SLD-70BG2
Infrared Rejection Filter
Planar Photodiode
Features
1.9
Optical
Clear Epoxy
Low capacitance, fast switching time
Linear response vs irradiance
IR blocking filter
Multiple dark current ranges available
Red dot
5.1
7.2
Description
BG Filter
The planar photodiode is designed to operate in
either photoconductive or photovoltaic modes. This
diode incorporates a BG filter that rejects infrared
wavelengths and approximates the response of the
human eye. High sensitivity and low dark current
allow use in low irradiance applications. The
photodiode measures 3.6 mm X 3.6 mm (0.140” X
0.140”) and is supplied on a ceramic base with a
clear epoxy dome package.
0.50-0.52
3.4
Max.
6.3
Chip Size = 3.6 mm X 3.6 mm
Active Area = 9.8 sq.mm.
Cathode
Dimensions in mm. (+/- 0.2)
Directional Sensitivity Characteristics
40°
30°
20°
10°
1.0
50°
0.8
60°
0.6
Half Angle = 60°
Absolute Maximum Ratings
Storage Temperature
Operating Temperature
Soldering Temperature (1)
-20C to +85C
-20C to +85C
260C
Notes: (1) >2 mm from case for < 5 sec.
(2) Ee = source @ 2854K
(3) Ee = source @ = 580 nm
0.4
70°
0.2
80°
0.0
90°
100°
1.0
Electrical Characteristics (TA=25C unless otherwise noted)
Symbol
Parameter
Min
Typ
ISC
Short Circuit Current
40
55
VOC
Open Circuit Voltage
0.40
ID
Reverse Dark Current:
100
SLD-70BG2A
100
SLD-70BG2B
SLD-70BG2C
5
SLD-70BG2D
1
SLD-70BG2E
CJ
Junction Capacitance
180
tR
Rise Time
4
tF
Fall Time
6
TCI
Temp. Coef., ISC
+0.2
VBR
Reverse Breakdown Voltage
50
Maximum Sensitivity Wavelength
550
P
Sensitivity Spectral Range
400
R
Acceptance Half Angle
60
1/2
Specifications subject to change without notice.
Advanced Photonix Canada Inc.,
300 St-Sacrement
Suite 519
Montréal, QC, Canada H2Y 1X4
Anode
38 nom.
Page 1
0.8
Max
700
0.6
0.4
20°
40°
60°
80°
100°
120°
Units
Test Conditions
2
VR=0V, Ee=25mW/cm (2)
A
2
V
Ee=25mw/cm (2)
nA
nA
nA
nA
nA
pF
s
s
%/C
V
nm
nm
deg
VR=100mV, Ee=0
VR=5V, Ee=0
VR=5V, Ee=0
VR=5V, Ee=0
VR=5V, Ee=0
VR=0V, Ee=0, f=1MHz
VR=5V, RL=1k (3)
VR=5V, RL=1k (3)
(2)
IR=100A
(off center-line)
REV 04/30-14
Phone:(514) 768-8000
Fax: (514) 768-8889
http://www.advancedphotonix.com
很抱歉,暂时无法提供与“SLD-70BG2A”相匹配的价格&库存,您可以联系我们找货
