DF12NB-40DS-0.5V(51) 数据手册
0.5mm Pitch SMT Board-to-Board Connectors
DF12N Series
Pick & Place Mounting
Sep.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Vacuum Pick-up Area Available for Pick & Place
Mounting Machines.
Fig.1
■Features
1. Wide Variety of Stacking Heights
Stacking heights of 3mm, 3.5mm 4mm and 5mm are provided in addition to the ultra-compact size of 0.5mm pitch.
DF12#(3.0)-*DS-0.5V
Combination Stacking Height
DF12#-*DS-0.5V
DF12#(3.0)-*DP-0.5V
3.0
DF12#(3.5)-*DP-0.5V
3.5
DF12#(4.0)-*DP-0.5V
4.0
DF12#(5.0)-*DP-0.5V
5.0
Header/Receptacle
Note 1 : The (**) after DF12# indicates the stacking height.
Note 2 : The stacking height does not include the soldering paste thickness.
[Stacking Height Variations]
Stacking Height
3.0mm
3.5mm
4.0mm
5.0mm
10pos.
14pos.
20pos.
30pos.
No. of Pos.
32pos.
36pos.
40pos.
50pos.
60pos.
80pos.
2. Pick & Place Mounting
The connector has the vacuum pick-up area to enable automatic mounting with the embossed tape packaging.
(Fig.1)
3. Solder Tabs on the Soldering Portion
In consideration of mounting on FPC, solder tabs are provided on the product in order to prevent solder peeling.
4. 5Gbps Transmission Speed
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2021.5②
1
DF12N Series●0.5mm Pitch SMT Board-to-Board Connectors
■Product Specifications
Ratings
Operating Temperature -55 to +125ç (Note 1) Storage Temperature Range -10 to +60ç (Note 2)
Rated Current 0.3A
Storage Humidity Range -40 to 70% (Note 2)
Rated Voltage 50V AC Operating Humidity Range -40 to 80%
Items
Specifications
Conditions
1. Insulation Resistance
500MΩ min.
100V DC
2. Withstanding Voltage
No flashover or insulation breakdown.
150V AC per min.
3. Contact Resistance
50mΩ max.
20mV AC or less 1kHz, 1mA.
4. Vibration
No electrical discontinuity of 1μs or more
Frequency : 10 to 55 Hz, single amplitude of 0.75mm, 2 hours in each of the 3 directions.
5. Humidity (Steady State) Contact resistance : 50mΩ max. Insulation resistance : 500MΩ min 96 hours at temperature of 40±2ç and humidity of 90% to 95%
6. Temperature Cycle
Contact resistance : 50mΩ max. Insulation resistance : 500MΩ min (-65ç : 30 minutes 5 to 35ç : 3 minutes 125ç : 30 minutes 5 to 35ç : 3 minutes) 5 cycles
7. Mating Durability
50 cycles
8. Resistance to Soldering Heat No deformation of components affecting performance.
SMT Reflow : At the recommended temperature profile
Type Manual soldering : 350ç for 3 seconds
Note 1 : Includes temperature rise due to current flow. (105ç in automotive vibration environment)
Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range
and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation.
