The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information.
All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative.
1.25mm Pitch Super Low profile Crimping Connector
■Features
1. Super Low Profile
This is a connector special for right angle which has pursued a low
profile on the board.
Board mounting height: 2.5mm
A signal can be fetched from the area where there is no board to
board space. (Refer to fig.1)
Offset type is available.
Board mounting height: 1.6mm (Refer to fig.2)
Board Mounting Figure
2. Correspond to Automatic Mounting
The header has the vacuum mount face which enables the vacuum
absorption and the automatic mounting by the embossed tape
packaging.In addition, the tube packaging can be selected.
3. Four Wall Type Without Friction to Board by Socket
The header has the box structure to prevent from being twisted and
has the perfect mis-insertion prevention method. Moreover the
header has the wall on the board side and doesn't have any trouble
resulted from the friction to board by socket.
In addition, the metal fitting is attached to prevent the solder peel.
■Applications
(7.3)
(1)
(1.6)
LCD, Note PC, Mobile Terminal Small business equipment, Video
camera
DF14H
B234
fig.1
DF14(A)
(2.4)
Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
DF14 Series
fig.2
or contact
your HiroseConnector
DF14website
Series●1.25mm
Crimping
■Product Specifications
Current rating
Rating
1A
Operating Temperature Range -35 to +85ç (Note 1) Storage Temperature Range -10 to +60ç (Note 2)
Voltage rating 150V AC Operating Moisture Range
Item
40 to 80%
Storage Moisture Range
Specification
40 to 70% (Note 2)
Condition
1. Insulation Resistance
500M ohms Min
100V DC
2. Withstanding voltage
No flashover or insulation breakdown.
500V AC/1 minute
3. Contact Resistance
30m ohms Max
100mA
4. Insertion/Extraction Force MIN0.15N (15gf), MAX3N (300gf)
Measure at the square steel pin of 0.3±0.002mm
5. Vibration
Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions.
No electrical discontinuity of 1µs or more
6. Humidity (Steady state) Contact resistance: 30m ohms Max Insulation resistance:500M ohms Min
7. Temperature Cycle
96 hours at temperature of 40ç and humidity of 90% to 95%
(-25ç: 30 minutes➝5 to 35ç: 10 minutes➝85ç: 30 minutes➝
Contact resistance: 30m ohms Max Insulation resistance: 500M ohms Min
5 to 35ç: 10 minutes) 5 cycles
8. Durability (Mating/un-mating) Contact resistance: 30m ohms Max
9. Resistance to Soldering heat
Tin plating: 30 cycles Gold plating: 50 cycles
Reflow: At the recommended temperature profile
No deformation of components affecting performance.
Manual soldering: 300ç for 3 seconds
Note 1: Includes temperature rise caused by current flow.
Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and
Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation.
Note 3: Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for
a specific part number shown.
■Material
Product
Part
Crimping Socket
Insulator
Crimping Contact for Socket
Contact
Insulator
Contact
Fitting
Pin Header
Material
Finish
Remarks
Polyamide
Beige
UL94V-0
Phosphor Copper
Tin-copper plated or gold plated
Polyamide
Beige
UL94V-0
Brass
Phosphor copper
Tin-copper plated
■Ordering Information
●Connector
DF 14 # - * S - 1.25 C
1
1
Series Name: DF14
2
Blank: Standard, with boss
2
3
4
4
6
Connector Type
S: Single row socket
P: Single row pin header
A: on-board, without boss
H: offset
3
5
Number of Contacts: 2 to 10, 15, 20, 25, 30
5
Contact Pitch: 1.25mm
6
Contact Type
C: Crimping socket
H: Right angle SMT
●Contact
DF14 - 2628 SCF A
1
1
Applicable cable size
2
2
2628: AWG26 to 28
3032: AWG30 to 32
3
Packaging Type
SCF: Socket contact/reel
3
Plating Type
Blank: Tin plated
A: Gold plated
B235
All non-RoHS
products
or willSuper
be discontinued
soon. Please
check the products
DF14
Series●1.25mm
Pitch
Low profile
Crimping
Connector
■Crimping Socket
Photo: Contact insertion state
Unit: mm
Part Number
DF14- 2S-1.25C
DF14- 3S-1.25C
DF14- 4S-1.25C
DF14- 5S-1.25C
DF14- 6S-1.25C
DF14- 7S-1.25C
DF14- 8S-1.25C
DF14- 9S-1.25C
DF14-10S-1.25C
DF14-15S-1.25C
DF14-20S-1.25C
DF14-25S-1.25C
DF14-30S-1.25C
CL No.
