T"DT78Tilt8Switch8Universal8LPBracket8P8PDNB8"95/
Product8Sheet8
[4
[0"mm]
Diaf85f/L48
[[[f98mm]
5f5L48Thkf8
[[f78mm]
Diaf85f"6648[]f0mm]
clearance8holes8for8
-/8or8M]8machine8screw8
[f048
[9]8mm]
[f[04
[06f[8mm]
T1 Unidirectional Tilt Switch
Application Notes
"f/604
[]/8mm]
T3 Omnidirectional Tilt Switch
Application Notes
For8complex8mounting8scenarios8use8universal8bracketsf8C8Two8brackets8can8be8used8
to8achieve8rotation8in878axesW8to8nearly8any8compound8anglef8888
T"8P8Tilt8switch8should8be8mounted8usingB8
"f8Spring8SHoseH8Clip
[f8WeatherPProof8Double8Sided8Tape
C
Use8-/8or8M]8screwsW8
nuts8and8lockPwashers8
to8mount8the8tilt8switch8and8
brakcetSsHf
to8mount8the8bracketSsHf
C
很抱歉,暂时无法提供与“1608”相匹配的价格&库存,您可以联系我们找货
