = 4 A; IB = 200 mA - 100 150 mV IC = 4 A; IB = 40 mA - 120 180 mV - 185 275 mV - 25 35 mΩ - 0.87 1 V - 1.04 1.2 V - 0.76 0.85 V - 40 - ns IC = 8 A VCEsat collector-emitter saturation voltage [1] IC = 7.5 A; IB = 375 mA RCEsat collector-emitter IC = 5 A; IB = 500 mA saturation resistance [1] VBEsat base-emitter saturation voltage [1] IC = 1 A; IB = 100 mA IC = 4 A; IB = 400 mA VBEon base-emitter turn-on voltage VCE = 2 V; IC = 2 A td delay time VCC = 12.5 V; IC = 1 A; IBon = 0.05 A; IBoff = −0.05 A tr rise time - 40 - ns ton turn-on time - 80 - ns ts storage time - 650 - ns tf fall time - 75 - ns toff turn-off time - 725 - ns fT transition frequency VCE = 10 V; IC = 100 mA; f = 100 MHz - 115 - MHz Cc collector capacitance VCB = 10 V; IE = ie = 0 A; f = 1 MHz - 85 - pF [1] PBSS4021SN Product data sheet [1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. All information provided in this document is subject to legal disclaimers. Rev. 2 — 11 October 2010 © Nexperia B.V. 2017. All rights reserved 6 of 15 PBSS4021SN Nexperia 20 V, 7.5 A NPN/NPN low VCEsat (BISS) transistor 006aac238 800 (1) hFE 006aac239 16.0 IB (mA) = 70 IC (A) 600 63 56 49 12.0 42 (2) 35 28 400 21 8.0 14 (3) 200 7 4.0 0 10−1 1 10 102 103 0.0 0.0 104 105 IC (mA) 1.0 2.0 3.0 4.0 5.0 VCE (V) Tamb = 25 °C VCE = 2 V (1) Tamb = 100 °C (2) Tamb = 25 °C (3) Tamb = −55 °C Fig 5. DC current gain as a function of collector current; typical values Fig 6. 006aac240 1.2 VBE (V) Collector current as a function of collector-emitter voltage; typical values 006aac241 1.4 VBEsat (V) (1) 0.8 1.0 (1) (2) 0.4 (2) 0.6 (3) (3) 0.0 10−1 1 10 102 103 0.2 10−1 104 105 IC (mA) 1 VCE = 2 V IC/IB = 20 (1) Tamb = −55 °C (1) Tamb = −55 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = 100 °C (3) Tamb = 100 °C Fig 7. Base-emitter voltage as a function of collector current; typical values PBSS4021SN Product data sheet Fig 8. 10 102 103 104 105 IC (mA) Base-emitter saturation voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. Rev. 2 — 11 October 2010 © Nexperia B.V. 2017. All rights reserved 7 of 15 PBSS4021SN Nexperia 20 V, 7.5 A NPN/NPN low VCEsat (BISS) transistor 006aac242 1 006aac243 1 VCEsat (V) VCEsat (V) 10−1 10−1 (2) (3) (1) (1) 10−2 10−2 (2) (3) 10−3 10−1 1 102 10 103 104 105 IC (mA) 10−3 10−1 1 102 103 104 105 IC (mA) Tamb = 25 °C IC/IB = 20 (1) Tamb = 100 °C (1) IC/IB = 100 (2) Tamb = 25 °C (2) IC/IB = 50 (3) Tamb = −55 °C (3) IC/IB = 10 Fig 9. 10 Collector-emitter saturation voltage as a function of collector current; typical values 006aac244 103 Fig 10. Collector-emitter saturation voltage as a function of collector current; typical values 006aac245 103 RCEsat (Ω) RCEsat (Ω) 102 102 10 10 1 1 (1) (2) (1) (2) 10−1 10−2 10−1 (3) 1 10 102 (3) 10−1 103 104 IC (mA) 10−2 10−1 1 (1) Tamb = 100 °C (1) IC/IB = 100 (2) Tamb = 25 °C (2) IC/IB = 50 (3) Tamb = −55 °C (3) IC/IB = 10 Fig 11. Collector-emitter saturation resistance as a function of collector current; typical values Product data sheet 102 103 104 105 IC (mA) Tamb = 25 °C IC/IB = 20 PBSS4021SN 10 Fig 12. Collector-emitter saturation resistance as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. Rev. 2 — 11 October 2010 © Nexperia B.V. 2017. All rights reserved 8 of 15 PBSS4021SN Nexperia 20 V, 7.5 A NPN/NPN low VCEsat (BISS) transistor 8. Test information IB input pulse (idealized waveform) 90 % IBon (100 %) 10 % IBoff output