538-0005-8
538-0006-0
538-0007-3
538-0008-6
538-0009-9
538-0010-8
538-0011-0
538-0013-6
538-0014-9
538-0054-3
538-0059-7
538-0064-7
538-0012-3
Number of Contacts
2
3
4
5
6
7
8
9
10
15
30
A
4.45
5.70
6.95
8.20
9.45
10.70
11.95
13.20
14.45
20.70
26.95
33.20
39.45
B
1.25
2.50
3.75
5.00
6.25
7.50
8.75
10.00
11.25
17.50
23.75
30.00
36.25
RoHS
Yes
Note 1.The quantity is delivered per bag(100 pcs). If needed, please order the products per bag.
■Socket Crimping Contact
Part Number
DF14-2628SCF
DF14-3032SCF
DF14-2628SCFA
DF14-3032SCFA
CL No.
538-0001-7-**
538-0003-2-**
538-0002-0-**
538-0004-5-**
Packaging Type
Reel
Reel
Reel
Reel
Quantity
RoHS
Tin plated
10,000
KApplicable Cable (Tin plating Annealed copper wire)
Conductor Size (Wire construction)
AWG26(7 cores/0.16mm)
AWG28(7 cores/0.127mm)
AWG30(7 cores/0.1mm)
AWG32(7 cores/0.08mm)
Finish
Jacket Diameter
Ø0.54 to Ø1mm
Yes
Gold plated
KRecommended Cable
UL1571
KStrip Length
1.2 to 1.9mm
Note:If other cables are used instead of the applicable cable, contact Hirose
sales department.
BApplicable Crimping Tool
Type
Applicator
Press Main Unit
Manual Crimping Tool
Part Number
AP105-DF14-2628S
AP105-DF14-3032S
CM-105
DF14-2628/CR-HT
DF14-3032/CR-HT
CL No.
901-4548-1
901-4544-0
901-0005-4
550-0261-1
550-0262-4
Applicable Contact
DF14-2628SCF/SCFA
DF14-3032SCF/SCFA
--------------------------------------------DF14-2628SCF/SCFA
DF14-3032SCF/SCFA
Note 1.If a trouble has occurred due to tools, which are not designated by Hirose, Hirose won't guarantee any product.
Note 2.Use the reel contact sequentially cut for manual crimping tool.
B236
or contact
DF14website
Series●1.25mm
Crimping
■Right Angle Pin Header (SMT)
Note 1."Without boss" indicates the style with no boss.
BPCB mounting pattern
BTube Packaging Dimensions
[Specific No.]–**,(**)
(25): Tin-copper plated tube packaging
(26): Tin-copper plated embossed tape packaging
(55): Gold plated tube packaging
(56): Gold plated embossed tape packaging
Note 2."Without boss" indicates that no hole is needed.
Unit: mm
With boss
Part Number
Without boss
CL No.
Part Number
CL No.
