PSMN7R0-100ES
N-channel 100V 6.8 mΩ standard level MOSFET in I2PAK.
Rev. 03 — 23 February 2010
Product data sheet
1. Product profile
1.1 General description
Standard level N-channel MOSFET in I2PAK package qualified to 175C. This product is
designed and qualified for use in a wide range of industrial, communications and domestic
equipment.
1.2 Features and benefits
High efficiency due to low switching
and conduction losses
Suitable for standard level gate drive
1.3 Applications
DC-to-DC converters
Motor control
Load switching
Server power supplies
1.4 Quick reference data
Table 1.
Quick reference
Symbol Parameter
VDS
Conditions
Min
Typ
Max
Unit
100
V
100
A
269
W
-55
175
°C
VGS = 10 V; Tj(init) = 25 °C;
ID = 100 A; Vsup ≤ 100 V;
unclamped; RGS = 50 Ω
315
mJ
drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C
ID
drain current
Tmb = 25 °C; VGS = 10 V;
see Figure 1
Ptot
total power
dissipation
Tmb = 25 °C; see Figure 2
Tj
junction temperature
[1]
Avalanche ruggedness
EDS(AL)S non-repetitive
drain-source
avalanche energy
Dynamic characteristics
QGD
gate-drain charge
VGS = 10 V; ID = 25 A;
VDS = 50 V; see Figure 15
and 14
36
nC
QG(tot)
total gate charge
VDS = 50 V; see Figure 14
and 15
125
nC
PSMN7R0-100ES
Nexperia
Table 1.
Quick reference
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VGS = 10 V; ID = 15 A;
Tj = 100 °C; see Figure 12
12
mΩ
Tj = 25 °C; see Figure 13
5.4
6.8
mΩ
Static characteristics
RDSon
[1]
drain-source
on-state resistance
Continuous current is limited by package
2. Pinning information
Table 2.
Pinning information
Pin
Symbol
Description
1
G
gate
2
D
drain
Simplified outline
Graphic symbol
mb
3
S
source
mb
D
mounting base; connected to
drain
D
G
mbb076
S
1 2 3
SOT226 (I2PAK)
3. Ordering information
Table 3.
Type number
Package
Name
PSMN7R0-100ES I2PAK
PSMN7R0-100ES_3
Product data sheet
Description
Version
plastic single-ended package (I2PAK); TO-262
SOT226
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 15
PSMN7R0-100ES
Nexperia
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
100
V
VDGR
drain-gate voltage
Tj ≤ 175 °C; Tj ≥ 25 °C; RGS = 20 kΩ
100
V
VGS
gate-source voltage
-20
V
ID
drain current
85
A
100
A
475
A
VGS = 10 V; Tmb = 100 °C; see Figure 1
[1]
VGS = 10 V; Tmb = 25 °C; see Figure 1
IDM
peak drain current
tp ≤ 10 µs; pulsed; Tmb = 25 °C; see Figure 3
Ptot
total power dissipation
269
W
Tstg
storage temperature
-55
175
°C
Tj
-55
175
°C
Tsld(M)
peak soldering temperature
260
°C
100
A
Source-drain diode
[1]
IS
source current
Tmb = 25 °C;
ISM
peak source current
475
A
VGS = 10 V; Tj(init) = 25 °C; ID = 100 A;
Vsup ≤ 100 V; unclamped; RGS = 50 Ω
315
mJ
non-repetitive drain-source
avalanche energy
EDS(AL)S
[1]
003aad558
150
ID
(A)
03aa16
120
Pder
80
100
(1)
40
50
Fig 1.
50
100
Continuous drain current as a function of
mounting base temperature
PSMN7R0-100ES_3
Product data sheet
200
Tmb (°C)
50
100
150
200
Tmb (°C)
Fig 2.
Normalized total power dissipation as a
function of mounting base temperature
3 of 15
PSMN7R0-100ES
Nexperia
003aad559
103
ID
(A)
Limit RDSon = V DS / ID
tp = 10 μ s
102
100 μ s
10
DC
1 ms
10 ms
1
100 ms
10-1
1
Fig 3.
102
10
103
VDS (V)
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
PSMN7R0-100ES_3
Product data sheet
4 of 15
PSMN7R0-100ES
Nexperia
5. Thermal characteristics
Table 5.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-mb)
thermal resistance from junction to
mounting base
see Figure 4
0.3
0.56
K/W
Rth(j-a)
ambient
vertical in free air
60
K/W
003a a d560
1
Zth (j-mb)
(K/W)
δ = 0.5
10-1
0.2
0.1
0.05
10-2
0.02
δ=
P
tp
T
10-3
s ingle s hot
t
tp
T
10-4
1e -6
Fig 4.
