PMEG1030EH; PMEG1030EJ
10 V, 3 A ultra low VF MEGA Schottky barrier rectifiers
Rev. 04 — 15 January 2010
Product data sheet
1. Product profile
1.1 General description
Planar Maximum Efficiency General Application (MEGA) Schottky barrier rectifiers with an
integrated guard ring for stress protection encapsulated in small SMD plastic packages.
Table 1.
Product overview
Type number
Package
Configuration
Nexperia
JEITA
PMEG1030EH
SOD123F
single isolated diodes
PMEG1030EJ
SOD323F
SC-90
1.2 Features
Forward current: 3 A
Reverse voltage: 10 V
Ultra low forward voltage
Small and flat lead SMD package
1.3 Applications
Low voltage rectification
High efficiency DC-to-DC conversion
Switched-mode power supply
Inverse polarity protection
Low power consumption applications
1.4 Quick reference data
Table 2.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
IF
forward current
Tsp ≤ 55 °C
3
A
VR
reverse voltage
10
V
390
530
mV
VF
[1]
forward voltage
Pulse test: tp ≤ 300 μs; δ ≤ 0.02.
IF = 3 A
[1]
Nexperia
2. Pinning information
Table 3.
Pinning
Pin
Description
1
cathode
2
anode
Simplified outline
Symbol
[1]
1
1
2
2
sym001
001aab540
[1]
The marking bar indicates the cathode.
3. Ordering information
Table 4.
Type number
Package
Name
Description
Version
PMEG1030EH
plastic surface mounted package; 2 leads
SOD123F
PMEG1030EJ
SC-90
SOD323F
4. Marking
Table 5.
Marking codes
Type number
Marking code
PMEG1030EH
AC
PMEG1030EJ
E7
PMEG1030EH_EJ_4
Product data sheet
2 of 9
Nexperia B.V. 2017. All rights reserved
Nexperia
5. Limiting values
Table 6.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol Parameter
Conditions
Min
Max
Unit
VR
reverse voltage
10
V
IF
forward current
Tsp ≤ 55 °C
3
A
IFRM
repetitive peak forward
current
tp ≤ 1 ms; δ ≤ 0.25
5.5
A
IFSM
non-repetitive peak forward
current
t = 8 ms; square
wave
[1]
9
A
Ptot
total power dissipation
Tamb ≤ 25 °C
[1]
375
mW
[2]
830
mW
[1]
360
mW
[2]
830
mW
PMEG1030EH
PMEG1030EJ
Tj
junction temperature
150
°C
Tamb
ambient temperature
−65
+150
°C
Tstg
storage temperature
−65
+150
°C
[1]
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard
footprint.
[2]
Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm2.
6. Thermal characteristics
Table 7.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-a)
thermal resistance from
junction to ambient
in free air
[1][2]
330
K/W
[2][3]
150
K/W
[1][2]
350
K/W
[2][3]
150
K/W
PMEG1030EH
60
K/W
PMEG1030EJ
55
K/W
PMEG1030EH
PMEG1030EJ
Rth(j-sp)
junction to solder point
[1]
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
[2]
For Schottky barrier diodes thermal run-away has to be considered, as in some applications the reverse
power losses PR are a significant part of the total power losses. Nomograms for determining the reverse
power losses PR and IF(AV) rating will be available on request.
[3]
PMEG1030EH_EJ_4
Product data sheet
3 of 9
Nexperia
7. Characteristics
Table 8.
Characteristics
Tamb = 25 °C unless otherwise specified.
Symbol
Parameter
Min
Typ
Max
Unit
IF = 0.01 A
100
130
mV
IF = 0.1 A
170
200
mV
IF = 1 A
280
350
mV
[1]
forward voltage
VF
reverse current
IR
diode capacitance
Cd
[1]
Conditions
IF = 3 A
390
530
mV
VR = 5 V
0.55
2
mA
VR = 8 V
0.8
2.5
mA
VR = 10 V
1
3
mA
VR = 1 V; f = 1 MHz
70
85
pF
006aaa290
104
006aaa291
106
IR
(μA)
105
IF
(mA)
103
(1)
(2)
(1)
102
(2)
(3)
104
(4)
103
(3)
10
102
1
10
(4)
10−1
1
0.2
0.3
0.4
0.5
VF (V)
(1) Tamb = 125 °C
6
8
10
VR (V)
(1) Tamb = 125 °C
(2) Tamb = 85 °C
(2) Tamb = 85 °C
(3) Tamb = 25 °C
(3) Tamb = 25 °C
(4) Tamb = −40 °C
(4) Tamb = −40 °C
Fig 1.
