Nokia 5110/3310 Monochrome LCD
Created by lady ada
https://learn.adafruit.com/nokia-5110-3310-monochrome-lcd
Last updated on 2021-12-09 03:18:56 PM EST
©Adafruit Industries
Page 1 of 32
Table of Contents
Overview
3
Power Requirements
4
Arduino Wiring
4
• Dimmable Backlight Option:
8
Arduino Testing
10
Graphics Library
12
Wiring (fewer pins)
13
CircuitPython Wiring
13
CircuitPython Setup
14
• CircuitPython Installation of PCD8544 Library
14
CircuitPython Usage
15
15
15
16
17
19
Initialization
Controlling the Backlight LED
Contrast and Bias
Drawing
Text
Invert
Full Example Code
Python Wiring
23
Python Setup
23
• Python Installation of PCD8544 Library
• DejaVu TTF Font
• Pillow Library
Python Usage
Initialization
Contrast and Bias
Example Code
Downloads
24
24
24
25
25
25
26
27
32
Page 2 of 32
Overview
This is a quick tutorial for our 84x48 pixel monochrome LCD display. These displays
are small, only about 1.5" diameter, but very readable due and comes with a backlight.
This display is made of 84x48 individual pixels, so you can use it for graphics, text or
bitmaps. These displays are inexpensive, easy to use, require only a few digital I/O
pins and are fairly low power as well.
To drive the display, you will need 3 to 5 digital output pins (depending on whether
Page 3 of 32
you want to manually control the chip select and reset lines). Another pin can be used
to control (via on/off or PWM) the backlight. To make things easy for you, we've
written a nice graphics library that can print text, pixels, rectangles, circles and lines!
The library is written for the Arduino but can easily be ported to your favorite
microcontroller.
You can pick up one of these displays at the adafruit shop! (https://adafru.it/aIH)
Power Requirements
The display uses the PCD8544 controller chip from Philips and were used in Nokia
3310 and 5110 cell phones. This chip is designed to run only at 3.3V and have 3v
communication levels, so for 5V microcontrollers a logic level shifter is required
(otherwise you could easily damage the display).
If you want to use the backlight, that can draw up to 80mA (4 white LEDs at 20mA
each). The backlight pin is connected to a transistor so you can PWM all 4 LEDs at
once from a microcontroller pin.
Arduino Wiring
The LCD runs at 3.3V so you'll need to use a level shifting chip to use with a 5V
microcontroller. The following will assume that is the case. If you're running a 3.3V
microcontroller system, you can skip the level shifter.
We'll assume you want to use this in a breadboard, take a piece of 0.1" header 8 pins
Page 4 of 32
long and insert it into a breadboard.
Slide either side of the LCD onto the header, the 'thicker' end is the top.
Solder all the pins.
Page 5 of 32
Place the level shifter chip off to the side. Pin 1 is on the left here.
Page 6 of 32
We'll start with the power lines. the system must be powered by 3.3V so red here is
connected to the 3V pin from the Arduino. Ground is black.
• Connect pin 1 of the 4050, the LCD VCC pin and the LCD backlight pin to 3.3V.
• Connect pin 8 of the 4050 and the GND pin of the LCD to ground.
Verify you see the backlight LEDs light up
Page 7 of 32
Newer versions of these boards have a sightly different backlight circuit that is
brighter than the older boards. You can add a pot to the backlight so that you can
control the brightness. (This works with the older boards too, but the range of
brightness will be lower).
The optional pot can be wired as in the photo below:
Next we'll start wiring up the data lines.
• Connect the RST (reset) pin of the LCD (orange wire) to pin 2 of the 4050
• Connect the CS (chip select) pin (yellow wire) to pin 4 of the 4050.
Page 8 of 32
• Connect the D/C (data/command) pin (green wire) to pin 6 of the 4050.
Next, connect:
• DIN (data in) pin (blue wire) to pin 15 of the 4050
• CLK(clock) pin (purple wire) to pin 12 of the 4050.
