LM358A-SR
LM358A-SR
    3PEAK(思瑞浦)
    SOIC8_150MIL
    1.2MHz,低功耗36V运算放大器 SOIC8_150MIL
LM358A-SR 数据手册
LM321A/ LM358A/ LM324A 36V General Purpose Op Amps Features Description  Supply Voltage: 3V to 36V The LM321A/358A/324A series amplifiers are newest high  Low Supply Current: 100μA per channel supply voltage amplifiers with low offset, low power and stable  Input Common-Mode Voltage Range Includes Ground  Can Work as Comparator  Rail to Rail Output  Bandwidth: 0.9 MHz current per amplifier. The input common-mode voltage range  Slew Rate: 0.5V/μs extends to V–, and the outputs swing rail-to-rail. The  Excellent EMI Suppress Performance: 71dB at 1GHz LM321A/358A/324A  Offset Voltage: ±3mV Maximum replacements for many commercially available op-amps to  Offset Voltage Temperature Drift: 7 μV/°C reduce power and improve input/output range and performance.  –40°C to 125°C Operation Temperature Range The combination of features makes the LM321A/358A/324A frequency response. They incorporate 3PEAK’s proprietary and patented design techniques to achieve very good AC performance with 0.9MHz bandwidth, 0.5V/μs slew rate and maximum 3mV offset while drawing only 100μA of quiescent family can be used as plug-in ideal choices for power module, industrial control, motor control Applications  Power Module  Sensor Interface  Motor Control  Audio and audio application. Pin Configuration +In LM321A LM358A LM324A 5-Pin SOT23 8-Pin SOIC/TSSOP/MSOP 14-Pin SOIC/TSSOP -T Suffixes -S, -TS and -V Suffixes -S and -T Suffixes 1 -VS 2 -In 3 5 4 +VS Out Out A 1 ﹣In A 2 ﹢In A 3 ﹣Vs 4 ﹢Vs Out A 1 14 Out D 7 Out B ﹣In A 2 13 ﹣In D 6 ﹣In B 5 ﹢In B 8 A B A ﹢In A 3 12 ﹢In D ﹢Vs 4 11 ﹣Vs ﹢In B 5 10 ﹢In C B www.3peakic.com.cn 1 / 17 D C ﹣In B 6 9 ﹣In C Out B 7 8 Out C Rev.Pre LM321A/ LM358A/ LM324A 36V General Purpose Op Amps Table of Contents Features ........................................................................................................................................................................... 1 Applications ..................................................................................................................................................................... 1 Description....................................................................................................................................................................... 1 Pin Configuration ............................................................................................................................................................ 1 Table of Contents ............................................................................................................................................................ 2 Revision History .............................................................................................................................................................. 3 Order Information ............................................................................................................................................................ 3 Absolute Maximum Ratings Note 1 ................................................................................................................................... 4 ESD Rating ....................................................................................................................................................................... 4 Thermal Information ....................................................................................................................................................... 4 Electrical Characteristics ............................................................................................................................................... 5 Typical Performance Characteristics ............................................................................................................................ 