CMCW1608F150KTT
承 认 书
SPECIFICATION FOR APPROVAL
CUSTOMER:
CUSTOMER P/N:
Cybermax P/N:
CMCW1608F150KTT
DRAWN NO.:
CM19062101
DATE:
REVISION NO. A
19.06.21
Signature:
APPROVED BY
Rev.01
CHECKED BY
DRAWN BY
黄
谢
申
19.06.21
19.06.21
19.06.21
大燕
焕飞
双凤
Page 1 of 11
www.cybermaxtech.com
CMCW1608F150KTT
Chang Item
DATE
Rev.01
Page 2 of 11
CMCW1608F150KTT
CUSTOMER:
CUSTOMER P/N:
Cybermax P/N:
DRAWN NO.:
CMCW1608F150KTT
CM19062101
PAGE:
REVISION:
DATE:
1/10
19.06.21
SHAPE & DIMENSION (UNIT:mm)
Marking Code:
Color:Orange
Size:
typeface:
ELECREICAL SPECIFICATION
MEAS.
SPEC.
ITEM
CONDITIONS
TEST FREQ.
L
15
µH
10%
DCR
3.70
Ω
20%
Isat
0.20
A
MAX
2.5MHz/0.1V
△L/L≤30%
Irms
0.24
A
MAX
2.5MHz/0.1V
△T≤40℃
2.5MHz/0.1V
Ta=25℃,Idc=0A
Ta=25℃
GENERAL SPECIFICATION
Electrical specifications :
Operation Temperature:
Storage Temperature:
at 25℃
-40~+125℃
-40~+125℃
(1)WIRE TYPE: ¢0.03mm
(2)WINDING: 57.5Ts(Ref.)
Rev.01
Page 3 of 11
CMCW1608F150KTT
CUSTOMER:
CUSTOMER P/N:
Cybermax P/N:
DRAWN NO.:
CMCW1608F150KTT
CM19062101
PAGE:
REVISION:
DATE:
2/10
19.06.21
Reliability Test
No.
1
2
3
4
Item
Temperature Shock.
Humidity Resistance.
High Temperature
Resistance.
Low Temperature
Resistance.
Specification
Appearance: No damage.
Temperature: -25±2℃~+105±2℃ Kept for 30 minutes.
Inductance: within ±10% of
Transition time : 5 minutes.
initial.
100 Cycles.
Temperature: 40±2℃.
Relative Humidity: 90%.
initial.
Duration: 500 +4/-0 hours.
initial.
initial.
5
Vibration test.
initial.
Solderability Heat test. Inductance: within ±10% of
initial.
7
Solderability test.
Temperature: 105±2℃.
Duration: 1000 +4/-0 hours.
Temperature: -25±2℃.
Oscillation Frequency: 10Hz to 55Hz to 10Hz in 60 seconds
as a period. Total amplitude: 1.5mm.
Testing Time: a period of 2 hours in each 3 mutually
perpendicular directions (total of 6 hours).
6
Test Method
90% or more of electrode area
shall be coated by new solder.
Solder temperature: 260 +0/-5℃. Duration: 5 sec.
Allowed reflow time: 2 times.
Preheating: 160℃,60sec.
Solder temperature: 245±5℃.
Duration : 5 sec.
Flexure: 2mm.
8
Flexure Strength.
No visible mechanical damage. Pressurizing Speed: 0.5mm/sec.
Keep time: 30±1sec.
Force: 0.45Kg for 0603 series. Force: 0.9Kg for 0805
9
Terminal Strength.
No visible mechanical damage. series. Force: 1.8Kg for 1008 series above.
Keep time: 5 sec,X,Y directs.
