Metallized Polypropylene Film Interference Suppression Capacitors
金属化聚丙烯膜抑制电磁电源干扰用电容器
(MP1-Class X1 300VAC Series)
■ 引用标准 Reference standards
GB/T6346.14-2015/ UL60384-14/VDE0565-1/ CSA E60384-14
IEC60384-14 /EN60384-14
■ 结构 Structure
介质:(金属化)聚丙烯膜
封装:阻燃环氧树脂,符合 UL94 V-0
外壳:阻燃 PBT 塑壳,符合 UL94 V-0
Dielectric: Metallized Polypropylene film
Encapsulation: Flame retardant epoxy resin, conforming to UL94 V-0
Shell: Flame retardant PBT plastic shell, conforming to UL94 V-0
典型应用 Typical
Application
跨线、抑制突波、交流场合 EMI 滤波;电源开关等。如:灯具、电源等
Interlines, Surge suppression, Across-in-line as EMI filter;
Power switch etc. Such as: Lamps, Power Sources etc.
特点 Features
外观一致性好;有良好自愈性
抗湿性强;高耐温
长寿命,耐过电压优良
符合 RoHS 及 REACH 环保标准
电性能规范
Good appearance consistency; Good self-healing property;
Good resistance to humidity; Can withstand high temperature;
Long lifetime; Good ability to withstand surge voltage.
Compliance with RoHs & REACH requirements.
Performance Specifications
气候类别 Climate category
40/110/56
阻燃等级 Passive flammability class
B
额定电压 Rated Voltage
300VAC
容量误差 Capacitance Tolerance
K: ±10%
容量范围
0.0022μF~4.7μF
Capacitance Range
Test Condition:
耐电压
No breakdown or electric arcing
Withstand Voltage
Terminal to terminal:4.3UR(Vdc),5S
Terminal to shell:2380VAC 60S
损耗角
≤0.0020
10KHZ
CR≤1.0μF
Test Condition :
Dissipation factor
≤0.0010
1KHZ
CR>1.0μF
绝缘电阻或时间常数
CR≤0.33μF IR≥15000MΩ
Insulation Resistance
CR>0.33μF IR≥5000S
最大脉冲爬升速率
P=10mm
dV / dt = 500V/μs
P=15mm
dV / dt = 400V/μs
P=22.5mm dV / dt = 200V/μs
P=27.5mm dV / dt = 150V/μs
P=31.5mm dV / dt = 100V/μs
P=41mm
dV / dt = 60V/μs
Max. Pulse Rise Time
(dV / dt)
20℃, 1KHz, 1Vrms
20℃ 1V
Test Condition : 20℃
100V
1 min
金属化聚丙烯膜抑制电磁电源干扰用电容器
电性能规范 Performance Specifications
稳态湿热
温度 Temp.:40±2℃
无可见损伤,标志清晰
Steady-state
Damp-heat Test
相对湿度 Humidity:93%RH
no visible damage,clear mark
绝缘电阻 IR:≥ 额定值的 50%
IR:≥ 50% of Rated value
持续时间 Duration Time:56 Days
容量变化(相对初始值):
Capacitance change:△C/C≤±5%
损耗角增加 Dissipation factor:
Rise ≤0.0080(10KHZ),CR≤1uF
Rise ≤0.0050(1KHZ),CR>1uF
绝缘电阻 Insulation Resistance
耐久性试验
温度 Temp.: +110℃,
Endurance Test
施加电压:1.25×额定电压(每小时增加
IR:≥ 50% of rated value
电压到 1000Vac,0.1 秒,1 次)
容量变化(相对初始值):△C/C≤±10%
Test Voltage:
Capacitance change: △C/C≤±10%
1.25 Times Rated Voltage(Rise the
voltage to 1000Vac for .01s once
per hours )
持续时间 Duration Time: 1000H
安规认证
Safety Certification
认证标志
额定电压
证书号码
引用标准
认证国家
Certification
Rated Voltage
Certificate No.
