PSMN3R3-80ES
N-channel 80 V, 3.3 mΩ standard level MOSFET in I2PAK
Rev. 1 — 31 October 2011
Product data sheet
1. Product profile
1.1 General description
Standard level N-channel MOSFET in I2PAK package qualified to 175C. This product is
designed and qualified for use in a wide range of industrial, communications and domestic
equipment.
1.2 Features and benefits
High efficiency due to low switching
and conduction losses
Suitable for standard level gate drive
1.3 Applications
DC-to-DC converters
Motor control
Load switch
Server power supplies
1.4 Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage
Tj ≥ 25 °C; Tj ≤ 175 °C
80
V
120
A
338
W
-55
175
°C
4.6
5.4
mΩ
2.8
3.3
mΩ
ID
drain current
Tmb = 25 °C; VGS = 10 V; see Figure 1
Ptot
total power dissipation
Tmb = 25 °C; see Figure 2
Tj
junction temperature
[1]
Static characteristics
RDSon
drain-source on-state
resistance
VGS = 10 V; ID = 25 A; Tj = 100 °C;
see Figure 12
VGS = 10 V; ID = 25 A; Tj = 25 °C;
see Figure 13
[2]
Dynamic characteristics
QGD
gate-drain charge
QG(tot)
total gate charge
VGS = 10 V; ID = 75 A; VDS = 40 V;
see Figure 14; see Figure 15
27
nC
139
nC
676
mJ
Avalanche ruggedness
EDS(AL)S
non-repetitive drain-source
avalanche energy
[1]
Continuous current is limited by package.
[2]
Measured 3 mm from package.
VGS = 10 V; Tj(init) = 25 °C; ID = 120 A;
Vsup ≤ 80 V; RGS = 50 Ω; unclamped
PSMN3R3-80ES
Nexperia
2. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
1
G
gate
2
D
drain
3
S
source
mb
D
drain
Simplified outline
Graphic symbol
mb
D
G
mbb076
S
1 2 3
SOT226 (I2PAK)
3. Ordering information
Table 3.
Type number
Package
PSMN3R3-80ES
Name
Description
Version
I2PAK
plastic single-ended package (I2PAK); TO-262
SOT226
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
80
V
VDGR
drain-gate voltage
Tj ≥ 25 °C; Tj ≤ 175 °C; RGS = 20 kΩ
80
V
VGS
gate-source voltage
drain current
ID
-20
V
VGS = 10 V; Tmb = 100 °C; see Figure 1
[1]
120
A
VGS = 10 V; Tmb = 25 °C; see Figure 1
[1]
120
A
IDM
peak drain current
pulsed; tp ≤ 10 µs; Tmb = 25 °C;
see Figure 3
830
A
Ptot
338
W
Tstg
storage temperature
-55
175
°C
Tj
-55
175
°C
Tsld(M)
peak soldering temperature
260
°C
Source-drain diode
[1]
IS
source current
Tmb = 25 °C
120
A
ISM
peak source current
830
A
676
mJ
EDS(AL)S
[1]
avalanche energy
PSMN3R3-80ES
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 14
PSMN3R3-80ES
Nexperia
ID
(A)
003aag824
240
03aa16
120
Pder
200
80
160
120
(1)
80
40
40
Fig 1.
50
100
150
Tmb (°C)
200
100
150
200
Tmb (°C)
Continuous drain current as a function of
mounting base temperature
Fig 2.
Normalized total power dissipation as a
function of mounting base temperature
003aag823
103
Limit RDSon = VDS / ID
ID
(A)
tp =10 μ s
10
2
100 μ s
10
DC
1 ms
10 ms
100 ms
1
10-1
0.1
1
10
100
1000
VDS (V)
Fig 3.
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
PSMN3R3-80ES
Product data sheet
3 of 14
PSMN3R3-80ES
Nexperia
5. Thermal characteristics
Table 5.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-mb)
thermal resistance from junction to mounting base
see Figure 4
0.22
0.44
K/W
Rth(j-a)
thermal resistance from junction to ambient
Vertical in free air
60
K/W
003aaf613
1
Zth(j-mb)
(K/W)
10-1
δ = 0.5
0.2
0.1
0.05
10-2
P
0.02
δ=
tp
T
single shot
t
tp
T
-3
10
10-6
Fig 4.
