74LV4060DB,118
74LV4060DB,118
    NEXPERIA(安世)
    SSOP16_208MIL
    IC 14STAGE BINARY RIPPLE 16SSOP
74LV4060DB,118 数据手册
74LV4060 14-stage binary ripple counter with oscillator Rev. 5 — 24 March 2021 Product data sheet 1. General description The 74LV4060 is a 14-stage ripple-carry counter/divider and oscillator with three oscillator terminals (RS, RTC and CTC), ten buffered parallel outputs (Q3 to Q9 and Q11 to Q13) and an overriding asynchronous master reset (MR). The oscillator configuration allows design of either RC or crystal oscillator circuits. The oscillator may be replaced by an external clock signal at input RS. In this case, keep the oscillator pins (RTC and CTC) floating. The counter advances on the HIGH-to-LOW transition of RS. A HIGH level on MR clears all counter stages and forces all outputs LOW, independent of the other input conditions. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess VCC. 2. Features and benefits • • • • • • • • • • • Wide supply voltage range from 1.0 V to 5.5 V Optimized for low voltage applications from 1.0 V to 3.6 V CMOS low power dissipation Latch-up performance exceeds 100 mA per JESD 78 Class II Level B Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V Typical VOLP (output ground bounce) < 0.8 V at VCC = 3.3 V; Tamb = 25 °C Typical VOHV (output VOH undershoot) > 2 V at VCC = 3.3 V; Tamb = 25 °C All active components on-chip RC or crystal oscillator configuration Complies with JEDEC standard no. 7A ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115A exceeds 200 V 3. Applications • • • • Control counters Timers Frequency dividers Time-delay circuits 4. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LV4060D -40 °C to +125 °C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 74LV4060PW -40 °C to +125 °C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 74LV4060 Nexperia 14-stage binary ripple counter with oscillator 5. Functional diagram 10 9 CTR14 RTC CTC 11 12 RS MR Q3 7 Q4 5 Q5 4 Q6 6 Q7 14 Q8 13 Q9 15 Q11 1 Q12 2 Q13 3 !G CTC 9 11 RS 6 11 12 MR 14 12 CT 4 AND 15 11 1 14 CT 13 9 6 + CT = 0 13 9 15 11 1 2 13 2 3 13 (a) FF 1 RS 4 + FF 10 CP FF 12 CP Q CP Q MR Q MR MR 001aai468 FF 14 CP Q MR (b) 3 IEC logic symbol FF 4 CP 7 5 RTC Fig. 2. RTC 3 5 CT = 0 Logic symbol CTC 7 10 001aai467 Fig. 1. CTR14 3 Q3 Q MR Q9 MR Q11 Q13 001aai114 Fig. 3. Logic diagram 10 RTC 11 12 RS MR 9 CTC CP MR Q3 7 Fig. 4. 14-STAGE BINARY COUNTER Q4 5 Q5 4 Q6 6 Q7 14 Q8 13 Q9 15 Q11 Q12 Q13 1 2 3 001aai113 Functional diagram 74LV4060 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 March 2021 © Nexperia B.V. 2021. All rights reserved 2 / 17 74LV4060 Nexperia 14-stage binary ripple counter with oscillator 6. Pinning information 6.1. Pinning 74LV4060 Q11 1 16 VCC Q12 2 15 Q9 Q13 3 14 Q7 Q5 4 13 Q8 Q4 5 12 MR Q6 6 11 RS Q3 7 10 RTC GND 8 9 CTC aaa-012907 Fig. 5. Pin configuration SOT109-1 (SO16) and SOT403-1 (TSSOP16) 6.2. Pin description Table 2. Pin description Symbol Pin Description Q11 to Q13 1, 2, 3 counter output Q3 to Q9 7, 5, 4, 6, 14, 13, 15 counter output GND 8 ground (0 V) CTC 9 external capacitor connection RTC 10 external resistor connection RS 11 clock input/oscillator pin MR 12 master reset VCC 16 supply voltage 74LV4060 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 March 2021 © Nexperia B.V. 2021. All rights reserved 3 / 17 74LV4060 Nexperia 14-stage binary ripple counter with oscillator 7. Functional description 1 2 4 8 16 32 64 128 256 512 1024 2048 4096 8192 16384 RS MR Q3 Q4 Q5 Q6 Q7 Q8 Q9 Q11 Q12 Q13 001aai117 Fig. 6. Timing diagram 8. Limiting values Table 3. