74LV4060
14-stage binary ripple counter with oscillator
Rev. 4 — 17 March 2016
Product data sheet
1. General description
The 74LV4060 is a low-voltage Si-gate CMOS device and is pin and function compatible
with the 74HC4060; 74HCT4060.
The 74LV4060 is a 14-stage ripple-carry counter/divider and oscillator with three oscillator
terminals (RS, RTC and CTC). It has ten buffered outputs (Q3 to Q9 and Q11 to Q13) and
an overriding asynchronous master reset (MR). The oscillator configuration allows design
of either RC or crystal oscillator circuits. The oscillator can be replaced by an external
clock signal at input RS. In this case, keep the oscillator pins (RTC and CTC) floating.
The counter advances on the negative-going transition of RS. A HIGH-level on MR resets
the counter (Q3 to Q9 and Q11 to Q13 = LOW), independent of the other input conditions.
2. Features and benefits
Wide operating voltage range from 1.0 V to 5.5 V
Optimized for low voltage applications from 1.0 V to 3.6 V
Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V
Typical VOLP (output ground bounce) < 0.8 V at VCC = 3.3 V; Tamb = 25 C
Typical VOHV (output VOH undershoot) > 2 V at VCC = 3.3 V; Tamb = 25 C
All active components on-chip
RC or crystal oscillator configuration
Complies with JEDEC standard no. 7A
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115A exceeds 200 V
3. Applications
Control counters
Timers
Frequency dividers
Time-delay circuits
74LV4060
Nexperia
4. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74LV4060D
40 C to +125 C
SO16
plastic small outline package; 16 leads; body width
3.9 mm
SOT109-1
74LV4060DB
40 C to +125 C
SSOP16
plastic shrink small outline package; 16 leads; body
width 5.3 mm
SOT338-1
74LV4060PW
40 C to +125 C
TSSOP16
plastic thin shrink small outline package; 16 leads;
body width 4.4 mm
SOT403-1
5. Functional diagram
57& &7&
56
05
4
4
4
4
4
4
4
4
4
4
DDL
Fig 1.
Logic symbol
&75
&75
&7&
57&
56
05
&7
&7
$1'
&7
&7
D
E
DDL
Fig 2.
IEC logic symbol
74LV4060
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 22
74LV4060
Nexperia
&7&
57&
56
&3
&3
&3
&3
4
05
4
05
4
05
4
05
&3
4
4
05
4
05
4
4
DDL
Fig 3.
Logic diagram
57&
&7&
56
&3
05
67$*(%,1$5
很抱歉,暂时无法提供与“74LV4060PW,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 466+2.58700466+0.31314
- 500+2.56289500+0.31023
- 1000+1.913851000+0.23166
- 3000+1.895683000+0.22946
- 国内价格 香港价格
- 2500+1.132322500+0.13706
- 10000+1.0568910000+0.12793
- 25000+1.0505325000+0.12716