■Materials / Finish
Product
Receptacle/Header
Part
Material
Finish
Remarks
Insulator
Polyamide
Black
UL94V-0
Contact
Phosphor Copper
Gold Plated
Solder Tab
Brass
Tin Plated
Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Receptacle
DF12 #(※※)- * DS - 0.5 V(**)
❶
q Series Name
❷
❸
❹
❺
❻
❼
e Stacking Height
: DF12
w Type
3.0
y Contact Pitch : 0.5mm
u Contact Style
: 3.0mm
Blank : 3.5 to 5.0mm
Solder Tab
V : Straight SMT
NB
r No. of Pos. : 10, 14, 20, 30, 32, 36, 40,
NC
50, 60, 80
❽
i Packaging Type
(51) : Embossed Tape Packaging
t Connector Type
(1,000pcs/reel)
DS : Double-row Receptacle
●Header
DF12 #(※※)- * DP - 0.5 V(**)
❶
q Series Name
❷
❸
❹
❺
❻
❼
e Stacking Height
: DF12
w Type
Indication Stacking Height
Solder Tab
NB
NC
3.0
3.0mm
3.5
3.5mm
4.0
4.0mm
5.0
5.0mm
❽
t Connector Type
DP : Double-row Pin Header
u Contact Style
V : Straight SMT
i Packaging Type
rNo. of Pos. : 10, 14, 20, 30, 32, 36, 40,
50, 60, 80
2
(1,000pcs/reel)
■Receptacle
Without Solder Tab
●Stacking Height : 3mm Product
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
DF12NC(3.0)-10DS-0.5V(51)
537-0191-0 51
10
4.6
2.0
3.1
DF12NC(3.0)-14DS-0.5V(51)
537-0192-0 51
14
5.6
3.0
4.1
DF12NC(3.0)-20DS-0.5V(51)
537-0193-0 51
4.5
5.6
DF12NC(3.0)-30DS-0.5V(51)
537-0194-0 51
30
9.6
7.0
8.1
DF12NC(3.0)-32DS-0.5V(51)
537-0195-0 51
32
10.1
7.5
8.6
DF12NC(3.0)-36DS-0.5V(51)
537-0196-0 51
36
11.1
8.5
9.6
DF12NC(3.0)-40DS-0.5V(51)
537-0197-0 51
40
12.1
9.5
10.6
DF12NC(3.0)-50DS-0.5V(51)
537-0198-0 51
50
14.6
12.0
13.1
DF12NC(3.0)-60DS-0.5V(51)
537-0199-0 51
60
17.1
14.5
15.6
DF12NC(3.0)-80DS-0.5V(51)
537-0285-0 51
80
22.1
19.5
20.6
E
Remarks
RoHS
2.2
Without
Solder Tab
YES
●Stacking Height : 3.5 to 5mm Product
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
DF12NC-20DS-0.5V(51)
537-0292-0 51
4.5
5.6
DF12NC-30DS-0.5V(51)
537-0293-0 51
30
9.6
7.0
8.1
DF12NC-32DS-0.5V(51)
537-0294-0 51
32
10.1
7.5
8.6
DF12NC-36DS-0.5V(51)
537-0295-0 51
36
11.1
8.5
9.6
DF12NC-40DS-0.5V(51)
537-0296-0 51
40
12.1
9.5
10.6
DF12NC-50DS-0.5V(51)
537-0297-0 51
50
14.6
12.0
13.1
DF12NC-60DS-0.5V(51)
537-0298-0 51
60
17.1
14.5
15.6
E
Remarks
RoHS
2.7
Without
Solder Tab
YES
Note : Please order the embossed tape packaging product per reel. (1,000pcs/reel)
3
■Receptacle With Solder Tab
F
A
B
C
0.25
E
0.2
1.5
4.6
2.4
1.5
3.6
0.5
P=0.5
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
E
F
DF12NB(3.0)-10DS-0.5V(51)
537-0097-0 51
10
4.6
2.0
3.1
5.6
DF12NB(3.0)-14DS-0.5V(51)
537-0098-0 51
14
5.6
3.0
4.1
6.6
DF12NB(3.0)-20DS-0.5V(51)
537-0099-0 51
4.5
5.6
8.1
DF12NB(3.0)-30DS-0.5V(51)
537-0185-0 51
30
9.6
7.0
8.1
10.6
DF12NB(3.0)-32DS-0.5V(51)
537-0186-0 51
32
10.1 7.5
8.6
11.1
DF12NB(3.0)-36DS-0.5V(51)
537-0187-0 51
36
11.1 8.5
9.6
DF12NB(3.0)-40DS-0.5V(51)
537-0188-0 51
40
12.1 9.5 10.6
2.2
12.1
Remarks
RoHS
With Solder
Tab
YES
13.1
DF12NB(3.0)-50DS-0.5V(51)
537-0189-0 51
50
14.6 12.0 13.1
15.6
DF12NB(3.0)-60DS-0.5V(51)
537-0190-0 51
60
17.1 14.5 15.6
18.1
DF12NB(3.0)-80DS-0.5V(51)
537-0095-0 51
80
22.1 19.5 20.6
23.1
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
F
DF12NB-20DS-0.5V(51)
537-0286-0 51
4.5
5.6
8.1
DF12NB-30DS-0.5V(51)
537-0287-0 51
30
9.6
7.0
8.1
10.6
DF12NB-32DS-0.5V(51)
537-0288-0 51
32
10.1 7.5
8.6
11.1
DF12NB-36DS-0.5V(51)
537-0289-0 51
36
11.1 8.5
9.6
2.7 12.1
537-0290-0 51
40
12.1 9.5 10.6
13.1
DF12NB-50DS-0.5V(51)
537-0291-0 51
50
14.6 12.0 13.1
15.6
DF12NB-60DS-0.5V(51)
537-0096-0 51
60
17.1 14.5 15.6
18.1
4
E
Remarks
RoHS
With Solder
Tab
YES
■Header Without Solder Tab
Part No.