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Min Max Unit VCC supply voltage IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V [1] -0.5 +7.0 V - ±20 mA IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V [1] - ±50 mA IO output current -0.5 V < VO < VCC + 0.5 V - ±25 mA ICC supply current - +50 mA IGND ground current -50 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW [1] [2] Conditions Tamb = -40 °C to +125 °C [2] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For SOT109-1 (SO16) package: Ptot derates linearly with 12.4 mW/K above 110 °C. For SOT403-1 (TSSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C. 74LV4060 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 March 2021 © Nexperia B.V. 2021. All rights reserved 4 / 17 74LV4060 Nexperia 14-stage binary ripple counter with oscillator 9. Recommended operating conditions Table 4. Recommended operating conditions Symbol Parameter Conditions Typ Max Unit 1.0 3.3 5.5 V VCC supply voltage VI input voltage 0 - VCC V VO output voltage 0 - VCC V Tamb ambient temperature in free air -40 - +125 °C Δt/ΔV input transition rise and fall rate VCC = 1.0 V to 2.0 V - - 500 ns/V VCC = 2.0 V to 2.7 V - - 200 ns/V VCC = 2.7 V to 3.6 V - - 100 ns/V VCC = 3.6 V to 5.5 V - - 50 ns/V [1] [1] Min The 74LV4060 is guaranteed to function down to VCC = 1.0 V (input levels GND or VCC); DC characteristics are guaranteed from VCC = 1.2 V to VCC = 5.5 V. 10. Static characteristics Table 5. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH HIGH-level input voltage Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ[1] Max Min Max VCC = 1.2 V 0.9 - - 0.9 - V VCC = 2.0 V 1.4 - - 1.4 - V VCC = 2.7 V to 3.6 V 2.0 - - 2.0 - V VCC = 4.5 V to 5.5 V 0.7VCC - - 0.7VCC - V VCC = 1.2 V 1.0 - - 1.0 - V VCC = 2.0 V 1.6 - - 1.6 - V VCC = 2.7 V to 3.6 V 2.4 - - 2.4 - V VCC = 4.5 V to 5.5 V 0.8VCC - - 0.8VCC - V VCC = 1.2 V - - 0.3 - 0.3 V VCC = 2.0 V - - 0.6 - 0.6 V VCC = 2.7 V to 3.6 V - - 0.8 - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3VCC - VCC = 1.2 V - - 0.2 - 0.2 V VCC = 2.0 V - - 0.4 - 0.4 V VCC = 2.7 V to 3.6 V - - 0.5 - 0.5 V VCC = 4.5 V to 5.5 V - - 0.2VCC - MR input RS input VIL LOW-level input voltage MR input 0.3VCC V RS input 74LV4060 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 March 2021 © 0.2VCC V Nexperia B.V. 2021. All rights reserved 5 / 17 74LV4060 Nexperia 14-stage binary ripple counter with oscillator Symbol Parameter VOH HIGH-level output voltage Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ[1] Max Min Max VCC = 1.2 V; IO = -3.4 mA - - - - - V VCC = 2.0 V; IO = -3.4 mA - - - - - V VCC = 2.7 V; IO = -3.4 mA - - - - - V VCC = 3.0 V; IO = -3.4 mA 2.40 2.82 - 2.20 - V VCC = 4.5 V; IO = -3.4 mA - - - - - V VCC = 1.2 V; IO = -0.8 mA - - - - - V VCC = 2.0 V; IO = -0.8 mA - - - - - V VCC = 2.7 V; IO = -0.8 mA - - - - - V VCC = 3.0 V; IO = -0.8 mA 2.40 2.82 - 2.20 - V VCC = 4.5 V; IO = -0.8 mA - - - - - V VCC = 1.2 V; IO = -100 μA 1.0 1.2 - 1.0 - V VCC = 2.0 V; IO = -100 μA 1.8 2.0 - 1.8 - V VCC = 2.7 V; IO = -100 μA - - - - - V VCC = 3.0 V; IO = -100 μA 2.8 3.0 - 2.8 - V VCC = 4.5 V; IO = -100 μA - - - - - V VCC = 1.2 V; IO = -100 μA 1.0 1.2 - 1.0 - V VCC = 2.0 V; IO = -100 μA 1.8 2.0 - 1.8 - V RTC output; RS = MR = GND