5.0SMDJ33CA
5.0SMDJ33CA
    PTTC(聚鼎)
    SMC(DO-214AB)
5.0SMDJ33CA 数据手册
T VS Diode – 5.0SMDJ Series Features          Plastic package, excellent insulation strength. Glass passivated chip junction in SMC package. Excellent voltage clamping capability. Low Zener impedance. 5000W peak pulse power capability on 10/1000s waveform. Typical leakage current less than 1A above 13V. Very fast response time, typically less than 1.0ps from 0 volt to VBR minimum. High temperature soldering guaranteed: 265°C/10 sec. MSL: JEDEC-J-STD-020, Level 1 Applications     I/O interface, VCC bus Telecom Industrial and consumer electronic applications. Relay and electromagnetic valve surge absorption. Agency Approval  UL file no.: E474915 Mechanical and Physical Data   Case: JEDEC SMC molded plastic. Surface mount device, solderable per MIL-STD-750, Method 2026  Polarity: Color band denoted cathode except bidirectional. Maximum Ratings and Thermal Characteristics Parameter Symbol Value Unit PPPM Min 5000 Watt Peak Pulse Current of 10/1000s waveform (Note 1, Fig.3). IPPM See Table Amp Steady State Power Dissipation at TL = 75°C, Lead lengths 0.375”, (9.5mm) (Fig.5). PM(AV) 6.5 Watt IFSM 300 Amp TJ, TSTG -55~150 °C Peak Pulse Power Dissipation on 10/1000s waveform (Note 1, Fig.1). Peak Forward Surge Current, 8.3 ms Single Half Sine Wave Superimposed on Rated Load (Note 2, Fig.6). Operating Junction and Storage Temperature Range. Note: 1. Non-repetitive current pulse, per Fig.3 and derated above TA = 25°C per Fig.2. 2. 8.3ms single half sine wave, or equivalent square wave, Duty cycle = 4 pulses per minutes maximum. Part Number Code 5.0SMDJ □□□ C A - □□□ Packaging Code (T13: Tape with 13” Reel; T7: Tape with 7”) VBR Voltage tolerance (A: 5%; Blank: 10%) C: Bi-directional; Blank: Uni-directional Reverse Stand-Off Voltage or Typical Breakdown Voltage 5.0SMDJ Series (5000W) 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 1 of 6 2017/12/28 Rev: C T VS Diode – 5.0SMDJ Series I-V Curve Characteristics PPPM Peak Pulse Power Dissipation – Maximum power dissipation VR Stand-off Voltage – Maximum voltage that can be applied to the TVS without operation VBR Breakdown Voltage – Maximum voltage that flows through the TVS at a specified test current (IT) VC Clamping Voltage – Peak voltage measured across the TVS at a specified IPPM (Peak Impulse Current) IR Reverse Leakage Current – Current measured at VR VF Forward Voltage Drop for Uni-directional Electrical Characteristics Part Number Marking Reverse Test Breakdown Voltage Stand Off Current VBR (V) @ IT Voltage VR IT Min. Max. (V) (mA) Maximum Clamping Voltage VC (V) @ IPP Maximum Peak Pulse Current IPP (A) Maximum Reverse