气候类别 / 阻燃等级
Climatic Category/Passive Flammability Category
工作温度范围 Operating Temperature Range
额定电压 Rated Voltage (UR)
电容量范围 Capacitance Range
电容量偏差 Capacitance Tolerance
耐电压 Voltage Proof
绝缘电阻 Insulation Resistance
损耗角正切 Dissipation Factor(tanδ)
注 : 1. 推荐用于电网额定电压不超过 250VAC 场合;
2. 如果需要用到承载一定纹波电流场合,建议选用 C6A 等专
用的滤波电容器;如有疑问,请与我司技术工程师联系;
3. 若用于户外或长期湿度较大场合,建议选用防潮设计。
110
40/110/56/B
-40℃  ̄ +110℃
305Vac/275Vac, 50/60Hz
0.0010μF  ̄ 25.0μF
±10%(K), ±20%(M)
引线之间 Between Terminals:
4.3UR(Vdc), 2s
极壳之间 Between Terminals To Case:
2 120Vac, 1min
R ≥ 15 000MΩ, CN ≤ 0.33μF
(20℃ ,100V, 1min)
RCN ≥ 5 000s, CN > 0.33μF
≤ 20 x 10-4(1kHz,20℃ )
≤ 20 x 10-4(10kHz,20℃ )
0.0010μF ≤ CN < 0.010μF
0.010μF ≤ CN < 0.47μF
≤ 10 x 10-4(1kHz,20℃ )
-4
0.47μF ≤ CN ≤ 1.0μF
≤ 20 x 10 (1kHz,20℃ )
≤ 40 x 10-4(10kHz,20℃ )
1.0μF < CN ≤ 10.0μF
≤ 30 x 10-4(1kHz,20℃ )
10.0μF < CN ≤ 50.0μF
≤ 40 x 10-4(1kHz,20℃ )
Recommend for max rated supply mains voltage 250Vac application;
If used in application which has ripple current applied, recommend to use AC filter series: C6A etc;
If have any questions please contact our technical engineer for more detail;
For outdoor or severe humidity condition application, recommend to use THB series.
很抱歉,暂时无法提供与“C42Q2475MBFC500”相匹配的价格&库存,您可以联系我们找货
