HG2269
Current Mode PWM Controller
GENERAL DESCRIPTION
HG2269 is a highly integrated current mode PWM
control IC optimized for high performance, low
standby power and cost effective offline flyback
converter applications.
PWM switching frequency at normal operation is
externally programmable and trimmed to tight range.
At no load or light load condition, the IC operates in
extended ‘burst mode’ to minimize switching loss.
Lower standby power and higher conversion
efficiency is thus achieved.
VDD low startup current and low operating current
contribute to a reliable power on startup design with
HG2269. A large value resistor could thus be used
in the startup circuit to minimize the standby power.
The internal slope compensation improves system
large signal stability and reduces the possible subharmonic oscillation at high PWM duty cycle output.
Leading-edge blanking on current sense input
removes the signal glitch due to snubber circuit diode
reverse recovery. This greatly helps to reduce the
external component count and system cost in
application.
HG2269 offers complete pr otection coverage with
automatic self-recovery feature including Cycle-byCycle current limiting (OCP), over load protection
(OLP), over temperature protection (OTP), VDD
over voltage protection (OVP) and under voltage
lockout (UVLO). The Gate-drive output is clamped
at 18V to protect the power MOSFET.
In HG2269, OCP threshold slope is internally
optimized to reach constant output power limit over
universal AC input range.
Excellent EMI performance is achieved with OnBright proprietary frequency shuffling technique
together with soft switching control at the totem pole
gate drive output.
http://www.hgsemi.com.cn
1
The tone energy at below 20KHZ is minimized in
operation. Consequently, audio noise performance is
greatly improved.
HG2269 is offered in both SOP-8 and DIP-8
packages.
FEATURES
On-Bright Proprietary Frequency Shuffling
Technology for Improved EMI Performance
■ Extended Burst Mode Control For Improved
Efficiency and Minimum Standby Power Design
■ Audio Noise Free Operation
Programmable PWM Switching
■ External
Frequency
■ Internal Synchronized Slope Compensation
■ Low VIN/VDD Startup Current(6.5uA) and Low
Operating Current (2.3mA)
■ Leading Edge Blanking on Current Sense Input
■ Complete Protection Coverage With Auto SelfRecovery
o External Programmable Over Temperature
Protection (OTP)
o With or Without On-chip VDD OVP for
System OVP
o Under Voltage Lockout with Hysteresis
(UVLO)
o Gate Output Maximum Voltage Clamp (18V)
o Line Compensated Cycle-by-Cycle Overcurrent Threshold Setting For Constant Output
Current Limiting Over Universal Input Voltage
Range (OCP)
o Over Load Protection. (OLP)
APPLICATIONS
Offline AC/DC flyback converter for
■ Laptop Power Adaptor
■ PC/TV/Set-Top Box Power Supplies
■ Open-frame SMPS
■ Battery Charger
2018 MAR
HG2269
TYPICAL APPLICATION
GENERAL INFORMATION
Pin Configuration
The HG2269 is offered in DIP and SOP packages
shown as below.
Package Dissipation Rating
Package
DIP8
SOP8
Absolute Maximum Ratings
Parameter
Value
VDD/VIN DC Supply
30 V
Voltage
VDD Zener Clamp
VDD_Clamp+0.1V
Note
Voltage
VDD Clamp Continuous
10 mA
Current
VFB Input Voltage
-0.3 to 7V
VSENSE Input Voltage to Sense -0.3 to 7V
Pin
VRT Input Voltage to RT Pin
-0.3 to 7V
VRI Input Voltage to RI Pin
-0.3 to 7V
Min/Max Operating Junction
-20 to 150 oC
Temperature TJ
Min/Max Storage
-55 to 150 oC
Temperature Tstg
Lead Temperature (Soldering, 260 oC
10secs)
Note: VDD_Clamp has a nominal value of 35V.
RθJA (°C/W)
90
150
Stresses beyond those listed under “absolute maximum ratings”
may cause permanent damage to the device. These are stress
ratings only, functional operation of the device at these or any
other conditions beyond those indicated under “recommended
operating conditions” is not implied. Exposure to absolute
maximum-rated conditions for extended periods may affect device
reliability.
2
2018 MAR
HG2269
TERMINAL ASSIGNMENTS
Pin Num
1
2
Pin Name
GND
FB
I/O
P
I
3
VIN
I
4
RI
I
5
6
RT
SENSE
I
I
7
8
VDD
GATE
P
O
Description
Ground
Feedback input pin. PWM duty cycle is determined by voltage level into this
pin and current-sense signal level at Pin 6.
