Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
DISCRETE SEMICONDUCTORS
DATA SHEET
ok, halfpage
M3D302
1PS74SB23
Schottky barrier diode
Product specification
Supersedes data of 2001 Aug 27
2003 Aug 04
1PS74SB23
FEATURES
PINNING
• Ultra fast switching speed
PIN
DESCRIPTION
• Low forward voltage
1
anode
• Fast recovery time
2
cathode
• Guard ring protected
3
anode
• Small plastic SMD package
4
anode
• Capability of absorbing very high surge current.
5
cathode
6
anode
APPLICATIONS
• Rectification
• Circuit protection
handbook, halfpage 6
• Polarity protection
5
4
• Switched-mode power supplies.
1, 3,
4, 6
2, 5
DESCRIPTION
1
Planar Schottky barrier diode encapsulated in an SC-74
(SOT457) small plastic SMD package.
2
Top view
3
MAM421
Marking code: P1.
Fig.1
Simplified outline SC-74 (SOT457) and
symbol.
LIMITING VALUES
In accordance with the Absolute Maximum Rating System (IEC 60134).
SYMBOL
PARAMETER
CONDITIONS
MIN.
MAX.
UNIT
25
V
1
A
25
A
0.5
A
storage temperature
−65
+150
°C
junction temperature
125
°C
VR
continuous reverse voltage
IF
continuous forward current
IFSM
non-repetitive peak forward current
tp = 8.3 ms; half sinewave;
JEDEC method; note 1
IRSM
non-repetitive peak reverse current
tp = 100 µs
Tstg
Tj
Note
1. Pins 1, 3, 4 and 6 are connected in parallel; pins 2 and 5 are connected in parallel.
2003 Aug 04
2
1PS74SB23
ELECTRICAL CHARACTERISTICS
Tamb = 25 °C unless otherwise specified.
SYMBOL
VF
PARAMETER
forward voltage
IR
reverse current
Cd
diode capacitance
CONDITIONS
TYP.
MAX.
UNIT
IF = 100 mA
260
300
mV
IF = 1 A
400
450
mV
VR = 20 V; note 1; see Fig.3
80
500
µA
VR = 25 V; note 1; see Fig.3
1
mA
f = 1 MHz; VR = 4 V; see Fig.4
100
pF
Note
1. Pulse test: tp = 300 µs; δ = 0.02.
THERMAL CHARACTERISTICS
SYMBOL
Rth j-a
PARAMETER
thermal resistance from junction to ambient
CONDITIONS
note 1
Note
1. Refer to SC-74 (SOT457) standard mounting conditions.
2003 Aug 04
3
VALUE
UNIT
250
K/W
1PS74SB23
GRAPHICAL DATA
MBL886
handbook,
4
10halfpage
MHB970
105
handbook, halfpage
IR
IF
(mA)
(1)
(µA)
(2)
104
103
(3)
103
(1)
(2)
102
(3)
(4)
10
10
1
1
400
600
800
VF (mV)
(1) Tamb = 125 °C.
(2) Tamb = 100 °C.
(3) Tamb = 75 °C.
(4) Tamb = 25 °C.
Fig.2
Fig.3
MBK571
Cd
(pF)
102
VR (V)
30
f = 1 MHz; Tamb = 25 °C.
Fig.4
Diode capacitance as a function of reverse
voltage; typical values.
2003 Aug 04
VR (V)
30
(1) Tamb = 125 °C.
(2) Tamb = 100 °C.
(3) Tamb = 75 °C.
(4) Tamb = 25 °C.
