74HC4067PW,118
74HC4067PW,118
    NEXPERIA(安世)
    TSSOP24_7.8X4.4MM
    16通道模拟多路复用器/解复用器
74HC4067PW,118 数据手册
74HC4067; 74HCT4067 16-channel analog multiplexer/demultiplexer Rev. 6 — 22 May 2015 Product data sheet 1. General description The 74HC4067; 74HCT4067 is a single-pole 16-throw analog switch (SP16T) suitable for use in analog or digital 16:1 multiplexer/demultiplexer applications. The switch features four digital select inputs (S0, S1, S2 and S3), sixteen independent inputs/outputs (Yn), a common input/output (Z) and a digital enable input (E). When E is HIGH, the switches are turned off. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits  Input levels S0, S1, S2, S3 and E inputs:  For 74HC4067: CMOS level  For 74HCT4067: TTL level  Low ON resistance:  80  (typical) at VCC = 4.5 V  70  (typical) at VCC = 6.0 V  60  (typical) at VCC = 9.0 V  Specified in compliance with JEDEC standard no. 7A  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  CDM JESD22-C101E exceeds 1000 V  Multiple package options  Specified from 40 C to +85 C and 40 C to +125 C  Typical ‘break before make’ built-in 3. Applications  Analog multiplexing and demultiplexing  Digital multiplexing and demultiplexing  Signal gating 74HC4067; 74HCT4067 Nexperia 16-channel analog multiplexer/demultiplexer 4. Ordering information Table 1. Ordering information Type number 74HC4067D Package Temperature range Name Description Version 40 C to +125 C SO24 plastic small outline package; 24 leads; body width 7.5 mm SOT137-1 40 C to +125 C SSOP24 plastic shrink small outline package; 24 leads; body width 5.3 mm SOT340-1 40 C to +125 C TSSOP24 plastic thin shrink small outline package; 24 leads; body width 4.4 mm SOT355-1 40 C to +125 C DHVQFN24 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 24 terminals; body 3.5  5.5  0.85 mm 74HCT4067D 74HC4067DB 74HCT4067DB 74HC4067PW 74HCT4067PW 74HC4067BQ 74HCT4067BQ SOT815-1 5. Functional diagram      6 6 6 6                   (
74HC4067PW,118 价格&库存
很抱歉,暂时无法提供与“74HC4067PW,118”相匹配的价格&库存,您可以联系我们找货
74HC4067PW,118
    • 1+5.05890
    • 10+4.14640
    • 30+3.69600
    • 100+3.24560
    • 500+2.93370
    • 1000+2.79510
    库存:15035
    74HC4067PW,118
    • 1+2.52344
    • 30+2.43642
    • 100+2.26239
    • 500+2.08836
    • 1000+2.00135
