APPROVAL SHEET
Customer’s Approval
Certificate
Approval Specification
TO:
Checked & Approved by:
Part No.:
Date:
Customer’s Part No.:
Please return this copy as a certification of
your approval
BEIJING ZHONGXUN SIFANG SCIENCE &
TECHNOLOGY CO.,LTD.
Tel:
Fax:
E-mail:
+86-010-58937383
+86-010-58937263
zxsf_sales@163.com
REACH
QQ:
3037058772
Website: http://www.bjzxsf.net http://www.sfsaw.com
Add:
No 201, Block A. Building 3. Yongjie Beilu
Yongfeng high-tech industrial base
Haidian District Beijing city
Part No.
SFR315K
Pages
7
Date
2015/1/21
Revision
1.0
Prepared by:
Checked by:
Approved by:
SAW Resonator
SFR315K
315.00MHz
History Record
Date
Part No.
Version No.
Please read notes at the end of this document. - 2 -
Modify Content
www.bjzxsf.net
Remark
www. sfsaw.com 2015/01/21
SAW Resonator
SFR315K
315.00MHz
Features
1-port Resonator
Ceramic Package for Surface Mounted Technology (SMT)
RoHS compatible
Package size 3.20x2.50x0.70mm3
Electrostatic Sensitive Device(ESD)
Application
Typical Low-Power Transmitter Application
Package Dimensions (DCC4C)
Typical Local Oscillator Application
Pin Configuration
1
Input/ Output
3
Output/ Input
2,4
Please read notes at the end of this document. - 3 -
www.bjzxsf.net
Ground
SAW Resonator
SFR315K
315.00MHz
Marki
SFR315K
SF
Trademark
R
SAW Resonator
315K
Part number
Test Circuit
Equivalent LC Model
Performance
Maximum Rating
Item
Value
Unit
VDC
±30
V
T
-40 ~ +85
Storage Temperature
Tstg
-40 ~ +85
RF Power Dissipation
P
15
dBm
DC Voltage
Operation Temperature
Please read notes at the end of this document. - 4 -
www.bjzxsf.net
SAW Resonator
SFR315K
315.00MHz
Electronic Characteristics
Test Temperature:
25℃±2℃
Terminating source impedance: 50Ω
Terminating load impedance: 50Ω
Item
Center
Frequency
Frequency
Aging
Maximum
Unit
315.00
MHz
△fc
±75
KHz
IL
1.3
Unloaded Q
QU
21571
50Ω Loaded Q
QL
3559
Absolute Value during the First Year
|fA|
≤10
Tolerance from 315.00MHz
DC Insulation Resistance between Any Two Pins
RF
Equivalent
RLC
Model
Typical
fc
Absolute Frequency
Insertion Loss(min)
Quality Factor
Minimum
2.0
dB
ppm/yr
1.0
MΩ
Ω
Motional Resistance
RM
19.7
Motional Inductance
LM
215.5
µH
Motional Capacitance
CM
1.18
fF
Static Capacitance
C0
1.80
2.08
22.0
2.4
pF
Frequency Response
Please read notes at the end of this document. - 5 -
www.bjzxsf.net
SAW Resonator
SFR315K
315.00MHz
Reliability(The SAW components shall remain electrical performance after tests)
No.
Test item
1
Temperature
Storage
2
Humidity Test
Test condition
(1) Temperature: 85℃±2℃ , Duration: 250h , Recovery time: 2h±0.5h
(2) Temperature: –40℃±3℃ , Duration: 250h ,Recovery time: 2h±0.5h
Conditions: 60℃±2℃ , 90~95% RH
Duration: 250h
Heat cycle conditions: TA=-40℃ ±3℃ , TB=85℃±2℃, t1=t2=30min, Switch
3
Thermal Shock
4
Vibration Fatigue
5
Drop Test
6
time: ≤3min , Cycle time: 100 times , Recovery time : 2h±0.5h.
Solder Ability Test
Frequency of vibration: 10~55Hz
Amplitude:1.5mm
Directions: X,Y and Z
Duration: 2h
Cycle time: 10 times
Height: 1.0m
Temperature: 245℃±5℃
Duration: 3.0s--5.0s
Depth: DIP--2/3 , SMD--1/5
(1)Thickness of PCB:1mm , Solder condition: 260℃±5℃ , Duration: 10±1s
7
Resistance to
Soldering Heat
(2)Temperature of Soldering Iron: 350℃±10℃ , Duration: 3~4s ,
Recovery time : 2 ± 0.5h
Recommended Reflow Soldering Diagram
280
Max peak
260+0/-5℃ 20-40sec
260
240
220
Temp (Deg ℃)
200
180
160
140
120
100
80
Pre-heating 50-180℃
heating 220℃
60-90sec
50-80sec
60
40
20 40 60 80 100 120 140 160 180 200 220 240 260 280 300 320 340 360 380
Time (Sec)
Please read notes at the end of this document. - 6 -
www.bjzxsf.net
SAW Resonator
SFR315K
315.00MHz
Notes
1. As a result of the particularity of inner structure of SAW products, it easy to be breakdown by
electrostatic, so we should pay attention to ESD protect in the test.
2. Static voltage between signal load and ground may cause deterioration and destruction of the
component. Please avoid static voltage.
3. Ultrasonic cleaning may cause deterioration and destruction of the component. Please avoid ultrasonic
cleaning.
4. Only leads of component may be soldered. Please avoid soldering another part of component.
5. There is a close relationship between the device's performance and matching network. The
specifications of this device are based on the test circuit shown above. L and C values may change
depending on board layout. Values shown are intended as a guide only.
Please read notes at the end of this document. - 7 -
www.bjzxsf.net
很抱歉,暂时无法提供与“SFR315K”相匹配的价格&库存,您可以联系我们找货