Forward current as a function of forward
103
handbook, halfpage
10
(4)
102
4
Reverse current as a function of reverse
1PS74SB23
PACKAGE OUTLINE
Plastic surface mounted package; 6 leads
SOT457
D
E
B
y
A
HE
6
5
X
v M A
4
Q
pin 1
index
A
A1
c
1
2
3
Lp
bp
e
w M B
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
bp
c
D
E
e
HE
Lp
Q
v
w
y
mm
1.1
0.9
0.1
0.013
0.40
0.25
0.26
0.10
3.1
2.7
1.7
1.3
0.95
3.0
2.5
0.6
0.2
0.33
0.23
0.2
0.2
0.1
OUTLINE
VERSION
SOT457
2003 Aug 04
REFERENCES
IEC
JEDEC
EIAJ
SC-74
5
EUROPEAN
PROJECTION
ISSUE DATE
97-02-28
01-05-04
1PS74SB23
DATA SHEET STATUS
LEVEL
DATA SHEET
STATUS(1)
PRODUCT
STATUS(2)(3)
Development
DEFINITION
I
Objective data
II
Preliminary data Qualification
This data sheet contains data from the preliminary specification.
Supplementary data will be published at a later date. Philips
Semiconductors reserves the right to change the specification without
notice, in order to improve the design and supply the best possible
product.
III
Product data
This data sheet contains data from the product specification. Philips
Semiconductors reserves the right to make changes at any time in order
to improve the design, manufacturing and supply. Relevant changes will
be communicated via a Customer Product/Process Change Notification
(CPCN).
Production
This data sheet contains data from the objective specification for product
development. Philips Semiconductors reserves the right to change the
specification in any manner without notice.
Notes
1. Please consult the most recently issued data sheet before initiating or completing a design.
2. The product status of the device(s) described in this data sheet may have changed since this data sheet was
published. The latest information is available on the Internet at URL http://www.semiconductors.philips.com.
3. For data sheets describing multiple type numbers, the highest-level product status determines the data sheet status.
DEFINITIONS
DISCLAIMERS
Short-form specification The data in a short-form
specification is extracted from a full data sheet with the
same type number and title. For detailed information see
the relevant data sheet or data handbook.
Life support applications These products are not
designed for use in life support appliances, devices, or
systems where malfunction of these products can
reasonably be expected to result in personal injury. Philips
Semiconductors customers using or selling these products
for use in such applications do so at their own risk and
agree to fully indemnify Philips Semiconductors for any
damages resulting from such application.
Limiting values definition Limiting values given are in
(IEC 60134). Stress above one or more of the limiting
values may cause permanent damage to the device.
These are stress ratings only and operation of the device
at these or at any other conditions above those given in the
Characteristics sections of the specification is not implied.
Exposure to limiting values for extended periods may
affect device reliability.
Right to make changes Philips Semiconductors
reserves the right to make changes in the products including circuits, standard cells, and/or software described or contained herein in order to improve design
and/or performance. When the product is in full production
(status ‘Production’), relevant changes will be
Notification (CPCN). Philips Semiconductors assumes no
responsibility or liability for the use of any of these
products, conveys no licence or title under any patent,
copyright, or mask work right to these products, and
makes no representations or warranties that these
products are free from patent, copyright, or mask work
right infringement, unless otherwise specified.
Application information Applications that are
described herein for any of these products are for
illustrative purposes only. Philips Semiconductors make
no representation or warranty that such applications will be
suitable for the specified use without further testing or
modification.
2003 Aug 04
6
Philips Semiconductors – a worldwide company
Contact information
For additional information please visit http://www.semiconductors.philips.com.
Fax: +31 40 27 24825
For sales offices addresses send e-mail to: sales.addresses@www.semiconductors.philips.com.
SCA75
© Koninklijke Philips Electronics N.V. 2003
All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner.
The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed
without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license
under patent- or other industrial or intellectual property rights.
Printed in The Netherlands
613514/03/pp7
Date of release: 2003
Aug 04
Document order number:
9397 750 11055
很抱歉,暂时无法提供与“1PS74SB23,125”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4.007501+0.48482
- 10+3.0855710+0.37329
- 100+1.85217100+0.22407
- 500+1.71529500+0.20752
- 1000+1.166371000+0.14111
