Adafruit Perma-Proto Quarter-sized Breadboard PCB - Single ID: 1608
DESCRIPTION
Page 1 of 2
Page 2 of 2
Customers have asked us to carry basic perf-board, but we never liked the look of
most basic perf: its always crummy quality, with pads that flake off and no labeling.
Then we thought about how people actually prototype - usually starting with a
solderless breadboard and then transferring the parts to a more permanent PCB.
That's when we realized what people would really like is a proto board that makes
it easy!
This proto-board is the PCB you always wish you had, but never realized it! We
took the basic layout of a quarter-sized breadboard (basically, a 'tiny' breadboard
plus power rails) and turned that into a beautiful PCB. The top side has a white
silkscreen, and the same markings you're familiar with, to make transferring
components easy. The bottom has the 5-hole pad design that matches a classic
breadboard, with 4 power bus lines on the sides, and no mask so you can easily cut
traces when necessary. We used 1.2mm diameter drill holes so even parts with big
leads will fit. All holes are thru-plated for strength - these wont peel off with
rework. The finish is a gold plate - you won't get oxidation like with bare copper
perf! There are also two mounting holes so you can attach the PCB to your project
box.
Once you use a Perma-Proto board, you'll never go back!
http://www.adafruit.com/products/1608
2/23/2015
很抱歉,暂时无法提供与“1608”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+33.363811+4.03849