Number
of
Contacts
A
B
C
D
Tube
Packaging
Quantity
DF14- 2P-1.25H(**)
538-0021-4-** DF14A- 2P-1.25H(**) 538-0033-3-**
2
7.45
1.25
6.45
8.05
66
DF14- 3P-1.25H(**)
538-0022-7-** DF14A- 3P-1.25H(**) 538-0034-6-**
3
8.70
2.50
7.70
9.30
56
DF14- 4P-1.25H(**)
538-0023-0-** DF14A- 4P-1.25H(**) 538-0035-9-**
4
9.95
3.75
8.95
10.55
49
DF14- 5P-1.25H(**)
538-0024-2-** DF14A- 5P-1.25H(**) 538-0036-1-**
5
11.20
5.00
10.20
11.80
44
DF14- 6P-1.25H(**)
538-0025-5-** DF14A- 6P-1.25H(**) 538-0037-4-**
6
12.45
6.25
11.45
13.05
39
DF14- 7P-1.25H(**)
538-0026-8-** DF14A- 7P-1.25H(**) 538-0038-7-**
7
13.70
7.50
12.70
14.30
36
DF14- 8P-1.25H(**)
538-0027-0-** DF14A- 8P-1.25H(**) 538-0039-0-**
8
14.95
8.75
13.95
15.55
32
DF14- 9P-1.25H(**)
538-0028-3-** DF14A- 9P-1.25H(**) 538-0040-9-**
9
16.20
10.00
15.20
16.80
30
DF14-10P-1.25H(**)
538-0029-6-** DF14A-10P-1.25H(**) 538-0041-1-**
10
17.45
11.25
16.45
18.05
28
DF14-15P-1.25H(**)
538-0084-4-** DF14A-15P-1.25H(**) 538-0114-3-**
15
23.70
17.50
22.70
24.30
DF14-20P-1.25H(**)
538-0089-8-** DF14A-20P-1.25H(**) 538-0119-7-**
23.75
28.95
30.55
16
DF14-25P-1.25H(**)
538-0094-8-** DF14A-25P-1.25H(**) 538-0124-7-**
25
36.20
30.00
35.20
36.80
13
DF14-30P-1.25H(**)
538-0020-1-** DF14A-30P-1.25H(**) 538-0045-2-**
30
42.45
36.25
41.45
43.05
11
RoHS
Yes
Note 1.Please order the tube packaging product, multiplying the packaging quantity (pcs.).
Note 2.Please order the embossed tape packaging product according to reel number. (1000 pcs./reel)
B237
All non-RoHS
products
or willSuper
be discontinued
soon. Please
check the products
DF14
Series●1.25mm
Pitch
Low profile
Crimping
Connector
■Right Angle Pin Header (Offset, SMT)
A
Contact No. 1
P=1.25
5.7
1.6
0.3
B238
2.4
0.8
D +0.2
A±0.05
P=1.25±0.05
1.4±0.1
(0.4)
(0.5)
0.7±0.05
6.7±0.1
(0.3)
3.6±0.1
(0.5)
B
C
1.3 +0.2
Unit: mm
Part Number
CL No.
