Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
PBSS4160U
60 V, 1 A NPN low VCEsat (BISS) transistor
Rev. 03 — 11 December 2009
Product data sheet
1. Product profile
1.1 General description
NPN low VCEsat Breakthrough In Small Signal (BISS) transistor in a SOT323 (SC-70)
Surface Mounted Device (SMD) plastic package.
PNP complement: PBSS5160U.
1.2 Features
Low collector-emitter saturation voltage VCEsat
High collector current capability: IC and ICM
High collector current gain (hFE) at high IC
High efficiency due to less heat generation
Smaller required Printed-Circuit Board (PCB) area than for conventional transistors
1.3 Applications
High voltage DC-to-DC conversion
High voltage MOSFET gate driving
High voltage motor control
High voltage power switches (e.g. motors, fans)
Automotive applications
1.4 Quick reference data
Table 1.
Symbol
Parameter
Conditions
VCEO
collector-emitter voltage
open base
IC
collector current (DC)
ICM
peak collector current
RCEsat
resistance
[1]
single pulse; tp ≤ 1 ms
IC = 1 A; IB = 100 mA
[1]
Device mounted on a ceramic PCB, Al2O3, standard footprint.
[2]
Pulse test: tp ≤ 300 μs; δ ≤ 0.02.
[2]
Min
Typ
Max
Unit
60
V
1
A
2
A
230
280
mΩ
PBSS4160U
NXP Semiconductors
2. Pinning information
Table 2.
Pinning
Pin
Description
1
base
2
emitter
3
collector
Simplified outline
Symbol
3
3
1
1
2
2
sym021
3. Ordering information
Table 3.
Type number
PBSS4160U
Package
Name
Description
Version
SC-70
plastic surface mounted package; 3 leads
SOT323
4. Marking
Table 4.
Marking codes
Type number
Marking code[1]
PBSS4160U
52*
[1]
* = -: made in Hong Kong
* = p: made in Hong Kong
* = t: made in Malaysia
* = W: made in China
PBSS4160U_3
Product data sheet
© NXP B.V. 2009. All rights reserved.
2 of 14
PBSS4160U
NXP Semiconductors
5. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VCBO
VCEO
collector-base voltage
open emitter
80
V
open base
60
V
VEBO
emitter-base voltage
open collector
IC
5
V
[1]
750
mA
[2]
930
mA
[3]
1
A
2
A
300
mA
ICM
IB
base current (DC)
IBM
peak base current
Ptot
total power dissipation
Tamb ≤ 25 °C
1
A
[1]
250
mW
[2]
350
mW
[3]
415
mW
Tj
junction temperature
150
°C
Tamb
ambient temperature
−65
+150
°C
Tstg
storage temperature
−65
+150
°C
[1]
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
[2]
Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 1 cm2.
[3]
006aaa501
0.5
Ptot
(W)
(1)
0.4
(2)
0.3
(3)
0.2
0.1
80
120
160
Tamb (°C)
(1) Ceramic PCB, Al2O3, standard footprint
(2) FR4 PCB, mounting pad for collector 1 cm2
(3) FR4 PCB, standard footprint
Fig 1.
Power derating curves
PBSS4160U_3
Product data sheet
3 of 14
PBSS4160U
NXP Semiconductors
6. Thermal characteristics
Table 6.
Symbol
Parameter
Conditions
thermal resistance from
junction to ambient
Rth(j-a)
in free air
Min
Typ
Max
Unit
[1]
500
K/W
[2]
357
K/W
[3]
301
K/W
150
K/W
junction to solder point
Rth(j-sp)
[1]
[2]
[3]
006aaa502
103
Zth(j-a)
(K/W)
102
δ=1
0.75
0.50
0.20
0.33
0.10
0.05
10
0.02
0.01
10−5
10−4
10−3
10−2
10−1
1
10
102
103
tp (s)
Fig 2.
Transient thermal impedance from junction to ambient as a function of pulse time; typical values
PBSS4160U_3
Product data sheet
4 of 14
PBSS4160U
NXP Semiconductors
006aaa503
103
Zth(j-a)
(K/W)
δ=1
0.75
0.50
102
0.33
0.20
0.10
0.05
10
0.02
0.01
10−5
10−4
10−3
10−2
10−1
1
10
102
103
tp (s)
Fig 3.
006aaa504
103
Zth(j-a)
(K/W)
δ=1
0.75
102
0.50
0.33
0.20
0.10
0.05
10
0.02
0.01
10−5
10−4
10−3
10−2
10−1
1
10
102
103
tp (s)
Fig 4.
