PHOTONIC
Silicon Photodiode, Blue Enhanced Photoconductive
DETECTORS INC. Type PDB-C136 , with daylight filter Type PDB-C136F
PACKAGE DIMENSIONS INCH [mm]
0.213 [5.41]
CLEAR PLASTIC (PDB-C138)
BLACK PLASTIC (PDB-C138F)
0.047 [1.20]
CHIP ACTIVE
SURFACE
Ø0.228 [5.80]
Ø0.197
[5.00]
0.984 [25.00]
MIN
CATHODE
C
L
0.100 [2.54]
C
L
94°
VIEWING
ANGLE
0.020 [0.50] SQ
2 PLACES
0.060 [1.52]
SQUARE
ANODE
0.039 [1.00]
0.059 [1.50] MAX
1.043 [26.50]
0.049 [1.24] SQUARE
ACTIVE AREA
T 1 3/4 FLAT TOP PACKAGE
ACTIVE AREA = 1.55 mm2
DESCRIPTION: The PDB-C136 detector is
a 1.55 mm2 planar PIN photodiode packaged
in a T 1 3/4, flat top, water clear plastic
housing. Designed for high speed, low
capacitance, photoconductive applications.
The PDB-C136F includes a daylight filter.
-40
+80
O
TS
Soldering Temperature*
+260
O
IL
Light Current
C
C
mA
0.3
0.2
0.1
*1/16 inch from case for 3 secs max
WAVELENGTH (nm)
ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted)
SYMBOL CHARACTERISTIC
TEST CONDITIONS
MIN
TYP
ISC
Short Circuit Current
H = 100 fc, 2850 K
ID
Dark Current
H = 0, V R = 10 V
Shunt Resistance
H = 0, V R = 10 mV
TC RSH
RSH Temp. Coefficient
CJ
Junction Capacitance
RSH
λrange
MAX
UNITS
mA
27
2
30
nA
2
GΩ
H = 0, V R = 10 mV
-8
% / oC
H = 0, V R = 10 V*
6
Spectral Application Range (without daylight filter)**
λp
Spectral Response - Peak
VBR
Breakdown Voltage
I = 10 m A
NEP
Noise Equivalent Power
VR = 10 V @ Peak
Response Time
RL = 1 KΩ VR = 50 V
tr
1200
Operating Temperature Range
0.4
1100
TO
C
900
O
1000
+100
800
-40
0%
=10
QE
0.5
700
Storage Temperature
0.6
600
TSTG
500
V
500
100
400
Reverse Voltage
300
VBR
SPECTRAL RESPONSE
0.7
190
ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted)
SYMBOL
PARAMETER
MIN
MAX
UNITS
APPLICATIONS
Smoke detectors
Light pen detectors
Fiber optics
Bar code detectors
RESPONSIVITY (A/W)
FEATURES
Large active area
Photoconductive
Low cost
High speed
.5
400
950
50
pF
1100
nm
nm
100
V
1.8x10
-13
10
10
W/
Hz
nS
Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications
are subject to change without notice. * f = 1 MHz, ** daylight filter = 700 - 1100 nm
[FORM NO. 100-PDB-C136 REV C]
很抱歉,暂时无法提供与“PDB-C136F”相匹配的价格&库存,您可以联系我们找货