Unit : mm
HRS No.
No. of Pos.
A
B
C
DF12NC(3.0)-10DP-0.5V(51)
537-0396-0 51
10
4.7
2.0
3.2
DF12NC(3.0)-14DP-0.5V(51)
537-0397-0 51
14
5.7
3.0
4.2
DF12NC(3.0)-20DP-0.5V(51)
537-0398-0 51
4.5
5.7
DF12NC(3.0)-30DP-0.5V(51)
537-0399-0 51
30
9.7
7.0
8.2
DF12NC(3.0)-32DP-0.5V(51)
537-0487-0 51
32
10.2
7.5
8.7
DF12NC(3.0)-36DP-0.5V(51)
537-0488-0 51
36
11.2
8.5
9.7
DF12NC(3.0)-40DP-0.5V(51)
537-0489-0 51
40
12.2
9.5
10.7
DF12NC(3.0)-50DP-0.5V(51)
537-0490-0 51
50
14.7
12.0
13.2
DF12NC(3.0)-60DP-0.5V(51)
537-0491-0 51
60
17.2
14.5
15.7
DF12NC(3.0)-80DP-0.5V(51)
537-0492-0 51
80
22.2
19.5
20.7
E
Remarks
RoHS
2.3
Without
Solder Tab
YES
5
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
DF12NC(3.5)-20DP-0.5V(51)
537-0499-0 51
4.5
5.7
DF12NC(3.5)-30DP-0.5V(51)
537-0587-0 51
30
9.7
7.0
8.2
DF12NC(3.5)-36DP-0.5V(51)
537-0588-0 51
36
11.2
8.5
9.7
DF12NC(3.5)-40DP-0.5V(51)
537-0589-0 51
40
12.2
9.5
10.7
DF12NC(3.5)-50DP-0.5V(51)
537-0590-0 51
50
14.7
12.0
13.2
DF12NC(3.5)-60DP-0.5V(51)
537-0591-0 51
60
17.2
14.5
15.7
DF12NC(4.0)-20DP-0.5V(51)
537-0599-0 51
4.5
5.7
DF12NC(4.0)-30DP-0.5V(51)
537-0699-0 51
30
9.7
7.0
8.2
DF12NC(4.0)-32DP-0.5V(51)
537-0872-0 51
32
10.2
7.5
8.7
DF12NC(4.0)-36DP-0.5V(51)
537-0873-0 51
36
11.2
8.5
9.7
DF12NC(4.0)-40DP-0.5V(51)
537-0874-0 51
40
12.2
9.5
10.7
DF12NC(4.0)-50DP-0.5V(51)
537-0875-0 51
50
14.7
12.0
13.2
DF12NC(4.0)-60DP-0.5V(51)
537-0876-0 51
60
17.2
14.5
15.7
DF12NC(5.0)-20DP-0.5V(51)
537-0883-0 51
4.5
5.7
DF12NC(5.0)-30DP-0.5V(51)
537-0884-0 51
30
9.7
7.0
8.2
DF12NC(5.0)-36DP-0.5V(51)
537-0885-0 51
36
11.2
8.5
9.7
DF12NC(5.0)-40DP-0.5V(51)
537-0886-0 51
40
12.2
9.5
10.7
DF12NC(5.0)-50DP-0.5V(51)
537-0887-0 51
50
14.7
12.0
13.2
DF12NC(5.0)-60DP-0.5V(51)
537-0888-0 51
60
17.2
14.5
15.7
6
E
Remarks
RoHS
Without
Solder Tab
YES
2.8
3.3
4.3
■Header With Solder Tab
F
A
B
4.6
1.5
2.45
3.8
0.4
P=0.5
0.25
E
0.25
C
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
E
F
DF12NB(3.0)-10DP-0.5V(51)
537-0299-0 51
10
4.7
2.0
3.2
5.6
DF12NB(3.0)-14DP-0.5V(51)
