Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
PBSS303PD
60 V, 3 A PNP low VCEsat (BISS) transistor
Rev. 02 — 20 November 2009
Product data sheet
1. Product profile
1.1 General description
PNP low VCEsat Breakthrough In Small Signal (BISS) transistor in a SOT457 (SC-74)
small Surface-Mounted Device (SMD) plastic package.
NPN complement: PBSS303ND.
1.2 Features
Low collector-emitter saturation voltage VCEsat
High collector current capability IC and ICM
High collector current gain (hFE) at high IC
High efficiency due to less heat generation
Smaller required Printed-Circuit Board (PCB) area than for conventional transistors
1.3 Applications
High-voltage DC-to-DC conversion
High-voltage MOSFET gate driving
High-voltage motor control
High-voltage power switches (e.g. motors, fans)
Thin Film Transistor (TFT) backlight inverter
Automotive applications
1.4 Quick reference data
Table 1.
Symbol Parameter
VCEO
collector-emitter voltage
Conditions
open base
[1]
IC
collector current
ICM
peak collector current
single pulse;
tp ≤ 1 ms
RCEsat
collector-emitter
saturation resistance
IC = −2 A;
IB = −200 mA
[1]
Device mounted on a ceramic PCB, Al2O3, standard footprint.
[2]
Pulse test: tp ≤ 300 μs; δ ≤ 0.02.
[2]
Min
Typ
Max
Unit
−60
V
−3
A
−6
A
75
100
mΩ
PBSS303PD
NXP Semiconductors
2. Pinning information
Table 2.
Pinning
Pin
Description
1
collector
2
collector
3
base
4
emitter
5
collector
6
collector
Simplified outline
6
5
Symbol
4
1, 2, 5, 6
3
1
2
3
4
sym030
3. Ordering information
Table 3.
Type number
PBSS303PD
Package
Name
Description
Version
SC-74
plastic surface-mounted package (TSOP6); 6 leads
SOT457
4. Marking
Table 4.
Marking codes
Type number
Marking code
PBSS303PD
AH
PBSS303PD_2
Product data sheet
© NXP B.V. 2009. All rights reserved.
2 of 16
PBSS303PD
NXP Semiconductors
5. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VCBO
collector-base voltage
open emitter
−60
V
VCEO
open base
−60
V
VEBO
emitter-base voltage
open collector
collector current
IC
ICM
IB
base current
IBM
peak base current
single pulse;
tp ≤ 1 ms
Ptot
total power dissipation
Tamb ≤ 25 °C
−5
V
−1
A
[2]
−3
A
−6
A
−800
mA
−2
A
[1]
360
mW
[3]
600
mW
[4]
750
mW
[2]
1.1
W
[1][5]
2.5
W
single pulse;
tp ≤ 1 ms
Tj
junction temperature
150
°C
Tamb
ambient temperature
−65
+150
°C
Tstg
storage temperature
−65
+150
°C
[1]
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
[2]
[3]
Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 1 cm2.
[4]
Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 6 cm2.
[5]
Pulse test: tp ≤ 10 ms; δ ≤ 10 %.
PBSS303PD_2
Product data sheet
[1]
3 of 16
PBSS303PD
NXP Semiconductors
006aaa270
1600
Ptot
(mW)
1200
(1)
800
(2)
(3)
(4)
400
−75
−25
25
75
125
175
Tamb (°C)
(1) Ceramic PCB, Al2O3, standard footprint
(2) FR4 PCB, mounting pad for collector 6 cm2
(3) FR4 PCB, mounting pad for collector 1 cm2
(4) FR4 PCB, standard footprint
Fig 1.
Power derating curves
6. Thermal characteristics
Table 6.
