TXM20.000M0002491LFBEO00T
    TAE(雅晶鑫)
    HC-49S/SMD
    无源晶振 40Ω 20MHz 20pF ±30ppm HC-49S/SMD -20℃~+70℃
TXM20.000M0002491LFBEO00T 数据手册
雅晶鑫 ● TXM20.000M0002491LFBEO00T ELECTRICAL PARAMETERS 谐振器产品技术指标 1.Holder Type(型号规格) 2.Mode of Oscillation(振动模式) 3.Frequency(标称频率) 4.Load Capacitance (CL)(负载电容) 5.Drive Level(激励功率) 6.Equivalent Resistance(谐振电阻) 7.Shunt Capacitance (Co)(静态电容) 8.Motional Capacitance (C1) (动态电容) 9.Frequency Tolerance at 25℃(调整频差) 10.Stability over operation temperance(温度频差) 11.Insulation Resistance (at DC 100V)(绝缘电阻) 12.Operating Temperature Range(工作温度范围) 13.Storage Temperature Range(储存温度范围) 14.Aging(老化率) 15.DLD2 16.FLD2 N/A 17.RLD2 18.SPDB N/A 19.Other(其它) Min Max Units SEAM 49SM Fundamental MHZ 20.000000 pF 20 uw 100 Ω 40 pF 0 7 fF N/A ppm -30 30 ppm ± 30 MΩ 500 -20 70 ℃ -40 85 ℃ ±5 ppm/year N/A Ω N/A ppm N/A Ω N/A db N/A
TXM20.000M0002491LFBEO00T 价格&库存
很抱歉,暂时无法提供与“TXM20.000M0002491LFBEO00T”相匹配的价格&库存,您可以联系我们找货
  • 1+0.17520
  • 100+0.16320
  • 300+0.15120
  • 500+0.13920
  • 2000+0.13320
  • 5000+0.12960
库存:3