RTC output; RS = MR = VCC VOH HIGH-level output voltage RTC output; RS = MR = GND RTC output; RS = MR = VCC VCC = 2.7 V; IO = -100 μA - - - - - V VCC = 3.0 V; IO = -100 μA 2.8 3.0 - 2.8 - V VCC = 4.5 V; IO = -100 μA - - - - - V VCC = 1.2 V; IO = -3.8 mA - 1.2 - - - V VCC = 2.0 V; IO = -3.8 mA - - - - - V VCC = 2.7 V; IO = -3.8 mA - - - - - V VCC = 3.0 V; IO = -3.8 mA 2.40 2.82 - 2.20 - V VCC = 4.5 V; IO = -3.8 mA - - - - - V VCC = 1.2 V; IO = -100 μA 1.0 1.2 - 1.0 - V VCC = 2.0 V; IO = -100 μA 1.8 2.0 - 1.8 - V VCC = 2.7 V; IO = -100 μA - - - - - V VCC = 3.0 V; IO = -100 μA 2.8 3.0 - 2.8 - V VCC = 4.5 V; IO = -100 μA - - - - - V VCC = 1.2 V; IO = -6 mA - - - - - V VCC = 2.0 V; IO = -6 mA - - - - - V VCC = 2.7 V; IO = -6 mA - - - - - V VCC = 3.0 V; IO = -6 mA 2.40 2.82 - 2.20 - V VCC = 4.5 V; IO = -6 mA - - - - - V CTC output; RS = VIH and MR = VIL except RTC output; VI = VIH or VIL except RTC and CTC outputs; VI = VIH or VIL 74LV4060 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 March 2021 © Nexperia B.V. 2021. All rights reserved 6 / 17 74LV4060 Nexperia 14-stage binary ripple counter with oscillator Symbol Parameter VOL LOW-level output voltage VOL LOW-level output voltage Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ[1] Max Min Max VCC = 1.2 V; IO = -3.4 mA - - - - - V VCC = 2.0 V; IO = -3.4 mA - - - - - V VCC = 2.7 V; IO = -3.4 mA - - - - - V VCC = 3.0 V; IO = -3.4 mA - 0.25 0.40 - 0.50 V VCC = 4.5 V; IO = -3.4 mA - - - - - V VCC = 1.2 V; IO = -100 μA - 0 0.2 - 0.2 V VCC = 2.0 V; IO = -100 μA - 0 0.2 - 0.2 V VCC = 2.7 V; IO = -100 μA - - - - - V VCC = 3.0 V; IO = -100 μA - 0 0.2 - 0.2 V VCC = 4.5 V; IO = -100 μA - - - - - V VCC = 1.2 V; IO = -3.8 mA - - - - - V VCC = 2.0 V; IO = -3.8 mA - - - - - V VCC = 2.7 V; IO = -3.8 mA - - - - - V VCC = 3.0 V; IO = -3.8 mA - 0.25 - 0.40 0.50 V VCC = 4.5 V; IO = -3.8 mA - - - - - V VCC = 1.2 V; IO = -100 μA - 0 0.2 - 0.2 V VCC = 2.0 V; IO = -100 μA - 0 0.2 - 0.2 V VCC = 2.7 V; IO = -100 μA - - - - - V VCC = 3.0 V; IO = -100 μA - 0 0.2 - 0.2 V VCC = 4.5 V; IO = -100 μA - - - - - V VCC = 1.2 V; IO = -6 mA - - - - - V VCC = 2.0 V; IO = -6 mA - - - - - V VCC = 2.7 V; IO = -6 mA - 0.25 0.40 - 0.50 V VCC = 3.0 V; IO = -6 mA - - - - - V VCC = 4.5 V; IO = -6 mA - - - - - V RTC output; RS = VCC and MR = GND RTC output; RS = VCC and MR = GND; CTC output; RS = VIH and MR = VIL; except RTC output; VI = VIH or VIL; except RTC and CTC output; VI = VIH or VIL II input leakage current VCC = 5.5 V; VI = VCC or GND - - 1.0 - 1.0 μA ICC supply current VCC = 3.6 V; VI = VCC or GND; IO = 0 A - - 20 - 160 μA VCC = 5.5 V; VI = VCC or GND; IO = 0 A - - - - 80 μA VCC = 2.7 V to 3.6 V; VI = VCC - 0.6 V; IO = 0 A - - 500 - 850 μA - 3.5 - - - pF ΔICC additional supply current CI input capacitance [1] All typical values are measured at Tamb = 25 °C. 74LV4060 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 March 2021 © Nexperia B.V. 2021. All rights reserved 7 / 17 74LV4060 Nexperia 14-stage binary ripple counter with oscillator 11. Dynamic characteristics Table 6. Dynamic characteristics GND = 0 V; for test circuit, see Fig. 10. Symbol Parameter tpd Conditions -40 °C to +85 °C Min Typ[1] VCC = 1.2 V - VCC = 2.0 V - VCC = 2.7 V VCC = 3.3 V; CL = 15 pF propagation delay RS to Q3; see Fig. 7 and Fig. 9 -40 °C to +125 °C Unit Max Min Max 180 - - - ns 52 84 - 105 ns - 42 66 - 83 ns - 29 - - - ns [2] VCC = 3.0 V to 3.6 V [3] - 33 53 - 66 