Connected through a large value resistor to rectified line input for Startup IC
supply and line voltage sensing.
Internal Oscillator frequency setting pin. A resistor connected between RI
and GND sets the PWM frequency.
Temperature sensing input pin. Connected through a NTC resistor to GND.
Current sense input pin. Connected to MOSFET current sensing resistor
node.
DC power supply pin.
Totem-pole gate drive output for power MOSFET.
BLOCK DIAGRAM
RECOMMENDED OPERATING CONDITION
Symbol
VDD
RI
TA
Parameter
VDD Supply Voltage
RI Resistor Value
Operating Ambient Temperature
Min
12
24
-20
3
Max
23
31
85
Unit
V
Kohm
o
C
2018 MAR
HG2269
ESD INFORMATION
Symbol
HBMNote
MM
Parameter
Human Body Model
on All Pins Except
VIN and VDD
Machine Model on
All Pins
Test Conditions
MIL-STD
Min
JEDEC-STD
Typ
3
Max
250
Unit
KV
V
Note: HBM all pins pass 3KV except High Voltage Input pin. The details are VIN passes 1kV, VDD passes 1.5KV, all other I/Os pass 3KV.
In system application, High Voltage Input pin is either a high impedance input or connected to a cap. The lower rating has minimum impacts
on system ESD performance.
ELECTRICAL CHARACTERISTICS
(TA = 25OC, VDD=16V, RI=24Kohm if not otherwise noted)
Symbol
Parameter
Test Conditions
Supply Voltage (VDD)
I_VDD_Startup
VDD Start up
VDD =15V, Measure
Current
current into VDD
I_VDD_Operation Operation Current
VFB=3V
UVLO(Enter)
VDD Under Voltage
Lockout Enter
UVLO(Exit)
VDD Under Voltage
Lockout Exit
(Startup)
*Optional
OVP(ON)
VDD Over Voltage
Protection Enter
OVP(OFF)*Optional VDD Over Voltage
Protection Exit
(Recovery)
*Optional
OVP_Hys
OVP Hysteresis
OVP(ON)-OVP(OFF)
TD_OVP
VDD OVP
Debounce time
VDD_Clamp
VDD Zener Clamp
I(VDD ) = 5mA
Voltage
Feedback Input Section(FB Pin)
AVCS
PWM Input Gain
ΔVFB /ΔVcs
VFB_Open
VFB Open Voltage
IFB_Short
FB pin short circuit
current
VTH_0D
Zero Duty Cycle FB
Threshold Voltage
VTH_BM
Burst Mode FB
Threshold Voltage
VTH_PL
Power Limiting FB
Threshold Voltage
TD_PL
Power limiting
Debounce Time
ZFB_IN
Input Impedance
Current Sense Input(Sense Pin)
T_blanking
Sense Input Leading
Edge Blanking Time
ZSENSE_IN
Sense Input
Short FB pin to GND,
measure current
Min
Typ
Max
Unit
6.5
uA
9.5
2.3
10.5
11.5
mA
V
15.5
16.5
17.5
V
23.5
25
26.5
V
21.5
23
24.5
V
2
80
V
uSec
35
V
2.8
5.9
V/V
V
0.80
mA
0.95
4
V
1.7
V
4.4
V
80
mSec
7.2
Kohm
250
nS
30
Kohm
2018 MAR
HG2269
TD_OC
VTH_OC_0
VTH_OC_1
Oscillator
FOSC
∆f_Temp
∆f_VDD
RI_range
V_RI_open
F_BM
DC_max
DC_min
Impedance
Over Current
Detection and
Control Delay
Current Limiting
Threshold at No
Compensation
Current Limiting
Threshold at
Compensation
Normal Oscillation
Frequency
Frequency
Temperature
Stability
Frequency Voltage
Stability
Operating RI Range
RI open voltage
Burst Mode Base
Frequency
Maxmum Duty
Cycle
Minimum Duty
Cycle
Gate Drive Output
VOL
Output Low Level
VOH
Output High Level
VG_Clamp
Output Clamp
Voltage Level
T_r
Output Rising Time
T_f
Output Falling Time
Over Temperature Protection
I_RT
Output Current of
RT pin
VTH_OTP