Then we can connect the data lines from the arduino to the LCD. We can use any 5
pins but you may want to start with our example first.
• Arduino pin
• Arduino pin
• Arduino pin
• Arduino pin
• Arduino pin
3 (orange) goes to pin 3 of the 4050.
4 (yellow) goes to pin 5 of the 4050.
5 (green) goes to pin 7 of the 4050.
6 (blue) goes to pin 14 of the 4050.
7 (violet) goes to pin 11 of the 4050.
Page 9 of 32
Now you are ready to test!
Arduino Testing
You can find our Nokia Display Arduino library on github (https://adafru.it/aHn). You
should install it through the Arduino Library Manager.
Open up the Arduino Library Manager:
Search for the Adafruit PCD8544 library and install it
Page 10 of 32
Search for the Adafruit GFX library and install it
If using an earlier version of the Arduino IDE (prior to 1.8.10), also locate and install Ad
afruit_BusIO (newer versions will install this dependency automatically).
We also have a great tutorial on Arduino library installation at:
http://learn.adafruit.com/adafruit-all-about-arduino-libraries-install-use
You should see the pcdtest example in File>Examples>Adafruit PCD8544 Nokia 5110
LCD library. Load that example and flash it to your Arduino
You can control the backlight, its much brighter when you connect the backlight pin to
5V (you don't need a level shifter if you are using a Nokia display from Adafruit). You
can control the backlight using an Arduino pin since there is a transistor on the board.
Page 11 of 32
Graphics Library
We have a ready to go basic graphics library that has primitives for bitmaps, shapes
and text. You can probably do everything you want using it. Because of the way the
display works we need to buffer the entire display in ram which is 84x48 bits (504
bytes). However, screen updates are very fast.
For more details about the Adafruit GFX library, please visit http://learn.adafruit.com/
adafruit-gfx-graphics-library (https://adafru.it/aPx) - it supports lines, rectangles,
roundrects, circles, text of different sizes etc.
Note that since this display is MONOCHROMATIC it only supports two colors: BLACK
or WHITE. BLACK is a displayed dot and WHITE is for erasing pixels
Dont forget, after drawing anything to the screen, call display() to write it out to the
LCD!
Page 12 of 32
Wiring (fewer pins)
You can save some pins by connecting the CS pin to ground (this means you cant
reuse the LCD's pins between screen updates but maybe thats OK. You can also
connect the RST pin to the Arduino reset so that it will reset the screen automatically.
It's easy to use the Nokia 5110/3310 LCD with CircuitPython and the Adafruit
CircuitPython PCD8544 (https://adafru.it/God) module. This module allows you to
easily write Python code to control the display.
You can use this sensor with any CircuitPython microcontroller board or with a
computer that has GPIO and Python thanks to Adafruit_Blinka, our CircuitPython-forPython compatibility library (https://adafru.it/BSN).
We'll cover how to wire the Nokia LCD to your CircuitPython microcontroller board.
First assemble your LCD.
We're going to show you how to wire it up to a Feather M4 Express. Because the logic
levels on a Feather M4 Express are already 3.3v, you don't need a logic level shifter.
Connect the LCD to your microcontroller board as shown below.
Page 13 of 32
• Microcontroller GND to LCD Gnd
• Microcontroller 3V to LCD Vcc
• Microcontroller SCK to LCD Clk
• Microcontroller MOSI to LCD Din
• Microcontroller D6 to LCD D/C
• Microcontroller D5 to LCD CS
• Microcontroller D9 to LCD Rst
• Microcontroller D10 to LCD Led
Download the Fritzing Diagram
https://adafru.it/GtB
CircuitPython Setup
Library
To use the Nokia 5110/3310 LCD with your Adafruit CircuitPython board you'll need to
install the Adafruit CircuitPython PCD8544 (https://adafru.it/God) module on your
board.