Reference standard
Certification Country
UL/CUL
300VAC
E319615
UL60384-14
VDE
300VAC
40025029
EN60384-14
德国 Germany
ENEC
300VAC
40025029
EN60384-14
欧盟 Europe
CQC
300VAC
CQC12001070301
GB/T6346.14-2015
中国 China
产品编码说明
美国、加拿大
America / Canada
Part No. Description:
15 位产品编码如下:
The Part No. Is total 15 digits, details as follow:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
M
4
R
8
Digit 1-3
P
1
1
K
型号代码 Product Name Code
3
D
MP1= Class X1 Capacitors
Digit 4-6
标称容量 Rated Capacitance Value
For example : 104= 10×104pF = 0.1F
Digit 7
容量偏差 Capacitance Tolerance
K=±10%
Digit 8-9
额定电压 Rated Voltage Code
30=300VAC
Digit 10-11 壳号 Plastic shell code
Digit 12
塑壳颜色 Plastic Shell Color
R = Grey Color with LOGO on the shell top
Digit 13
线径代码 Line diameter code
6=0.6 8=0.8
Digit 14-15 成型或内部识别码 Forming Type or Internal Use
金属化聚丙烯膜抑制电磁电源干扰用电容器
料号明细及尺寸 Part No. List and Dimensions
容量
成品编码
等级
电压
尺寸 Dimension (mm)
Class
Voltage
Capacitance
(μF)
MP1103K30B1R5LC
X1
300VAC
0.01
10
4
9
7.5
0.5
MP1103K30C2R6LC
X1
300VAC
0.01
13
5
11
10
0.6
MP1103K30D1R6LC
X1
300VAC
0.01
18
5
11
15
0.6
MP1104K30C3R6LC
X1
300VAC
0.1
13
6
12
10
0.6
MP1104K30D2R8LC
X1
300VAC
0.1
18
6
12
15
0.8
MP1105K30E6R8LC
X1
300VAC
1.0
26
12
21.5
22.5
0.8
MP1125K30E6R8LC
X1
300VAC
1.2
26
12
21.5
22.5
0.8
MP1153K30C2R6LC
X1
300VAC
0.015
13
5
11
10
0.6
MP1154K30C3R6LC
X1
300VAC
0.15
13
6
12
10
0.6
MP1103K30B1R5LC
X1
300VAC
0.01
10
4
9
7.5
0.5
MP1103K30C2R6LC
X1
300VAC
0.01
13
5
11
10
0.6
MP1103K30D1R6LC
X1
300VAC
0.01
18
5
11
15
0.6
MP1104K30C3R6LC
X1
300VAC
0.1
13
6
12
10
0.6
MP1104K30D2R8LC
X1
300VAC
0.1
18
6
12
15
0.8
MP1105K30E6R8LC
X1
300VAC
1.0
26
12
21.5
22.5
0.8
MP1125K30E6R8LC
X1
300VAC
1.2
26
12
21.5
22.5
0.8
MP1153K30C2R6LC
X1
300VAC
0.015
13
5
11
10
0.6
MP1154K30C3R6LC
X1
300VAC
0.15
13
6
12
10
0.6
MP1103K30B1R5LC
X1
300VAC
0.01
10
4
9
7.5
0.5
MP1103K30C2R6LC
X1
300VAC
0.01
13
5
11
10
0.6
MP1103K30D1R6LC
X1
300VAC
0.01
18
5
11
15
0.6
MP1104K30C3R6LC
X1
300VAC
0.1
13
6
12
10
0.6
MP1104K30D2R8LC
X1
300VAC
0.1
18
6
12
15
0.8
MP1154K30D2R8LC
X1
300VAC
0.15
18
6
12
15
0.8
MP1155K30E5R8LC
X1
300VAC
1.5
26.5
11
0.8
MP1223K30C2R6LC
X1
300VAC
0.022
13
5
11
10
0.6
MP1224K30C3R690
X1
300VAC
0.22
13
6
12
10
0.6
MP1224K30D4R8LC
X1
300VAC
0.22
18
8.4
14.5
15
0.8
MP1224K30E2R8LC
X1
300VAC
0.22
26.5
7
16.5
22.5
0.8
MP1225K30F3R8LC
X1
300VAC
2.2
31
14
25
27.5
0.8
MP1333K30C2R6LC
X1
300VAC
0.033
13
5
11
10
0.6
MP1334K30D4R8LC
X1
300VAC
0.33
18
8.4
14.5
15
0.8
MP1335K30F8R8LC
X1
300VAC
3.3
31.5
21
31
27.5
0.8
Part No.
说明 Note: “**”表示内部特征码
“**”=Internal use.
W±0.5
T±0.5
H±0.5
P±0.5
Φd±0.05
金属化聚丙烯膜抑制电磁电源干扰用电容器
容量
成品编码
等级
电压
尺寸 Dimension (mm)
Part No.
Class
Voltage
Capacitance
(μF)
MP1394K30D6R8LC
X1
300VAC
0.39
18
10
15.8
15
0.8
MP1472K30C2R6LC
X1
300VAC
0.0047
13
5
11
10
0.6
MP1473K30C2R6LC
X1
300VAC
0.047
13
5
11
10
0.6
MP1474K30D6R8LC
X1
300VAC
0.47
18
10
15.8
15
0.8
MP1474K30E4R8LC
X1
300VAC
0.47
26.5
10
19
22.5
0.8
MP1474K30F1R8LC
X1
300VAC
0.47
31.5
10.8
19.5
27.5
0.8
MP1564K30E4R8LC
X1
300VAC
0.56
26.5
10
19
22.5
0.8
MP1683K30C2R6LC
X1
300VAC
0.068
13
5
11
10
0.6
MP1683K30C3R6LC
X1
300VAC
0.068
13
6
12
10
0.6
MP1684K30D8R8LC
X1
300VAC
0.68
18
11.2
19.2
15
0.8
MP1394K30D6R8LC
X1
300VAC
0.39
18
10
15.8
15
0.8
MP1472K30C2R6LC
X1
300VAC
0.0047
13
5
11
10
0.6
MP1473K30C2R6LC
X1
300VAC
0.047
13
5
11
10
0.6
MP1474K30D6R8LC
X1
300VAC
0.47
18
10
15.8
15
0.8
MP1474K30E4R8LC
X1
300VAC
0.47
26.5
10
19
22.5
0.8
MP1474K30F1R8LC
X1
300VAC
0.47
31.5
10.8
19.5
27.5
0.8
MP1564K30E4R8LC
X1
300VAC
0.56
26.5
10
19
22.5
0.8
MP1683K30C2R6LC
X1
300VAC
0.068
13
5
11
10
0.6
MP1683K30C3R6LC
X1
300VAC
0.068
13
6
12
10
0.6
W±0.5
T±0.5
H±0.5
P±0.5
Φd±0.05
“**”=Internal use.
Note: We can customize the capacitors according to customers special requirements.
很抱歉,暂时无法提供与“MP1104K30C3R6LC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.46303
- 100+0.37663
- 500+0.33343
- 1000+0.30103