OTP Threshold
Voltage
VTH_OTP_off
OTP Recovery
Threshold Voltage
TD_OTP
OTP De-bounce
Time
V_RT_Open
RT Pin Open
Voltage
Frequency Shuffling
Frequency
∆f_OSC
Modulation range
/Base frequency
Freq_Shuffling
Shuffling Frequency
CL=1nf at GATE,
I(VIN) = 0uA
120
0.85
I(VIN) = 150uA
0.90
nSec
0.95
0.81
60
65
V
V
70
KHZ
-20oC to 100oC
2
VDD = 12-25V
2
Io = -20 mA
Io = +20 mA
VDD=20V
12
24
2.0
22
60
Kohm
V
KHZ
75
80
85
18
V
V
V
120
50
nSec
nSec
70
uA
11
CL = 1nf
CL = 1nf
1.015
1.065
5
V
1.165
V
100
uSec
3.5
V
-3
RI = 24Kohm
1.115
3
32
HZ
2018 MAR
HG2269
CHARACTERIZATION PLOTS
VDD Startup Current vs Temperature
11
10
9
8
7
6
5
4
3
2
1
Istartup(uA)
S tart-up C urrent (uA )
VDD Start-up Current vs. Voltage
6
4
2
4
6
8
10
12
14
-25
16
5
35
Fosc 50Khz
2.5
I(VDD) (mA)
VDD Current (mA)
3
2
1.5
1
0.5
2
6
8
10
12
14
16
125
18
Fosc 65Khz
Fosc 100Khz
6
5
4
3
2
1
500
VDD UVLO(enter) vs. Temperature
1000
1500
Gatedrive Loading (pf)
VDD Voltage (V)
2000
VDD UVLO(exit) vs. Temperature
10.6
10.55
10.5
10.45
10.4
10.35
10.3
UVLO(exit) (V)
UVLO(enter) (V)
95
VDD Operation Current vs. Load
VDD UVLO and Operation Current
Temperature(C)
VDD VOLTAGE (V)
16.9
16.8
16.7
16.6
16.5
16.4
-10
10
30
50
70
90
-10
110
30
50
70
90
110
Temperature(C)
Temperature(C)
10
6
2018 MAR
HG2269
Fosc(KHz) vs. Temperature
Fosc(KHz) vs RI(Kohm)
110
Fosc(KHz)
Fosc(KHz)
140
80
50
24
36
RI(Kohm)
48
-20
60
5
30
55 80
Temp(C)
105
130
I_RT vs. Temperature
Vth_OC(50KHz)
Vth_OC(65KHz)
1.0
71.4
0.9
71.2
I_RT(uA)
V th_O C (V )
Vth_OC vs. I(vin)
66.0
65.5
65.0
64.5
64.0
63.5
0.8
0.7
71
70.8
70.6
0.6
100
150
200
250
-20
300
60
80
100 120
Temperature(C)
I(vin) (uA)
2018 MAR
HG2269
OPERATION DESCRIPTION
to minimize the switching loss thus reduce the
standby power consumption to the greatest extend.
The nature of high frequency switching also
reduces the audio noise at any loading conditions.
The HG2269 is a highly integrated PWM
controller IC optimized for offline flyback
converter applications. The extended burst mode
control greatly reduces the standby power
consumption and helps the design easily meet the
international power conservation requirements.
z Oscillator Operation
A resistor connected between RI and GND sets the
constant current source to charge/discharge the
internal cap and thus the PWM oscillator frequency
is determined. The relationship between RI and
switching frequency follows the below equation
within the specified RI in Kohm range at nominal
loading operational condition.
• Startup Current and Start up Control
Startup current of HG2269 is designed to be very
low so that VDD could be charged up above
UVLO(exit) threshold level and device starts up
quickly. A large value startup resistor can therefore
be used to minimize the power loss yet reliable
startup in application. For a typical AC/DC adaptor
with universal input range design, a 2 MΩ, 1/8 W
startup resistor could be used together with a VDD
capacitor to provide a fast startup and yet low
power dissipation design solution.