10-5
10-4
10-3
10-2
10-1
1
tp (s )
10
Transient thermal impedance from junction to mounting base as a function of pulse duration
PSMN7R0-100ES_3
Product data sheet
5 of 15
PSMN7R0-100ES
Nexperia
6. Characteristics
Table 6.
Symbol
Characteristics
Parameter
Conditions
Min
Typ
Max
Unit
ID = 0.25 mA; VGS = 0 V; Tj = -55 °C
90
V
ID = 0.25 mA; VGS = 0 V; Tj = 25 °C
100
V
ID = 1 mA; VDS = VGS; Tj = 175 °C; see Figure 10
1
V
ID = 1 mA; VDS = VGS; Tj = 25 °C; see Figure 11
and 10
2
3
4
V
V(BR)DSS
drain-source
breakdown voltage
VGS(th)
gate-source threshold
voltage
IDSS
drain leakage current
IGSS
gate leakage current
RDSon
drain-source on-state
resistance
RG
ID = 1 mA; VDS = VGS; Tj = -55 °C; see Figure 10
4.8
V
VDS = 100 V; VGS = 0 V; Tj = 125 °C
150
µA
VDS = 100 V; VGS = 0 V; Tj = 25 °C
0.08
4
µA
VGS = 20 V; VDS = 0 V; Tj = 25 °C
10
100
nA
VGS = -20 V; VDS = 0 V; Tj = 25 °C
10
100
nA
VGS = 10 V; ID = 15 A; Tj = 100 °C; see Figure 12
12
mΩ
VGS = 10 V; ID = 15 A; Tj = 175 °C; see Figure 12
15
19
mΩ
VGS = 10 V; ID = 15 A; Tj = 25 °C; see Figure 13
5.4
6.8
mΩ
0.74
Ω
ID = 25 A; VDS = 50 V; VGS = 10 V; see Figure 14
and 15
125
nC
ID = 0 A; VDS = 0 V; VGS = 10 V
100
nC
internal gate resistance f = 1 MHz
(AC)
QG(tot)
total gate charge
QGS
gate-source charge
ID = 25 A; VDS = 50 V; VGS = 10 V; see Figure 15
and 14
28
nC
QGS(th)
pre-threshold
gate-source charge
19.4
nC
QGS(th-pl)
post-threshold
gate-source charge
9
nC
QGD
gate-drain charge
and 14
36
nC
VGS(pl)
gate-source plateau
voltage
VDS = 50 V; see Figure 15 and 14
4.3
V
Ciss
input capacitance
6686
pF
output capacitance
VDS = 50 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C;
see Figure 16
Coss
438
pF
Crss
reverse transfer
capacitance
272
pF
34.6
ns
45.6
ns
VDS = 50 V; RL = 2 Ω; VGS = 10 V;
RG(ext) = 4.7 Ω; Tj = 25 °C
td(on)
turn-on delay time
tr
rise time
td(off)
turn-off delay time
103.9
ns
tf
fall time
49.5
ns
PSMN7R0-100ES_3
Product data sheet
6 of 15
PSMN7R0-100ES
Nexperia
Table 6.
Characteristics …continued
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Source-drain diode
VSD
source-drain voltage
IS = 25 A; VGS = 0 V; Tj = 25 °C; see Figure 17
0.8
1.2
V
trr
reverse recovery time
64
ns
Qr
recovered charge
IS = 25 A; dIS/dt = 100 A/µs; VGS = 0 V;
VDS = 50 V
167
nC
003a a d562
300
ID
(A)
6
5.5
C
(pF)
10000
10
240
5
180
003a a d566
12000
Cis s
8000
Crs s
120
6000
4.5
60
4000
VGS (V) = 4
Fig 5.
1
2
3
VDS (V)
4
Output characteristics: drain current as a
function of drain-source voltage; typical values
Fig 6.
10
15
VGS (V)
Input and reverse transfer capacitances as a
function of gate-source voltage; typical values
003a a d572
240
003a a d568
60
ID
(A)
gfs
(S )
180
45
120
30
60
15
Fig 7.
5
50
100
150
200
PSMN7R0-100ES_3
Product data sheet
Tj = 25 °C
I D (A)
Forward transconductance as a function of
drain current; typical values
Tj = 175 °C
Fig 8.
2
4
VGS (V)
6
Transfer characteristics: drain current as a
7 of 15
PSMN7R0-100ES
Nexperia
003a a d571
40
003aad280
5
VGS(th)
(V)
RDS on
(mΩ)
4
max
30
3
typ
min
10
1
−60
Fig 9.