537-0387-0 51
14
5.7
3.0
4.2
6.6
DF12NB(3.0)-20DP-0.5V(51)
537-0388-0 51
4.5
5.7
8.1
DF12NB(3.0)-30DP-0.5V(51)
537-0389-0 51
30
9.7
7.0
8.2
10.6
DF12NB(3.0)-32DP-0.5V(51)
537-0390-0 51
32
10.2 7.5
8.7
DF12NB(3.0)-36DP-0.5V(51)
537-0391-0 51
36
11.2 8.5
9.7
2.3
11.1
12.1
DF12NB(3.0)-40DP-0.5V(51)
537-0392-0 51
40
12.2 9.5 10.7
13.1
DF12NB(3.0)-50DP-0.5V(51)
537-0393-0 51
50
14.7 12.0 13.2
15.6
DF12NB(3.0)-60DP-0.5V(51)
537-0394-0 51
60
17.2 14.5 15.7
18.1
DF12NB(3.0)-80DP-0.5V(51)
537-0395-0 51
80
22.2 19.5 20.7
23.1
Remarks
RoHS
With Solder
Tab
YES
7
F
A
B
4.6
1.5
2.45
3.8
0.4
P=0.5
0.25
E
0.25
C
Part No.
HRS No.
Unit : mm
No. of Pos.
A
B
C
F
DF12NB(3.5)-20DP-0.5V(51)
537-0493-0 51
4.5
5.7
8.1
DF12NB(3.5)-30DP-0.5V(51)
537-0494-0 51
30
9.7
7.0
8.2
10.6
9.7
DF12NB(3.5)-36DP-0.5V(51)
537-0495-0 51
36
11.2 8.5
DF12NB(3.5)-40DP-0.5V(51)
537-0496-0 51
40
12.2 9.5 10.7
DF12NB(3.5)-50DP-0.5V(51)
537-0497-0 51
50
14.7 12.0 13.2
15.6
DF12NB(3.5)-60DP-0.5V(51)
537-0498-0 51
60
17.2 14.5 15.7
18.1
2.8
RoHS
With Solder
Tab
YES
13.1
DF12NB(4.0)-20DP-0.5V(51)
537-0592-0 51
4.5
5.7
8.1
537-0593-0 51
30
9.7
7.0
8.2
10.6
DF12NB(4.0)-32DP-0.5V(51)
537-0594-0 51
32
10.2 7.5
8.7
11.1
DF12NB(4.0)-36DP-0.5V(51)
537-0595-0 51
36
11.2 8.5
9.7
3.3 12.1
DF12NB(4.0)-40DP-0.5V(51)
537-0596-0 51
40
12.2 9.5 10.7
13.1
DF12NB(4.0)-50DP-0.5V(51)
537-0597-0 51
50
14.7 12.0 13.2
15.6
DF12NB(4.0)-60DP-0.5V(51)
537-0598-0 51
60
17.2 14.5 15.7
18.1
DF12NB(5.0)-20DP-0.5V(51)
537-0877-0 51
4.5
5.7
8.1
DF12NB(5.0)-30DP-0.5V(51)
537-0878-0 51
30
9.7
7.0
8.2
10.6
9.7
DF12NB(5.0)-36DP-0.5V(51)
537-0879-0 51
36
11.2 8.5
DF12NB(5.0)-40DP-0.5V(51)
537-0880-0 51
40
12.2 9.5 10.7
DF12NB(5.0)-50DP-0.5V(51)
537-0881-0 51
50
14.7 12.0 13.2
15.6
DF12NB(5.0)-60DP-0.5V(51)
537-0882-0 51
60
17.2 14.5 15.7
18.1
4.3
Remarks
12.1
DF12NB(4.0)-30DP-0.5V(51)
8
E
12.1
13.1
BEmbossed Carrier Tape Dimensions
H
A±0.3
B±0.1
H-H
A±0.3
B±0.1
H-H
1.75±0.1
C±0.1
.1
+0 0
H
2±0.1
4±0.1
.5
Ø1
C±0.1
.1
+0 0
.5
Ø1
2±0.1
4±0.1
1.75±0.1
