30PSI-G-4V
30PSI-G-4V
    ALLSENSORS
    SIP4
    SENSOR30PSIG4VDUAL
30PSI-G-4V 数据手册
Amplified Middle Pressure Sensors Features • 0 to ±0.3 to 0 to 150 psi Pressure Ranges • Ratiometric 4V Output • Temperature Compensated • Calibrated Zero and Span • Medical Instrumentation • Environmental Instrumentation • HVAC Instrumentation General Description The Amplified line of middle pressure sensors are based upon a proprietary package technology to reduce errors. This model provides all sensors Applications induced parasitic stress and strain. In addition the sensor utilizes a silicon, micromachined, stress concentration enhanced structure to provide a very linear output to measured pressure. These calibrated and temperature compensated sensors give an accurate and stable output over a wide temperature range. Each sensor is internally compensated using an ASIC compensation technique. This series is intended for use with non-corrosive, non-ionic working The output of the device is ratiometric to the supply voltage over a supply voltage range of 4.5 to 5.5 volts. Physical Dimensions Equivalent Circuit 2.54 0.100 (Typ) 8.74 0.344 1.27 0.050 27.43 1.080 5.33 0.210 Port B 3.56 0.140 10.67 0.420 10.67 0.420 Port A 3.18 R0.125 12.19 0.480 pin 1: Vsupply pin 2: Common 20.32 0.800 13.97 0.550 pin 3: Voutput 21.59 0.850 pin 4: do not connect Approvals MKT DATE As Is With Change MFG DATE As Is 4 All Sensors With Change TITLE: pin, No Port Cut, As A-Package, Is Barb, Flat4With No LeadsChange SIZE FILE NAME DS-0028 RevAD All Sensors 5 ENG DATE 3 2 A4AAF Rev B 1 QA DATE As Is With Change a 16035 Vineyard Blvd. Morgan Hill, CA 95037 0.020" x 0.010" Pin 0.30" minimum length Pin 1 Identifier 3.18 0.125 Port 0.179"/0.189" CL p 408 225 4314 f 408 225 2079 fluids such as air, dry gases and the like. e www.allsensors.com a ratiometric 4-volt output with superior output characteristics. The sensor housing has been designed specifically to reduce package Pressure Sensor Ratings Environmental Specifications +4.5 to +5.5 Vdc Supply Voltage, Vs -10 to +10 psig Common-mode pressure 250°C Lead Temperature, max (soldering 2-4 sec.) Temperature Ranges Compensated 5 to 50° C Operating -25 to 85° C Storage -40 to 125° C Humidity Limits 0 to 95% RH (non condensing) Standard Pressure Ranges Part Number Operating Pressure Nominal Span Proof Pressure Burst Pressure 0.3 PSI-D-4V ±0.3 PSI ±2 V 5 PSI 10 PSI 0.3 PSI-G-4V 0 - 0.3 PSI 4V 5 PSI 10 PSI 1 PSI-D-4V ±1 PSI ±2 V 5 PSI 10 PSI 1 PSI-G-4V 0 - 1 PSI 4V 5 PSI 10 PSI 2.5 PSI-D-4V ±2.5 PSI ±2 V 10 PSI 20 PSI 2.5 PSI-G-4V 0 - 2.5 PSI 4V 10 PSI 20 PSI 5 PSI-D-4V ± 5 PSI ±2 V 15 PSI 30 PSI 5 PSI-G-4V 0 - 5 PSI 4V 15 PSI 30 PSI 15 PSI-A-4V 0 - 15 PSIA 4V 45 PSI 60 PSI 15 PSI-D-4V ±15 PSI ±2 V 45 PSI 60 PSI 15 PSI-G-4V 0 - 15 PSI 4V 45 PSI 60 PSI 30 PSI-A-4V 0 - 30 PSIA 4V 60 PSI 60 PSI 30 PSI-D-4V ±30 PSI ±2 V 60 PSI 60 PSI 30 PSI-G-4V 0 - 30 PSI 4V 60 PSI 100 PSI 100 PSI-A-4V 0 - 100 PSI 4V 150 PSI 150 PSI 100 PSI-D-4V ±100 PSI ±2 V 150 PSI 150 PSI 100 PSI-G-4V 0 - 100 PSI 4V 150 PSI 150 PSI 150 PSI-D-4V ±150 PSI ±2 V 200 PSI 200 PSI 150 PSI-G-4V 0 - 150 PSI 4V 200 PSI 200 PSI 600 - 1100 mbarA 4V 45 PSI 60 PSI BARO-A-4V Performance Characteristics for 0.3 PSI-D-4V Minimum Nominal Maximum Units Output Span, note 4 (FSS) ±1.90 ±2.0 ±2.10 V Offset Voltage @ zero differential pressure 2.15 2.25 2.35 V Offset Temperature Shift, note 2 -- -- ±40.0 mV Linearity, hysteresis error, note 3 -- -- ±0.5 %FSS Span Temperature Shift, note 2 -- -- ±2.0 %FSS Parameter, note 1 Amplified Output Medium Pressure Sensor Output Span, note 4 (FSS) 3.90 4.0 4.10 V Offset Voltage @ zero gage pressure 0.15 0.25 0.35 V Offset Temperature Shift, note 2 -- -- ±40.0 mV Linearity, hysteresis error, note 3 -- -- ±0.5 %FSS Span Temperature Shift, note 2 -- -- ±2.0 %FSS Minimum Nominal Maximum Units Output Span, note 4 (FSS) ±1.90 ±2.0 ±2.10 V Offset Voltage @ zero differential pressure 2.15 2.25 2.35 V Offset Temperature Shift, note 2 -- -- ±40.0 mV Linearity, hysteresis error, note 3 -- -- ±0.5 %FSS Span Temperature Shift, note 2 -- -- ±1.0 %FSS Minimum Nominal Maximum Units Output Span, note 4 (FSS) 3.90 4.0 4.10 V Offset Voltage @ zero gage pressure 0.15 0.25 0.35 V Offset Temperature Shift, note 2 -- -- ±40.0 mV Linearity, hysteresis error, note 3 -- -- ±0.5 %FSS Span Temperature Shift, note 2 -- -- ±1.0 %FSS Minimum Nominal Maximum Units Output Span, note 4 (FSS) ±1.90 ±2.0 ±2.10 V Offset Voltage @ zero differential pressure 2.15 2.25 2.35 V Offset Temperature Shift, note 2 -- -- ±20.0 mV Linearity, hysteresis error, note 3 -- -- ±0.5 %FSS Span Temperature Shift, note 2 -- -- ±1.0 %FSS Performance Characteristics for 1 PSI-D-4V Parameter, note 1 Performance Characteristics for: 1 PSI-G-4V Parameter, note 1 Performance Characteristics for 2.5 PSI-D-4V Parameter, note 1 All Sensors DS-0028 Rev D e www.allsensors.com Units f 408 225 2079 Maximum p 408 225 4314 Nominal a 16035 Vineyard Blvd. Morgan Hill, CA 95037 Minimum Parameter, note 1 all sensors Performance Characteristics for 0.3 PSI-G-4V Performance Characteristics for: 2.5 PSI-G-4V Parameter, note 1 Minimum Nominal Maximum Units Output Span, note 4 (FSS) 3.90 4.0 4.10 V Offset Voltage @ zero gage pressure 0.15 0.25 0.35 V Offset Temperature Shift, note 2 -- -- ±20.0 mV Linearity, hysteresis error, note 3 -- -- ±0.5 %FSS Span Temperature Shift, note 2 -- -- ±1.0 %FSS Minimum Nominal Maximum Units Output Span, note 4 (FSS) ±1.90 ±2.0 ±2.10 V Offset Voltage @ zero differential pressure 2.15 2.25 2.35 V Offset Temperature Shift, note 2 -- -- ±20.0 mV Linearity, hysteresis error, note 3 -- -- ±0.5 %FSS Span Temperature Shift, note 2 -- -- ±1.0 %FSS Minimum Nominal Maximum Units Output Span, note 4 (FSS) 3.90 4.0 4.10 V Offset Voltage @ zero gage pressure 0.15 0.25 0.35 V Offset Temperature Shift, note 2 -- -- ±20.0 mV Linearity, hysteresis error, note 3 -- -- 0.5 %FSS Span Temperature Shift, note 2 -- -- ±1.0 %FSS Minimum Nominal Maximum Units Output Span, note 4 (FSS) 3.90 4.0 4.10 V Offset Voltage @ zero absolute pressure 0.15 0.25 0.35 V Offset Temperature Shift, note 2 -- -- ±20.0 mV Linearity, hysteresis error, note 3 -- -- ±0.5 %FSS Span Temperature Shift, note 2 -- -- ±1.0 %FSS Performance Characteristics for: 5 PSI-D-4V Parameter, note 1 Performance Characteristics for: 5 PSI-G-4V Parameter, note 1 Performance Characteristics for 15 PSI-A-4V Parameter, note 1 Amplified Output Medium Pressure Sensor Units Output Span, note 4 (FSS) ±1.90 ±2.0 ±2.10 V Offset Voltage @ zero differential pressure 2.15 2.25 2.35 V Offset Temperature Shift, note 2 -- -- ±20.0 mV Linearity, hysteresis error, note 3 -- -- ±0.5 %FSS Span Temperature Shift, note 2 -- -- ±1.0 %FSS Minimum Nominal Maximum Units Output Span, note 4 (FSS) 3.90 4.0 4.10 V Offset Voltage @ zero gage pressure 0.15 0.25 0.35 V Offset Temperature Shift, note 2 -- -- ±20.0 mV Linearity, hysteresis error, note 3 -- -- ±0.5 %FSS Span Temperature Shift, note 2 -- -- ±1.0 %FSS Minimum Nominal Maximum Units Output Span, note 4 (FSS) 3.90 4.0 4.10 V Offset Voltage @ zero absolute pressure 0.15 0.25 0.35 V Offset Temperature Shift, note 2 -- -- ±20.0 mV Linearity, hysteresis error, note 3 -- -- ±0.5 %FSS Span Temperature Shift, note 2 -- -- ±1.0 %FSS Performance Characteristics for 15 PSI-G-4V Parameter, note 1 Performance Characteristics for 30 PSI-A-4V Parameter, note 1 Performance Characteristics for 30 PSI-D-4V Minimum Nominal Maximum Units Output Span, note 4 (FSS) ±1.90 ±2.0 ±2.10 V Offset Voltage @ zero differential pressure 2.15 2.25 2.35 V Offset Temperature Shift, note 2 -- -- ±20.0 mV Linearity, hysteresis error, note 3 -- -- ±0.5 %FSS Span Temperature Shift, note 2 -- -- ±1.0 %FSS Parameter, note 1 All Sensors DS-0028 Rev D e www.allsensors.com Maximum f 408 225 2079 Nominal p 408 225 4314 Minimum a 16035 Vineyard Blvd. Morgan Hill, CA 95037 Parameter, note 1 all sensors Performance Characteristics for 15 PSI-D-4V Performance Characteristics for 30 PSI-G-4V Parameter, note 1 Minimum Nominal Maximum Units Output Span, note 4 (FSS) 3.90 4.0 4.10 V Offset Voltage @ zero gage pressure 0.15 0.25 0.35 V Offset Temperature Shift, note 2 -- -- ±20.0 mV Linearity, hysteresis error, note 3 -- -- ±0.5 %FSS Span Temperature Shift, note 2 -- -- ±1.0 %FSS Minimum Nominal Maximum Units Output Span, note 4 (FSS) 3.90 4.0 4.10 V Offset Voltage @ zero absolute pressure 0.15 0.25 0.35 V Offset Temperature Shift, note 2 -- -- ±20.0 mV Linearity, hysteresis error, note 3 -- -- ±0.5 %FSS Span Temperature Shift, note 2 -- -- ±1.0 %FSS Minimum Nominal Maximum Units Output Span, note 4 (FSS) ±1.90 ±2.0 ±2.10 V Offset Voltage @ zero differential pressure 2.15 2.25 2.35 V Offset Temperature Shift, note 2 -- -- ±20.0 mV Linearity, hysteresis error, note 3 -- -- ±0.5 %FSS Span Temperature Shift, note 2 -- -- ±1.0 %FSS Minimum Nominal Maximum Units Output Span, note 4 (FSS) 3.90 4.0 4.10 V Offset Voltage @ zero gage pressure 0.15 0.25 0.35 V Offset Temperature Shift, note 2 -- -- ±20.0 mV Linearity, hysteresis error, note 3 -- -- ±0.5 %FSS Span Temperature Shift, note 2 -- -- ±1.0 %FSS Performance Characteristics for 100 PSI-A-4V Parameter, note 1 Performance Characteristics for 100 PSI-D-4V Parameter, note 1 Performance Characteristics for 100 PSI-G-4V Parameter, note 1 Amplified Output Medium Pressure Sensor Units Output Span, note 4 (FSS) ±1.90 ±2.0 ±2.10 V Offset Voltage @ zero differential pressure 2.15 2.25 2.35 V Offset Temperature Shift, note 2 -- -- ±20.0 mV Linearity, hysteresis error, note 3 -- -- ±0.5 %FSS Span Temperature Shift, note 2 -- -- ±1.0 %FSS Minimum Nominal Maximum Units Output Span, note 4 (FSS) 3.90 4.0 4.10 V Offset Voltage @ zero gage pressure 0.15 0.25 0.35 V Offset Temperature Shift, note 2 -- -- ±20.0 mV Linearity, hysteresis error, note 3 -- -- ±0.5 %FSS Span Temperature Shift, note 2 -- -- ±1.0 %FSS Minimum Nominal Maximum Units Output Voltage @ 1,100 mbar 4.20 4.25 4.30 V Output Voltage @ 600 mbar 0.20 0.25 0.30 V Offset Temperature Shift, note 2 -- -- ±20.0 mV Linearity, hysteresis error, note 3 -- 0.05 ±0.25 %FSS Span Temperature Shift, note 2 -- -- ±1.0 %FSS Performance Characteristics for 150 PSI-G-4V Parameter, note 1 Performance Characteristics for BARO-A-4V Parameter, note 1 Pressure Response: for any pressure applied the response time to get to 90% of pressure applied is typically less than 500 useconds. Specification Notes 1: All parameters are measured at 5.0 volt excitation, for the nominal full scale pressure and room temperature unless otherwise specified. Pressure measurements are with Port B. Absolute devices require pressure to be applied to port A. note 2: Shift is relative to 25°C over the compensated temperature range. note 3: Measured at one-half full scale rated pressure using best straight line curve fit. note 4: The span is the algebraic difference between full scale output voltage and the offset voltage. note positive pressure applied to All Sensors DS-0028 Rev D e www.allsensors.com Maximum f 408 225 2079 Nominal p 408 225 4314 Minimum a 16035 Vineyard Blvd. Morgan Hill, CA 95037 Parameter, note 1 all sensors Performance Characteristics for 150 PSI-D-4V
30PSI-G-4V 价格&库存
很抱歉,暂时无法提供与“30PSI-G-4V”相匹配的价格&库存,您可以联系我们找货