10-5
10-4
10-3
10-2
10-1
tp (s)
1
Transient thermal impedance from junction to mounting base as a function of pulse duration
PSMN3R3-80ES
Product data sheet
4 of 14
PSMN3R3-80ES
Nexperia
6. Characteristics
Table 6.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
V(BR)DSS
drain-source breakdown
voltage
ID = 250 µA; VGS = 0 V; Tj = -55 °C
73
V
ID = 250 µA; VGS = 0 V; Tj = 25 °C
80
V
VGS(th)
gate-source threshold
voltage
ID = 1 mA; VDS = VGS; Tj = 175 °C;
see Figure 10
1
V
ID = 1 mA; VDS = VGS; Tj = -55 °C;
see Figure 10
4.6
V
ID = 1 mA; VDS = VGS; Tj = 25 °C;
see Figure 10; see Figure 11
2
3
4
V
IDSS
drain leakage current
VDS = 80 V; VGS = 0 V; Tj = 25 °C
0.02
10
µA
VDS = 80 V; VGS = 0 V; Tj = 175 °C
500
µA
IGSS
gate leakage current
VGS = -20 V; VDS = 0 V; Tj = 25 °C
100
nA
VGS = 20 V; VDS = 0 V; Tj = 25 °C
100
nA
VGS = 10 V; ID = 25 A; Tj = 175 °C;
see Figure 12
6.7
7.9
mΩ
see Figure 12
4.6
5.4
mΩ
2.8
3.3
mΩ
f = 1 MHz
0.9
Ω
RDSon
resistance
see Figure 13
RG
internal gate resistance (AC)
[1]
QG(tot)
total gate charge
ID = 0 A; VDS = 0 V; VGS = 10 V
135
nC
139
nC
gate-source charge
ID = 75 A; VDS = 40 V; VGS = 10 V;
QGS
51
nC
QGS(th)
pre-threshold gate-source
charge
30
nC
QGS(th-pl)
post-threshold gate-source
charge
21
nC
QGD
gate-drain charge
27
nC
VGS(pl)
gate-source plateau voltage
ID = 25 A; VDS = 40 V; see Figure 14;
see Figure 15
5.8
V
Ciss
input capacitance
9961
pF
Coss
output capacitance
VDS = 40 V; VGS = 0 V; f = 1 MHz;
Tj = 25 °C; see Figure 16
847
pF
Crss
reverse transfer capacitance
401
pF
td(on)
turn-on delay time
tr
rise time
td(off)
tf
VDS = 40 V; RL = 0.53 Ω; VGS = 10 V;
RG(ext) = 10 Ω; ID = 75 A
41
ns
43
ns
turn-off delay time
109
ns
fall time
44
ns
PSMN3R3-80ES
Product data sheet
5 of 14
PSMN3R3-80ES
Nexperia
Table 6.
Characteristics …continued
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
0.8
1.2
V
63
ns
121
nC
Source-drain diode
VSD
source-drain voltage
IS = 25 A; VGS = 0 V; Tj = 25 °C;
see Figure 17
trr
reverse recovery time
Qr
recovered charge
IS = 25 A; dIS/dt = 100 A/µs;
VGS = 0 V; VDS = 20 V
[1]
003aaf602
250
gfs
(S)
003aaf603
75
ID
(A)
200
50
150
100
25
Tj = 175 °C
50
Fig 5.
60
ID (A)
80
Forward transconductance as a function of
drain current; typical values
003aag797
8
RDSon
(mΩ)
Fig 6.
2
4
VGS (V)
003aaf606
16000
C
(pF)
Ciss
12000
4
8000
2
4000
8
12
16
Drain-source on-state resistance as a function
of gate-source voltage; typical values
PSMN3R3-80ES
Product data sheet
VGS (V)
Fig 8.
6
Transfer characteristics: drain current as a
function of gate-source voltage; typical values
6
Fig 7.
