Metallized Polypropylene Film Interference Suppression Capacitors
金属化聚丙烯膜抑制电磁电源干扰用电容器
(MP1-Class X1 440VAC Series)
■ 引用标准 Reference standards
GB/T6346.14-2015/ UL60384-14/VDE0565-1/ CSA E60384-14
IEC60384-14 /EN60384-14
■ 结构 Structure
介质:(金属化)聚丙烯膜
封装:阻燃环氧树脂,符合 UL94 V-0
外壳:阻燃 PBT 塑壳,符合 UL94 V-0
Dielectric: Metallized Polypropylene film
Encapsulation: Flame retardant epoxy resin, conforming to UL94 V-0
Shell: Flame retardant PBT plastic shell, conforming to UL94 V-0
典型应用 Typical
Application
跨线、抑制突波、交流场合 EMI 滤波;电源开关等。如:灯具、电源等
Interlines, Surge suppression, Across-in-line as EMI filter;
Power switch etc. Such as: Lamps, Power Sources etc.
特点 Features
外观一致性好;有良好自愈性
抗湿性强;高耐温
长寿命,耐过电压优良
符合 RoHS 及 REACH 环保标准
电性能规范
Good appearance consistency; Good self-healing property;
Good resistance to humidity; Can withstand high temperature;
Long lifetime; Good ability to withstand surge voltage.
Compliance with RoHs & REACH requirements.
Performance Specifications
气候类别 Climate category
40/110/56
阻燃等级 Passive flammability class
B
额定电压 Rated Voltage
440VAC
容量误差 Capacitance Tolerance
K: ±10%
容量范围
0.0022μF~4.7μF
Capacitance Range
Test Condition:
耐电压
No breakdown or electric arcing
Withstand Voltage
Terminal to terminal:4.3UR(Vdc),5S
Terminal to shell:2380VAC 60S
损耗角
≤0.0020
10KHZ
CR≤1.0μF
Test Condition :
Dissipation factor
≤0.0010
1KHZ
CR>1.0μF
绝缘电阻或时间常数
CR≤0.33μF IR≥15000MΩ
Insulation Resistance
CR>0.33μF IR≥5000S
最大脉冲爬升速率
P=10mm
dV / dt = 500V/μs
P=15mm
dV / dt = 400V/μs
P=22.5mm dV / dt = 200V/μs
P=27.5mm dV / dt = 150V/μs
P=37.5mm dV / dt = 80V/μs
Max. Pulse Rise Time
(dV / dt)
20℃, 1KHz, 1Vrms
20℃ 1V
Test Condition : 20℃
100V
1 min
金属化聚丙烯膜抑制电磁电源干扰用电容器
电性能规范 Performance Specifications
稳态湿热
温度 Temp.:40±2℃
无可见损伤,标志清晰
Steady-state
Damp-heat Test
相对湿度 Humidity:93%RH
no visible damage,clear mark
绝缘电阻 IR:≥ 额定值的 50%
IR:≥ 50% of Rated value
持续时间 Duration Time:56 Days
容量变化(相对初始值):
Capacitance change:△C/C≤±5%
损耗角增加 Dissipation factor:
Rise ≤0.0080(10KHZ),CR≤1uF
Rise ≤0.0050(1KHZ),CR>1uF
绝缘电阻 Insulation Resistance
耐久性试验
温度 Temp.: +110℃,
Endurance Test
施加电压:1.25×额定电压(每小时增加
IR:≥ 50% of rated value
电压到 1000Vac,0.1 秒,1 次)
容量变化(相对初始值):△C/C≤±10%
Test Voltage:
Capacitance change: △C/C≤±10%
1.25 Times Rated Voltage(Rise the
voltage to 1000Vac for .01s once
per hours )
持续时间 Duration Time: 1000H
安规认证
Safety Certification
认证标志
额定电压
证书号码
引用标准
认证国家
Certification
Rated Voltage
Certificate No.
Reference standard
Certification Country
UL/CUL
440VAC
E319615
UL60384-14
VDE
440VAC
40025029
EN60384-14
德国 Germany
ENEC
440VAC
40025029
EN60384-14
欧盟 Europe
CQC
440VAC
CQC09001032856
GB/T6346.14-2015
中国 China
产品编码说明
美国、加拿大
America / Canada
Part No. Description:
15 位产品编码如下:
The Part No. Is total 15 digits, details as follow:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
M
6
R
8
Digit 1-3
P
1
1
K
型号代码 Product Name Code
4
4
D
MP1= Class X1 Capacitors
Digit 4-6
标称容量 Rated Capacitance Value
For example : 104= 10×104pF = 0.1F
Digit 7
容量偏差 Capacitance Tolerance
K=±10%
Digit 8-9
额定电压 Rated Voltage Code
44=440VAC
Digit 10-11 壳号 Plastic shell code
Digit 12
塑壳颜色 Plastic Shell Color
R = Grey Color with LOGO on the shell top
Digit 13
线径代码 Line diameter code
6=0.6 8=0.8
Digit 14-15 成型或内部识别码 Forming Type or Internal Use
金属化聚丙烯膜抑制电磁电源干扰用电容器
料号明细及尺寸 Part No. List and Dimensions
容量
成品编码
等级
电压
尺寸 Dimension (mm)
Part No.
