Solderable Planar Photodiode
PRELIMINARY
SLSD-71N700
Advanced Photonix, Inc.
Precision – Control – Results
WWW.ADVANCEDPHOTONIX.COM
DESCRIPTION
FEATURES
The SLSD-71N700 is a solderable planar photodiode featuring low cost,
high reliability, and linear short circuit current over a wide range of
illumination. These devices are widely used for light sensing and power
generation because of their stability and high efficiency. They are
particularly suited to power conversion applications due to their low
internal impedance, relatively high shunt impedance, and stability. The
photodiodes have a protective coating that protects them from humidity
effects. These devices also provide a reliable and inexpensive detector for
instrumentation and light beam sensing applications.
RELIABILITY
APPLICATIONS
• Light sensing
• Power generation
This API high-reliability detector is in principle able to meet military test
requirements (Mil-STD-750, Mil-STD-883) after proper screening and
group test.
Contact API for recommendations on specific test conditions and
procedures.
Visible to IR spectral irradiance range
High reliability
Oxide passivation
Linear short circuit current
Low capacitance, high speed
Si surface protected with a thin film
coating
ABSOLUTE MAXIMUM RATINGS
Operating Temperature
Storage Temperature
Soldering Temperature
Wavelength Range
-40
-40
to
to
400
to
Information in this technical datasheet is believed to
be correct and reliable. However, no responsibility is
assumed for possible inaccuracies or omission.
Specifications are subject to change without notice.
+105
+105
+240
1100
°C
°C
°C
nm
non condensing
REV 08-24-15
Page 1/2
© 2015 Advanced Photonix, Inc. All rights reserved.
Advanced Photonix Inc. 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935
PRELIMINARY
SLSD-71N700
Ta = 23°C unless noted otherwise
OPTO-ELECTRICAL PARAMETERS
PARAMETER
TEST CONDITIONS
Short Circuit Current
Open Circuit Voltage
Dark Current
Junction Capacitance
Spectral Sensitivity
Breakdown Voltage
Maximum Sensitivity
Wavelength
Acceptance Half Angle
MIN
TYP
MAX
UNITS
VR =0V, Ee=25mW/cm² **
Ee=25mW/cm² **
VR =5V, Ee=0, T=25°C
VR=0V, Ee=0, f=1MHz
λ=940nm; Flood illumination*
IR=100µA
2.5
0.40
2.5
0.55
5.0
mA
V
µA
nF
A/W
V
930
nm
(off center-line)
60
deg
* Minimum 50% of active area illuminated
** Light source @ 2854°K
TYPICAL PERFORMANCE
DIRECTIONAL SENSITIVITY
REV 08-24-15
Page 2/2
很抱歉,暂时无法提供与“SLSD-71N700”相匹配的价格&库存,您可以联系我们找货
