GU256X64D-3900
GU256X64D-3900
    NORITAKE
    MODULE VF GRAPHIC DISPLAY 256X64
GU256X64D-3900 数据手册
Graphic VFD Module GU256x64D-3900 Ref: MC-019 Mar.03 Single 5V power supply High Brightness Blue Green Display Operating Temp -40°C to +70°C 6x8, 8x16, 16x32 Font table 16x16 Asian(Japanese, Chinesex2. Korean) fon RS232C, Parallel, USB(option) Interface Easy drawing function Power ON/OFF control 44.0 50.0 □ □ □ □ □ I/O Port controllability User window definition and individual control High speed Graphic animation ability Character & Bitmap image download 8 level brightness control Development Kit Available (GUD-3000) RS233C cable, Power supply, Sample software 159.0 153.0 3.0 □ □ □ □ □ □ □ □ 3.0 Display Area : 115.05 x 28.65 Φ3.5 11.5 MAX. Unit : mm Parallel Interface Connecter Power & Serial Interface Connecter INTERNATIONAL FONT n=0 COMMON FONT ELECTRICAL SPECIFICATION Parameter Symbol Value Power Supply Voltage VCC 5.0VDC Power Supply Current ICC 0.85ADC typ. Logic Hi Input (Parallel) VIH 0.8VDC min. Vcc max. Logic Low Input (Parallel) VIL 0VDV min. 0.2Vcc max. Logic HI output (Parallel) VOH 3.5VDC min. Vcc max. Logic Low output (Parallel) VOL 0VDV min. 0.6Vcc max. Logic Hi Input (RS232) VIH 3.0VDC min. 15VDC max. Logic Low Input (RS233) VIL -15VDC min. -3VDC max. Logic Hi output (RS233) VOH 5.0VDC min. Logic Low output (RS232) VOL -5VDC max. OPTICAL and ENVIRONMENTAL SPECIFICATIONS Parameter Value PCB Size (X x Y mm) 159.00 x 50.00 Display Area (X x Y mm) 115.05 x 28.65 Dot size / Pitch (X x Y mm) 0.30 / 0.45 Luminance 800 cd/m2 Typ. Color of Illumination Blue Green Operating Temperature -40°C to +85°C Operating Humidity 20 to 80 % RH (non condensing) SOFTWARE COMMANDS - Popular codes, more included Command Code Write Character to Display 20H~FFH BS, HT, LF, CR, Display Clear 08H, 09H, 0AH, 0DH, 0CH Initialize Display 1BH Specify International Font 1BH 52H n Vertical / Horizontal Scroll Mode 1FH 02H / 1FH 03H Scroll Display Action 1FH 28H 61H 10H wL wH cL cH s Display Blink 1FH 28H 61H 11H p t1 t2 c Font Size Select 1FH 28H 67H 01H m Font Magnified Display 1FH 28H 67H 40H x y Brightness Level Setting 1FH 58H n n=19 6x8, 8x16, 16x32 Font table abailable. Also, 4 types of 16x16 Asian font include Serial Interface (CN1) Pin Sig 1 RXD 2 DTR 3 DSR 4 TXD 5 TEST 6 VCC 7 GND Baud rate: 38,400 or 19,200 Atlanta Boston Chicago Dallas 1-888-326-3423 1-888-395-3423 1-800-779-5846 1-888-318-3423 Parallel interface (CN5) Pin Sig Pin Sig 1 D7 2 D6 3 D5 4 D4 5 D3 6 D2 7 D1 8 D0 9 GND 10 WR 11 GND 12 READY 13 GND 14 GND 15 VCC1(5V) 16 VCC1(5V) Please inquire for full specification. ** Subject to change without notice ** Los Angels 1-888-795-3423 New York 1-888-296-3423 Canada 1-416-291-2946
GU256X64D-3900 价格&库存
很抱歉,暂时无法提供与“GU256X64D-3900”相匹配的价格&库存,您可以联系我们找货