Class
Voltage
Capacitance
(μF)
MP1222K44B2R6**
X1
440VAC
0.0022
10
5
11
7.5
0.6
MP1272K44B2R6**
X1
440VAC
0.0027
10
5
11
7.5
0.6
MP1332K44B2R6**
X1
440VAC
0.0033
10
5
11
7.5
0.6
MP1392K44B2R6**
X1
440VAC
0.0039
10
5
11
7.5
0.6
MP1472K44B2R6**
X1
440VAC
0.0047
10
5
11
7.5
0.6
MP1562K44B2R6**
X1
440VAC
0.0056
10
5
11
7.5
0.6
MP1682K44B2R6**
X1
440VAC
0.0068
10
5
11
7.5
0.6
MP1822K44B2R6**
X1
440VAC
0.0082
10
5
11
7.5
0.6
MP1103K44B2R6**
X1
440VAC
0.01
10
5
11
7.5
0.6
MP1123K44B3R6**
X1
440VAC
0.012
10
6
12
7.5
0.6
MP1222K44C2R6**
X1
440VAC
0.0022
13
5
11
10
0.6
MP1272K44C2R6**
X1
440VAC
0.0027
13
5
11
10
0.6
MP1332K44C2R6**
X1
440VAC
0.0033
13
5
11
10
0.6
MP1392K44C2R6**
X1
440VAC
0.0039
13
5
11
10
0.6
MP1472K44C2R6**
X1
440VAC
0.0047
13
5
11
10
0.6
MP1562K44C2R6**
X1
440VAC
0.0056
13
5
11
10
0.6
MP1682K44C2R6**
X1
440VAC
0.0068
13
5
11
10
0.6
MP1822K44C2R6**
X1
440VAC
0.0082
13
5
11
10
0.6
MP1103K44C2R6**
X1
440VAC
0.01
13
5
11
10
0.6
MP1123K44C2R6**
X1
440VAC
0.012
13
5
11
10
0.6
MP1153K44C2R6**
X1
440VAC
0.015
13
5
11
10
0.6
MP1183K44C2R6**
X1
440VAC
0.018
13
5
11
10
0.6
MP1273K44C3R6**
X1
440VAC
0.027
13
6
12
10
0.6
MP1223K44CDR6**
X1
440VAC
0.023
12.5
5
13
10
0.6
MP1333K44CGR6**
X1
440VAC
0.033
12.5
6
15.5
10
0.6
MP1103K44D2R8**
X1
440VAC
0.01
18
6
12
15
0.8
MP1123K44D2R8**
X1
440VAC
0.012
18
6
12
15
0.8
MP1153K44D2R8**
X1
440VAC
0.015
18
6
12
15
0.8
MP1183K44D2R8**
X1
440VAC
0.018
18
6
12
15
0.8
MP1223K44D2R8**
X1
440VAC
0.022
18
6
12
15
0.8
MP1273K44D2R8**
X1
440VAC
0.027
18
6
12
15
0.8
MP1333K44D2R8**
X1
440VAC
0.033
18
6
12
15
0.8
MP1393K44D2R8**
X1
440VAC
0.039
18
6
12
15
0.8
MP1473K44DDR8**
X1
440VAC
0.047
17.5
6
15.5
15
0.8
说明 Note: “**”表示内部特征码
“**”=Internal use.
W±0.5
T±0.5
H±0.5
P±0.5
Φd±0.05
金属化聚丙烯膜抑制电磁电源干扰用电容器
容量
成品编码
等级
电压
尺寸 Dimension (mm)
Part No.