First make sure you are running the latest version of Adafruit CircuitPython (https://
adafru.it/Amd) for your board.
Next you'll need to install the necessary libraries to use the hardware--carefully follow
the steps to find and install these libraries from Adafruit's CircuitPython library bundle
(https://adafru.it/uap). Our CircuitPython starter guide has a great page on how to
install the library bundle (https://adafru.it/ABU).
If you choose, you can manually install the libraries individually on your board:
• adafruit_pcd8544
• adafruit_framebuf
• adafruit_bus_device
Page 14 of 32
Before continuing make sure your board's lib folder or root filesystem has the
adafruit_pcd8544.mpy, adafruit_framebuf.mpy and adafruit_bus_device files and
folders copied over.
Next connect to the board's serial REPL (https://adafru.it/Awz) so you are at the
CircuitPython >>> prompt.
CircuitPython Usage
You can use this display with any CircuitPython microcontroller board.
To demonstrate the usage, we'll initialize the library and use Python code to control
the LCD from the board's Python REPL.
Initialization
First need to initialize the SPI bus. To do that, run the following commands:
import
import
import
import
adafruit_pcd8544
board
busio
digitalio
spi = busio.SPI(board.SCK, MOSI=board.MOSI)
dc = digitalio.DigitalInOut(board.D6) # data/command
cs = digitalio.DigitalInOut(board.D5) # Chip select
reset = digitalio.DigitalInOut(board.D9) # reset
display = adafruit_pcd8544.PCD8544(spi, dc, cs, reset)
The last three parameters to the initializer are the pins connected to the display's
DC, CS, and reset lines in that order. Again make sure to use the right pin names as
you have wired up to your board!
You can control the display backlight LED as well. Just be sure the LED line is wired
up to your microcontroller. Just start by initializing it as a DigitalInOut output line.
If you wired it to a different output, be sure to change the port accordingly.
Page 15 of 32
backlight = digitalio.DigitalInOut(board.D10) # backlight
backlight.switch_to_output()
To turn it on, just set it to True and to turn it off, just set it to False .
# Turn Backlight on
backlight.value = True
#Turn Backlight off
backlight.value = False
Contrast and Bias
Two important settings so that you can see what is on the display are the contrast and
Bias Settings. Let's start by taking a look at the Bias Setting.
Bias
The Bias setting controls the amount of voltage that goes to the display. The higher
the value, the darker the display will be. It's kind of like the brightness setting on a
monitor, but will make the pixels more intense. A value of 4-5 is usually pretty good.
For example, to set it to 5, you would type:
display.bias = 5
Contrast
The contrast setting controls the difference between the dark and light pixels and can
be set to anywhere between 0-127. This is like the contrast setting on a monitor. Too
high of a value will make everything appear dark and to low of a value will make
everything appear too light. A value of around 50-60 seems to look good. For
example, to set it to 50, you would type:
display.contrast = 50
You may want to play around with different combinations of these values to see what
makes your particular display the most readable.
Page 16 of 32
Drawing
The PCD8544 module currently supports a basic set of commands to draw on the
display. You can set individual pixels, fill the screen, and write lines of text.
To fill or clear the entire screen use the fill function. This function takes a
parameter which specifies the color to fill with, either 0 for white or 1 for black. For
example to fill the screen black:
display.fill(1)
display.show()
Notice the fill function doesn't actually change the display. You must call show af
ter making drawing commands to send the updated pixel data to the display!
To clear the screen to white just call fill again but with the color 0 :
display.fill(0)
display.show()
Page 17 of 32
To set a pixel use the pixel function. This function takes the following parameters:
• Pixel X position
• Pixel Y position
• Pixel color ( 0 = white, 1 = black)
For example to set the first pixel black:
display.pixel(0, 0, 1)
display.show()
Page 18 of 32
Try setting other pixels white by changing the X and Y position. Remember you have
to call show (https://adafru.it/Dvz) after setting pixels to see them appear!
