HEF4051B
8-channel analog multiplexer/demultiplexer
Rev. 12 — 25 March 2016
Product data sheet
1. General description
The HEF4051B is an 8-channel analog multiplexer/demultiplexer with three address
inputs (S1 to S3), an active LOW enable input (E), eight independent inputs/outputs
(Y0 to Y7) and a common input/output (Z). The device contains eight bidirectional analog
switches, each with one side connected to an independent input/output (Y0 to Y7) and the
other side connected to a common input/output (Z). With E LOW, one of the eight
switches is selected (low-impedance ON-state) by S1 to S3. With E HIGH, all switches
are in the high-impedance OFF-state, independent of S1 to S3. If break before make is
needed, then it is necessary to use the enable input.
VDD and VSS are the supply voltage connections for the digital control inputs (S1 to S3,
and E). The VDD to VSS range is 3 V to 15 V. The analog inputs/outputs (Y0 to Y7, and Z)
can swing between VDD as a positive limit and VEE as a negative limit. VDD VEE may not
exceed 15 V. Unused inputs must be connected to VDD, VSS, or another input. For
operation as a digital multiplexer/demultiplexer, VEE is connected to VSS (typically
ground). VEE and VSS are the supply voltage connections for the switches.
2. Features and benefits
Fully static operation
5 V, 10 V, and 15 V parametric ratings
Standardized symmetrical output characteristics
Specified from 40 C to +85 C and 40 C to +125 C
Complies with JEDEC standard JESD 13-B
3. Applications
Analog multiplexing and demultiplexing
Digital multiplexing and demultiplexing
Signal gating
HEF4051B
Nexperia
4. Ordering information
Table 1.
All types operate from 40 C to +125 C.
Type number
Package
Name
Description
Version
HEF4051BT
SO16
plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
HEF4051BTS
SSOP16
plastic shrink small outline package; 16 leads; body width 5.3 mm
SOT338-1
HEF4051BTT
TSSOP16
plastic thin shrink small outline package; 16 leads; body width 4.4 mm
SOT403-1
5. Functional diagram
9''
很抱歉,暂时无法提供与“HEF4051BTT,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.60126
- 10+3.23622
- 30+3.03966
- 100+2.81502
- 500+0.96174
- 1000+0.91962