PBSS4160U_3
Product data sheet
5 of 14
PBSS4160U
NXP Semiconductors
7. Characteristics
Table 7.
Characteristics
Tamb = 25 °C unless otherwise specified.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
ICBO
collector-base cut-off
current
VCB = 60 V; IE = 0 A
100
nA
VCB = 60 V; IE = 0 A;
Tj = 150 °C
50
μA
ICES
collector-emitter cut-off
current
VCE = 60 V; VBE = 0 V
100
nA
IEBO
emitter-base cut-off current VEB = 5 V; IC = 0 A
100
nA
hFE
DC current gain
250
500
200
420
VCEsat
voltage
VCE = 5 V; IC = 1 mA
VCE = 5 V; IC = 500 mA
[1]
VCE = 5 V; IC = 1 A
[1]
100
180
IC = 100 mA; IB = 1 mA
90
115
mV
IC = 500 mA;
IB = 50 mA
120
150
mV
[1]
230
280
mV
RCEsat
resistance
[1]
230
280
mΩ
VBEsat
base-emitter saturation
voltage
IC = 1 A; IB = 50 mA
[1]
0.95
1.1
V
VBEon
base-emitter turn-on
voltage
VCE = 5 V; IC = 1 A
[1]
0.85
0.9
V
td
delay time
IC = 0.5 A;
IBon = 25 mA;
IBoff = −25 mA
11
ns
78
ns
90
ns
tr
rise time
ton
turn-on time
ts
storage time
340
ns
tf
fall time
160
ns
toff
turn-off time
500
ns
fT
transition frequency
VCE = 10 V;
IC = 50 mA;
f = 100 MHz
150
220
MHz
Cc
collector capacitance
VCB = 10 V;
IE = ie = 0 A; f = 1 MHz
5.5
10
pF
[1]
PBSS4160U_3
Product data sheet
6 of 14
PBSS4160U
NXP Semiconductors
006aaa505
800
hFE
006aaa506
1.2
VBE
(V)
(1)
1.0
600
(2)
0.8
(1)
400
(2)
0.6
(3)
200
(3)
0.4
10−1
1
102
10
0.2
10−1
103
104
IC (mA)
1
10
VCE = 5 V
VCE = 5 V
(1) Tamb = 100 °C
(1) Tamb = −55 °C
(2) Tamb = 25 °C
(2) Tamb = 25 °C
(3) Tamb = −55 °C
Fig 5.
102
103
104
IC (mA)
(3) Tamb = 100 °C
DC current gain as a function of collector
current; typical values
Fig 6.
006aaa507
1
Base-emitter voltage as a function of collector
006aaa508
1
VCEsat
(V)
VCEsat
(mV)
10−1
(1)
(2)
10−1
10−2
10−1
1
10
(3)
10−2
(1)
(2)
(3)
102
103
104
IC (mA)
10−3
10−1
1
(1) Tamb = 100 °C
(1) IC/IB = 100
(2) Tamb = 25 °C
(2) IC/IB = 50
(3) Tamb = −55 °C
(3) IC/IB = 10
Collector-emitter saturation voltage as a
function of collector current; typical values
Fig 8.
103
104
IC (mA)
PBSS4160U_3
Product data sheet
102
Tamb = 25 °C
IC/IB = 20
Fig 7.
10
7 of 14
PBSS4160U
NXP Semiconductors
006aaa509
1.2
VBEsat
(V)
006aaa510
103
RCEsat
(Ω)
1.0
102
(1)
0.8
10
(2)
0.6
(3)
(1)
(2)
(3)
1
0.4
0.2
10−1
1
10
102
103
104
IC (mA)
10−1
10−1
IC/IB = 20
1
102
103
104
IC (mA)
IC/IB = 20
(1) Tamb = −55 °C
(1) Tamb = 100 °C
(2) Tamb = 25 °C
(2) Tamb = 25 °C
(3) Tamb = 100 °C
(3) Tamb = −55 °C
Fig 9.
