Amplified Middle Pressure Sensors
Features
• 0 to ±0.3 to 0 to 150 psi Pressure Ranges
• Ratiometric 4V Output
• Temperature Compensated
• Calibrated Zero and Span
• Medical Instrumentation
• Environmental Instrumentation
• HVAC Instrumentation
General Description
The Amplified line of middle pressure sensors are based upon a proprietary package technology to reduce errors. This model provides
all sensors
Applications
induced parasitic stress and strain. In addition the sensor utilizes a silicon, micromachined, stress concentration enhanced structure to
provide a very linear output to measured pressure.
These calibrated and temperature compensated sensors give an accurate and stable output over a wide temperature range. Each sensor
is internally compensated using an ASIC compensation technique. This series is intended for use with non-corrosive, non-ionic working
The output of the device is ratiometric to the supply voltage over a supply voltage range of 4.5 to 5.5 volts.
Physical Dimensions
Equivalent Circuit
2.54
0.100
(Typ)
8.74
0.344
1.27
0.050
27.43
1.080
5.33
0.210
Port B
3.56
0.140
10.67
0.420
10.67
0.420
Port A
3.18
R0.125
12.19
0.480
pin 1: Vsupply
pin 2: Common
20.32
0.800
13.97
0.550
pin 3: Voutput
21.59
0.850
pin 4: do not connect
Approvals
MKT DATE
As Is
With Change
MFG DATE
As Is
4
All Sensors
With Change
TITLE:
pin, No Port Cut,
As A-Package,
Is Barb, Flat4With
No
LeadsChange
SIZE
FILE NAME
DS-0028 RevAD
All Sensors
5
ENG DATE
3
2
A4AAF Rev B
1
QA DATE
As Is
With Change
a 16035 Vineyard Blvd. Morgan Hill, CA 95037
0.020" x 0.010" Pin
0.30" minimum length
Pin 1 Identifier
3.18
0.125
Port 0.179"/0.189"
CL
p 408 225 4314
f 408 225 2079
fluids such as air, dry gases and the like.
e www.allsensors.com
a ratiometric 4-volt output with superior output characteristics. The sensor housing has been designed specifically to reduce package
Pressure Sensor Ratings
Environmental Specifications
+4.5 to +5.5 Vdc
Supply Voltage, Vs
-10 to +10 psig
Common-mode pressure
250°C
Lead Temperature, max
(soldering 2-4 sec.)
Temperature Ranges
Compensated
5 to 50° C
Operating
-25 to 85° C
Storage
-40 to 125° C
Humidity Limits
0 to 95% RH
(non condensing)
Standard Pressure Ranges
Part Number
Operating Pressure
Nominal Span
Proof Pressure
Burst Pressure
0.3 PSI-D-4V
±0.3 PSI
±2 V
5 PSI
10 PSI
0.3 PSI-G-4V
0 - 0.3 PSI
4V
5 PSI
10 PSI
1 PSI-D-4V
±1 PSI
±2 V
5 PSI
10 PSI
1 PSI-G-4V
0 - 1 PSI
4V
5 PSI
10 PSI
2.5 PSI-D-4V
±2.5 PSI
±2 V
10 PSI
20 PSI
2.5 PSI-G-4V
0 - 2.5 PSI
4V
10 PSI
20 PSI
5 PSI-D-4V
± 5 PSI
±2 V
15 PSI
30 PSI
5 PSI-G-4V
0 - 5 PSI
4V
15 PSI
30 PSI
15 PSI-A-4V
0 - 15 PSIA
4V
45 PSI
60 PSI
15 PSI-D-4V
±15 PSI
±2 V
45 PSI
60 PSI
15 PSI-G-4V
0 - 15 PSI
4V
45 PSI
60 PSI
30 PSI-A-4V
0 - 30 PSIA
4V
60 PSI
60 PSI
30 PSI-D-4V
±30 PSI
±2 V
60 PSI
60 PSI
30 PSI-G-4V
0 - 30 PSI
4V
60 PSI
100 PSI
100 PSI-A-4V
0 - 100 PSI
4V
150 PSI
150 PSI
100 PSI-D-4V
±100 PSI
±2 V
150 PSI
150 PSI
100 PSI-G-4V
0 - 100 PSI
4V
150 PSI
150 PSI
150 PSI-D-4V
±150 PSI
±2 V
200 PSI
200 PSI
150 PSI-G-4V
0 - 150 PSI
4V
200 PSI
200 PSI
600 - 1100 mbarA
4V
45 PSI
60 PSI
BARO-A-4V
Performance Characteristics for 0.3 PSI-D-4V
Minimum
Nominal
Maximum
Units
Output Span, note 4 (FSS)
±1.90
±2.0
±2.10
V
Offset Voltage @ zero differential pressure
2.15
2.25
2.35
V
Offset Temperature Shift, note 2
±40.0
mV
Linearity, hysteresis error, note 3
±0.5
%FSS
Span Temperature Shift, note 2
±2.0
%FSS
Parameter, note 1
Amplified Output Medium Pressure Sensor
3.90
4.0
4.10
V
Offset Voltage @ zero gage pressure
0.15
0.25
0.35
V
±40.0
mV
±0.5
%FSS
±2.0
%FSS
Minimum
Nominal
Maximum
Units
±1.90
±2.0
±2.10
V
2.15
2.25
2.35
V
±40.0
mV
±0.5
%FSS
±1.0
%FSS
Minimum
Nominal
Maximum
Units
3.90
4.0
4.10
V
0.15
0.25
0.35
V
±40.0
