R-0
ITEM
P/N
Page
Common Mode Filter
ICMF112P350MFR
1
Data Sheet
- ITEM
COMMON MODE FILTER
- PART NO
ICMF112P350MFR
- CONDITION : 1.
2.
3.
4.
R-0
ITEM
P/N
Page
Common Mode Filter
ICMF112P350MFR
2
1. Generals
This specification covers the engineering requirements for the ICMF112P350MFR
(Common Mode Filter)
2. Features
Effective for suppressing common mode noise and almost no effect for high speed differential
data line
Ultra low profile (1.27ⅹ1.0ⅹ0.6mm)
Ceramic multilayer type SMD component
Non-polarized product
It is a product conforming to RoHS directive.
3. Applications
LVDS lines in notebook computers
USB2.0, UBS3.1 Gen 1, IEEE1394, DVI, HDMI lines in PDP, LCD TV, DVD Player, PC, Audio player,
DSC
MDDI, MIPI in mobile phone
4. Product specifications
4. 1 Part number code
ICMF
①
11
②
2P
③
350
④
M
⑤
F
⑥
R
⑦
① Series name of ICT’s Common Mode Filter
② Dimensions, 1.27mm (L) ⅹ 1.0mm (W)
③ The Number of lines, 2P = 2 lines
④ Common Mode Impedance (at 100MHz), 350 = 35Ω
⑤Tolerance of common mode impedance, M= ±25%
⑥ Type of electrode plating: F= Lead Free
⑦ Packing Type, R= Reel
R-0
ITEM
P/N
Page
Common Mode Filter
ICMF112P350MFR
3
4. 2 Specification of electrical characteristics
Characteristics
Common Mode
Impedance
Resistance
Insulation
Resistance
Rated
Current
symbol
ZCM
RDC
IRCR
IR
Units
Ω
Ω
MΩ
mA
Test
Condition
@100MHz
25℃±2℃
5V
25℃±2℃
Value
35(±25%)
Max 4.0
Min 10
Max 100
CTF
- Impedance Curves
1000
Z11
- Transmission characteristics (S-parameter)
S21
LOG - LOG
LOG
10 dB/REF 0 dB
-3
Common Mode
100
10
Differential Mode
Insertion loss(dB)
IMPEDANCE ()
Common Mode
Differential Mode
-6
-9
-12
-15
1
1M
10M
100M
FREQUENCY (Hz)
1G
1M
10M
100M
1G
FREQUENCY(Hz)
4. 3 Operating Temperature
DESCRIPTION
REQUIREMENTS
-40℃ ∼ + 85℃
(including self-temperature rise)
R-0
ITEM
P/N
Page
Common Mode Filter
ICMF112P350MFR
4
5. Equivalent Circuit & Recommended Foot print & Stencil Mask
Unit : mm
Stencil Mask T : 0.10mm
①
②
④
③
[ Equivalent circuit ]
[ Foot print ]
[ Stencil Mask ]
6. Appearance and Dimension
Unit : mm
0.1
R-0
ITEM
P/N
Page
Common Mode Filter
ICMF112P350MFR
5
7. Test method of Electrical property
- PIN INDEX
ITEM
DESCRIPTION
SOURCE
EQUIPMENT
Rdc
Pin 1 to 4, 2 to 3
10mA DC Source
Source Meter
CM Impedance
Pin 1-2(Short) to Pin 3-4(Short)
LCR Meter (3GHz)
7. 1 Rdc (Model: KEITHLEY 2400)
- Off power and On power.
- Press button ‘Ω’ of MEAS.
- Measure Rdc value using test fixture.
Terminal
Terminal
7. 2 Common Mode Impedance (Model: Agilent 4287A)
- Calibrate equipment
- Measure CM Impedance (at 100MHz) using test fixture.
Terminal
Terminal
R-0
ITEM
P/N
Page
Common Mode Filter
ICMF112P350MFR
6
8. Reflow condition
8. 1 Recommended soldering profile (Lead-free condition)
Dwell: max 260℃-10sec
185℃
160℃
Δ T≤
220℃
130
250℃
ΔT ≤130℃
30~50 sec
30~50 sec
Soldering Soldering
Pre-heating
110 ±10 sec
Gradual Cooling
25℃
60 sec
Time (sec)
8. 2 Recommended Lead-free solder paste
- Supplier : Tamura Donghwa
- Main composition : Sn-Ag-Cu
- Ratio of composition : 96.5%-3.0%-0.5%
8. 3 Recommended hand solder
- Max Temperature: Max 380 ℃(Max 5sec)
R-0
ITEM
P/N
Page
Common Mode Filter
ICMF112P350MFR
7
9. Packing specification
9. 1 Taping figure
9. 2 Carrier tape dimensions
Unit : mm
SYMBOL
DIMENSION
11
A
B
1.15
1.5
0.05
0.05
W
8.0
+0.30
-0.10
F
E
P1
P2
P0
D
t
3.5
1.75
4.0
2.0
4.0
1.55
0.75
0.05
0.05
0.10
0.05
0.10
0.03
0.05
R-0
ITEM
P/N
Page
Common Mode Filter
ICMF112P350MFR
8
9. 3 Reel dimensions
(1) Reel Materials: Polystyrene
(2) Label
(3) Taping
- Standard Packing Quantity per Reel (178)
- Paper Tape: 4,000pcs
Unit : mm
CODE
A
B
C
D
E
W
t
R
DIMENSION
1782
Min. 50
130.5
200.8
3.00.5
101.5
1.30.2
1.00.2
9. 4 Label code
ICMF112P350MFR
K01218TA
B
001
QTY 4,000 PCS
ICMF112P350MFR
K01218TA
1210, 2P, 35ohm
- P/N : Part Number
- L/N : Lot Number
- C/N : Customer Number
- SPEC : Size, Line numbers & CM Impedance
- DATE : Date code
- Q’TY : Quantity
190101
4,000
R-0
ITEM
P/N
Page
Common Mode Filter
ICMF112P350MFR
9
9. 5 Reel packing
Part Number / Company Name
MADE IN KOREA (Country of region )
(1)
(2)
Product box material : Card board
5 Reels in each SPQ Box
(3)
PQ Box contains 10 SPQ Boxes (50 Reels)
Packing box + Product weight
Size
L x W x H(mm)
Product
Common Mode
Filter
Common Mode
ESD Filter
Size
weight(g)
/1 unit
S-box + 5reel
M-box + 5S-box
L-box + 10S-box
185 x 70 x 185
370 x 190 x 200
380 x 370 x 200
Total(g)
Chip(g)
Total(g)
Chip(g)
Total(g)
Chip(g)
0806
0.00124
317
62
1954
310
4596
620
1210
0.00262
307
52
1906
262
4500
524
2012
0.0075
405
150
2394
750
5476
1500
0806
0.00128
319
64
1964
320
4616
640
1210
0.0048
351
96
2124
480
4936
960
1608
0.00237
701
47
3515
237
7017
474
2012
0.00756
406
151
2400
756
5488
1512
很抱歉,暂时无法提供与“ICMF112P350MFR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.70989
- 50+0.58029
- 150+0.51549
- 500+0.46689