Symbol
Parameter
Rth(j-a)
Rth(j-sp)
Conditions
thermal resistance from
junction to ambient
in free air
junction to solder point
Typ
Max
Unit
350
K/W
[2]
208
K/W
[3]
167
K/W
[4]
113
K/W
[1][5]
50
K/W
45
K/W
[1]
[2]
[3]
[4]
[5]
PBSS303PD_2
Product data sheet
Min
[1]
4 of 16
PBSS303PD
NXP Semiconductors
006aaa271
103
Zth(j-a)
(K/W)
102
duty cycle =
1
0.75
0.5
0.33
0.2
0.1
0.05
10
0.02
0.01
1
10−1
10−5
10−4
10−3
10−2
10−1
1
10
102
103
tp (s)
Fig 2.
Transient thermal impedance from junction to ambient as a function of pulse duration; typical values
006aaa272
103
Zth(j-a)
(K/W)
102
duty cycle =
1
0.75
0.5
0.33
0.2
0.1
10
0.05
0.02
0.01
1
10−1
10−5
10−4
10−3
10−2
10−1
1
10
102
103
tp (s)
Fig 3.
PBSS303PD_2
Product data sheet
5 of 16
PBSS303PD
NXP Semiconductors
006aaa273
103
Zth(j-a)
(K/W)
102
duty cycle =
1
0.75
0.5
0.33
0.2
0.1
10
0.05
0.02
0.01
1
10−1
10−5
10−4
10−3
10−2
10−1
1
10
102
103
tp (s)
Fig 4.
006aaa751
103
Zth(j-a)
(K/W)
102
duty cycle =
1
0.75
0.5
0.33
0.2
0.1
10
0.05
0.02
0.01
1
10−1
10−5
10−4
10−3
10−2
10−1
1
10
102
103
tp (s)
Fig 5.
PBSS303PD_2
Product data sheet
6 of 16
PBSS303PD
NXP Semiconductors
7. Characteristics
Table 7.
Characteristics
Tamb = 25 °C unless otherwise specified.
Symbol Parameter
ICBO
Conditions
collector-base cut-off VCB = −60 V; IE = 0 A
current
VCB = −60 V; IE = 0 A;
Tj = 150 °C
Typ
Max
Unit
−100
nA
−50
μA
ICES
collector-emitter
cut-off current
VCE = −48 V; VBE = 0 V
−100
nA
IEBO
emitter-base cut-off
current
VEB = −5 V; IC = 0 A
−100
nA
hFE
DC current gain
VCE = −2 V; IC = −500 mA
VCEsat
collector-emitter
saturation voltage
180
265
VCE = −2 V; IC = −1 A
[1]
160
235
VCE = −2 V; IC = −2 A
[1]
130
185
VCE = −2 V; IC = −3 A
[1]
95
135
VCE = −2 V; IC = −4 A
[1]
60
80
VCE = −2 V; IC = −5 A
[1]
35
50
VCE = −2 V; IC = −6 A
[1]
−55
−70
mV
IC = −500 mA; IB = −50 mA
−100
−135
mV
IC = −2 A; IB = −200 mA
[1]
−150
−200
mV
IC = −3 A; IB = −150 mA
[1]
−275
−365
mV
IC = −3 A; IB = −300 mA
[1]
−210
−290
mV
IC = −4 A; IB = −400 mA
[1]
−285
−385
mV
IC = −5 A; IB = −500 mA
[1]
−375
−495
mV
IC = −6 A; IB = −600 mA
[1]
−515
−675
mV
RCEsat
collector-emitter
[1]
75
100
mΩ
VBEsat
base-emitter
saturation voltage
VBEon
base-emitter turn-on
voltage
IC = −1 A; IB = −50 mA
−0.78
−0.87
V
−0.80
−0.89
V
IC = −1 A; IB = −100 mA
[1]
−0.83
−0.92
V
[1]
−0.92
−0.99
V
[1]
PBSS303PD_2
Product data sheet
Min
−0.94
−1.02
V
−0.80
−1.00
V
7 of 16
PBSS303PD
NXP Semiconductors
Table 7.