ns VCC = 4.5 V to 5.5 V [4] - 24 39 - 49 ns VCC = 1.2 V - 40 - - - ns VCC = 2.0 V - 14 23 - 29 ns VCC = 2.7 V - 10 16 - 20 ns Qn to Qn+1; see Fig. 8 and Fig. 9 VCC = 3.3 V; CL = 15 pF tPHL tW - 6 - - - ns VCC = 3.0 V to 3.6 V [3] - 8 13 - 16 ns VCC = 4.5 V to 5.5 V [4] - 6 9 - 11 ns - 100 - - - ns VCC = 2.0 V - 29 46 - 58 ns VCC = 2.7 V - 24 39 - 49 ns VCC = 3.3 V; CL = 15 pF - 16 - - - ns MR to Qn; see Fig. 8 and Fig. 9 HIGH to LOW propagation delay VCC = 1.2 V pulse width VCC = 3.0 V to 3.6 V [3] - 19 31 - 39 ns VCC = 4.5 V to 5.5 V [4] - 14 23 - 29 ns VCC = 2.0 V 34 9 - 38 - ns VCC = 2.7 V 25 6 - 30 - ns RS HIGH or LOW; see Fig. 7 VCC = 3.0 V to 3.6 V [3] 20 5 - 24 - ns VCC = 4.5 V to 5.5 V [4] 16 4 - 20 - ns VCC = 2.0 V 34 10 - 38 - ns VCC = 2.7 V 25 8 - 30 - ns MR HIGH; see Fig. 9 trec recovery time 74LV4060 Product data sheet VCC = 3.0 V to 3.6 V [3] 20 6 - 24 - ns VCC = 4.5 V to 5.5 V [4] 16 4 - 20 - ns VCC = 2.0 V 29 18 - 37 - ns VCC = 2.7 V 26 16 - 32 - ns MR to RS; see Fig. 9 VCC = 3.0 V to 3.6 V [3] 18 11 - 23 - ns VCC = 4.5 V to 5.5 V [4] 12 7 - 15 - ns All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 March 2021 © Nexperia B.V. 2021. All rights reserved 8 / 17 74LV4060 Nexperia 14-stage binary ripple counter with oscillator Symbol Parameter fmax Conditions -40 °C to +85 °C Min Typ[1] Max VCC = 2.0 V 14 40 VCC = 2.7 V 19 70 - VCC = 3.3 V; CL = 15 pF [1] [2] [3] [4] [5] Min Max - 9 - MHz - 12 - MHz 99 - - - MHz see Fig. 7 maximum frequency CPD -40 °C to +125 °C Unit power dissipation capacitance VCC = 3.0 V to 3.6 V [3] 24 90 - 15 - MHz VCC = 4.5 V to 5.5 V [4] 30 100 - 19 - MHz [5] - 40 - - - pF VI = GND to VCC All typical values are measured at Tamb = 25 °C. tpd is the same as tPLH and tPHL. Typical value measured at VCC = 3.3 V. Typical value measured at VCC = 5.0 V. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL x VCC x fo) = sum of outputs. 11.1. Waveforms and test circuit 1/fmax VI RS input VM GND tW tPHL tPLH VOH VM Qn output VOL aaa-012961 Measurement points are given in Table 7. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 7. Waveforms showing the clock (RS) to output (Qn) propagation delays, the clock pulse width, the output transition times and the maximum frequency VOH Qn output VM VOL VOH tPLH tPHL VM Qn+1 output VOL 001aai120 Measurement points are given in Table 7. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 8. Waveforms showing the output Qn to output Qn+1 propagation delays 74LV4060 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 March 2021 © Nexperia B.V. 2021. All rights reserved 9 / 17 74LV4060 Nexperia 14-stage binary ripple counter with oscillator VI MR input VM GND tW trec VI RS input VM GND tPHL VOH VM Qn output VOL 001aai119 Measurement points are given in Table 7. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 9. Waveforms showing the master reset (MR) pulse width, the master reset to output (Qn) propagation delays and the master reset to clock (RS) recovery time Table 7. Measurement points Supply voltage Input Output VCC VM VM < 2.7 V 0.5VCC 0.5VCC 2.7 V to 3.6 V 1.5 V 1.5 V ≥ 4.5 V 0.5VCC 0.5VCC VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VCC PULSE GENERATOR VI VO DUT RT CL RL 001aaf615 Test data is given in Table 8. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. Fig. 10. Test circuit for measuring switching times 74LV4060 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 March 2021 © Nexperia B.V. 2021. All rights reserved 10 / 17 74LV4060 Nexperia 14-stage binary ripple counter with oscillator Table 8. Test data Supply voltage Input VCC VI tr, tf CL RL VCC < 2.7 V VCC 2.5 ns 50 pF 1 kΩ 2.7 V < VCC < 3.6 V 2.7 V 2.5 ns 15 pF, 50 pF 1 kΩ VCC ≥ 4.5 V VCC 2.5 ns 50 pF 1 kΩ Load 12. Typical forward transconductance aaa-012962 20 gfs (mA/V) 15 Rbias 560 kΩ 10 VCC 0.47 pF VI (fi = 1 kHz) 100 µF 5 input output A IO GND aaa-014024 gfs = ΔIO / ΔVI at VO is constant; MR = LOW See Fig. 12. Fig. 11. Test setup for measuring forward transconductance 0 0 1 2 3 VCC (V) 4 Tamb = 25 °C Fig. 12. Typical forward transconductance as function of the supply voltage 13. RC oscillator 13.1. Timing component limitations The oscillator frequency is mainly determined by Rt x Ct, provided R2 ≈ 2Rt and R2 x C2 is much less than Rt x Ct. The function of R2 is to minimize the influence of the forward voltage across the input protection diodes on the frequency. The stray capacitance C2 should be kept as small as possible. In consideration of accuracy, Ct must be larger than the inherent stray capacitance. Rt must be larger than the ‘ON’ resistance in series with it, which typically is 280 Ω at VCC = 1.2 V, 130 Ω at VCC = 2.0 V and 100 Ω at VCC 3.0 V. The recommended values for these components to maintain agreement with the typical oscillation formula are: Ct > 50 pF, up to any practical value, 10 kΩ < Rt < 1 MΩ. In order to avoid start-up problems, Rt ≥ 1 kΩ. 74LV4060 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 March 2021 © Nexperia B.V. 2021. All rights reserved 11 / 17 74LV4060 Nexperia 14-stage binary ripple counter with oscillator MR (from logic) 11 RS C2 R2 RTC 10 CTC 9 Rt Ct aaa-013006 Typical formula for oscillator frequency: Fig. 13. Example of an RC oscillator 001aai125 105 fosc (Hz) 001aai127 105 fosc (Hz) Rt 104 104 Ct 103 103 102 102 10 103 104 105 Rt (Ω) 10 10- 4 106 VCC = 1.2 V to 3.6 V; Tamb = 25 °C Rt curve: Ct = 1 nF; R2 = 2 × Rt 10- 3 10- 2 Ct (µF) 10- 1 VCC = 1.2 V to 3.6 V; Tamb = 25 °C Ct curve: Rt = 100 kΩ; R2 = 200 kΩ Fig. 14. RC oscillator frequency as a function of Rt Fig. 15. RC oscillator frequency as a function of Ct 13.2. Typical crystal oscillator circuit In Fig. 16, R2 is the power limiting resistor. For starting and maintaining oscillation, a minimum transconductance is necessary, so R2 must not be too large. A practical value for R2 is 2.2 kΩ. MR (from logic) 11 RS Rbias RTC 10 100 kΩ to 1MΩ R2 2.2 kΩ C3 22 pF to 37 pF C2 100 pF aaa-012963 Fig. 16. External components connection for a typical crystal oscillator 74LV4060 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 March 2021 © Nexperia B.V. 2021. All rights reserved 12 / 17 74LV4060 Nexperia 14-stage binary ripple counter with oscillator 14. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e w M bp 0 2.5 detail X 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.16 0.15 0.05 0.039 0.016 0.028 0.020 0.01 0.01 0.004 0.028 0.012 0.244 0.041 0.228 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig. 17. Package outline SOT109-1 (SO16) 74LV4060 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 March 2021 © Nexperia B.V. 2021. All rights reserved 13 / 17 74LV4060 Nexperia 14-stage binary ripple counter with oscillator TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm D SOT403-1 E A X c y HE v M A Z 9 16 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 8 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig. 18. Package outline SOT403-1 (TSSOP16) 74LV4060 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 March 2021 © Nexperia B.V. 2021. All rights reserved 14 / 17 74LV4060 Nexperia 14-stage binary ripple counter with oscillator 15. Abbreviations Table 9. