HEF4052B
Dual 4-channel analog multiplexer/demultiplexer
Rev. 10 — 25 March 2016
Product data sheet
1. General description
The HEF4052B is a dual 4-channel analog multiplexer/demultiplexer with common
channel select logic. Each multiplexer/demultiplexer has four independent inputs/outputs
(nY0 to nY3) and a common input/output (nZ). The common channel select logic includes
two select inputs (S1 and S2) and an active LOW enable input (E). Both
multiplexers/demultiplexers contain four bidirectional analog switches, each with one side
connected to an independent input/output (nY0 to nY3) and the other side connected to a
common input/output (nZ). With E LOW, one of the four switches is selected
(low-impedance ON-state) by S1 and S2. With E HIGH, all switches are in the
high-impedance OFF-state, independent of S1 and S2. If break before make is needed,
then it is necessary to use the enable input.
VDD and VSS are the supply voltage connections for the digital control inputs (S1 and S2,
and E). The VDD to VSS range is 3 V to 15 V. The analog inputs/outputs (nY0 to nY3, and
nZ) can swing between VDD as a positive limit and VEE as a negative limit. VDD VEE may
not exceed 15 V. Unused inputs must be connected to VDD, VSS, or another input. For
operation as a digital multiplexer/demultiplexer, VEE is connected to VSS (typically
ground). VEE and VSS are the supply voltage connections for the switches.
2. Features and benefits
Fully static operation
5 V, 10 V, and 15 V parametric ratings
Standardized symmetrical output characteristics
Specified from 40 C to +85 C and 40 C to +125 C
Complies with JEDEC standard JESD 13-B
3. Applications
Analog multiplexing and demultiplexing
Digital multiplexing and demultiplexing
Signal gating
HEF4052B
Nexperia
4. Ordering information
Table 1.
All types operate from 40 C to +125 C.
Type number
Package
Name
Description
Version
HEF4052BT
SO16
plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
HEF4052BTT
TSSOP16
plastic thin shrink small outline package; 16 leads; body width 4.4 mm
SOT403-1
5. Functional diagram
9''
6
6
/2*,&
/(9(/
&219(56,21
2)
'(&2'(5
很抱歉,暂时无法提供与“HEF4052BTT,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5000+1.07163
- 10000+1.07054
- 国内价格 香港价格
- 2500+1.323052500+0.16050
- 5000+1.316865000+0.15975
- 7500+1.316847500+0.15975
- 12500+1.3168112500+0.15975
- 25000+1.3167725000+0.15974
- 国内价格 香港价格
- 1+1.795381+0.21780
- 25000+1.7863225000+0.21670
- 125000+1.77725125000+0.21560
- 250000+1.77725250000+0.21560
- 1250000+1.777251250000+0.21560