●Receptacle
.75
E
D
0.2
0.9
H
Unreeling Direction
0.9
H
Unreeling Direction
E
D
I-I
H
H-H
I
A±0.3
A±0.3
B±0.1
B±0.1
.1
+0 0
H-H
1.75±0.1
C±0.1
.1
+0 0
.5
H
2±0.1
4±0.1
.5
C±0.1
Ø1
2±0.1
4±0.1
1.75±0.1
●Header
Ø1
I
.75
I
I
R0
0.9
H
E
D
Unreeling Direction
0.2
R0
0.9
H
E
D
Unreeling Direction
I-I
Connector
DF12#(3.0)-10DS-0.5V
DF12#(3.0)-14DS-0.5V
DF12#(3.0)-20DS-0.5V
DF12#(3.0)-30DS-0.5V
DF12#(3.0)-32DS-0.5V
DF12#(3.0)-36DS-0.5V
DF12#(3.0)-40DS-0.5V
DF12#(3.0)-50DS-0.5V
DF12#(3.0)-60DS-0.5V
DF12#(3.0)-80DS-0.5V
DF12#(3.0)-10DP-0.5V
DF12#(3.0)-14DP-0.5V
DF12#(3.0)-20DP-0.5V
DF12#(3.0)-30DP-0.5V
DF12#(3.0)-32DP-0.5V
DF12#(3.0)-36DP-0.5V
DF12#(3.0)-40DP-0.5V
DF12#(3.0)-50DP-0.5V
DF12#(3.0)-60DP-0.5V
DF12#(3.0)-80DP-0.5V
DF12#-20DS-0.5V
DF12#-30DS-0.5V
DF12#-32DS-0.5V
DF12#-36DS-0.5V
DF12#-40DS-0.5V
DF12#-50DS-0.5V
DF12#-60DS-0.5V
A
B
16
7.5
C
D
G
0.38 25.5 29.5
32 14.2
44 20.2
7.5
F
17.5 21.5
24 11.5
16
E
0.30
2.6
33.5 37.5
45.5 49.5
0.30
12
17.5 21.5
24 11.5
25.5 29.5
0.38
32 14.2
44 20.2
16 7.5
24 11.5
8
12
8
32 14.2 12
33.5 37.5
45.5 49.5
17.5 21.5
3.1
Connector
DF12#(3.5)-20DP-0.5V
DF12#(3.5)-30DP-0.5V
DF12#(3.5)-36DP-0.5V
DF12#(3.5)-40DP-0.5V
DF12#(3.5)-50DP-0.5V
DF12#(3.5)-60DP-0.5V
DF12#(4.0)-20DP-0.5V
DF12#(4.0)-30DP-0.5V
DF12#(4.0)-32DP-0.5V
DF12#(4.0)-36DP-0.5V
DF12#(4.0)-40DP-0.5V
DF12#(4.0)-50DP-0.5V
DF12#(4.0)-60DP-0.5V
DF12#(5.0)-20DP-0.5V
DF12#(5.0)-30DP-0.5V
DF12#(5.0)-36DP-0.5V
DF12#(5.0)-40DP-0.5V
DF12#(5.0)-50DP-0.5V
DF12#(5.0)-60DP-0.5V
A
16
B
7.5
24 11.5
32 14.2
16 7.5
24 11.5
C
D
12
8
12
8
0.38
3.1
12
8
12
8
E
3.6
F
G
17.5 21.5
0.30
25.5 29.5
0.38
0.30
33.5 37.5
0.38 17.5 21.5
0.30
25.5 29.5
0.38
0.30
32 14.2
16 7.5
33.5 37.5
17.5 21.5
12
24 11.5
8
32 14.2 12
0.38
4.6
25.5 29.5
0.30
0.38 33.5 37.5
0.30
25.5 29.5
0.38
0.30
0.38 33.5 37.5
9
Ø1
3±
Product Name Label
0.2
●Reel Dimensions
Ø80±1
Ø330±2
PS
Lead Hole Depth
F±0.5
G±1
BRecommended PCB mounting pattern
■DF12N with Solder Tab
■DF12N without Solder Tab
Note 1 : Refer to 3 to 8 for dimensions A and B.