Text
To write text to your display, you must download a font file and copy it to your
CIRCUITPY drive. Click the button below to download the file, and then copy font5x8.
bin to your CIRCUITPY drive.
Download the font5x8.bin file
https://adafru.it/DvA
You can write a line of text with the text function. This function takes the following
parameters:
• String of text
• Text X position
• Text Y position
• Text color ( 0 = white, 1 = black)
For example to clear the screen and then write two lines of text:
display.fill(0)
display.text('Hello', 0, 0, 1)
display.text('World', 0, 10, 1)
display.show()
Page 19 of 32
Notice the second line of text starts at Y position 10 , this moves it down the display
10 pixels so it's below the first line of text. The font used by the text function is 8
pixels tall so a size of 10 gives a bit of room between the lines.
Invert
Finally you can invert the display colors with the invert property:
display.invert = True
Page 20 of 32
Note that the invert function doesn't need to have show called after it to see the
change.
To go back to a non-inverted display run:
display.invert = False
That's all there is to drawing on the Nokia 5110/3310 LCD display with CircuitPython!
The drawing functions are basic but provide building blocks for more advanced
usage. For example you can display text with sensor readings or other state, or even
program a simple game like pong!
Full Example Code
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
# SPDX-License-Identifier: MIT
import
import
import
import
time
board
busio
digitalio
import adafruit_pcd8544
# Initialize SPI bus and control pins
Page 21 of 32
display.bias = 4
display.contrast = 60
# Turn on the Backlight LED
print("Pixel test")
# Clear the display.
# update visible!
display.fill(0)
display.show()
# backlight
Always call show after changing pixels to make the display
# Set a pixel in the origin 0,0 position.
# Set a pixel in the middle position.
display.pixel(display.width // 2, display.height // 2, 1)
# Set a pixel in the opposite corner position.
display.pixel(display.width - 1, display.height - 1, 1)
display.show()
time.sleep(2)
print("Lines test")
# we'll draw from corner to corner, lets define all the pair coordinates here
corners = (
(0, 0),
(0, display.height - 1),
(display.width - 1, 0),
(display.width - 1, display.height - 1),
display.fill(0)
for corner_from in corners:
for corner_to in corners:
display.line(corner_from[0], corner_from[1], corner_to[0], corner_to[1], 1)
display.show()
time.sleep(2)
print("Rectangle test")
display.fill(0)
w_delta = display.width / 10
h_delta = display.height / 10
for i in range(11):
display.rect(0, 0, int(w_delta * i), int(h_delta * i), 1)
display.show()
time.sleep(2)
print("Text test")
display.fill(0)
display.text("hello world", 0, 0, 1)
display.text("this is the", 0, 8, 1)
display.text("CircuitPython", 0, 16, 1)
display.text("adafruit lib-", 0, 24, 1)
display.text("rary for the", 0, 32, 1)
display.text("PCD8544! :) ", 0, 40, 1)
display.show()
while True:
time.sleep(0.5)
time.sleep(0.5)
Page 22 of 32
Python Wiring
It's easy to use the Nokia 5110/3310 LCD with Python and the Adafruit CircuitPython
PCD8544 (https://adafru.it/God) module. This module allows you to easily write
We'll cover how to wire the Nokia LCD to your Raspberry Pi. First assemble your LCD.
Since there's dozens of Linux computers/boards you can use we will show wiring for
Raspberry Pi. For other platforms, please visit the guide for CircuitPython on Linux to
see whether your platform is supported (https://adafru.it/BSN).
Connect the LCD as shown below to your Raspberry Pi.