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 16. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LV4060 v.5 20210324 Product data sheet - 74LV4060 v.4 Modifications: • • • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Section 1 and Section 2 updated. Section 8: Derating values for Ptot total power dissipation updated. Type number 74LV4060DB (SOT338-1/SSOP16) removed. 74LV4060 v.4 20160317 Modifications: • 74LV4060 v.3 20140728 Modifications: • 74LV4060 v.2 20140703 Modifications: • • 74LV4060 v.1 74LV4060 Product data sheet Product data sheet - 74LV4060 v.3 Type number 74LV4060N (SOT38-4) removed. Product data sheet - 74LV4060 v.2 Minimum value VOH and VOL corrected (errata). Product data sheet - 74LV4060 v.1 The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. Legal texts have been adapted to the new company name where appropriate. 19980623 Product specification - All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 March 2021 - © Nexperia B.V. 2021. All rights reserved 15 / 17 74LV4060 Nexperia 14-stage binary ripple counter with oscillator 17. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74LV4060 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 March 2021 © Nexperia B.V. 2021. All rights reserved 16 / 17 74LV4060 Nexperia 14-stage binary ripple counter with oscillator Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Ordering information....................................................1 5. Functional diagram.......................................................2 6. Pinning information......................................................3 6.1. Pinning.........................................................................3 6.2. Pin description............................................................. 3 7. Functional description................................................. 4 8. Limiting values............................................................. 4 9. Recommended operating conditions..........................5 10. Static characteristics..................................................5 11. Dynamic characteristics.............................................8 11.1. Waveforms and test circuit........................................ 9 12. Typical forward transconductance..........................11 13. RC oscillator............................................................. 11 13.1. Timing component limitations.................................. 11 13.2. Typical crystal oscillator circuit................................ 12 14. Package outline........................................................ 13 15. Abbreviations............................................................ 15 16. Revision history........................................................15 17. Legal information......................................................16 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 24 March 2021 74LV4060 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 March 2021 © Nexperia B.V. 2021. All rights reserved 17 / 17
74LV4060DB,118 价格&库存
很抱歉,暂时无法提供与“74LV4060DB,118”相匹配的价格&库存,您可以联系我们找货