5
10
15
VGS (V)
Drain-source on-state resistance as a function
ID
(A)
min
10−2
typ
60
120
180
Tj (°C)
Fig 10. Gate-source threshold voltage as a function of
03aa35
10−1
003aad774
3.2
a
max
2.4
10−3
1.6
10−4
0.8
10−5
10−6
4
6
120
VGS (V)
Fig 11. Sub-threshold drain current as a function of
gate-source voltage
PSMN7R0-100ES_3
Product data sheet
Tj (°C)
180
Fig 12. Normalized drain-source on-state resistance
factor as a function of junction temperature
8 of 15
PSMN7R0-100ES
Nexperia
003a a d563
VGS (V) = 4.5
RDS on
(mΩ)
003aad569
10
VGS
(V)
80 V
8
15
20 V
6
VDS = 50 V
10
4
5
6
5
10
2
60
80
I D (A)
Fig 13. Drain-source on-state resistance as a function
of drain current; typical values
50
100
QG (nC)
150
Fig 14. Gate-source voltage as a function of gate
charge; typical values
003aad567
104
VDS
Ciss
C
(pF)
ID
VGS(pl)
VGS(th)
103
VGS
QGS1
Coss
QGS2
QGS
QGD
QG(tot)
Crss
003aaa508
102
10-1
Fig 15. Gate charge waveform definitions
PSMN7R0-100ES_3
Product data sheet
1
10
VDS (V)
102
Fig 16. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
9 of 15
PSMN7R0-100ES
Nexperia
003a a d570
100
IS
(A)
80
60
Tj = 175 °C
40
25 °C
0.6
0.9
VS D (V)
1.2
Fig 17. Source (diode forward) current as a function of source-drain (diode forward) voltage; typical values
PSMN7R0-100ES_3
Product data sheet
10 of 15
PSMN7R0-100ES
Nexperia
7. Package outline
Plastic single-ended package (I2PAK); low-profile 3-lead TO-262
SOT226
A
A1
E
D1
mounting
base
D
L1
Q
b1
L
1
2
3
c
b
e
e
10 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
b
b1
c
D
max
D1
E
e
L
L1
Q
mm
4.5
4.1
1.40
1.27
0.85
0.60
1.3
1.0
0.7
0.4
11
1.6
1.2
10.3
9.7
2.54
15.0
13.5
3.30
2.79
2.6
2.2
OUTLINE
VERSION
SOT226
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
06-02-14
09-08-25
TO-262
Fig 18. Package outline SOT226 (I2PAK)
PSMN7R0-100ES_3
Product data sheet
11 of 15
PSMN7R0-100ES
Nexperia
8. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PSMN7R0-100ES_3
20100223
Product data sheet
PSMN7R0-100ES_2
Modifications:
Various changes to content.
PSMN7R0-100ES_2
20100114
Objective data sheet
PSMN7R0-100ES_1
PSMN7R0-100ES_1
20090917
PSMN7R0-100ES_3
Product data sheet
12 of 15
PSMN7R0-100ES
Nexperia
9. Legal information
9.1
Data sheet status
Document status [1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nexperia.com.
9.2
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
9.3
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on a weakness or default in the
customer application/use or the application/use of customer’s third party
customer(s) (hereinafter both referred to as “Application”). It is customer’s
sole responsibility to check whether the Nexperia product is
suitable and fit for the Application planned. Customer has to do all necessary
testing for the Application in order to avoid a default of the Application and the
product. Nexperia does not accept any liability in this respect.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
PSMN7R0-100ES_3
Product data sheet
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
13 of 15
PSMN7R0-100ES
Nexperia
Export control — This document as well as the item(s) described herein may
be subject to export control regulations. Export might require a prior
authorization from national authorities.
Non-automotive qualified products — Unless the data sheet of an
Nexperia product expressly states that the product is automotive
qualified, the product is not suitable for automotive use. It is neither qualified
nor tested in accordance with automotive testing or application requirements.
non-automotive qualified products in automotive equipment or applications. In
the event that customer uses the product for design-in and use in automotive
applications to automotive specifications and standards, customer (a) shall
use the product without Nexperia’s warranty of the product for
such automotive applications, use and specifications, and (b) whenever
customer uses the product for automotive applications beyond Nexperia’
specifications such use shall be solely at customer’s own risk, and (c)
customer fully indemnifies Nexperia for any liability,
damages or failed product claims resulting from customer design and use of
the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
9.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
10. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
PSMN7R0-100ES_3
Product data sheet
14 of 15
PSMN7R0-100ES
Nexperia
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3
Thermal characteristics . . . . . . . . . . . . . . . . . . .5
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 11
Revision history . . . . . . . . . . . . . . . . . . . . . . . . .12
Legal information. . . . . . . . . . . . . . . . . . . . . . . .13
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .13
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .13
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .13
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .14
Contact information. . . . . . . . . . . . . . . . . . . . . .14
Date of release: 23 February 2010