• Raspberry Pi GND to LCD Gnd
• Raspberry Pi 3.3V to LCD Vcc
• Raspberry Pi SCK (GPIO 11) to
LCD Clk
• Raspberry Pi MOSI (GPIO 10) to LCD
Din
• Raspberry Pi GPIO 6 to LCD D/C
• Raspberry Pi CE0 (GPIO 8) to
LCD CS
• Raspberry Pi GPIO 5 to LCD Rst
• Raspberry Pi GPIO 13 to LCD Led
https://adafru.it/Gue
Python Setup
You'll need to install the Adafruit_Blinka library that provides the CircuitPython
support in Python. This may also require enabling SPI on your platform and verifying
you are running Python 3. Since each platform is a little different, and Linux changes
often, please visit the CircuitPython on Linux guide to get your computer ready (https
://adafru.it/BSN)!
Page 23 of 32
Once that's done, from your command line run the following command:
• pip3 install adafruit-circuitpython-pcd8544
If your default Python is version 3 you may need to run 'pip' instead. Just make sure
you aren't trying to use CircuitPython on Python 2.x, it isn't supported!
If that complains about pip3 not being installed, then run this first to install it:
• sudo apt-get install python3-pip
DejaVu TTF Font
Raspberry Pi usually comes with the DejaVu font already installed, but in case it didn't,
you can run the following to install it:
• sudo apt-get install fonts-dejavu
This package was previously calls ttf-dejavu, so if you are running an older version of
Raspberry Pi OS, it may be called that.
Pillow Library
We also need PIL, the Python Imaging Library, to allow using text with custom fonts.
There are several system libraries that PIL relies on, so installing via a package
manager is the easiest way to bring in everything:
• sudo apt-get install python3-pil
That's it. You should be ready to go.
Page 24 of 32
Python Usage
You can use this display with a computer that has GPIO and Python thanks to
Adafruit_Blinka, our CircuitPython-for-Python compatibility library (https://adafru.it/
BSN).
Since we are running full CPython on our Linux/computer, we can take advantage of
the powerful Pillow image drawing library to handle text, shapes, graphics, etc. Pillow
is a gold standard in image and graphics handling, you can read about all it can do
here (https://adafru.it/FU7).
Initialization
import
import
import
import
adafruit_pcd8544
board
busio
digitalio
cs = digitalio.DigitalInOut(board.CE0) # Chip select
reset = digitalio.DigitalInOut(board.D5) # reset
Page 25 of 32
backlight = digitalio.DigitalInOut(board.D13) # backlight
# Turn Backlight on
#Turn Backlight off
Contrast and Bias
Bias
display.bias = 5
Contrast
Page 26 of 32
Example Code
This demo will fill the screen with white, draw a black box on top
and then print Hello World! in the center of the display
This example is for use on (Linux) computers that are using CPython with
Adafruit Blinka to support CircuitPython libraries. CircuitPython does
not support PIL/pillow (python imaging library)!
import board
import busio
import digitalio
from PIL import Image, ImageDraw, ImageFont
# Parameters to Change
BORDER = 5
FONTSIZE = 10
# Contrast and Brightness Settings
display.bias = 4
# backlight
# Clear display.
display.fill(0)
display.show()
# Create blank image for drawing.
# Make sure to create image with mode '1' for 1-bit color.
image = Image.new("1", (display.width, display.height))
# Get drawing object to draw on image.
draw = ImageDraw.Draw(image)
# Draw a black background
draw.rectangle((0, 0, display.width, display.height), outline=255, fill=255)
# Draw a smaller inner rectangle
draw.rectangle(
(BORDER, BORDER, display.width - BORDER - 1, display.height - BORDER - 1),
outline=0,
fill=0,
# Load a TTF font.
font = ImageFont.truetype("/usr/share/fonts/truetype/dejavu/DejaVuSans.ttf",
FONTSIZE)
Page 27 of 32
# Draw Some Text
text = "Hello World!"