Rev.01
Page 4 of 11
CMCW1608F150KTT
CUSTOMER:
CUSTOMER P/N:
Cybermax P/N:
DRAWN NO.:
Rev.01
CMCW1608F150KTT
CM19062101
Page 5 of 11
PAGE:
REVISION:
DATE:
4/10
19.06.21
CMCW1608F150KTT
CUSTOMER:
CUSTOMER P/N:
Cybermax P/N:
DRAWN NO.:
CMCW1608F150KTT
CM19062101
PAGE:
REVISION:
DATE:
5/10
19.06.21
B.O.M
项目名称
型号及规格
磁芯(DRUM CORE)
MF801SWI1608C050A-LS
线材(WIRE)
P180G1-0.03mm
胶水(GLUE)
UV-523
Rev.01
Page 6 of 11
制造商
环保要求
佳叶
RoHS
益利素勒
RoHS
贺盛
RoHS
CMCW1608F150KTT
CUSTOMER:
CUSTOMER P/N:
Cybermax P/N:
DRAWN NO.:
CMCW1608F150KTT
CM19062101
PAGE:
REVISION:
DATE:
6/10
19.06.21
Isat(飽和電流):電感瞬間的突波電流
TME(秒)
Rev.01
CMCW1608F150KTT
Lsat(A)
L(UH)
△L/L(%)
1
0.000
14.5
0.00%
1
0.025
14.5
0.00%
1
0.050
14.5
0.00%
1
0.075
14.5
0.00%
1
0.100
14.4
-0.69%
1
0.125
14.3
-1.38%
1
0.150
14.2
-2.07%
1
0.175
14.1
-2.76%
1
0.200
13.5
-6.90%
1
0.225
12.5
-13.79%
1
0.250
8.63
-40.48%
Page 7 of 11
CMCW1608F150KTT
CUSTOMER:
CUSTOMER P/N:
Cybermax P/N:
DRAWN NO.:
PAGE:
REVISION:
DATE:
CMCW1608F150KTT
CM19062101
7/10
19.06.21
單點溫昇
TIME(S)
Irms(A)
30
0.000
14.80
0.00%
29.0
0.0
30
0.25
14.80
0.00%
29.0
0.0
30
0.50
14.80
0.00%
29.0
0.0
30
0.75
14.70
-0.68%
30.0
1.0
30
1.00
14.70
-0.68%
31.0
2.0
30
1.25
14.60
-1.35%
33.0
4.0
30
1.50
14.50
-2.03%
35.0
6.0
30
1.75
14.30
-3.38%
38.0
9.0
30
2.00
13.80
-6.76%
42.0
13.0
30
2.25
11.70
-20.95%
46.0
17.0
30
2.50
6.27
-57.64%
52.0
23.0
※DC bias current characteristics in the
Rev.01
CMCW1608F150KTT
L(uH)
ΔL/L(%)
Temp(℃)
ΔT(℃)
ambient temperature 25℃ Frequency 2.5MHz/0.1V
Page 8 of 11
CMCW1608F150KTT
CUSTOMER:
CUSTOMER P/N:
Cybermax P/N:
DRAWN NO.:
PAGE:
REVISION:
DATE:
CMCW1608F150KTT
CM19062101
8/10
19.06.21
TEST DATA FOR PREPRODUCTION SAMPLE
TEST RESOLUTION
DIMENSION (Unit:mm)
MEAS.
L
D.C.R
长
宽
高
ITEM
uH
Ω
mm
mm
mm
15
3.7
1.80Max
1.20Max
1.0Max
10%
20%
SPEC.
TEST
2.5MHz/0.1
Isat
FREQ.
V
0.2A
1
14.5
3.78
13.5
-6.9%
1.65
1.06
0.97
2
14.3
3.80
13.2
-7.7%
1.64
1.05
0.98
3
14.7
3.76
13.4
-8.8%
1.68
1.04
0.95
4
15.0
3.78
14.0
-6.7%
1.65
1.13
0.96
5
14.8
3.78
13.5
-8.8%
1.69
1.07
0.99
6
14.2
3.84
13.7
-3.5%
7
14.6
3.76
13.2
-9.6%
8
15.2
3.77
13.4
-11.8%
9
14.8
3.83
13.2
-10.8%
10
14.2
3.85
14.0
-1.4%
AVG.
14.630
3.8
13.510
-7.61%
R
1
0.09
1.60
-4.20%
APPROVED BY
△L/L≦30%
CHECKED BY
黄
19.06.21
大燕
Rev.01
Page 9 of 11
DRAWN BY
谢
19.06.21
申
19.06.21
焕飞
双凤
CMCW1608F150KTT
CUSTOMER:
CUSTOMER P/N:
Cybermax P/N:
DRAWN NO.:
CMCW1608F150KTT
CM19062101
PAGE:
REVISION:
DATE:
9/10
19.06.21
PACKAGING
热封包装
载带前空 200mm
载带后空 400mm
4000
Rev.01
Page 10 of 11
CMCW1608F150KTT
CUSTOMER:
CUSTOMER P/N:
Cybermax P/N:
DRAWN NO.:
PAGE:
REVISION:
DATE:
CMCW1608F150KTT
CM19062101
10/10
19.06.21
PACKAGING
1.1 外箱: 39*38*18.5 cm 一箱裝 8 內箱
1.2 內箱: 18.7*18.4*8.3 cm 一箱装 5 卷制品
1.3 外箱材質: A 三 A
1.4 內箱材質: A=A
1.5 每 5 卷制品用一只静电袋包裝
1.6 每一静电袋內放一只袋干燥剂
1.7 每一卷上面依标签样式的要求贴上标签明细
1.8 出货內外箱贴上该箱內实际內容明细
1.9 出货标签规格如下: 尺寸=长度:39mm
宽度:29mm
(如: 客戶有特殊要求時, 則依客戶要求實施.)
备注:如果捆包数量小于内箱捆包数量时就用内箱包装
Rev.01
Page 11 of 11
很抱歉,暂时无法提供与“CMCW1608F150KTT”相匹配的价格&库存,您可以联系我们找货
