74HC4067; 74HCT4067
16-channel analog multiplexer/demultiplexer
Rev. 6 — 22 May 2015
Product data sheet
1. General description
The 74HC4067; 74HCT4067 is a single-pole 16-throw analog switch (SP16T) suitable for
use in analog or digital 16:1 multiplexer/demultiplexer applications. The switch features
four digital select inputs (S0, S1, S2 and S3), sixteen independent inputs/outputs (Yn), a
common input/output (Z) and a digital enable input (E). When E is HIGH, the switches are
turned off. Inputs include clamp diodes. This enables the use of current limiting resistors
to interface inputs to voltages in excess of VCC.
2. Features and benefits
Input levels S0, S1, S2, S3 and E inputs:
For 74HC4067: CMOS level
For 74HCT4067: TTL level
Low ON resistance:
80 (typical) at VCC = 4.5 V
70 (typical) at VCC = 6.0 V
60 (typical) at VCC = 9.0 V
Specified in compliance with JEDEC standard no. 7A
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
CDM JESD22-C101E exceeds 1000 V
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C
Typical ‘break before make’ built-in
3. Applications
Analog multiplexing and demultiplexing
Digital multiplexing and demultiplexing
Signal gating
74HC4067; 74HCT4067
Nexperia
4. Ordering information
Table 1.
Type number
74HC4067D
Package
Temperature range
Name
Description
Version
40 C to +125 C
SO24
plastic small outline package; 24 leads;
body width 7.5 mm
SOT137-1
40 C to +125 C
SSOP24
plastic shrink small outline package; 24 leads;
body width 5.3 mm
SOT340-1
40 C to +125 C
TSSOP24
plastic thin shrink small outline package; 24 leads;
body width 4.4 mm
SOT355-1
40 C to +125 C
DHVQFN24 plastic dual in-line compatible thermal enhanced very
thin quad flat package; no leads; 24 terminals;
body 3.5 5.5 0.85 mm
74HCT4067D
74HC4067DB
74HCT4067DB
74HC4067PW
74HCT4067PW
74HC4067BQ
74HCT4067BQ
SOT815-1
5. Functional diagram
6
6
6
6
很抱歉,暂时无法提供与“74HC4067DB,118”相匹配的价格&库存,您可以联系我们找货
