74LV4052
Dual 4-channel analog multiplexer/demultiplexer
Rev. 5 — 17 March 2016
Product data sheet
1. General description
The 74LV4052 is a low-voltage CMOS device and is pin and function compatible with the
74HC/HCT4052.
The 74LV4052 is a dual 4-channel analog multiplexer/demultiplexer with a common select
logic. Each multiplexer has four independent inputs/outputs (nY0 to nY3) and a common
input/output (nZ). The common channel select logics include two digital select inputs (S0
and S1) and an active LOW enable input (E). With E LOW, one of the four switches is
selected (low impedance ON-state) by S0 and S1. With E HIGH, all switches are in the
high impedance OFF-state, independent of S0 and S1. VCC and GND are the supply
voltage pins for the digital control inputs (S0, S1 and E). The VCC to GND ranges are 1.0 V
to 6.0 V. The analog inputs/outputs (nY0, to nY3, and nZ) can swing between VCC as a
positive limit and VEE as a negative limit. VCC - VEE may not exceed 6.0 V. For operation
as a digital multiplexer/demultiplexer, VEE is connected to GND (typically ground).
2. Features and benefits
Optimized for low-voltage applications: 1.0 V to 6.0 V
Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V
Low ON resistance:
145 (typical) at VCC VEE = 2.0 V
90 (typical) at VCC VEE = 3.0 V
60 (typical) at VCC VEE = 4.5 V
Logic level translation:
To enable 3 V logic to communicate with 3 V analog signals
Typical ‘break before make’ built in
ESD protection:
HBM JESD22-A114E exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
Multiple package options
Specified from 40 C to +85 C and from 40 C to +125 C
74LV4052
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74LV4052D
40 C to +125 C
SO16
plastic small outline package; 16 leads; body
width 3.9 mm
SOT109-1
74LV4052DB
40 C to +125 C
SSOP16
plastic shrink small outline package; 16 leads; body
width 5.3 mm
SOT338-1
74LV4052PW
40 C to +125 C
TSSOP16
plastic thin shrink small outline package; 16 leads;
body width 4.4 mm
SOT403-1
4. Functional diagram
9&&
6
/2*,&
/(9(/
&219(56,21
很抱歉,暂时无法提供与“74LV4052D,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2500+1.062112500+0.12884
- 5000+1.057155000+0.12824
- 10000+1.0571210000+0.12824
- 12500+1.0571012500+0.12823
- 37500+1.0570837500+0.12823