mV
±0.5
%FSS
±1.0
%FSS
Minimum
Nominal
Maximum
Units
±1.90
±2.0
±2.10
V
2.15
2.25
2.35
V
±20.0
mV
±0.5
%FSS
±1.0
%FSS
Performance Characteristics for 1 PSI-D-4V
Parameter, note 1
Performance Characteristics for: 1 PSI-G-4V
Parameter, note 1
Performance Characteristics for 2.5 PSI-D-4V
Parameter, note 1
All Sensors
DS-0028 Rev D
Units
f 408 225 2079
Maximum
p 408 225 4314
Nominal
Minimum
Parameter, note 1
all sensors
Performance Characteristics for 0.3 PSI-G-4V
Performance Characteristics for: 2.5 PSI-G-4V
Parameter, note 1
Minimum
Nominal
Maximum
Units
3.90
4.0
4.10
V
0.15
0.25
0.35
V
±20.0
mV
±0.5
%FSS
±1.0
%FSS
Minimum
Nominal
Maximum
Units
±1.90
±2.0
±2.10
V
2.15
2.25
2.35
V
±20.0
mV
±0.5
%FSS
±1.0
%FSS
Minimum
Nominal
Maximum
Units
3.90
4.0
4.10
V
0.15
0.25
0.35
V
±20.0
mV
0.5
%FSS
±1.0
%FSS
Minimum
Nominal
Maximum
Units
3.90
4.0
4.10
V
Offset Voltage @ zero absolute pressure
0.15
0.25
0.35
V
±20.0
mV
±0.5
%FSS
±1.0
%FSS
Performance Characteristics for: 5 PSI-D-4V
Parameter, note 1
Performance Characteristics for: 5 PSI-G-4V
Parameter, note 1
Performance Characteristics for 15 PSI-A-4V
Parameter, note 1
Units
±1.90
±2.0
±2.10
V
2.15
2.25
2.35
V
±20.0
mV
±0.5
%FSS
±1.0
%FSS
Minimum
Nominal
Maximum
Units
3.90
4.0
4.10
V
0.15
0.25
0.35
V
±20.0
mV
±0.5
%FSS
±1.0
%FSS
Minimum
Nominal
Maximum
Units
3.90
4.0
4.10
V
0.15
0.25
0.35
V
±20.0
mV
±0.5
%FSS
±1.0
%FSS
Performance Characteristics for 15 PSI-G-4V
Parameter, note 1
Performance Characteristics for 30 PSI-A-4V
Parameter, note 1
Performance Characteristics for 30 PSI-D-4V
Minimum
Nominal
Maximum
Units
±1.90
±2.0
±2.10
V
2.15
2.25
2.35
V
±20.0
mV
±0.5
%FSS
±1.0
%FSS
Parameter, note 1
All Sensors
DS-0028 Rev D
Maximum
f 408 225 2079
Nominal
p 408 225 4314
Minimum
Parameter, note 1
all sensors
Performance Characteristics for 15 PSI-D-4V
Performance Characteristics for 30 PSI-G-4V
Parameter, note 1
Minimum
Nominal
Maximum
Units
3.90
4.0
4.10
V
0.15
0.25
0.35
V
±20.0
mV
±0.5
%FSS
±1.0
%FSS
Minimum
Nominal
Maximum
Units
3.90
4.0
4.10
V
0.15
0.25
0.35
V
±20.0
mV
±0.5
%FSS
±1.0
%FSS
Minimum
Nominal
Maximum
Units
±1.90
±2.0
±2.10
V
2.15
2.25
2.35
V
±20.0
mV
±0.5
%FSS
±1.0
%FSS
Minimum
Nominal
Maximum
Units
3.90
4.0
4.10
V
0.15
0.25
0.35
V
±20.0
mV
±0.5
%FSS
±1.0
%FSS
Performance Characteristics for 100 PSI-A-4V
Parameter, note 1
Performance Characteristics for 100 PSI-D-4V
Parameter, note 1
Performance Characteristics for 100 PSI-G-4V
Parameter, note 1
Units
±1.90
±2.0
±2.10
V
2.15
2.25
2.35
V
±20.0
mV
±0.5
%FSS
±1.0
%FSS
Minimum
Nominal
Maximum
Units
3.90
4.0
4.10
V
0.15
0.25
0.35
V
±20.0
mV
±0.5
%FSS
±1.0
%FSS
Minimum
Nominal
Maximum
Units
Output Voltage @ 1,100 mbar
4.20
4.25
4.30
V
Output Voltage @ 600 mbar
0.20
0.25
0.30
V
±20.0
mV
0.05
±0.25
%FSS
±1.0
%FSS
Performance Characteristics for 150 PSI-G-4V
Parameter, note 1
Performance Characteristics for BARO-A-4V
Parameter, note 1
Pressure Response: for any pressure applied the response time to get to 90% of pressure applied is typically less than 500 useconds.
Specification Notes
1: All parameters are measured at 5.0 volt excitation, for the nominal full scale pressure and room temperature unless otherwise specified. Pressure measurements are with
Port B. Absolute devices require pressure to be applied to port A.
note 2: Shift is relative to 25°C over the compensated temperature range.
note 3: Measured at one-half full scale rated pressure using best straight line curve fit.
note 4: The span is the algebraic difference between full scale output voltage and the offset voltage.
note
positive pressure applied to
All Sensors
DS-0028 Rev D
Maximum
f 408 225 2079
Nominal
p 408 225 4314
Minimum
Parameter, note 1
all sensors
Performance Characteristics for 150 PSI-D-4V