Note 2 :
10
If there is a pattern on the shaded area and no resist is applied, it may come into contact with the connector contact.
BPrecautions for Use
1.Recommended Temperature Profile (SMT)
Temperature (ç)
250
250ç
220ç
200
60sec Max.
Soldering
180ç
150
150ç
90 to 120sec
Preheating
100
50
Room
Temperature
100
150
200
250
300
Time (sec)
Note 1 : Up to 2 cycles of Reflow soldering are possible under the
same conditions, provided that there is a return to normal
temperature between the first and second cycle.
Note 2 : The temperature profile indicates the temperature of the
surface of the connector lead.
2.Recommended Manual Soldering Condition (SMT) Soldering iron temperature : 350ç, Soldering time : Within 3 seconds
3.Recommended Screen Thickness and 0.12mm
Open Area Ratio(Pattern Area Ratio)
Open area ratio : 70%
4.Board Warp(SMT)
Maxmum 0.02mm in the connector center area, based on both connector edges
5.Cleaning Condition
Refer to "Nylon Connector Use Handbook".
6.Cautions
■ The receptacle is designed with the contacts exposed. Touching the contacts
with bare hands may cause contact failure or damage to the device due to static
electricity.
■ Insertion/extraction when not mounted to the board may result in damage or
contact deformation.
■ Avoid securing the board only with the connector. Please use other methods to
secure the board.
■ Excessive prying during insertion and extraction may result in damage.
■ Do not apply flux that will result in flux rise during manual soldering.
■ The color of the mold may differ slightly depending on the production lot however
this does not affect the performance.
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
https://www.hirose.com/
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 05/2021. Contents are subject to change without notice for the purpose of improvements.
11
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Hirose Electric:
DF12NB(3.0)-10DP-0.5V(51) DF12NB(3.0)-10DS-0.5V(51) DF12NB(3.0)-14DP-0.5V(51) DF12NB(3.0)-14DS0.5V(51) DF12NB(3.0)-20DP-0.5V(51) DF12NB(3.0)-20DS-0.5V(51) DF12NC-20DS-0.5V(51) DF12NC-30DS0.5V(51) DF12NC-40DS-0.5V(51) DF12NC-50DS-0.5V(51) DF12NC(5.0)-20DP-0.5V(51) DF12NC(5.0)-50DP0.5V(51) DF12NC(4.0)-30DP-0.5V(51) DF12NC(3.0)-50DS-0.5V(51) DF12NC(3.0)-40DS-0.5V(51) DF12NC(3.0)20DP-0.5V(51) DF12NC(3.0)-30DS-0.5V(51) DF12NB-36DS-0.5V(51) DF12NB-40DS-0.5V(51) DF12NB-50DS0.5V(51) DF12NB-60DS-0.5V(51) DF12NC(3.0)-10DP-0.5V(51) DF12NB(5.0)-40DP-0.5V(51) DF12NB(5.0)-50DP0.5V(51) DF12NB(5.0)-60DP-0.5V(51) DF12NB-20DS-0.5V(51) DF12NB(4.0)-40DP-0.5V(51) DF12NB(4.0)-50DP0.5V(51) DF12NB(5.0)-20DP-0.5V(51) DF12NB(5.0)-30DP-0.5V(51) DF12NB(5.0)-36DP-0.5V(51) DF12NB(3.5)50DP-0.5V(51) DF12NB(4.0)-20DP-0.5V(51) DF12NB(4.0)-36DP-0.5V(51) DF12NB(3.0)-80DP-0.5V(51)
DF12NB(3.0)-80DS-0.5V(51) DF12NB(3.0)-40DP-0.5V(51) DF12NB(3.0)-40DS-0.5V(51) DF12NB(3.0)-50DP-0.5V(51)
DF12NB(3.0)-50DS-0.5V(51) DF12NB(3.0)-60DP-0.5V(51) DF12NB(3.0)-60DS-0.5V(51) DF12NB(3.0)-30DP0.5V(51) DF12NB(3.0)-30DS-0.5V(51)