7 Tape and Reel Information ............................................................................................................................................. 9 Package Outline Dimensions ....................................................................................................................................... 10 SC70-5 /SOT-353 ....................................................................................................................................................................... 10 SOT23-5..................................................................................................................................................................................... 10 SOP-8 .........................................................................................................................................................................................11 TSSOP-8 .................................................................................................................................................................................... 12 MSOP-8 ..................................................................................................................................................................................... 13 DFN-8 1.5*1.5 ............................................................................................................................................................................ 14 SOP-14 ...................................................................................................................................................................................... 15 TSSOP-14 .................................................................................................................................................................................. 16 www.3peakic.com.cn 2 / 17 Rev.Pre LM321A/ LM358A/ LM324A 36V General Purpose Op Amps Revision History Date Revision Notes 2018/3/21 Rev.Pre Pre-Release Version Order Information Order Number Operating Temperature Range Package Marking Information MSL Transport Media, Quantity LM321A-TR Note 1 -40 to 125°C 5-Pin SOT23 21AXX Note 2 3 Tape and Reel, 3000 LM358A-SR -40 to 125°C 8-Pin SOIC 3 Tape and Reel, 4000 LM358A-CSR -40 to 85°C 8-Pin SOIC 3 Tape and Reel, 4000 LM358A-F1R -40 to 125°C 8-Pin DFN 1.5*1.5 3 Tape and Reel, 3000 LM358A-TSR Note 1 -40 to 125°C 8-Pin TSSOP 3 Tape and Reel, 3000 LM358A-VR Note 1 -40 to 125°C 8-Pin MSOP 3 Tape and Reel, 3000 LM324A-SR -40 to 125°C 14-Pin SOIC 3 Tape and Reel, 2500 LM324A-CSR -40 to 85°C 14-Pin SOIC 3 Tape and Reel, 2500 LM324A-TR Note 1 -40 to 125°C 14-Pin TSSOP 3 Tape and Reel, 3000 LM358A XXXX Note 3 LM358A XXXX Note 3 58A XXXX Note 3 LM358A XXXX Note 3 LM358A XXXX Note 3 LM324A XXXX Note 3 LM324A XXXX Note 3 LM324A XXXX Note 3 Note 1: The sample will be ready in 1 month. Note 2: XX is the date code. Note 3: XXXX is date code. www.3peakic.com.cn 3 / 17 Rev.Pre LM321A/ LM358A/ LM324A 36V General Purpose Op Amps Absolute Maximum Ratings Note 1 Parameters Rating Supply Voltage, (+VS)– (-VS) 40 V Input Voltage (-VS) – 0.3 to (+VS) + 0.3 Differential Input Voltage (+VS) - (-VS) Input Current: +IN, –IN ±10mA Note 2 Output Short-Circuit Duration Note 3 Infinite Maximum Junction Temperature 150°C Operating Temperature Range –40 to 125°C Storage Temperature Range –65 to 150°C Lead Temperature (Soldering, 10 sec) 260°C Note 1: Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime. Note 2: The inputs are protected by ESD protection diodes to each power supply. If the input extends more than 300mV beyond the power supply, the input current should be limited to less than 10mA. Note 3: A heat sink may be required to keep the junction temperature below the absolute maximum. This depends on