Leakage IR (A) @ VR Uni Bi Uni Bi 5.0SMDJ11A 5.0SMDJ11CA 5PEN 5BEN 11.0 12.2 13.5 10 18.2 275.0 800 5.0SMDJ12A 5.0SMDJ12CA 5PEP 5BEP 12.0 13.3 14.7 10 19.9 252.0 800 5.0SMDJ13A 5.0SMDJ13CA 5PEQ 5BEQ 13.0 14.4 15.9 10 21.5 233.0 500 5.0SMDJ14A 5.0SMDJ14CA 5PER 5BER 14.0 15.6 17.2 10 23.2 216.0 200 5.0SMDJ15A 5.0SMDJ15CA 5PES 5BES 15.0 16.7 18.5 1 24.4 205.0 100 5.0SMDJ16A 5.0SMDJ16CA 5PET 5BET 16.0 17.8 19.7 1 26.0 193.0 50 5.0SMDJ17A 5.0SMDJ17CA 5PEU 5BEU 17.0 18.9 20.9 1 27.6 181.0 20 5.0SMDJ18A 5.0SMDJ18CA 5PEV 5BEV 18.0 20.0 22.1 1 29.2 172.0 10 5.0SMDJ20A 5.0SMDJ20CA 5PEW 5BEW 20.0 22.2 24.5 1 32.4 155.0 5 5.0SMDJ22A 5.0SMDJ22CA 5PEX 5BEX 22.0 24.4 26.9 1 35.5 141.0 5 5.0SMDJ24A 5.0SMDJ24CA 5PEZ 5BEZ 24.0 26.7 29.5 1 38.9 129.0 5 5.0SMDJ26A 5.0SMDJ26CA 5PFE 5BFE 26.0 28.9 31.9 1 42.1 119.0 5 5.0SMDJ28A 5.0SMDJ28CA 5PFG 5BFG 28.0 31.1 34.4 1 45.4 110.0 5 5.0SMDJ30A 5.0SMDJ30CA 5PFK 5BFK 30.0 33.3 36.8 1 48.4 103.0 5 5.0SMDJ33A 5.0SMDJ33CA 5PFM 5BFM 33.0 36.7 40.6 1 53.3 93.9 5 5.0SMDJ36A 5.0SMDJ36CA 5PFP 5BFP 36.0 40.0 44.2 1 58.1 86.1 5 5.0SMDJ40A 5.0SMDJ40CA 5PFR 5BFR 40.0 44.4 49.1 1 64.5 77.6 5 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 2 of 6 2017/12/28 Rev: C T VS Diode – 5.0SMDJ Series Part Number Marking Reverse Test Breakdown Voltage Stand Off Current VBR (V) @ IT Voltage VR IT Min. Max. (V) (mA) Maximum Clamping Voltage VC (V) @ IPP Maximum Peak Pulse Current IPP (A) Maximum Reverse Leakage IR (A) @ VR Uni Bi Uni Bi 5.0SMDJ43A 5.0SMDJ43CA 5PFT 5BFT 43.0 47.8 52.8 1 69.4 72.1 5 5.0SMDJ45A 5.0SMDJ45CA 5PFV 5BFV 45.0 50.0 55.3 1 72.7 68.8 5 5.0SMDJ48A 5.0SMDJ48CA 5PFX 5BFX 48.0 53.3 58.9 1 77.4 64.7 5 5.0SMDJ51A 5.0SMDJ51CA 5PFZ 5BFZ 51.0 56.7 62.7 1 82.4 60.7 5 5.0SMDJ54A 5.0SMDJ54CA 5RGE 5BGE 54.0 60.0 66.3 1 87.1 57.5 5 5.0SMDJ58A 5.0SMDJ58CA 5PGG 5BGG 58.0 64.4 71.2 1 93.6 53.5 5 5.0SMDJ60A 5.0SMDJ60CA 5PGK 5BGK 60.0 66.7 73.7 1 96.8 51.7 5 5.0SMDJ64A 5.0SMDJ64CA 5PGM 5BGM 64.0 71.1 78.6 1 103.0 48.6 5 5.0SMDJ70A 5.0SMDJ70CA 5PGP 5BGP 70.0 77.8 86.0 1 113.0 44.3 5 5.0SMDJ75A 5.0SMDJ75CA 5PGR 5BGR 75.0 83.3 92.1 1 121.0 41.4 5 5.0SMDJ78A 5.0SMDJ78CA 5PGT 5BGT 78.0 86.7 95.8 1 126.0 39.7 5 5.0SMDJ85A 5.0SMDJ85CA 5PGV 5BGV 85.0 94.4 104.0 1 137.0 36.5 5 5.0SMDJ90A 5.0SMDJ90CA 5PGX 5BGX 90.0 100.0 111.0 1 146.0 34.3 5 5.0SMDJ100A 5.0SMDJ100CA 5PGZ 5BGZ 100.0 111.0 123.0 1 162.0 30.9 5 5.0SMDJ110A 5.0SMDJ110CA 5PHE 5BHE 110.0 122.0 135.0 1 177.0 28.3 5 5.0SMDJ120A 5.0SMDJ120CA 5PHG 5BHG 120.0 133.0 147.0 1 193.0 26.0 5 5.0SMDJ130A 5.0SMDJ130CA 5PHK 5BHK 130.0 144.0 159.0 1 209.0 24.0 5 5.0SMDJ150A 5.0SMDJ150CA 5PHM 5BHM 150.0 167.0 185.0 1 243.0 20.6 5 5.0SMDJ160A 5.0SMDJ160CA 5PHP 5BHP 160.0 178.0 197.0 1 259.0 19.3 5 