Tj = 25 °C
Crss
1
2
VGS (V) 10
10
Input and reverse transfer capacitances as a
6 of 14
PSMN3R3-80ES
Nexperia
003aag796
80
10.0 6.0 5.0
VGS (V) =
ID
(A)
003aad280
5
VGS(th)
(V)
4
max
60
3
typ
4.5
40
2
min
Fig 9.
0.2
0.4
0.6
0.8
VDS (V)
−60
1
Output characteristics; drain current as a
function of drain-source voltage; typical values
ID
(A)
60
120
180
Tj (°C)
Fig 10. Gate-source threshold voltage as a function of
03aa35
10−1
003aaf608
3
a
min
10−2
typ
max
2.4
10−3
1.8
10−4
1.2
10−5
0.6
10−6
4
6
120
VGS (V)
Fig 11. Sub-threshold drain current as a function of
gate-source voltage
PSMN3R3-80ES
Product data sheet
Tj (°C)
180
Fig 12. Normailzed drain-source on-state resistance
factor as a function of junction temperature
7 of 14
PSMN3R3-80ES
Nexperia
003aag798
12
RDSon VGS (V) =
(mΩ)
10
VDS
4.5
ID
8
VGS(pl)
VGS(th)
6
VGS
5.0
4
QGS1
6.0
QGS
10.0
2
QGS2
QGD
QG(tot)
003aaa508
60
ID (A)
80
Fig 13. Drain-source on-state resistance as a function
of drain current; typical values
003aaf609
10
VGS
(V)
Fig 14. Gate charge waveform definitions
003aaf610
105
C
(pF)
40V 64V
104
7.5
Ciss
VDS = 16V
103
5
Coss
Crss
102
2.5
80
120 Q (nC)160
G
Fig 15. Gate-source voltage as a function of gate
charge; typical values
PSMN3R3-80ES
Product data sheet
10
10-1
1
10
VDS (V)
102
Fig 16. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
8 of 14
PSMN3R3-80ES
Nexperia
003aaf611
25
IS
(A)
10
5
Tj = 175 °C
Tj = 25 °C
0.5
0.75
VSD (V)
1
Fig 17. Source current as a function of source-drain voltage; typical values
PSMN3R3-80ES
Product data sheet
9 of 14
PSMN3R3-80ES
Nexperia
7. Package outline
Plastic single-ended package (I2PAK); low-profile 3-lead TO-262
SOT226
A
A1
E
D1
mounting
base
D
L1
Q
b1
L
1
2
3
c
b
e
e
10 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
b
b1
c
D
max
D1
E
e
L
L1
Q
mm
4.5
4.1
1.40
1.27
0.85
0.60
1.3
1.0
0.7
0.4
11
1.6
1.2
10.3
9.7
2.54
15.0
13.5
3.30
2.79
2.6
2.2
OUTLINE
VERSION
SOT226
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
06-02-14
09-08-25
TO-262
Fig 18. Package outline SOT226 (I2PAK)
PSMN3R3-80ES
Product data sheet
10 of 14
PSMN3R3-80ES
Nexperia
8. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PSMN3R3-80ES v.1
20111031
Product data sheet
PSMN3R3-80ES
Product data sheet
11 of 14
PSMN3R3-80ES
Nexperia
9. Legal information
9.1
Data sheet status
Document status [1] [2]
Product status [3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nexperia.com.
9.2
Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
9.3
Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
PSMN3R3-80ES
Product data sheet
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
12 of 14
PSMN3R3-80ES
Nexperia
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein may
be subject to export control regulations. Export might require a prior
authorization from competent authorities.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
9.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
non-automotive qualified products in automotive equipment or applications.
10. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
PSMN3R3-80ES
Product data sheet
13 of 14
PSMN3R3-80ES
Nexperia
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .2
Thermal characteristics . . . . . . . . . . . . . . . . . . .4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5
Package outline . . . . . . . . . . . . . . . . . . . . . . . . .10
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 11
Legal information. . . . . . . . . . . . . . . . . . . . . . . .12
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .12
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .12
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .12
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .13
Contact information. . . . . . . . . . . . . . . . . . . . . .13
Date of release: 31 October 2011