the power supply voltage and how many amplifiers are shorted. Thermal resistance varies with the amount of PC board metal connected to the package. The specified values are for short traces connected to the leads. ESD Rating Symbol Parameter Condition Minimum Level Unit HBM Human Body Model ESD MIL-STD-883H Method 3015.8 4 kV CDM Charged Device Model ESD JEDEC-EIA/JESD22-C101E 2 kV Thermal Information Package Type θJA θJC Unit 5-Pin SOT23 250 81 °C/W 8-Pin SOIC 158 43 °C/W 8-Pin TSSOP 191 44 °C/W 8-Pin MSOP 210 45 °C/W 14-Pin SOIC 120 36 °C/W 14-Pin TSSOP 180 35 °C/W www.3peakic.com.cn 4 / 17 Rev.Pre LM321A/ LM358A/ LM324A 36V General Purpose Op Amps Electrical Characteristics All test condition is VS = 30V, TA = 25°C, RL = 10kΩ, CL =100pF, unless otherwise noted. Symbol Parameter TA Conditions Min Typ Max Unit 36 V 200 μA 300 μA 150 μA 250 μA Power Supply VS Supply Voltage Range 3 110 VS = 30V Operating Range IQ Quiescent Current per Amplifier 100 VS = 5V Operating Range PSRR Power Supply Rejection Ratio 120 dB 90 dB VS = 5V to 36V Operating Range Input Characteristics -3 0.1 3 mV 7 mV 3 mV 7 mV VS = 30V, VCM = 0V to 28V Operating Range VOS -7 Input Offset Voltage -3 0.1 VS = 5V, VCM = 0V to 3V Operating Range VOS TC Input Offset Voltage Drift IB Input Bias Current -7 7 μV/°C 60 pA 600 pA 60 pA 5 nA 20 nA Differential Mode 5 pF Common Mode 5 pF 110 dB 90 dB Operating Range Operating Range IOS Input Offset Current IIN Different Input Current VS = 36V, VID = 36V Operating Range VS = 36V, VID = 36V CIN Av Input Capacitance Open-loop Voltage Gain Operating Range Common-mode Input Voltage VCMR (V-) (V+) - 2 V Range CMRR Common Mode Rejection Ratio 120 dB 90 dB VCM = 0V to 28V Operating Range Output Characteristics VOH, VOL Maximum Output Voltage RLOAD = 10kΩ to 0V 200 300 mV Swing RLOAD = 2kΩ to 0V 1.1 1.3 V VS = 5V, RLOAD = 10kΩ to 0V 5 mV 30 mA 0.9 MHz Maximum Output Voltage VOL Swing Low ISC Output Short-Circuit Current AC Specifications GBW Gain-Bandwidth Product SR Slew Rate G = 1, 2V step 0.5 V/μs tS Settling Time, 0.1% G = 1, 2V step 4 μs www.3peakic.com.cn 5 / 17 Rev.Pre LM321A/ LM358A/ LM324A 36V General Purpose Op Amps Settling Time, 0.01% 3.1 μs PM Phase Margin VS = 30V, RL=1K, CL=100pF 60 ° GM Gain Margin VS = 30V, RL=1K, CL=100pF 15 dB Channel Separation f = 1 kHz to 20 kHz 80 dB Noise Performance EN Input Voltage Noise f = 0.1Hz to 10Hz 3 μVRMS eN Input Voltage Noise Density f = 1kHz 70 nV/√Hz iN Input Current Noise f = 1kHz 3 fA/√Hz THD+N Total Harmonic Distortion and f = 1kHz, G =1, RL = 10kΩ, 0.001 % Noise VOUT = 6VRMS www.3peakic.com.cn 6 / 17 Rev.Pre LM321A/ LM358A/ LM324A 36V General Purpose Op Amps Typical Performance Characteristics VS = ±15V, VCM = 0V, RL = 10kΩ, unless otherwise specified. Figure 1. Quiescent Current vs. Supply Voltage Figure 2. Quiescent Current vs. Temperature 2000 1500 Vos :uV 1000 500 0 -500 -1000 -1500 -2000 -50 Figure 3. Offset Voltage vs. Common Mode Voltage 0 50 Temperture :℃ 100 150 Figure 4. Offset Voltage vs. Temperature 150 200 150 100 50 0 Phase (°) Gain(dB) 100 50 0 -50 -50 -100 -100 0.01 1 100 10k 1M Frequency (Hz) Figure 5. EMIRR+ vs. Frequency www.3peakic.com.cn Figure 6. Open Loop Gain and Phase vs. Frequency 7 / 17 Rev.Pre LM321A/ LM358A/ LM324A 36V General Purpose Op Amps VS = ±15V, VCM = 0V, RL = 10kΩ, unless otherwise specified. Figure 7. PSRR vs. Frequency VS= +5V RL= 1MΩ CL = 30pF 5μV/div Noise(nV/√Hz) 1000 Figure 8. CMRR vs. Frequency 100 10 1 1 10 100 1k 10k 100k 1M Time (1s/div) Frequency(Hz) Figure 9. Voltage Noise Spectral Density vs. Frequency www.3peakic.com.cn Figure 10. 