Number of Contacts
A
B
C
D
6.8
10.1
7.2
DF14H-02P-1.25H(**)
538-0177-3-**
2
1.25
DF14H-20P-1.25H(**)
538-0167-0-**
30
23.75
29.3
32.6
29.7
DF14H-30P-1.25H(**)
538-0188-0-**
30
36.25
41.8
45.1
42.2
RoHS
Note 1.Please order the embossed tape packaging product according to reel number. (1000 pcs./reel)
Yes
or contact
DF14website
Series●1.25mm
Crimping
BEmbossed Carrier Tape Dimensions (JIS-C-0806)
■ 2 to 10 Contacts
■ 15, 20, 25, 30 Contacts
Unit: mm
Inserted Connector
Number of Contacts
A
B
C
D
DF14/14A- 2P-1.25H
2
16
7.5
16.4
DF14/14A- 3P-1.25H
3
16
7.5
16.4
DF14/14A- 4P-1.25H
4
24
11.5
24.4
DF14/14A- 5P-1.25H
5
24
11.5
24.4
DF14/14A- 6P-1.25H
6
24
11.5
24.4
DF14/14A- 7P-1.25H
7
24
11.5
24.4
DF14/14A- 8P-1.25H
8
24
11.5
24.4
DF14/14A- 9P-1.25H
9
24
11.5
24.4
DF14/14A-10P-1.25H
10
24
11.5
24.4
DF14/14A-15P-1.25H
15
44
20.2
44.4
40.4
DF14/14A-20P-1.25H
20.2
44.4
40.4
DF14/14A-25P-1.25H
25
56
26.2
56.4
52.4
DF14/14A-30P-1.25H
30
56
26.2
56.4
52.4
B239
All non-RoHS
products
or willSuper
be discontinued
soon. Please
check the products
DF14
Series●1.25mm
Pitch
Low profile
Crimping
Connector
DF14H-*P- 1.25H
B240
2±0.1
12±0.1
0.3±0.1
4±0.1
(3)
.5 +
B—B
D±0.1
A±0.3
C
B
Unreeling direction
C—C
Ø1.5 Lead hole depth
A
Product name label
Ø21±
0.8
Ø330±2
(Ø80)
3±
0.5
Unreeling direction
2±0.5
C +20
(C+6)MAX
Unit: mm
Inserted Connector
Number of Contacts
(3)
0.3±0.1
B±0.1
B±0.1
A±0.3
C
Ø1
B
Ø1
.5
+0
0 .1
12±0.1
Ø1
2±0.1
4±0.1
1.75±0.1
■ 20, 30 Contacts
1.75±0.1
■ 2 Contacts
A
B
C
D
DF14H- 2P-1.25H
2
24
11.5
24.4
DF14H- 20P-1.25H
20.2
44.4
40.4
DF14H- 30P-1.25H
30
56
26.2
56.4
52.4
or contact
DF14website
Series●1.25mm
Crimping
BPrecautions
1. Recommended Temperature Profile (SMT)
Temperature
250ç
Preheating area 150ç for 60 to 120 seconds
Max. 240
220
200ç
150ç
Powered by TCPDF (www.tcpdf.org)
IR reflow condition
10s max.
Soldering area 250 for 10 seconds max.
220ç min. 60 seconds max.
60s max.
Soldering
60 to 120s
Preheating
100ç
Time
2. Recommended Manual Soldering Condition (SMT)
3. Recommended Screen Thickness (SMT)
4. Board Sled (SMT)
5. Cleaning Condition
6. Connection Condition
7. Precautions
8. Cautions
Note 1.Up to 2 cycles of Reflow soldering are possible under the same conditions, provided
that there is a return to normal temperature between the first and second cycle.
Note 2.The temperature profile indicates the board surface temperature at the point of
contacts with the connector terminals.
Manual soldering: 290ç for 2 seconds
0.15 to 0.2mm
Max 0.03mm at the connector center area, based on both connector edges
Refer to Nylon Connector Use Hand book.
■Be careful to carry out the crimping operation according to the "Crimping Condition Sheet"
and "Crimping Quality Reference", because the crimping contact style is too small.
■Be careful for an excessive scoop insertion/extraction, which will cause damage to the
product.
BPrecautions
Precautions at Time of Insertion
Precautions at Time of Disconnection
Handling
Handling
Method: Lightly grasping the base of the cable, press the
connector with your finger and insert it.
Method: Grasp the cable so that the entire cable is pulled
evenly and pull it out.
Insertion Angle
Angle of Removal
[Caution] Do not insert at an angle of 30° or greater. Doing so
will cause contact deformation or case damage.
Method: Insert with the connector parallel.
[Caution] Do not remove at an angle of 30° or greater. Doing so
Method: Remove with the connector parallel.
Parallel
Diagonal
Parallel
Diagonal
Parallel
Diagonal
Parallel
Diagonal
B241