FOSC =
z
Current Sensing and Leading Edge
Blanking
Cycle-by-Cycle current limiting is offered in
HG2269 current mode PWM control. The switch
current is detected by a sense resistor into the sense
pin. An internal leading edge blanking circuit chops
off the sense voltage spike at initial MOSFET on
state due to snubber diode reverse recovery so that
the external RC filtering on sense input is no longer
required. The current limit comparator is disabled
and thus cannot turn off the external MOSFET
during the blanking period. PWM duty cycle is
determined by the current sense input voltage and
the FB input voltage.
z Operating Current
The Operating current of HG2269 is low at
2.3mA. Good efficiency is achieved with HG2269
low operating current together with extended burst
mode control schemes.
z Frequency shuffling for EMI improvement
The frequency Shuffling/jittering (switching
frequency modulation) is implemented in
HG2269. The oscillation frequency is modulated
with a internally generated random source so that
the tone energy is evenly spread out. The spread
spectrum minimizes the conduction band EMI and
therefore eases the system design in meeting
stringent EMI requirement.
z Internal Synchronized Slope Compensation
Built-in slope compensation circuit adds voltage
ramp onto the current sense input voltage for PWM
generation. This greatly improves the close loop
stability at CCM and prevents the sub-harmonic
oscillation and thus reduces the output ripple
voltage.
z Burst Mode Operation
At zero load or light load condition, most of the
power dissipation in a switching mode power
supply is from switching loss on the MOSFET
transistor, the core loss of the transformer and the
loss on the snubber circuit. The magnitude of
power loss is in proportion to the number of
switching events within a fixed period of time.
Reducing switching events leads to the reduction
on the power loss and thus conserves the energy.
HG2269 self adjusts the switching mode
according to the loading condition. At from no load
to light/medium load condition, the FB input drops
below burst mode threshold level (1.8V). Device
enters Burst Mode control. The Gate drive output
switches only when VDD voltage drops below a
preset level and FB input is active to output an on
state. Otherwise the gate drive remains at off state
1560
( Khz )
RI ( Kohm)
z Over Temperature Protection
A NTC resistor in series with a regular resistor
should connect between RT and GND for
temperature sensing and protection. NTC resistor
value becomes lower when the ambient temperature
rises. With the fixed internal current IRT flowing
through the resistors, the voltage at RT pin
becomes lower at high temperature. The internal
OTP circuit is triggered and shutdown the
MOSFET when the sensed input voltage is lower
than VTH_OTP.
8
2018 MAR
HG2269
z
Gate Drive
HG2269 Gate is connected to the Gate of an
external MOSFET for power switch control. Too
weak the gate drive strength results in higher
conduction and switch loss of MOSFET while too
strong gate drive output compromises the EMI.
Good tradeoff is achieved through the built-in
totem pole gate drive design with right output
strength and dead time control. The low idle loss
and good EMI system design is easier to achieve
with this dedicated control scheme. An internal
18V clamp is added for MOSFET gate protection at
higher than expected VDD input.
The OCP threshold value is self adjusted lower at
higher current into VIN pin. This OCP threshold
slope adjustment helps to compensate the increased
output power limit at higher AC voltage caused by
inherent Over-Current sensing and control delay. A
constant output power limit is achieved with
recommended OCP compensation scheme on
HG2269.
At output overload condition, FB voltage is biased
higher. When FB input exceeds power limit
threshold value for more than 80mS, control circuit
reacts to turnoff the power MOSFET.
Similarly, control circuit shutdowns the power
MOSFET when an Over Temperature condition is
detected. HG2269 resumes the operation when
temperature drops below the hysteresis value.
VDD is supplied with transformer auxiliary
winding output. It is clamped when VDD is higher
than 35V. MOSFET is shut down when VDD drops
below UVLO(enter) limit and device enters power
on
startup
sequence
thereafter.
z Protection Controls
Good system reliability is achieved with
HG2269’s rich protection features including
Cycle-by-Cycle current limiting (OCP), Over Load
Protection (OLP), over temperature protection
(OTP), on-chip VDD over voltage protection (OVP,
optional) and under voltage lockout (UVLO).
9
2018 MAR
HG2269
Important statement:
Huaguan Semiconductor Co,Ltd. reserves the right to change
the products and services provided without notice. Customers
should obtain the latest relevant information before ordering,
and verify the timeliness and accuracy of this information.
Customers are responsible for complying with safety
standards and taking safety measures when using our
products for system design and machine manufacturing to
avoid potential risks that may result in personal injury or
property damage.
Our products are not licensed for applications in life support,
military, aerospace, etc., so we do not bear the consequences
of the application of these products in these fields.
Our documentation is only permitted to be copied without
any tampering with the content, so we do not accept any
responsibility or liability for the altered documents.
10
2018 MAR
很抱歉,暂时无法提供与“HG2269M/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.91768
- 50+0.80428
- 150+0.75568
- 500+0.69498
- 2500+0.63558