0.1 Hz TO 10 Hz Input Voltage Noise 8 / 17 Rev.Pre LM321A/ LM358A/ LM324A 36V General Purpose Op Amps Tape and Reel Information Order Number Package D1 W1 A0 B0 K0 P0 W0 Pin1 Quadrant LM321A-TR 5-Pin SOT23 180.0 13.1 3.2 3.2 1.4 4.0 8.0 Q3 LM358A-SR 8-Pin SOIC 330.0 17.6 6.4 5.4 2.1 8.0 12.0 Q1 LM358A-VR 8-Pin MSOP 330.0 17.6 5.2 3.3 1.5 8.0 12.0 Q1 LM358A-TSR 8-Pin TSSOP 330.0 17.6 6.8 3.3 1.2 8.0 12.0 Q1 LM324A-SR 14-Pin SOIC 330.0 21.6 6.5 9.0 2.1 8.0 16.0 Q1 LM324A-TR 14-Pin TSSOP 330.0 17.6 6.8 5.4 1.2 8.0 12.0 Q1 www.3peakic.com.cn 9 / 17 Rev.Pre LM321A/ LM358A/ LM324A 36V General Purpose Op Amps Package Outline Dimensions SC70-5 /SOT-353 Dimensions Dimensions In Millimeters In Inches Min Max Min Max A 0.900 1.100 0.035 0.043 A1 0.000 0.100 0.000 0.004 A2 0.900 1.000 0.035 0.039 b 0.150 0.350 0.006 0.014 C 0.080 0.150 0.003 0.006 D 2.000 2.200 0.079 0.087 E 1.150 1.350 0.045 0.053 E1 2.150 2.450 0.085 0.096 e 0.650TYP 0.026TYP e1 1.200 0.047 L 0.525REF 0.021REF L1 0.260 0.460 0.010 0.018 θ 0° 8° 0° 8° Symbol 1.400 0.055 SOT23-5 Dimensions Dimensions In Millimeters In Inches Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.400 0.012 0.016 C 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950TYP 0.037TYP e1 1.800 0.071 L 0.700REF 0.028REF L1 0.300 0.460 0.012 0.024 θ 0° 8° 0° 8° Symbol www.3peakic.com.cn 10 / 17 2.000 0.079 Rev.Pre LM321A/ LM358A/ LM324A 36V General Purpose Op Amps SOP-8 A2 C θ L1 A1 e E D Symbol E1 b 11 / 17 Dimensions In In Millimeters Inches Min Max Min Max A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.330 0.510 0.013 0.020 C 0.190 0.250 0.007 0.010 D 4.780 5.000 0.188 0.197 E 3.800 4.000 0.150 0.157 E1 5.800 6.300 0.228 0.248 e www.3peakic.com.cn Dimensions 1.270 TYP 0.050 TYP L1 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° Rev.Pre LM321A/ LM358A/ LM324A 36V General Purpose Op Amps TSSOP-8 Symbol Dimensions In Millimeters Min Dimensions In Inches Max Min Max D 2.900 3.100 0.114 0.122 E 4.300 4.500 0.169 0.177 b 0.190 0.300 0.007 0.012 c 0.090 0.200 0.004 0.008 E1 6.250 6.550 0.246 0.258 A 1.200 0.047 A2 0.800 1.000 0.031 0.039 A1 0.050 0.150 0.002 0.006 e 0.65(BSC) L 0.500 H 0.25(BSC) θ 1° www.3peakic.com.cn 0.026(BSC) 0.700 0.020 0.028 0.01(BSC) 7° 12 / 17 1° 7° Rev.Pre LM321A/ LM358A/ LM324A 36V General Purpose Op Amps MSOP-8 Dimensions Dimensions In In Millimeters Inches Min Max Min Max A 0.800 1.200 0.031 0.047 A1 0.000 0.200 0.000 0.008 A2 0.760 0.970 0.030 0.038 b 0.30 TYP 0.012 TYP C 0.15 TYP 0.006 TYP D 2.900 e 0.65 TYP E 2.900 3.100 0.114 0.122 E1 4.700 5.100 0.185 0.201 L1 0.410 0.650 0.016 0.026 θ 0° 6° 0° 6° Symbol E E1 A A2 e b D 3.100 0.114 0.122 0.026 A1 R1 R θ L1 www.3peakic.com.cn L L2 13 / 17 Rev.Pre LM321A/ LM358A/ LM324A 36V General Purpose Op Amps DFN-8 1.5*1.5 www.3peakic.com.cn 14 / 17 Rev.Pre LM321A/ LM358A/ LM324A 36V General Purpose Op Amps SOP-14 Dimensions In Millimeters Symbol MIN 1.35 1.60 1.75 A1 0.10 0.15 0.25 A2 1.25 1.45 1.65 A3 0.55 0.65 0.75 b 0.36 b1 0.35 c 0.16 c1 0.15 0.20 0.25 D 8.53 8.63 8.73 E 5.80 6.00 6.20 E1 3.80 3.90 4.00 L 15 / 17 MAX A e www.3peakic.com.cn NOM 0.49 0.40 0.45 0.25 1.27 BSC 0.45 0.60 L1 1.04 REF L2 0.25 BSC 0.80 R 0.07 R1 0.07 h 0.30 θ 0° θ1 6° 8° 10° θ2 6° 8° 10° θ3 5° 7° 9° θ4 5° 7° 9° 0.40 0.50 8° Rev.Pre LM321A/ LM358A/ LM324A 36V General Purpose Op Amps TSSOP-14 Dimensions In Millimeters E1 E A A2 e Symbol c D MIN TYP MAX A - - 1.20 A1 0.05 - 0.15 A2 0.90 1.00 1.05 b 0.20 - 0.28 c 0.10 - 0.19 D 4.86 4.96 5.06 E 6.20 6.40 6.60 E1 4.30 4.40 4.50 e L A1 R1 R 0.65 BSC 0.45 0.60 L1 1.00 REF L2 0.25 BSC 0.75 R 0.09 - - θ 0° - 8° θ L1 www.3peakic.com.cn L L2 16 / 17 Rev.Pre LM321A/ LM358A/ LM324A 36V General Purpose Op Amps 3PEAK and the 3PEAK logo are registered trademarks of 3PEAK INCORPORATED. All other trademarks are the property of their respective owners. www.3peakic.com.cn 17 / 17 Rev.Pre
LM358A-SR 价格&库存
很抱歉,暂时无法提供与“LM358A-SR”相匹配的价格&库存,您可以联系我们找货
LM358A-SR
    • 1+0.23620
    LM358A-SR
      LM358A-SR
      • 5+0.77455
      • 20+0.70620
      • 100+0.63786
      • 500+0.56952
      • 1000+0.53763
      • 2000+0.51485
      库存:2049
      LM358A-SR
        • 2400+0.24506