Class
Voltage
Capacitance
(μF)
MP1563K44DDR8**
X1
440VAC
0.056
17.5
6
15.5
15
0.8
MP1683K44DGR8**
X1
440VAC
0.068
17.5
7
17.5
15
0.8
MP1823K44DGR8**
X1
440VAC
0.082
17.5
7
17.5
15
0.8
MP1104K44DKR8**
X1
440VAC
0.1
17.5
8
18.5
15
0.8
MP1124K44DNR8**
X1
440VAC
0.12
17.5
9
19.5
15
0.8
MP1154K44DRR8**
X1
440VAC
0.15
17.5
10
22.5
15
0.8
MP1184K44DRR8**
X1
440VAC
0.18
17.5
10
22.5
15
0.8
MP1224K44DUR8**
X1
440VAC
0.22
17.5
11
23.5
15
0.8
MP1393K44E2R8**
X1
440VAC
0.039
26.5
7
16.5
22.5
0.8
MP1473K44E2R8**
X1
440VAC
0.047
26.5
7
16.5
22.5
0.8
MP1563K44E2R8**
X1
440VAC
0.056
26.5
7
16.5
22.5
0.8
MP1683K44E2R8**
X1
440VAC
0.068
26.5
7
16.5
22.5
0.8
MP1823K44E2R8**
X1
440VAC
0.082
26.5
7
16.5
22.5
0.8
MP1104K44E2R8**
X1
440VAC
0.1
26.5
7
16.5
22.5
0.8
MP1124K44E2R8**
X1
440VAC
0.12
26.5
7
16.5
22.5
0.8
MP1154K44E2R8**
X1
440VAC
0.15
26.5
7
16.5
22.5
0.8
MP1184K44E3R8**
X1
440VAC
0.18
26.5
8.5
17
22.5
0.8
MP1224K44E3R8**
X1
440VAC
0.22
26.5
8.5
17
22.5
0.8
MP1274K44E4R8**
X1
440VAC
0.27
26.5
10
19
22.5
0.8
MP1334K44E5R8**
X1
440VAC
0.33
26.5
11
0.8
MP1394K44E6R8**
X1
440VAC
0.39
26.5
12
21.5
22.5
0.8
MP1474K44E7R8**
X1
440VAC
0.47
26.5
13
23
22.5
0.8
MP1154K44F1R8**
X1
440VAC
0.15
31.5
10.8
19.5
27.5
0.8
MP1184K44F1R8**
X1
440VAC
0.18
31.5
10.8
19.5
27.5
0.8
MP1224K44F1R8**
X1
440VAC
0.22
31.5
10.8
19.5
27.5
0.8
MP1274K44F1R8**
X1
440VAC
0.27
31.5
10.8
19.5
27.5
0.8
MP1334K44F1R8**
X1
440VAC
0.33
31.5
10.8
19.5
27.5
0.8
MP1394K44F1R8**
X1
440VAC
0.39
31.5
10.8
19.5
27.5
0.8
MP1474K44F2R8**
X1
440VAC
0.47
31.5
13
21.5
27.5
0.8
MP1564K44F2R8**
X1
440VAC
0.56
31.5
13
21.5
27.5
0.8
MP1684K44F3R8**
X1
440VAC
0.68
31
14
25
27.5
0.8
MP1824K44F4R8**
X1
440VAC
0.82
31.5
16
25.5
27.5
0.8
MP1105K44F5R8**
X1
440VAC
1.0
31.5
16
30
27.5
0.8
“**”=Internal use.
W±0.5
T±0.5
H±0.5
P±0.5
Φd±0.05
金属化聚丙烯膜抑制电磁电源干扰用电容器
容量
成品编码
等级
电压
尺寸 Dimension (mm)
Part No.
Class
Voltage
Capacitance
(μF)
MP1125K44F6R8**
X1
440VAC
1.2
31
18
33
27.5
0.8
MP1155K44F6R8**
X1
440VAC
1.5
31
18
33
27.5
0.8
MP1334K44S0R1**
X1
440VAC
0.33
41
11
22
37.5
1.0
MP1394K44S0R1**
X1
440VAC
0.39
41
11
22
37.5
1.0
MP1474K44S0R1**
X1
440VAC
0.47
41
11
22
37.5
1.0
MP1564K44S0R1**
X1
440VAC
0.56
41
11
22
37.5
1.0
MP1684K44S0R1**
X1
440VAC
0.68
41
11
22
37.5
1.0
MP1824K44S1R1**
X1
440VAC
0.82
41
12
26
37.5
1.0
MP1105K44S1R1**
X1
440VAC
1.0
41
12
26
37.5
1.0
MP1125K44S2R1**
X1
440VAC
1.2
41
14
28
37.5
1.0
MP1155K44S3R1**
X1
440VAC
1.5
41
16
30
37.5
1.0
MP1185K44S4R1**
X1
440VAC
1.8
41
17
32
37.5
1.0
MP1205K44S5R1**
X1
440VAC
2.0
41
18.5
33.5
37.5
1.0
MP1225K44S5R1**
X1
440VAC
2.2
41
18.5
33.5
37.5
1.0
MP1255K44S6R1**
X1
440VAC
2.5
41
22
37
37.5
1.0
MP1275K44S6R1**
X1
440VAC
2.7
41
22
37
37.5
1.0
MP1305K44S7R1**
X1
440VAC
3.0
41
26
41
37.5
1.0
MP1335K44S7R1**
X1
440VAC
3.3
41
26
41
37.5
1.0
MP1355K44S7R1**
X1
440VAC
3.5
41
26
41
37.5
1.0
MP1395K44S7R1**
X1
440VAC
3.9
41
26
41
37.5
1.0
MP1405K44S8R1**
X1
440VAC
4.0
41
28
43
37.5
1.0
MP1455K44S9R1**
X1
440VAC
4.5
42
30
45
37.5
1.0
MP1475K44S9R1**
X1
440VAC
4.7
42
30
45
37.5
1.0
W±0.5
T±0.5
H±0.5
P±0.5
Φd±0.05
“**”=Internal use.
Note: We can customize the capacitors according to customers special requirements.
很抱歉,暂时无法提供与“MP1104K44D2R8LC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.94443
- 50+0.78027
- 150+0.69819
- 500+0.56563
