H
N04H
40V /50A Single N Power MOSFET
SM4184T9RL
N
V
General Description
Very low on-resistance RDS(on) @ VGS=4.5 V
Pb-free lead plating; RoHS compliant
DS
RDS(on),TYP@VGS=10V
RDS(on),TYP@VGS=4.5
ID
Part ID
Package Type
Marking
Tape and reel
infomation
SM4184T9RL
TO-252
50N04
2500
Parameter
50N04H
40
V
4.9
mΩ
6.7
mΩ
50
A
100% UIS Tested
100% Rg Tested
Symbol
Maximum
Units
Drain-Source Voltage
VDS
40
V
Gate-Source Voltage
VGS
±V
Continuous Drain Current A
Pulsed Drain Current
Avalanche Current
TA=25°C
TA=70°C
B
Power Dissipation
G
80.0
IAR
16.0
EAR
36.8
TA=25°C
A
A
mJ
50
PD
TA=70°C
Junction and Storage Temperature Range
40*
IDM
G
Repetitive avalanche energy L=0.1mH
50.0
ID
W
25*
-55 to 150
TJ, TSTG
°C
Thermal Characteristics
Parameter
Symbol
Maximum Junction-to-Ambient
A
t ≤ 10s
A
Steady State
Maximum Junction-to-Lead
V01
C
Steady State
1
www.sourcechips.com
RθJA
RθJL
Typ
Max
Units
23
35
°C/W
47
57
°C/W
14
22
°C/W
STATIC PARAMETERS
Symbol
BVDSS
Parameter
Drain-Source Breakdown
Voltage
Conditions
ID = -250uA, VGS = 0V
IDSS
Zero Gate Voltage Drain Current
VDS=40V, VGS=0V
IGSS
Gate-Body leakage current
VDS = 0V, VGS = ±20V
VGS(th)
Gate Threshold Voltage
VDS = VGS ID = 250µA
RDS(ON)
Static Drain-Source OnResistance
gFS
VSD
IS
Min
SM4184T9RL
Typ
Max
40
Units
V
1
5
uA
±100
nA
2
2.6
V
VGS=10V, ID=20A
4.9
7.0
VGS=4.5V, ID=20A
6.7
9.5
Forward Transconductance
VDS=5V, ID=20A
57
Diode Forward Voltage
IS=1A,VGS=172V
0.72
1.3
mΩ
S
1
V
50
A
Typ
Max
Units
1500
1830
pF
215
264
pF
135
160
pF
3
Ω
Max
Units
Maximum Body-Diode Continuous Current
DYNAMIC PARAMETERS
Symbol
Parameter
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Rg
Gate resistance
Conditions
Min
VGS=0V, VDS=15V, f=1MHz
VGS=0V, VDS=0V, f=1MHz
SWITCHING PARAMETERS
Symbol
Parameter
Qg (10V)
Total Gate Charge
Qg 4.5V)
Total Gate Charge
Qgs
Gate Source Charge
Qgd
Gate Drain Charge
6
tD(on)
Turn-On DelayTime
14.5
tr
Turn-On Rise Time
tD(off)
Turn-Off DelayTime
tf
Turn-Off Fall Time
Body Diode Reverse Recovery
Time
trr
Qrr
V01
Charge
Conditions
Min
Typ
14
VGS=10V, VDS=15V, ID=20A
VGS=10V, VDS=15V,RL=0.75Ω,
RGEN=3Ω
7
4.2
11.6
40.6
nC
ns
13.05
IF=-8A, dI/dt=500A/µs
29
ns
IF=18A, dI/dt=500A/µs
26
nC
2
www.sourcechips.com
V01
3
www.sourcechips.com
SM4184T9RL
V01
4
www.sourcechips.com
SM4184T9RL
很抱歉,暂时无法提供与“SM4184T9RL”相匹配的价格&库存,您可以联系我们找货