10
Base-emitter saturation voltage as a function
006aaa511
2.0
IB (mA) = 65.0
58.5
52.0 45.5
39.0
32.5
IC
(A)
1.6
26.0
1.2
Fig 10. Collector-emitter saturation resistance as a
006aaa512
103
RCEsat
(Ω)
102
19.5
13.0
10
6.5
0.8
(1)
(2)
1
0.4
(3)
10−1
2
3
4
5
10−1
1
VCE (V)
Tamb = 25 °C
10
102
103
104
IC (mA)
Tamb = 25 °C
(1) IC/IB = 100
(2) IC/IB = 50
(3) IC/IB = 10
Fig 11. Collector current as a function of
collector-emitter voltage; typical values
Fig 12. Collector-emitter saturation resistance as a
PBSS4160U_3
Product data sheet
8 of 14
PBSS4160U
NXP Semiconductors
8. Test information
IB
input pulse
(idealized waveform)
90 %
IBon (100 %)
10 %
IBoff
output pulse
IC
90 %
IC (100 %)
10 %
t
td
ts
tr
ton
tf
toff
006aaa003
Fig 13. BISS transistor switching time definition
VBB
RB
VCC
RC
Vo
(probe)
oscilloscope
450 Ω
(probe)
450 Ω
oscilloscope
R2
VI
DUT
R1
mlb826
IC = 0.5 A; IBon = 25 mA; IBoff = −25 mA; R1 = open; R2 = 100 Ω; RB = 300 Ω; RC = 20 Ω
Fig 14. Test circuit for switching times
PBSS4160U_3
Product data sheet
9 of 14
PBSS4160U
NXP Semiconductors
9. Package outline
2.2
1.8
1.1
0.8
0.45
0.15
3
2.2 1.35
2.0 1.15
1
2
0.4
0.3
0.25
0.10
1.3
Dimensions in mm
04-11-04
Fig 15. Package outline SOT323 (SC-70)
10. Packing information
Table 8.
Packing methods
The indicated -xxx are the last three digits of the 12NC ordering code.[1]
Type number
PBSS4160U
[1]
Package
SOT323
Description
4 mm pitch, 8 mm tape and reel
3000
10000
-115
-135
For further information and the availability of packing methods, see Section 14.
PBSS4160U_3
Product data sheet
Packing quantity
10 of 14
PBSS4160U
NXP Semiconductors
11. Soldering
2.65
0.75
1.325
1.30
solder lands
2
solder paste
0.60
2.35 0.85
(3×)
0.50
(3×) 1.90
3
solder resist
occupied area
1
Dimensions in mm
0.55
(3×)
2.40
msa429
Fig 16. Reflow soldering footprint
4.60
4.00
1.15
2
3.65
2.10
3
2.70
solder lands
1
0.90
(2×)
solder resist
occupied area
Dimensions in mm
preferred transport direction during soldering
msa419
Fig 17. Wave soldering footprint
PBSS4160U_3
Product data sheet
11 of 14
PBSS4160U
NXP Semiconductors
12. Revision history
Table 9.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PBSS4160U_3
20091211
Product data sheet
PBSS4160U_2
Modifications:
This data sheet was changed to reflect the new company name NXP Semiconductors,
including new legal definitions and disclaimers. No changes were made to the technical
content.
Figure 16 “Reflow soldering footprint”: updated
Figure 17 “Wave soldering footprint”: updated
PBSS4160U_2
20050719
Product data sheet
PBSS4160U_1
PBSS4160U_1
20040423
Objective data sheet
PBSS4160U_3
Product data sheet
12 of 14
PBSS4160U
NXP Semiconductors
13. Legal information
13.1 Data sheet status
Document status[1][2]
Product status[3]
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
Definition
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nxp.com.
13.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. NXP Semiconductors does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local NXP Semiconductors sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
13.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, NXP Semiconductors does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — NXP Semiconductors reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — NXP Semiconductors products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of an NXP Semiconductors product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. NXP Semiconductors accepts no liability for inclusion and/or use of
NXP Semiconductors products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. NXP Semiconductors makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — NXP Semiconductors products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nxp.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by NXP Semiconductors. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from national authorities.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
13.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
14. Contact information
For more information, please visit: http://www.nxp.com
For sales office addresses, please send an email to: salesaddresses@nxp.com
PBSS4160U_3
Product data sheet
13 of 14
PBSS4160U
NXP Semiconductors
15. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
10
11
12
13
13.1
13.2
13.3
13.4
14
15
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Thermal characteristics . . . . . . . . . . . . . . . . . . 4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Test information . . . . . . . . . . . . . . . . . . . . . . . . . 9
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10
Packing information . . . . . . . . . . . . . . . . . . . . 10
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12
Legal information. . . . . . . . . . . . . . . . . . . . . . . 13
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Contact information. . . . . . . . . . . . . . . . . . . . . 13
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section ‘Legal information’.
© NXP B.V. 2009.
Date of release: 11 December 2009
Document identifier: PBSS4160U_3