Characteristics …continued
Symbol Parameter
Conditions
Min
Typ
Max
Unit
td
delay time
VCC = −9.2 V; IC = −2 A;
IBon = −0.1 A; IBoff = 0.1 A
13
ns
tr
rise time
53
ns
ton
turn-on time
66
ns
ts
storage time
230
ns
tf
fall time
76
ns
toff
turn-off time
306
ns
fT
transition frequency
110
MHz
Cc
collector capacitance VCB = −10 V; IE = ie = 0 A;
f = 1 MHz
58
pF
[1]
VCE = −10 V; IC = −100 mA;
f = 100 MHz
PBSS303PD_2
Product data sheet
8 of 16
PBSS303PD
NXP Semiconductors
006aaa727
600
006aaa728
−6
IB = −190 mA
−171
−152
IC
−133
(A)
−114
−95
−4
−76
hFE
(1)
400
−57
−38
(2)
−19
−2
200
(3)
−10−1
−1
−10
−102
−103
−104
IC (mA)
VCE = −2 V
−0.4
−0.8
−1.2
−1.6
−2.0
VCE (V)
Tamb = 25 °C
(1) Tamb = 100 °C
(2) Tamb = 25 °C
(3) Tamb = −55 °C
Fig 6.
DC current gain as a function of collector
current; typical values
006aaa729
−1.2
VBE
(V)
Fig 7.
Collector current as a function of
collector-emitter voltage; typical values
006aaa730
−1.2
VBEsat
(V)
−0.8
−0.8
(1)
(1)
(2)
(2)
−0.4
−10−1
−1
(3)
−0.4
(3)
−10
−102
−10−1
−103
−104
IC (mA)
VCE = −2 V
−1
(1) Tamb = −55 °C
(2) Tamb = 25 °C
(2) Tamb = 25 °C
(3) Tamb = 100 °C
(3) Tamb = 100 °C
Base-emitter voltage as a function of collector
Fig 9.
−103
−104
IC (mA)
Base-emitter saturation voltage as a function
of collector current; typical values
PBSS303PD_2
Product data sheet
−102
IC/IB = 20
(1) Tamb = −55 °C
Fig 8.
−10
9 of 16
PBSS303PD
NXP Semiconductors
006aaa731
−1
006aaa732
−1
VCEsat
(V)
VCEsat
(V)
−10−1
(1)
(1)
(2)
(3)
−10−1
(2)
(3)
−10−2
−10−2
−10−1
−1
−10
−102
−103
−104
IC (mA)
−10−3
−10−1
−1
−10
−102
−103
−104
IC (mA)
Tamb = 25 °C
IC/IB = 20
(1) Tamb = 100 °C
(1) IC/IB = 100
(2) Tamb = 25 °C
(2) IC/IB = 50
(3) Tamb = −55 °C
(3) IC/IB = 10
Fig 10. Collector-emitter saturation voltage as a
function of collector current; typical values
006aaa733
103
Fig 11. Collector-emitter saturation voltage as a
RCEsat
(Ω)
102
102
10
10
1
006aaa734
103
RCEsat
(Ω)
(1)
(2)
1
(1)
(2)
(3)
(3)
10−1
10−1
10−2
−10−1
−1
−10
−102
−103
−104
IC (mA)
10−2
−10−1
−1
−102
−103
−104
IC (mA)
Tamb = 25 °C
IC/IB = 20
(1) Tamb = 100 °C
(1) IC/IB = 100
(2) Tamb = 25 °C
(2) IC/IB = 50
(3) Tamb = −55 °C
(3) IC/IB = 10
Fig 12. Collector-emitter saturation resistance as a
Fig 13. Collector-emitter saturation resistance as a
PBSS303PD_2
Product data sheet
−10
10 of 16
PBSS303PD
NXP Semiconductors
8. Test information
− IB
input pulse
(idealized waveform)
90 %
− I Bon (100 %)
10 %
− I Boff
output pulse
− IC
90 %
− I C (100 %)
10 %
t
td
ts
tr
t on
tf
t off
006aaa266
Fig 14. BISS transistor switching time definition
VBB
RB
VCC
RC
Vo
(probe)
oscilloscope
450 Ω
(probe)
450 Ω
oscilloscope
R2
VI
DUT
R1
mgd624
VCC = −9.2 V; IC = −2 A; IBon = −0.1 A; IBoff = 0.1 A
Fig 15. Test circuit for switching times
PBSS303PD_2
Product data sheet
11 of 16
PBSS303PD
NXP Semiconductors
9. Package outline
3.1
2.7
6
3.0
2.5
1.7
1.3
1.1
0.9
5
4
2
3
0.6
0.2
pin 1 index
1
0.40
0.25
0.95
0.26
0.10
1.9
Dimensions in mm
04-11-08
Fig 16. Package outline SOT457 (SC-74)
10. Packing information
Table 8.
