Issued by Module Components Div, TAMURA CORPORATION
Current Sensor : F01P***S05L
Features:
Backward compatible to F01PS05 series
Anti-Surge current (4kAT, 8/20uS, single)
Mounting area reduced ; pin compatible. Longitudinal dimension reduced
Super precision & High Stability (low temperature, drift)
Unipolar power voltage ; +5V
Multi-range models
F01P***S05L series are designed by the pin compatibility as high-end models of
S22P***X05M2 series.
Comparison of the main features of F******S05L series
Series
Features
F01P***S05L
No reference access
F02P***S05L
No reference access. Ref In/Out
F03P***S05L
No reference access. Ref In/Out. Higher creep age and clearance distance.
*** = Rated Current Symbol
Specification
F01P***S05L
Maximum Peak Current
4kAT (2kAx2. Number of primary tunes is two tunes)
Rated Current If (***= rated current symbol)
6A(006) / 15A(015) / 25A(025) 50A(050)
Maximum Current
±20A(If=6A) / ±51A(If=15A) / ±85A(If=25A) / ±150A(If=50A)
Existence of reference access
Number of primary busbar
3 pcs
Clearance distance ; Primary ↔Secondary
7.7 mm
Standards
UL508 (file#E243511) , EN501758, EN61010-1 , EN60950-1
Ambient Operating Temperature
-40°C ~ +105°C
Mounting Area
The mounting area has been reduced
more than the F01P series. However ,
F01P***S05L series are 100%
compatible with original footprint
mounting.
F01PxxxS05LrevA Dec 2013
1
Absolute Maximum Rating
Symbol
Unit
Value
Vcc
V
7
Primary Conductor Temperature
°C
110
ESD (HBM: Human Body Model)
kV
4
C=100pF , R=1.5kΩ
kAT
4
Current Waveform :
Front time 8ųs
Time to half value 20ųs
Single
Supply Voltage
Notes
Isolation Characteristics
Symbol
Unit
Value
Insulation Voltage
Vd
AC4200V for 1 min.
(Sensing Current 0.5mA)
Primary↔Secondary
Insulation Resistance
Ris
≥500mΩ (@DC500V)
Primary↔Secondary
Clearance distance
dCi
7.7mm (TYP)
Primary↔Secondary
Creep age distance
dCp
7.7mm (TYP)
Primary↔Secondary
UL94 V-0
CTI
V
600
300V , CAT Ⅲ , PD2
Reinforced Isolation
Non uniform field according to
EN50178 , EN61010
600V , CAT Ⅲ , PD2
Simple isolation
EN50178 , EN61010
Case material
Comparative Tracking Index (CTI)
Notes
Application Example
Environmental and Mechanical Characteristics
Symbol
Unit
Value
min
typ
max
Ta
°C
- 40
+ 105
Ambient Storage Temperature
Ts
°C
- 40
+105
g
Mass
12
2
Specification
(*1) = Offset voltage value is after removal of core hysteresis
Symbol
Unit
Value
min
Rated Current
F01P006S05L
F01P015S05L
F01P025S05L
If
15
A
25
50
F01P006S05L
F01P015S05L
F01P025S05L
Ipmax
A
F01P050S05L
Supply Voltage
Vcc
V
Number of primary turns
Np
T
Number of secondary turns
- 20
51
- 85
85
- 150
150
4.75
Ns
1737
T
1764
F01P050S05L
1600
F01P006S05L
25
F01P015S05L
F01P025S05L
Icc
30
mA
55
Output Voltage
Vo
V
Output Voltage (Ip=0A)
Vo
V
F01P006S05L
4.625
2.5
10.40
- 7.10
7.10
- 6.25
6.25
F01P050S05L
- 5.80
5.80
F01P006S05L
- 0.10
0.10
- 0.17
0.17
- 0.25
0.25
- 0.46
0.46
F01P025S05L
Voe
mV
F01P015S05L
F01P025S05L
F01P050S05L
0.375
- 10.40
F01P015S05L
Electrical Offset Current
referred to primary
Icc=15+Ip(mA) / Ns
35
F01P050S05L
Electrical Offset Voltage (*1 )
5.25
1816
F01P015S05L
Consumption current (at If)
5.00
1,2,3
F01P006S05L
F01P025S05L
max
6
F01P050S05L
Maximum Current
(@ Vcc : +5V , Ta : +105°C)
typ
Notes
Ioe
A
3
Specification
Symbol
Unit
Value
min
Temperature coefficient of
Output voltage (@ Ip=0A)
typ
max
±10.0
±80.0
±7.5
±70.0
±6.5
±60.0
F01P050S05L
±6.0
±60.0
F01P006S05L
104.2
F01P006S05L
F01P015S05L
F01P025S05L
Sensitivity
(Theoretical value)
TCVo
ppm/K
F01P015S05L
F01P025S05L
Sensitivity Error
Sensitivity (@Ta=-40°C~+105°C)
Output Linearity
Magnetic offset current referred
to primary (@ 10xIf)
F01P006S05L
mV/A
ᵋG
TCG
ppm/K
ᵋL
- 0.1
0.1
Iom
A
- 0.1
0.1
Ino
ųA/
(Hz)1/2
±40
36
F01P050S05L
300
mV
RL=1kΩ
40
160
F01P015S05L
15
60
F01P025S05L
10
40
F01P050S05L
5
F01P006S05L
RL=1kΩ
0.3
RL=1kΩ, di/dt=18A/ųs
0.3
RL=1kΩ, di/dt=44A/ųs
0.3
RL=1kΩ, di/dt=68A/ųs
F01P050S05L
0.3
RL=1kΩ, di/dt=100/ųs
F01P006S05L
0.3
0.3
0.3
0.3
F01P025S05L
tra
ųs
F01P015S05L
F01P025S05L
F01P050S05L
0.7
150
F01P015S05L
Response time (@90% of If)
- 0.7
F01P025S05L
(f typ=450kHz)
Reaction time (@ 10% of If)
12.5
90
F01P006S05L
625mV/If
25
F01P015S05L
Peak to peak output ripple at
oscillator frequency
ppm/K of 2.5V
( -40°C~+105°C)
41.67
Gth
F01P050S05L
Output current noise referred to
primary (@ 100Hz~100kHz)
Notes
tr
ųs
4
Specification
Symbol
Unit
Value
min
typ
Comment
max
Response time 2
(@ 10% of If to 90% of Vo)
Frequency bandwidth
(± 1dB)
Frequency bandwidth
(± 3dB)
Output Voltage Accuracy
(Overall)
tr
ųs
0.6
BW
kHz
200
RL=1kΩ
BW
kHz
300
RL=1kΩ
F01P006S05L
F01P015S05L
RL=1kΩ
2.5
XG
1.9
F01P025S05L
1.8
F01P050S05L
1.7
XG=(100xVoe/625)+ԐG+ԐL
Standards
EN 50178; EN 61010-1 ; EN 60950-1 ; UL 508 (file no. E243511)
Characteristic Curve (TYP)
5
Maximum Continuous DC primary current
According to which the following
conditions are true the maximum
continuous DC primary current plot
shows the boundary of the area.
1. Ip < Ipmax
2. Junction temperature
Tj < 125ºC
3. Primacy conductor temperature
< 110°C
4. Resistor power dissipation
< 0.5 x rated power
Frequency Derating
Figure 7 : Maximum RMS AC primary current / maximum DC primary current vs frequency
6
Connection
Dimension (mm)
Recommended Hole Diameter (mm)
7
很抱歉,暂时无法提供与“F01P015S05L”相匹配的价格&库存,您可以联系我们找货