5.0SMDJ170A 5.0SMDJ170CA 5PHR 5BHR 170.0 189.0 209.0 1 275.0 18.2 5 5.0SMDJ180A 5.0SMDJ180CA 5PHT 5BHT 180.0 200.0 220.0 1 291.0 17.1 5 5.0SMDJ190A 5.0SMDJ190CA 5PHV 5BHV 190.0 211.0 232.0 1 307.8 16.2 5 5.0SMDJ200A 5.0SMDJ200CA 5PHW 5BHW 200.0 224.0 247.0 1 324.0 15.4 5 5.0SMDJ220A 5.0SMDJ220CA 5PHX 5BHX 220.0 246.0 272.0 1 356.0 14.0 5 5.0SMDJ250A 5.0SMDJ250CA 5PHZ 5BHZ 250.0 279.0 309.0 1 405.0 12.3 5 5.0SMDJ300A 5.0SMDJ300CA 5PJE 5BJE 300.0 335.0 371.0 1 486.0 10.3 5 5.0SMDJ350A 5.0SMDJ350CA 5PJG 5BJG 350.0 391.0 432.0 1 567.0 8.8 5 5.0SMDJ400A 5.0SMDJ400CA 5PJK 5BJK 400.0 447.0 494.0 1 648.0 7.7 5 5.0SMDJ440A 5.0SMDJ440CA 5PJM 5BJM 440.0 492.0 543.0 1 713.0 7.0 5 Note: 1. For bi-directional type having VR of 10 volts and less, the IR limit is double. 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 3 of 6 2017/12/28 Rev: C T VS Diode – 5.0SMDJ Series Ratings and Characteristic Curves Fig 1 - Peak Pulse Power Rating Curve Fig 2 - Pulse Derating Curve Fig 3 - Pulse Waveform Fig 4 – Typical Junction Capacitance Uni-directional Fig 5 – Steady State Power Dissipation Derating Curve Fig 6 – Maximum Non-Repetitive Forward Surge Current (Uni-directional Only) 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 4 of 6 2017/12/28 Rev: C T VS Diode – 5.0SMDJ Series Marking Definitions PolyTrans Trade mark Lot No Marking Code Cathode Band (For Uni-directional product only) Physical Dimensions Dimension A B C D E F G H I J K L Millimeters Inches Min Max Min Max 2.90 6.60 5.59 2.20 0.76 7.75 0.15 3.30 2.40 2.40 3.20 7.11 6.22 2.80 1.52 0.20 8.13 0.31 4.20 - 0.114 0.260 0.220 0.087 0.030 0.305 0.006 0.129 0.094 0.094 0.126 0.280 0.245 0.110 0.060 0.008 0.320 0.012 0.165 - Lead Free Reflow Soldering Recommendations Preheat - Temperature Min (Ts_min) - Temperature Max (Ts_max) - Time (Ts_min to Ts_max) - Average Ramp-Up Rate 150ºC 200ºC 60-180 seconds 1~3ºC/second Peak Temperature 260ºC max. Time within 5ºC of actual Peak Temperature (tp) 40 seconds max. Ramp-Down Rate 6 ºC /second max. Note: If the soldering temperatures exceed the recommended profile, devices may not meet the performance requirements. 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 5 of 6 2017/12/28 Rev: C T VS Diode – 5.0SMDJ Series Packaging Information Part Number Packaging Code Component Package Quantity 5.0SMDJ Series 5.0SMDJ Series T13 T7 DO-214AB DO-214AB 3000 500 Packaging Option Tape & Reel – 16mm tape/13” reel Tape & Reel – 16mm tape/7” reel Packaging Specification EIA STD RS-481 EIA STD RS-481 Tape and Reel Specifications 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 6 of 6 2017/12/28 Rev: C
5.0SMDJ33CA 价格&库存
很抱歉,暂时无法提供与“5.0SMDJ33CA”相匹配的价格&库存,您可以联系我们找货
