Dot Graphic VFD Module
q
q
q
q
q
q
q
GU128X32-800A
128 x 32 Dot Graphic
Operating Temp -40° C to +85° C
Single 5V Supply.
High Brightness Blue Green Display
Selectable Parallel (i80/M68)/Serial Interface
Twin Screen Graphic RAM
16 Level Brightness Control Function
The module includes the Vacuum Fluorescent Display
glass, driver and control ASIC, with integral refresh Graphic
RAM and logic for parallel and synchronous serial
interfaces. The high speed 8 bit parallel interface is 5V
CMOS compatible suitable for connection to a host CPU
bus. Brightness control and power down functions are
provided. A full data sheet is available.
1.5
20.65
21.75
33.0
30.5 38.5
83.05
11.15
126.5
130.0
1.75
4.0
110.0
1.6
1
10.8 ± 1mm
10.0 max.
Dimensions in mm & subject to tolerances.
Mounting holes 3.5mm dia.
65.0
IDC(IMSA-9032B-26P)
PWR(JST-B3B-XH-A)
ELECTRICAL SPECIFICATION
Parameter
Symbol
Power Supply Voltage
V CC
Power Supply Current
ICC
Logic High Input
V IH
Logic Low Input
V IL
Logic High Output
V OH
Logic Low Output
V OL
Reset Input Voltage
V RH
Reset Input Voltage
V RL
BLOCK DIAGRAM
Value
5.0VDC +/- 5%
450mADC typ.
4.0 VDC min.
1.0 VDC max.
4.7 VDC min.
0.3 VDC max.
4.0 VDC min.
0.6 VDC max.
Condition
GND=0V
V CC= 5V
IIH = 2uA
IIL = -600uA
IOH = -300uA
IOL = 300uA
IRH = 5uA
IRL = -600uA
The power on rise time should be less than 100ms.The inrush current at power on can be 2 x ICC .
OPTICAL and ENVIRONMENTAL SPECIFICATIONS
Parameter
Value
Display Area (XxY mm)
83.05 x 20.65
Dot Size/Pitch (XxY mm)
0.5 x 0.5/0.65 x 0.65
Luminance
350 cd/m2 Min.
Colour of Illumination
Blue-Green (Filter for colours)
Operating Temperature
-40°C to +85°C
Storage Temperature
-40°C to +85°C
Operating Humidity (non condensing) 20 to 80% RH @ 25°C
SOFTWARE COMMANDS
Instruction
C//D
Instruction Byte
No. Bytes
Set Display On/Off / Layer Merge
1
20H-2FH
2
Set Display Brightness
1
40H-4FH
1
Clear Display
1
52H-5FH
1
Set Cursor XY Address
1
60H-67H
3
Set Display Start X Address
1
70H-7FH
2
Set Write Address Mode
1
80H-8FH
1
Scroll Display Vertically Up/Down
1
B0H-BFH
1
Read Cursor XY Address
1
D4H-D7H
3
Write Data
00H-FFH
1
TIMING PARAMETERS (min)
i80/M68 Parameters
Time
Write /WR/EN Cycle Time
400ns
Write /WR/EN Pulse Width 100ns
Set Up To Write /WR/EN
30ns
Hold after Write /WR/EN
20ns
SCROLLING GRAPHIC DISPLAY
Serial Parameters
Time
SCK Cycle Time
200ns
SCK Pulse Width
80ns
Set Up To SCK, /CSS=’L’
40ns
Delay After 8th bit, /CSS=’H’ 150ns
The pattern in GRAM can be scrolled around the display. Horizontal scroll is achieved by
increment/decrement of the Display Start X Address. The vertical scroll process considers
layer 0, then layer 1 as a continuous 128 bit high vertical area within RAM.
NORITAKE ITRON VFD MODULES
D0~D7
SO
SI
WR (R/W)
RD (ENCK)
CSS
C/D
FRP
/RES
DISPLAY
CONTROLLER
GRAPHIC
RAM
DC/DC + AC
Conv.
VCC
GND
BD VFD
FILAMENT (AC)
ANODE + GRID (DC)
GRAPHIC RAM
X ADDRESS
00H………………………….7FH
BYTE FORMAT
D0
D1
D2
D3
D4
D5
D6
D7
Y ADDRESS
0H
1H
2H
3H
4H
5H
6H
7H
GRAM
Layer 0
…………….7FH
GRAM
Layer 1
DH
The Graphic RAM is composed of 16384
EH
bits arranged as (128 x 64 bits) x 2 and the
FH
access is operated by 8 bit vertical data
IDC DATA CONNECTOR
3 PIN POWER CONNECTOR
Pin i80 M68 Serial Pin Sig
Pin
Sig
X
1 D7 D7
2 GND
1
Vcc
X
3 D6 D6
4 GND
2
Test (Factory only)
X
5 D5 D5
6 GND
3
GND
X
7 D4 D4
8 GND PCB JUMPERS (O)pen (L)ink
X
J2
9 D3 D3
10 GND Interface J1
X
Serial
L
O/L
11 D2 D2
12 GND
O
O
13 D1 D1 SO 14 GND i80 Parallel
SI 16 GND M68 Parallel
O
L
15 D0 D0
17 /WR R//W X 18 GND
CONTACT
19 C//D C//D C//D 20 GND
Noritake Sales Office Tel Nos
21 /RD ENCK SCK 22 GND Nagoya Japan: +81 (0)52-561-9867
Canada: +1-416-291-2946
23 /CSS /CSS /CSS 24 GND
Chicago USA: +1-847-439-9020
25 FRP FRP FRP 26 /RES
Subject to change without notice.
IUK Doc Ref: 03471 Iss:1 23/07/01
Munchen (D): +49 (0)89-3214-290
Itron UK: +44 (0)1493 601144
Rest Europe: +49 (0)61-0520-9220
www.noritake-itron.com
很抱歉,暂时无法提供与“GU128X32-800A”相匹配的价格&库存,您可以联系我们找货