Packing methods
The indicated -xxx are the last three digits of the 12NC ordering code.[1]
Type number
Package
Description
Packing quantity
3000
PBSS303PD
[1]
SOT457
4 mm pitch, 8 mm tape and reel; T1
-115
-135
4 mm pitch, 8 mm tape and reel; T2
[3]
-125
-165
For further information and the availability of packing methods, see Section 14.
[2]
T1: normal taping
[3]
T2: reverse taping
PBSS303PD_2
Product data sheet
10000
[2]
12 of 16
PBSS303PD
NXP Semiconductors
11. Soldering
3.45
1.95
solder lands
0.95
solder resist
0.45 0.55
3.30 2.825
occupied area
solder paste
1.60
1.70
3.10
3.20
msc422
Dimensions in mm
Fig 17. Reflow soldering footprint SOT457 (SC-74)
5.30
solder lands
5.05
0.45 1.45 4.45
solder resist
occupied area
1.40
msc423
4.30
Dimensions in mm
Fig 18. Wave soldering footprint SOT457 (SC-74)
PBSS303PD_2
Product data sheet
13 of 16
PBSS303PD
NXP Semiconductors
12. Revision history
Table 9.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PBSS303PD_2
20091120
Product data sheet
PBSS303PD_1
Modifications:
PBSS303PD_1
This data sheet was changed to reflect the new company name NXP Semiconductors,
including new legal definitions and disclaimers. No changes were made to the technical
content.
20060531
Product data sheet
PBSS303PD_2
Product data sheet
14 of 16
PBSS303PD
NXP Semiconductors
13. Legal information
13.1 Data sheet status
Document status[1][2]
Product status[3]
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
Definition
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nxp.com.
13.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. NXP Semiconductors does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local NXP Semiconductors sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
13.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, NXP Semiconductors does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — NXP Semiconductors reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — NXP Semiconductors products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of an NXP Semiconductors product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. NXP Semiconductors accepts no liability for inclusion and/or use of
NXP Semiconductors products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. NXP Semiconductors makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — NXP Semiconductors products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nxp.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by NXP Semiconductors. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from national authorities.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
13.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
14. Contact information
For more information, please visit: http://www.nxp.com
For sales office addresses, please send an email to: salesaddresses@nxp.com
PBSS303PD_2
Product data sheet
15 of 16
PBSS303PD
NXP Semiconductors
15. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
10
11
12
13
13.1
13.2
13.3
13.4
14
15
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Thermal characteristics . . . . . . . . . . . . . . . . . . 4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 7
Test information . . . . . . . . . . . . . . . . . . . . . . . . 11
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 12
Packing information . . . . . . . . . . . . . . . . . . . . 12
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 14
Legal information. . . . . . . . . . . . . . . . . . . . . . . 15
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 15
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Contact information. . . . . . . . . . . . . . . . . . . . . 15
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section ‘Legal information’.
© NXP B.V. 2009.
Date of release: 20 November 2009
Document identifier: PBSS303PD_2
