0717A0BA80C
0717A0BA80C
    ARGOSY(优群)
    CONN_29.9X7.2MM_SM
    MINIPCIE H8.0
0717A0BA80C 数据手册
A B C D E F Halogen Free C 7×0.8= 5.60 2.35 2.40 Date Code (Year Week) 1 XXXX 7.20 6.45 6.00 1 (2×) 0.15 CL OF KEY 1.65 CL 0.80 17×0.8= 13.60 2.40 2 0.80 PITCH 2.05 1.95 17×0.8= 13.60 ●◆ 7×0.8= 5.60 (2×)0.60 29.90 25.90 8.00 1.30 CL 3 4 Z 0.80 2 F +0.10 0.00 3 4 0.85 12.50 3.85 ●◆25.00 ±0.05 Pin #2 H Pin #51 NOTE: 1. SOLDER TAIL TO BE WITHIN 0.05mm UPWARD AND 0.2mm DOWNWARD FROM Z-DATUM PLACE, AND COPLANARITY OF SOLDER TAILS TO BE WITHIN 0.10mm, MEASUREMENT POINT IS SOLDER TAILS TIP. 2. HSF:HSF CONCRAFT LEVEL1 3. MATERIAL: HOUSING :HIGH-TEMPERATURE PLASTIC; COLOR:BLACK,UL 94 V-0 7 TERMINAL:COPPER ALLOY E130425A Allen Ma 12/31/2013 B E100161A Mason 06/01/2010 A E100017A Andrew 03/04/2010 REV. ECO NO. DRAW MATERIAL: SEE NOTES A SEE NOTES B SCALE: 4/1 ±0.30 X. ±0.20 .X ±0.10 .XX .XXX ±0.05 UNITS: mm SHEET: 1/2 C 6 4.FINISH: TERMINAL: NICKEL UNDERPLATING ALL OVER BASE MATERIAL CONTACT AREA : GOLD FLASH PLATING OVER UNDERPLATE SOLDER AREA : GOLD FLASH PLATING OVER UNDERPLATE 5. INSPECTION SYMBOL: ● : MANUFACTURER INSPECTION ◆ : Q.C INSPECTION DATE FINISH: 5 Pin#1 0.70 GENERAL TOLERANCE C 4.75 ±0.20 1.35 6 8 G 4.35 ±0.20 CL 3.80 5 1.10 3.40 Pin #52 ●◆0.15 ±0.02 TYP 0.15 F G H REV. C X.° .X° .XX° ±2.00° PART N0: DRAW: 0717A0BA80C Allen Ma TITLE: ±1.00° CHECKED: ±0.50° APPROVE: MINI PCI EXPRESS ASSEMBLY DRAWING NO: DATE: 12/31/2013 0717A0BA80C 深圳市逸沛兴电子科技有限公司 D 7 E F 8 A B C D E F Halogen Free 0.00 30.00 - 0.30 0.10 2.60 M A B C 24.20 CL C 1 2.4 max. (2×)5.80 1.35 max. 1 3.85 0.80 Pin#1 2×2.15 REF C 13.60 C B Pin#51 .8 2×R 0 B 25.70 CL of Card Width 0.10 M A B Pin#2 C 3 APPLICABLE MODULE DIMENSION 4.00 1.65 2.55 ±0.05 TYP 3 5.60 . 0 max Pin#52 A 2 3.20 min. 5.10 min. 13.60 4.20 5.60 3.20 min. 2 BOTTOM SIDE 8.20 DIM.B DIM.A+0/-0.30 (2×)5.80 TOP SIDE 0.60 ±0.05 TYP 0.10 A B L C 4.20 4.00 0.05 A 4.00 A 45° ± 2.05 0.25max. B (2×)5.80 0.10 A (2×) 5.80 2× 7° 1.00 0.10 0.80 PITCH 4 B (2 : 1) 1.50 A (2 : 1) 27.15 10.30 8.65REF (2×) 2.30 0.20 L (2×)3.20 0.20 L 5 CONNECTOR D E CL of inserted card key 7×0.8= 5.60 D E 1.10 ±0.05 17×0.8= 13.60 0.15 D E Pin#51 2.15 0.70 5 Pin#1 0.70 REF E 1.10 Pin#52 0.80 TYP. 2.00 ±0.10 P.C.B. 0.20 L D Pin#2 0.60 ±0.05 TYP 7×0.8= 5.60 E 17×0.8= 13.60 0.10 L 10.70 D 4.10 6.1 EF 30° R 5 1.60 ±0.0 6 MATING CONDITION 4.10 MODULE 2× 3.50 0.25 max. C (4 : 1) 4 6 E 0.05 D 25.00 7 DIM.A DIM.B HALF CARD 26.80 23.90 FULL CARD 50.95 48.05 Datum D is the top surface of PCB. RECOMMENDED P.C.B. LAYOUT TOP VIEW(2:1) GENERAL TOLERANCE 8 C E130425A Allen Ma 12/31/2013 B E100161A Mason 06/01/2010 A E100017A Andrew 03/04/2010 REV. ECO NO. MATERIAL: SEE NOTES A DRAW ±0.30 X. ±0.20 .X ±0.10 .XX .XXX ±0.05 UNITS: mm DATE FINISH: SEE NOTES B SCALE: 1:1 SHEET: 2/2 C REV. C X.° .X° .XX° ±2.00° 7 PART N0: DRAW: 0717A0BA80C Allen Ma TITLE: ±1.00° CHECKED: ±0.50° MINI PCI EXPRESS ASSEMBLY APPROVE: DRAWING NO: DATE: 12/31/2013 0717A0BA80C 深圳市逸沛兴电子科技有限公司 D E F 8
0717A0BA80C 价格&库存
很抱歉,暂时无法提供与“0717A0BA80C”相匹配的价格&库存,您可以联系我们找货
0717A0BA80C
    • 1+2.26800
    库存:66
