H
N04H
40V /20A Single N Power MOSFET
SM454AT9RL
N
V
General Description
RDS(on),TYP@VGS=10V
RDS(on),TYP@VGS=4.5
ID
Very low on-resistance RDS(on) @ VGS=4.5 V
Pb-free lead plating; RoHS compliant
Part ID
Package Type
SM454AT9RL
TO-252
DS
Tape and reel
infomation
Marking
Parameter
40
V
28.0
mΩ
44.0
mΩ
A
100% UIS Tested
100% Rg Tested
2500
454A
20N04H
Symbol
Maximum
Units
Drain-Source Voltage
VDS
40
V
Gate-Source Voltage
VGS
±V
Continuous Drain Current A
Pulsed Drain Current
Avalanche Current
TA=25°C
TA=70°C
B
Power Dissipation
G
32.0
IAR
6.4
EAR
14.7
TA=25°C
A
A
mJ
37
PD
TA=70°C
Junction and Storage Temperature Range
15.0
IDM
G
Repetitive avalanche energy L=0.1mH
20.0
ID
W
18
-55 to 150
TJ, TSTG
°C
Thermal Characteristics
Parameter
Symbol
Maximum Junction-to-Ambient
A
t ≤ 10s
A
Steady State
Maximum Junction-to-Lead
V02
C
Steady State
1
www.sourcechips.com
RθJA
RθJL
Typ
Max
Units
100
150
°C/W
200
240
°C/W
60
96
°C/W
STATIC PARAMETERS
Symbol
BVDSS
Parameter
Drain-Source Breakdown
Voltage
Conditions
ID = -250uA, VGS = 0V
IDSS
Zero Gate Voltage Drain Current
VDS=40V, VGS=0V
IGSS
Gate-Body leakage current
VDS = 0V, VGS = ±20V
VGS(th)
Gate Threshold Voltage
VDS = VGS ID = 250µA
RDS(ON)
Static Drain-Source OnResistance
gFS
VSD
IS
Min
SM454AT9RL
Typ
Max
40
Units
V
1
5
uA
±100
nA
2.3
3
V
VGS=-10V, ID=20A
28.0
40.0
VGS=4.5V, ID=20A
44.0
57.2
Forward Transconductance
VDS=5V, ID=20A
94
Diode Forward Voltage
IS=1A,VGS=89V
0.72
1.5
mΩ
S
1
V
A
Typ
Max
Units
516
629
pF
82
100
pF
43
51
pF
0.8
Ω
Max
Units
Maximum Body-Diode Continuous Current
DYNAMIC PARAMETERS
Symbol
Parameter
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Rg
Gate resistance
Conditions
Min
VGS=0V, VDS=15V, f=1MHz
VGS=0V, VDS=0V, f=1MHz
SWITCHING PARAMETERS
Symbol
Parameter
Qg (10V)
Total Gate Charge
Qg 4.5V)
Total Gate Charge
Qgs
Gate Source Charge
Qgd
Gate Drain Charge
1.6
tD(on)
Turn-On DelayTime
9
tr
Turn-On Rise Time
tD(off)
Turn-Off DelayTime
tf
Turn-Off Fall Time
Body Diode Reverse Recovery
Time
trr
Qrr
V02
Charge
Conditions
Min
Typ
8.3
VGS=10V, VDS=15V, ID=20A
VGS=10V, VDS=15V,RL=0.75Ω,
RGEN=3Ω
4.15
1.12
7.2
25.2
nC
ns
8.1
IF=-8A, dI/dt=500A/µs
18
ns
IF=18A, dI/dt=500A/µs
10
nC
2
www.sourcechips.com
V02
3
www.sourcechips.com
SM454AT9RL
V02
4
www.sourcechips.com
SM454AT9RL
很抱歉,暂时无法提供与“SM454AT9RL”相匹配的价格&库存,您可以联系我们找货
