0717A0BA40C
0717A0BA40C
    ARGOSY(优群)
    CONN_29.9X7.2MM_SM
    MINIPCIE H4.0
0717A0BA40C 数据手册
A B C D E F Halogen Free CL OF KEY 1.65 2×0.15 2.35 Date Code (Year Week) 1 2.40 0.80 2.40 1 7×0.8= 5.60 17×0.8= 13.60 CL 6.00 XXXX 7.20 6.45 C 2 2 2.05 ●◆ Z 1.95 17×0.8= 13.60 7×0.8= 5.60 1.15 0.80 TYP. 2x0.60 4.00 29.90 3 3 25.90 CL 1.30 + 0.10 0.00 F C 4 12.50 0.85 4 3.85 ●◆25.00 ±0.05 1.10 CL Allen Ma B E100161A Mason 06/01/2010 REV. ECO NO. DRAW. DATE MATERIAL: SEE NOTES A FINISH: SEE NOTES B ±0.30 X. ±0.20 .X ±0.10 .XX .XXX ±0.05 09/13/2013 SCALE: 4:1 UNITS: mm SHEET: 1/2 C 6 4.FINISH: TERMINAL: NICKEL UNDERPLATING ALL OVER BASE MATERIAL CONTACT AREA : GOLD FLASH PLATING OVER UNDERPLATE SOLDER AREA : GOLD FLASH PLATING OVER UNDERPLATE 5. INSPECTION SYMBOL: ● : MANUFACTURER INSPECTION ◆ : Q.C INSPECTION GENERAL TOLERANCE E130421A 4.75 ±0.20 Pin #1 0.70 NOTE: 1. SOLDER TAIL TO BE WITHIN 0.05mm UPWARD AND 0.2mm DOWNWARD FROM Z-DATUM PLACE, AND COPLANARITY OF SOLDER TAILS TO BE WITHIN 0.10mm, MEASUREMENT POINT IS SOLDER TAILS TIP. 2. HSF:HSF CONCRAFT LEVEL1 3. MATERIAL: HOUSING :HIGH-TEMPERATURE PLASTIC; COLOR:BLACK,UL 94 V-0 TERMINAL:COPPER ALLOY C 5 4.35 ±0.20 H Pin #51 8 5 1.3 6 7 G Pin #2 3.80 5 ●◆0.15 ±0.02 TYP. 0.15 F G H 3.40 Pin #52 REV. C X.° .X° .XX° ±2.00° PART N0: DRAW: 0717A0BA40C Allen Ma TITLE: ±1.00° CHECKED: ±0.50° MINI PCI EXPRESS ASSEMBLY APPROVE: DRAWING NO: DATE: 09/13/2013 0717A0BA40C 深圳市逸沛兴电子科技有限公司 D 7 E F 8 A B 2× 2.60 24.20 CL C 1 2.4 max. (2×)5.80 1.35 max. (2×)5.80 TOP SIDE DIM.B 1 BOTTOM SIDE 3.85 0.80 Pin#1 A 13.60 Pin#51 CL of Card Width C 5.60 C B 2×R 0.8 0m Pin#2 ax. B Pin#52 25.70 APPLICABLE MODULE DIMENSION 0.10 M A B 5.10 min. 13.60 2 2×2.15 REF 3.20 min. 5.60 3.20 min. DIM.A+0/-0.30 8.25 2 F Halogen Free (2×)5.80 B E 4.20 0.10 A M D (2×)5.80 30.00 0.10 C 0.00 - 0.30 A B C C 3 3 4.00 L A B C 0.05 A 2.05 A 45° ±7° 1.00 0.10 0.80 PITCH 4 B (2 : 1) C (4 : 1) A (2 : 1) 27.15 (2×)2.30 0.20 L (2×)3.20 0.20 L D E 5 MODULE 10.30 D E 8.65REF 17×0.8= 13.60 Pin#51 1.10 ±0.05 0.15 D E CONNECTOR CL of inserted card key 7×0.8= 5.60 2.15 0.70 Pin#1 5 4.10 1.50 2× 3.50 4 0.25max. 0.10 4.00 4.20 0.25 max. 0.60 ±0.05 TYP. 4.00 2.55 ±0.05 TYP. 1.65 5 1.60 ±0.0 F 6 E 2.1 30° RE 0.70 6 0.80 TYP Pin#52 MATING CONDITION P.C.B. 2.00 ±0.10 0.20 L D E 7×0.8= 5.60 17×0.8= 13.60 10.70 4.10 1.10 Pin#2 0.60 ±0.05 TYP 0.10 L D E 0.05 D 25.00 Card Types 7 HALF CARD FULL CARD 8 DIM.A DIM.B 26.80 50.95 23.90 48.05 C E130421A Allen Ma 09/13/2013 B E100161A Mason 06/01/2010 REV. ECO NO. DRAW DATE MATERIAL: SEE NOTES A FINISH: SEE NOTES B SCALE: 1:1 Datum D is the top surface of PCB. RECOMMENDED P.C.B. LAYOUT TOP VIEW(2:1) PART N0: DRAW: GENERAL TOLERANCE 0717A0BA40C Allen Ma ±2.00° ±0.30 X.° X. TITLE: ±0.20 .X° ±1.00° CHECKED: .X MINI PCI EXPRESS .XX° ±0.10 ±0.50° ASSEMBLY .XX .XXX ±0.05 APPROVE: DRAWING NO: DATE: UNITS: 0717A0BA40C mm 09/13/2013 SHEET: 2/2 C REV. C 深圳市逸沛兴电子科技有限公司 D E F 7 8
0717A0BA40C 价格&库存
很抱歉,暂时无法提供与“0717A0BA40C”相匹配的价格&库存,您可以联系我们找货
0717A0BA40C
    • 1+1.56975
    库存:538
    0717A0BA40C
      • 500+2.24480