4
Forward current as a function of forward
voltage; typical values
Fig 2.
Reverse current as a function of reverse
PMEG1030EH_EJ_4
Product data sheet
4 of 9
Nexperia
006aaa292
130
Cd
(pF)
110
90
70
50
30
4
6
8
10
VR (V)
Tamb = 25 °C; f = 1 MHz
Fig 3.
Diode capacitance as a function of reverse voltage; typical values
8. Package outline
1.7
1.5
1.2
1.0
1.35
1.15
1
0.80
0.65
0.5
0.3
1
0.55
0.35
3.6
3.4
2.7
2.3
2.7
2.5
1.8
1.6
2
2
0.70
0.55
Dimensions in mm
Fig 4.
04-11-29
Package outline SOD123F
0.25
0.10
0.40
0.25
0.25
0.10
Dimensions in mm
Fig 5.
04-09-13
Package outline SOD323F (SC-90)
9. Packing information
Table 9.
Packing methods
The -xxx numbers are the last three digits of the 12NC ordering code.[1]
Type number
Package
Description
Packing quantity
3000
10000
PMEG1030EH
SOD123F
4 mm pitch, 8 mm tape and reel
-115
-135
PMEG1030EJ
SOD323F
-115
-135
[1]
For further information and the availability of packing methods, see Section 13.
PMEG1030EH_EJ_4
Product data sheet
5 of 9
Nexperia
10. Soldering
4.4
4
2.9
1.6
solder lands
solder resist
2.1 1.6
1.1 1.2
solder paste
occupied area
1.1
(2×)
Reflow soldering is the only recommended soldering method.
Dimensions in mm
Fig 6.
Reflow soldering footprint SOD123F
3.05
2.80
2.10
1.60
solder lands
solder resist
1.65
0.95
0.50
0.60
occupied area
solder paste
0.50
(2×)
msa433
Dimensions in mm
Fig 7.
Reflow soldering footprint SOD323F (SC-90)
PMEG1030EH_EJ_4
Product data sheet
6 of 9
Nexperia
11. Revision history
Table 10.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PMEG1030EH_EJ_4
20100115
Product data sheet
PMEG1030EH_EJ_3
Modifications:
This data sheet was changed to reflect the new company name NXP Semiconductors,
including new legal definitions and disclaimers. No changes were made to the technical
content.
PMEG1030EH_EJ_3
20050602
Product data sheet
PMEG1030EH_EJ_2
PMEG1030EH_EJ_2
20050405
Product data sheet
PMEG1030EJ_1
PMEG1030EJ_1
20050124
Product data sheet
PMEG1030EH_EJ_4
Product data sheet
7 of 9
Nexperia
12. Legal information
12.1 Data sheet status
Document status[1][2]
Product status[3]
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
Definition
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
12.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
12.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published at
http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless explicitly
otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from national authorities.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
12.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
13. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
PMEG1030EH_EJ_4
Product data sheet
8 of 9
Nexperia
14. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
10
11
12
12.1
12.2
12.3
12.4
13
14
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . .
General description . . . . . . . . . . . . . . . . . . . . .
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . .
Quick reference data . . . . . . . . . . . . . . . . . . . .
Pinning information . . . . . . . . . . . . . . . . . . . . . .
Ordering information . . . . . . . . . . . . . . . . . . . . .
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . .
Thermal characteristics . . . . . . . . . . . . . . . . . .
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . .
Package outline . . . . . . . . . . . . . . . . . . . . . . . . .
Packing information . . . . . . . . . . . . . . . . . . . . .
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Revision history . . . . . . . . . . . . . . . . . . . . . . . . .
Legal information. . . . . . . . . . . . . . . . . . . . . . . .
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .
Contact information. . . . . . . . . . . . . . . . . . . . . .
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Date of release: 15 January 2010
1
1
1
1
1
2
2
2
3
3
4
5
5
6
7
8
8
8
8
8
8
9
