HMS_462_GTP
HMS_462_GTP
    VCC
    10MM LENS SEAL WASHER RTAINR
HMS_462_GTP 数据手册
8 D 5 6 7 4 NOTES: MOUNTING: Mounts in a .562 .002 [ 16.56mm .05] panel hole on .750 [19.05mm] 1. centers. Panel thickness .031 [.8mm] to .187 [4.75mm]. Panel hole should be deburred, but not chamfered. ASSEMBLY: Insert lens through panel hole, slide lock washer onto lens barrel and twist on 2. retaining ring. PCB mounted LEDs slide into lens when the panel cover is closed or the PCB card is inserted into the case. 3. MATERIAL: Lens-Polycarbonate, UL 94-V2 Lock Washer- FH Steel, Nickel plate Retaining ring - Thermoplastic, U.L. 94 V0 Rated Seal- EPDM 4. U.S. & Foreign Pat. Issued & Pend. ECN# C 1 REV. REVISIONS DESCRIPTION 001 REVISED PER ECR111009AZ01 DATE INITIALS 4-23-10 SMU D .623 15.82mm SEAL 2 3 LOCK WASHER .550 13.97mm .620 15.75mm RETAINING RING .780 19.81mm C .700 17.78mm B B .035±.003 0.89mm±0.08 .435 11.05mm .480 12.19mm ORDERING CODE : .340 8.64mm .018 0.44mm HMS 462 XXX MODEL LOCK WASHER LED DIMENSION STYLE: INCHES / MM GENERAL TOLERANCES UNLESS OTHERWISE SPECIFIED VCC A DISPLAY PANEL .X .XX .XXX PAT. PEND. RTP ATP GTP BTP YTP CTP LENS COLOR RED TRANSPARENT AMBER TRANSPARENT GREEN TRANSPARENT BLUE TRANSPARENT YELLOW TRANSPARENT CLEAR TRANSPARENT 7 MATERIAL OPTOELECTRONICS SEE NOTES MM .508 .254 .127 BREAK ALL CORNERS AND SHARP EDGES .030 MAX 190 BOSSTICK BLVD. SUITE 101 SAN MARCOS, CA 92069 U.S.A PHONE: (760) 560-1300, FAX: (760) 560-1301 EMAIL: vccsales@vcclite.com FINISH TITLE: SEE NOTES LENS RETAINING PCB RING 6 5 DATE APPROVAL THIRD ANGLE PROJECTION PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF VISUAL COMMUNICATIONS COMPANY, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF VISUAL COMMUNICATIONS COMPANY, INC IS PROHIBITED. ASSEMBLY 8 INCHES .020 .010 .005 ANGLE 1' 4 3 DRAWN: CHECKED: SMU 4-23-10 DZ 4-23-10 SIZE 10MM ROUND STANDARD THREADED FRESNEL LENS WITH SEAL SCALE: 4:1 DO NOT SCALE DRAWING 2 REV DWG. NO. B HMS 462 XXX 001 SHEET 1 OF 1 1 A
HMS_462_GTP 价格&库存
很抱歉,暂时无法提供与“HMS_462_GTP”相匹配的价格&库存,您可以联系我们找货
