MBRD1045CT
MBRD1045CT
    GOODWORK(固得沃克)
    TO-252
MBRD1045CT 数据手册
MBRD1045CT THRU MBRD10200CT 10 AMP SCHOTTKY BARRIER RECTIFIERS VOLTAGE RANGE 45 to 200 Volts CURRENT 10 Ampere FEATURES * Low forward voltage drop * High current capability * High reliability * High surge current capability * Epitaxial construction TO-252 Unit: mm 1.40 ± 0.2 6.50± 0.2 5.30± 0.2 2.30 ± 0.2 0.50± 0.2 2 3 0.70 ± 0.2 2.3±0.2 * Weight: 2.24 grams +0.28 1.50-0.1 1 0.127 max 2.90 ± 0.2 0.50 ± 0.2 9.90 ± 0.2 * Case: Molded plastic * Epoxy: UL 94V-0 rate flame retardant * Lead: Lead solderable per MIL-STD-202, method 208 guranteed * Polarity: As Marked * Mounting position: Any 5.90 ± 0.2 4 MECHANICAL DATA 4.60±0.2 Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current MBRD MBRD MBRD MBRD MBRD 1045CT 1060CT 10100CT 10150CT 10200CT 45 60 100 150 200 32 45 42 60 70 100 105 150 140 200 .375"(9.5mm) Lead Length at Tc=100 C Peak Forward Surge Current, 8.3 ms single half sine-wave superimposed on rated load (JEDEC method) Maximum Instantaneous Forward Voltage at 10A Maximum DC Reverse Current Ta=25 C at Rated DC Blocking Voltage Typical Junction Capacitance (Note1) Typical Thermal Resistance RqJA (Note 2) Operating Temperature Range TJ Storage Temperature Range TSTG Ta=125 C 150 0.70 0.85 0.90 0.02 0.1 2 5 400 8 -55 +150 -55 +150 V V V A 10 0.55 UNITS A V mA mA pF C/W C C NOTES: 1. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2. Thermal Resistance Junction to Ambient Vertical PC Board Mounting 0.5"(12.7mm) Lead Length. REV 1.0 2021 JAN PAGE:1/2 RATING AND CHARACTERISTIC CURVES (MBRD1045CT THRU MBRD10200CT) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL FORWARD 50 0 0 20 40 60 80 100 120 140 160 180 200 CASE TEMPERATURE,( C) FIG.3-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT MB RD 1 T CT 50 RD CT - 10 10 0C CT 60 01 45 10 10 RD RD MB RD 1 2 5.0 MB 4 10 MB 6 MB 8 02 00 CT 10 INSTANTANEOUS FORWARD CURRENT,(A) AVERAGE FORWARD CURRENT,(A) CHARACTERISTICS 12 1.0 Tj=25 C Pulse Width 300us 1% Duty Cycle 0.1 PEAK FORWARD SURGE CURRENT,(A) 150 .01 120 .1 .3 .5 .7 .9 1.1 1.3 1.5 FORWARD VOLTAGE,(V) 90 8.3ms Single Half Tj=25 C Sine Wave 60 JEDEC method 30 FIG.5 - TYPICAL REVERSE CHARACTERISTICS 0 1 5 50 10 100 100 NUMBER OF CYCLES AT 60Hz REVERSE LEAKAGE CURRENT, (mA) FIG.4-TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE,(pF) 1400 1200 1000 800 600 400 10 Tj=75 C 1.0 Tj=25 C .1 200 0 .01 .05 .1 .5 1 REVERSE VOLTAGE,(V) 5 10 50 100 .01 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) REV 1.0 2021 JAN PAGE:2/2
MBRD1045CT 价格&库存
很抱歉,暂时无法提供与“MBRD1045CT”相匹配的价格&库存,您可以联系我们找货
