A
B
D
3.70[0.146]±0.05
C
9.50[0.374]±0.10
2.60[0.102]
0.60[0.024]
2-Ø2.20[0.087]
3-0.50[0.02]
3-0.60[0.024]
5.05[0.199]5.05[0.199]
14.70[0.579]
5.40[0.213]
3
Circuit diagram
4
C
NO
NC
1
2
Rubber shell
Seal ring
PA66
Silica gel
3
Base
Brass
4
According to sincerity
Pom
5
Contact moving plate
Phosphor bronze
6
Strut
SUS
UNIT
A4
COMMON
MM
DRAWN BY FUYUAN
台普
A2
A1
ROCPU
DATE
REVISION DESCRIPTION
A
ISSUE
B
X.XX
± 0.10
X.X
± 0.15
X
± 0.25
ANGULAR
C
PROJCTED
DATE
2019
CHECKED BY
APPROVAL B
COCO
ALEN
MODEL NO: TP330313000
Https:
www.rocpu.tw
ROCPU TECHNOLONGY CO.,LTD
Copies are issued in strict confidence and shall not be reproduced or copied,or used as the basic of manufacture or sale of apparatus without permission
D
E
1
2
3
4
PRODUCT NAME:
TOLERANCE
A3
REV
G
Technical Parameters
技术参数
1.Electrical Rating: 0.1A 125/250VAC
3A/12VDC;0.1A/48VDC
1.电气额定值:0.1A 125/250VAC
3A/12VDC;0.1A/48VDC
2.Electrical lifetime:100,000 cycles
2.电气寿命:100,000 cycles
3.Mechanical lifetime:100,000 cycles
3.机械寿命:100,00 cycles
4.Contact Resistance:≤100mΩ
4.接触电阻:≤100兆欧
5.Operating force:1.0~3.5N
5.操作力:1.0~3.5N
6.Pretravel:0.3~1.0mm
6.动作行程:0.3~1.0mm
7.Withstand Voltage:Feet and Feet 750V/5S/5mA
Feet and Shell 1500/5S/5mA
7.耐压:脚与脚 750/5s/5mA
脚与壳 1500/5S/5mA
8.Insulation Resistance:≥100MΩ
8.绝缘电阻:≥100MΩ
9.Proof Tracking Index(PTI):175V
9.漏电起痕指数(PTI):175V
10.Ambient temperature:125°
10.环境温度:125°
11.Waterproof grade: IP67
11.防水等级:IP67
12.working temperature:-25~﹢105℃
12.工作温度:-25~﹢105℃
5.00[0.197]
2
5
F
1.40[0.055]
7.50[0.295]
1
E
F
G
5
很抱歉,暂时无法提供与“TP330313000”相匹配的价格&库存,您可以联系我们找货