(font_width, font_height) = font.getsize(text)
draw.text(
(display.width // 2 - font_width // 2, display.height // 2 - font_height // 2),
text,
font=font,
fill=255,
# Display image
display.image(image)
display.show()
Let's take a look at the sections of code one by one. We start by importing the board
so that we can access the pin definitions, busio so we can initialize SPI,
digitalio , several PIL modules for Image Drawing, and the adafruit_pcd8544
driver.
import board
import busio
import digitalio
In order to make it easy to change display sizes, we'll define a few variables in one
spot here. We have the border size and font size, which we will explain a little further
below.
BORDER = 5
FONTSIZE = 10
Next we set the SPI object to the board's SPI with busio.SPI() . We also define
some Pins that will be used for the display and initialize the display. See the
initialization section above for more details.
Next we set the Bias and Contrast. See the Contrast and Bias section for more details.
display.bias = 4
Page 28 of 32
After that we setup the backlight. See the Backlight section above for more
information.
Next we clear the display in case it was initialized with any random artifact data.
# Clear display.
display.fill(0)
display.show()
Next, we need to initialize PIL to create a blank image to draw on. Think of it as a
virtual canvas. Since this is a monochrome display, we set it up for 1-bit color, meaning
a pixel is either white or black. We can make use of the LCD's width and height
properties as well.
image = Image.new('1', (display.width, display.height))
Now we start the actual drawing. Here we are telling it we want to draw a rectangle
from (0,0) , which is the upper left, to the full width and height of the display. We
want it both filled in and having an outline of black, so we pass 255 for both numbers,
which represents the amount of fill.
If we ran the code now, it would still show a blank display because we haven't told
python to use our virtual canvas yet. You can skip to the end if you would like to see
how to do that. This is what our canvas currently looks like in memory.
Page 29 of 32
Next we will create a smaller white rectangle. The easiest way to do this is to draw
another rectangle a little smaller than the full screen with no fill or outline and place it
in a specific location. In this case, we will create a rectangle that is 5 pixels smaller on
each side. This is where the BORDER variable comes into use. It makes calculating
the size of the second rectangle much easier. We want the starting coordinate, which
consists of the first two parameters, to be our BORDER value. Then for the next two
parameters, which are our ending coordinates, we want to subtract our border value
from the width and height. Also, because this is a zero-based coordinate system, we
also need to subtract 1 from each number.
draw.rectangle((BORDER, BORDER, display.width - BORDER - 1, display.height - BORDER
- 1),
outline=0, fill=0)
Here's what our virtual canvas looks like in memory.
Page 30 of 32
Now drawing text with PIL is pretty straightforward. First we start by setting the font to
the default system text. After that we define our text and get the size of the text.
We're grabbing the size that it would render at so that we can calculate the center
position. Finally, we take the font size and screen size to calculate the position we
want to draw the text at and it appears in the center of the screen.
# Load a TTF font.
font = ImageFont.truetype('/usr/share/fonts/truetype/dejavu/DejaVuSans.ttf',
FONTSIZE)
# Draw Some Text
draw.text((display.width//2 - font_width//2, display.height//2 - font_height//2),
text, font=font, fill=255)
Finally, we need to display our virtual canvas to the LCD and we do that with 2
commands. First we set the image to the screen, then we tell it to show the image.
# Display image
display.show()
Don't forget you MUST call display.image(image) and display.show() to actually
display the graphics. The LCD takes a while to draw so cluster all your drawing
functions into the buffer (fast) and then display them once to the LCD (slow)
Here's what the final output should look like.
Page 31 of 32
Downloads
Our PCD8544 (Nokia 5110) LCD display Arduino library is on github (https://adafru.it/
aHn) which comes with example code. This library uses 1/2 Kbytes of RAM since it
needs to buffer the entire display but its very fast! The code is simple to adapt to any
other microcontroller.
You'll also need to get the Adafruit GFX Graphics core library which can print text,
bitmaps, pixels, rectangles, circles and lines, also available on github (https://adafru.it
/aJa).
The PCD8544 datasheet tells you all about what the display can do (https://adafru.it/
aTN).
Page 32 of 32