pulse (idealized waveform) IC 90 % IC (100 %) 10 % t td ts tr ton tf toff 006aaa003 Fig 13. BISS transistor switching time definition VBB RB VCC RC Vo (probe) oscilloscope 450 Ω (probe) 450 Ω oscilloscope R2 VI DUT R1 mlb826 VCC = 12.5 V; IC = 1 A; IBon = 0.05 A; IBoff = −0.05 A Fig 14. Test circuit for switching times PBSS4021SN Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 11 October 2010 © Nexperia B.V. 2017. All rights reserved 9 of 15 PBSS4021SN Nexperia 20 V, 7.5 A NPN/NPN low VCEsat (BISS) transistor 9. Package outline 5.0 4.8 1.75 1.0 0.4 6.2 5.8 4.0 3.8 pin 1 index 1.27 0.49 0.36 Dimensions in mm 0.25 0.19 03-02-18 Fig 15. Package outline SOT96-1 (SO8) 10. Packing information Table 9. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number PBSS4021SN [1] PBSS4021SN Product data sheet Package SOT96-1 Description 8 mm pitch, 12 mm tape and reel Packing quantity 1000 2500 -115 -118 For further information and the availability of packing methods, see Section 14. All information provided in this document is subject to legal disclaimers. Rev. 2 — 11 October 2010 © Nexperia B.V. 2017. All rights reserved 10 of 15 PBSS4021SN Nexperia 20 V, 7.5 A NPN/NPN low VCEsat (BISS) transistor 11. Soldering 5.50 0.60 (8×) 1.30 4.00 6.60 7.00 1.27 (6×) solder lands occupied area placement accuracy ± 0.25 Dimensions in mm sot096-1_fr Fig 16. Reflow soldering footprint SOT96-1 (SO8) 1.20 (2×) 0.60 (6×) enlarged solder land 0.3 (2×) 1.30 4.00 6.60 7.00 1.27 (6×) 5.50 board direction solder lands occupied area solder resist placement accurracy ± 0.25 Dimensions in mm sot096-1_fw Fig 17. Wave soldering footprint SOT96-1 (SO8) PBSS4021SN Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 11 October 2010 © Nexperia B.V. 2017. All rights reserved 11 of 15 PBSS4021SN Nexperia 20 V, 7.5 A NPN/NPN low VCEsat (BISS) transistor 12. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes PBSS4021SN v.2 20101011 Product data sheet - PBSS4021SN v.1 Modifications: PBSS4021SN v.1 PBSS4021SN Product data sheet • Figure 1 “Per device: Power derating curves”: updated. 20100714 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 2 — 11 October 2010 - © Nexperia B.V. 2017. All rights reserved 12 of 15 PBSS4021SN Nexperia 20 V, 7.5 A NPN/NPN low VCEsat (BISS) transistor 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 13.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. PBSS4021SN Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 11 October 2010 © Nexperia B.V. 2017. All rights reserved 13 of 15 PBSS4021SN Nexperia 20 V, 7.5 A NPN/NPN low VCEsat (BISS) transistor Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 14. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com PBSS4021SN Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 11 October 2010 © Nexperia B.V. 2017. All rights reserved 14 of 15 Nexperia PBSS4021SN 20 V, 7.5 A NPN/NPN low VCEsat (BISS) transistor 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Packing information . . . . . . . . . . . . . . . . . . . . 10 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12 Legal information. . . . . . . . . . . . . . . . . . . . . . . 13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Contact information. . . . . . . . . . . . . . . . . . . . . 14 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 11 October 2010
PBSS4021SN,115 价格&库存
很抱歉,暂时无法提供与“PBSS4021SN,115”相匹配的价格&库存,您可以联系我们找货
