ITEM
P/N
Page
Common Mode Filter
ICMF212P900MFR
1
Data Sheet
- ITEM
COMMON MODE FILTER
- PART NO
ICMF212P900MFR
- CONDITION : 1.
2.
3.
4.
ITEM
P/N
Page
Common Mode Filter
ICMF212P900MFR
2
1. GENERALS
This specification covers the engineering requirements for the ICMF212P900MFR
(Common Mode Filter)
2. FEATURES
Effective for suppressing common mode noise and almost no effect for high speed differential
data line
Ultra low profile (2.0ⅹ1.2ⅹ0.8mm)
Ceramic multilayer type SMD component
Non-polarized product
It is a product conforming to RoHS directive.
3. APPLICATIONS
LVDS lines in notebook computers
USB2.0, IEEE1394, DVI, HDMI lines in PDP, LCD TV, DVD Player, PC, Audio player, DSC
MDDI, MIPI in mobile phone
4. PRODUCT SPECIFICATIONS
4. 1 PART NUMBER CODE
ICMF
①
21
②
2P
③
900
④
M
⑤
F
⑥
R
⑦
① Series name of ICT’s Common Mode Filter
② Dimensions, 2.0mm (L) ⅹ 1.2mm (W)
③ The Number of lines, 2P = 2 lines
④ Common Mode Impedance (at 100MHz), 900= 90Ω
⑤Tolerance of common mode impedance, M= ±25%
⑥ Type of electrode plating: F= Lead Free
⑦ Packing Type, R= Reel
ITEM
P/N
Page
Common Mode Filter
ICMF212P900MFR
3
4. 2 SPECIFICATION OF ELECTRICAL CHARACTERISTICS
Common Mode
Impedance
Characteristics
Resistance
Insulation
Resistance
Rated
Current
CTF
symbol
ZCM
RDC
IRCR
IR
Units
Ω
Ω
MΩ
mA
Test
Condition
@100MHz
25℃±2℃
10V
25℃±2℃
Value
90(±25%)
Max 4.0
Min 10
Max 100
- Impedance Curves
Impedance()
1000
100
10
1
1M
10M
100M
1G
Frequency(Hz)
- Transmission characteristics (S-parameter)
Differential mode
Insertion loss(dB)
-5
-10
-15
-20
-25
-30
1M
10M
100M
Frequency(Hz)
1G
ITEM
P/N
Page
Common Mode Filter
ICMF212P900MFR
4
4. 3 OPERATING TEMPERATURE
DESCRIPTION
REQUIREMENTS
Operating Temperature
-40℃ ∼ + 85℃
5. Equivalent Circuit & Recommended Foot print & Stencil Mask
Unit : mm
Stencil Mask T : 0.10mm
①
②
③
④
[ EQUIVALENT CIRCUIT ]
[ Foot print ]
[ Stencil Mask ]
6. MECHANICAL PROPERTY
6. 1 Appearance and Dimension
Unit : mm
ITEM
P/N
Page
Common Mode Filter
ICMF212P900MFR
5
7. TEST METHOD OF ELECTRICAL PROPERTY
- PIN INDEX
ITEM
Rdc
CM
Impedance
DESCRIPTION
Pin 1 to 3, 2 to 4
SOURCE
EQUIPMENT
10mA DC Source
Source Meter
Pin 1-2(Short) to Pin 3-4(Short)
LCR Meter (3GHz)
7. 1 Rdc (Model: KEITHLEY 2400)
- Off power and On power.
- Press button ‘Ω’ of MEAS.
- Measure Rdc value using test fixture.
Terminal
Terminal
7. 2 Common Mode Impedance (Model: Agilent 4287A)
- Calibrate equipment
- Measure CM Impedance (at 100MHz) using test fixture.
Terminal
Terminal
ITEM
P/N
Page
Common Mode Filter
ICMF212P900MFR
6
8. REFLOW CONDITION
8. 1 RECOMMENDED SOLDERING PROFILE (Lead-free condition)
Dwell: max 260℃-10sec
185℃
160℃
Δ T≤
220℃
130
250℃
ΔT ≤130℃
30~50 sec
30~50 sec
Soldering Soldering
Pre-heating
110 ± 10 sec
Gradual Cooling
25℃
60 sec
Time (sec)
8. 2 RECOMMENDED LEAD-FREE SOLDER PASTE
- Supplier : Tamura Donghwa
- Main composition : Sn-Ag-Cu
- Ratio of composition : 96.5%-3.0%-0.5%
8. 3 RECOMMENDED HAND SOLDER
- Max Temperature: Max 380 ℃(Max 5sec)
ITEM
P/N
Page
Common Mode Filter
ICMF212P900MFR
7
9. PACKING SPECIFICATION
9. 1 TAPING FIGURE
9. 2 CARRIER TAPE DIMENSIONS
Unit : mm
SYMBOL
DIMENSION
21
A
B
W
F
E
P1
P2
P0
D
T
1.55
0.05
2.3
0.05
8.0
0.1
3.5
0.05
1.75
0.05
4.0
0.1
2.0
0.05
4.0
0.1
1.55
0.03
0.95
0.05
ITEM
P/N
Page
Common Mode Filter
ICMF212P900MFR
8
9. 3 REEL DIMENSIONS
(1) Reel Materials: Polystyrene
(2) Label
(3) Taping
- Standard Packing Quantity per Reel (178)
- Paper Tape: 4,000pcs
Unit : mm
CODE
A
B
C
D
E
W
t
R
DIMENSION
1782
Min. 50
130.5
200.8
3.00.5
101.5
1.30.2
1.00.2
9. 4 LABEL CODE
ICMF212P900MFR
K01218LA B
001
QTY 4,000 PCS
ICMF212P900MFR
K01218LA
2012, 2P, 90ohm
- P/N : Part Number
- L/N : Lot Number
- C/N : Customer Number
- SPEC : Size, Line numbers & CM Impedance
- DATE : Date code
- Q’TY : Quantity
150401
4,000
ITEM
P/N
Page
Common Mode Filter
ICMF212P900MFR
9
9. 5 REEL PACKING
Part Number / Company Name
MADE IN KOREA (Country of region )
(1)
(2)
Product box material : Card board
5 Reels in each SPQ Box
(3)
PQ Box contains 10 SPQ Boxes (50 Reels)
Packing box + Product weight
Size
L x W x H(mm)
Product
Common Mode
Filter
Common Mode
ESD Filter
Size
weight(g)
/1 unit
S-box + 5reel
M-box + 5S-box
L-box + 10S-box
185 x 70 x 185
370 x 190 x 200
380 x 370 x 200
Total(g)
Chip(g)
Total(g)
Chip(g)
Total(g)
Chip(g)
0806
0.00124
643
62
3215
310
6147
620
1210
0.00480
750
96
3758
480
7503
960
2012
0.00750
804
150
4028
750
8043
1500
0806
0.00128
646
65
3230
325
6177
650
1210
0.00490
752
98
3768
490
7523
980
1608
0.00237
701
47
3515
237
7017
474
2012
0.00760
806
152
4038
760
8063
1520
很抱歉,暂时无法提供与“ICMF212P900MFR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.86082
- 50+0.70766
- 150+0.63108
- 500+0.57365
- 2500+0.52075
